- Terrible customer service from a supporting vendor
- Odd RPM when shifting
- Can I fit these INVOs on my ZO6 wheels????
- Rattles after Track outing!
- Anybody know what this thing is called ?
- iPod Interfacing - Tech Forum
- gauge cluster/wiring question
- Stuck in PARK
- Motor Install Question On Starter Wiring
- C6 convertable Photos with Roll Bar Installed
- LS3 NA cam options - Max power/area under the curve
- *** New GT2 Seats Available Now from LG Motorsports! ***
- Shut off injectors for diagnosis while cranking?
- We are Va Speed.
- Blackwing Installation.
- Fog Light Replacement
- newbie need advice
- calling tech experts, please help
- ZO6 Exhaust
- Solar Panel Inside Windshield??
- Strange Occurance - Please Read!
- Valve spring help!!!
- Mail order tunes
- Ported OEM intake vs Fast 92
- AMSOIL Releases New Low Viscosity ATF (Dexron VI Fluid)
- AMSOIL Releases EAO50 Oil Filter for LS3/LS7
- Took mt 08 z51 to the track a few days ago
- OEM NAV vs aftermarket - need opinions
- DIY pulley mod for belt slip on S/C systems
- Help: Tires / Steering weird??
- Lingenfelter High Raise Stinger Hood - Starcraft Twin Turbo Hood
- Pros and cons removing cats on a C6?
- TPMS Trigger Re-Learn Issues
- adding homelink
- Engine light code P1010
- Differential leaking???
- Spinmonster polished/ported TB and ported intake
- 07 C6 6MN - Stock shift lever makes noise?
- Will this speaker fit?
- who knows of a wrecked Z06?
- Selecting a cam
- Trouble with HP Tuner in New PCM
- Tires and Nail
- Front Turn Signals no longer working
- LS3 + Cone Filter + open shoud = MAF issues??
- b&b fusion controls
- YANK Converters June Sale is here!
- TPS Question
- Need recommendations for best pad - Z51, desire good bite, low dust, NO NOISE
- cam install question i already searched no luck
- 18" Wheels & Tires & Where To Buy & What Size
- Ported heads
- newbie questions on mods
- 08' A6 Paddle Shifter Issue
- I need help... car takes 15 sec to turn off
- Stock A6 Converter Stall Speed
- Batteries
- Austin Local with Tuner SW/HW for '05?
- [PICS] Carbon fiber engine goodies. Katech Valve covers, Halltech Carbon Killer Bee
- VA SPEED Cam Package Special
- Exedy customer service
- Katech carbon fiber spoiler pricing announcement and pre-order available
- A6 Gear Ratios?
- 2005 water leak
- C-5 / C-6 shocks
- SLP Loudmouth 2 with the A6 auto. ??????
- Sound Bite: Video...1st-2nd gears w/cam, headers, Npp open
- I need help with valve adjustