View Full Version : C6 Tech/Performance
  1. Shock upgrade Question?
  2. Heavy duty brakes
  3. *NEW* Beautiful Leather Waterfall & Armrest.... how do you like it?
  4. Does CAI require a tune or not?
  5. Wide open throttle switch wire?
  6. battery replacement
  7. Happy Birthday
  8. take off
  9. is it me or do the M&H racemasters suck?
  10. Torque tube / chassis clearance question
  11. Vbp pre-summer sale 15% off through may
  12. new here
  13. Do people read their OWNERS MANUAL?
  14. Premium oil filter vs. standard oil filter
  15. Identify these headers?
  16. Forced Induction Sale!!!!!!!!!
  17. noob vararam question
  18. Will I need anything else?
  19. What's up with my Radio Volume
  20. OTC 1532 race jack review, mod for crossmember
  21. Cartek Cam only 11.1@123.7
  22. Passenger Window: No Power Down
  23. Harmonic Balancer/BCM/Service Charging System
  24. Tire ?'S
  25. 08 C6: Throwing codes after track weekend. Please help.
  26. Monro Shocks
  27. My C6 Impressions
  28. Unable to start C6
  29. Unable to start C6
  30. exhaust decibel
  31. tranny noise?
  32. Removal of the elbow on the PVC system to install a catch can....how?
  33. First impressions Firestone Firehawk wide ovals
  34. Help on HSW Interface Controller and A/F adjustment
  35. Question: Z06 Rear Spring on Lowered C6 Z51
  36. Thermosat
  37. Fuel pressure system
  38. timing question
  39. Help: Novice needs Brakes
  40. Exhaust options
  41. Power seat doesn't move when I turn the car off
  42. Trouble Code P0341 Help!!!
  43. 345 tire on stock c6, help.
  44. eingine compartment heat?
  45. C6 LS2 cam & ud pulley +61hp
  46. Brake-in Period for new cam and rear
  47. Battery Minder better than Tender?
  48. Rusted Rotors, Decayed Calipers, and Brake Squeal on C6
  49. HUD Harness. How to make it yourself?????
  50. What happened to the Xcelerator CIA?
  51. www.PartsTaxi.com Current Specials
  52. Locked out
  53. any write ups on porting the T/B?
  54. Will A 2005 M6 3.42 Diff Bolt Into A 2005 A4?
  55. Need advice in a switch? Please
  56. rough idle
  57. Still kickin around ideas... Nitrous wet kit..
  58. Mods VS Horsepower GAIN VS $$ ??
  59. 3 shops in 6 months, whose most at fault
  60. DIY: Battery relocation to passenger side rear cargo (PICTURES)
  61. Magnuson ZR1, oops....I mean TVS 2300 LS2 #s just in!
  62. Group Buy: 2005 D-Type Sport Steering Wheel (4 spoke)
  63. quick question about FAST intake
  64. Fichtner may super specials!
  65. Wheel/Tire/Lugs and Battery Weight Savings
  66. Vararam anything good to say?
  67. Extended Warranty
  68. P Zero Nero's or PS2's
  69. Chuck CoW TUNING @ the Corvette Museum -CF Cruise-In Event
  70. aftermarket mods for automatic trannys
  71. made a bet advice / suggestions ?
  72. how much pwr
  73. Alignment
  74. Sprayed C6 Track Times and pics...
  75. c3 guy with a c6
  76. active handling
  77. •• Hawk Brake Pad Special ••
  78. cant find this rim ANYWARE!!!!!!!
  79. pods
  80. My 06 Z06 needs a starter
  81. Navi input while driving (Lockpick)
  82. 1276 HORSEPOWER 21st Century Muscle Cars
  83. technical exhaust question
  84. Hand Held Tuner?
  85. Will kooks 1 7/8 z06 headers fit a reg c6?
  86. cai
  87. Lingenfelter 2-Step Launch Control Installed.
  88. C6 problem that everyone cannot find solution to fix
  89. Bad brake pads??
  90. Should I get a retune?
  91. Broke rim today!!!! Pics inside
  92. Texas Speed C6 Long Tube Headers & X Pipe Results & Pricing!!
  93. Big Brake Upgrade
  94. Can wide tires be a BAD thing?
  95. Tune
  96. putting a spark plug in the exhaust for flames?
  97. To lower the rear do you turn the adjuster CW or CCW?
  98. messed up threads on rear wheel bolts: please helppp
  99. blew a piston after a week being TT ..need advice
  100. Jackstands
  101. Exhaust question
  102. Camshaft for my C6 LS2
  103. So I need new brakes...advice?
  104. What Happen if you install Rear Mirror w/OnStar on a C6 w/regular rear mirror
  105. *** LG Motorsports G7X3 Cam - 546 RWHP - Graph Inside ***
  106. Very cool article about Toyo R888's tire pressure
  107. any probs with C6Z posi units?
  108. cotes 700 balancer - 500.00 a good deal
  109. How do you "heat Cycle" Toyo R888's
  110. Billy boat exhaust syst
  111. C5 spring in, no difference
  112. 2005 basic performance mods?
  113. axle/ nut issue
  114. Steam Cleaning the engine
  115. Wideband bung in z06 cat pipe
  116. widest possible tire on a c6?
  117. few error codes. could use some advice:)
  118. 17in wheels for track use
  119. PRO-CHARGER Installed A/C does not work
  120. 550RWHP: What's the optimal rear tire pressure 305/30/19's?
  121. Somethings wrong - needs suggestions
  122. Replacing end links - advice needed
  123. Best clutch for 700whp that feels like stock?
  124. confused, rotation
  125. Nitto NT 05 - 275/35/19 on Stock C6 Rear ?
  126. Stock Muffler Modification
  127. Condensor drain
  128. Wheel size on non-wide body question (not tire size..)
  129. I need help!!!!!!!
  130. Frame specifications
  131. M&H drag radials vs Mickey thompson e/t street radials 2
  132. Lightweight Battery Install (Pics)
  133. Another 3x idle video w/ daughter
  134. Track Alignment specs..help
  135. Carbon ZR1 Spoiler now available
  136. Exhaust Install Question
  137. headlight repainting?
  138. [EVENT] The Vette Doctors BBQ Saturday June 20
  139. C6 Factory NAV install after purchase
  140. Painting the word "Corvette" on the P/S dash
  141. TPS and it's lifespan?
  142. 2005 LS2 Power Steering Pulley help. . .
  143. Best Vette performance shop?
  144. Service charging system, code po621
  145. C6 Headers
  146. DIC Options Unavailable
  147. Is my car broke?
  148. Springtime!
  149. New Shoes! CCW C10 wheels and Toyo R888s
  150. are these used headers garbage?
  151. TPMS and tire change question
  152. CCWs and C6 Z06 rubber on a C6 with no fender flairs? Do-able?
  153. HELP! My car won't start
  154. Help,help,help
  155. LS3 manifold vaccum line size?
  156. Taking car out of storage - pull fuel pump fuse...???
  157. standard supercharger pulley size?
  158. Stupid Vararam tuning Question.
  159. i have auto c6 ls3 can i choose manual in diablo?
  160. Brake Squeal
  161. Heat cycling street tires ?
  162. HELP need Headlight Wiring diagram.
  163. Alignment
  164. ZO6 Header gasket part #
  165. o2 extensions
  166. Help on my C6 heating/stalling -- Know a chevy tech in houston,tx area?
  167. When to replace valve springs w/ high lift cam?
  168. how to change center console?
  169. NEED HELP. traction control active!
  170. M2W Fuel/Air Mixture
  171. Stock LS3 gains from custom dyno tune
  172. Any difference in 160* Thermostat brands?
  173. XMS Spring Into It Forced Induction Sale
  174. What's Better:RedLine D4 ATF or RP Synchromax?
  175. Lets talk rear mount turbos.. single / dual
  176. Who makes these long tube headers?
  177. Will a 2002 ZO6 DIFF WORK IN A 2005 C6
  178. Bump?
  179. Ever have this happen after filling with fuel???
  180. exhaust condensate leak
  181. clutch spring out; quick question
  182. When installing Z06 brakes on C6 coupe will..
  183. C6 oil change question
  184. EMERGENCY!!! Need a Pfadt C6 rear coil-over
  185. Stock C6 Upgrades, suspension, brakes
  186. Air conditioner dripping on transmission??
  187. Looking for a switch to turn on fans with motor OFF
  188. Did you hyper-mod your last Corvette? Doing the same with your current one?
  189. '09 C6 Wheel & Tire Sizing
  190. Need more 1/4 mile grip
  191. Nitto NT05's vs. Toyo R888's
  192. extra part were does it go.
  193. no oxygen sensor question
  194. LS9 Air Filter Drop in Replacement
  195. Lost FOB
  196. Displaying DTC on a 09 C6
  197. Which cam should I go with??? LG or Cartek
  198. If you thought LS3 and LS7 air filters were the same... (PICS)
  199. Vin #1G1YY34U355130514
  200. How tight? Oil pressure sensor
  201. Block heater cord - something to watch for
  202. Fuel Level Sensor TSB, anyone know where this can be found?
  203. Brake Experts
  204. **Free Titanium upgrade on all ForgeLine wheels from LG Motorsports**
  205. What Kind Of Performance Are You Getting In The 1/4 With Your 402-427 Motors
  206. Ported Fast 92 and Ported TB on LS2
  207. Cam only LS2
  208. •TECH TIP• How To Make The Stock Master Cylinder Adjustable
  209. Cam selection giving me a headache!!
  210. Define "bolt on's"
  211. Z06 mufflers on 6-speed 2006 C6
  212. Unusual exhaust question...
  213. Z51 Pads
  214. What are Z51 rotors and pads worth?
  215. Oil catchcan LS-3
  216. traction control keeps going active
  217. Need C6 alignment shop Hudson Valley, NY
  218. heads/cam
  219. Can't keep good traction...
  220. which coil
  221. How Loud is Loud? (opinions on exhaust)
  222. Service Fuel System
  223. HELP! Exhaust Question
  224. Looking for Light weight rotors for LS2 Z51 vendors come in!
  225. exhaust question
  226. Intake coupler
  227. Bad TPS....What are the consequences?
  228. Added some mods / Tune = Dyno #'s ...
  229. 08 auto tranny ?
  230. Need Help with exhaust
  231. questions about 09 vette and tires
  232. How do you like your lowered vette
  233. Stock radio
  234. Vortex Rammer?
  235. any problems with your c6's?
  236. (offical sales thread) DRM RTR, Let us build your dream car (dialup???)
  237. Calipers
  238. What spark plugs if replacing????
  239. Sway bars - which ones to use?
  240. Sway Bars
  241. 86 corvette engine knock
  242. Suggested First Mods?
  243. newbie questions
  244. Gtech ss
  245. Power cutting off at 5800rpms in second gear??? help
  246. Soundlip of 3x cam with stock exhaust w/headers
  247. So why doesn't anyone want to Drag Race at the Cruise In??
  248. Anyone make seat rail extenders for C6's??
  249. How to get tpms to work with drag wheels?
  250. rear end cracked on the vette, need help finding parts
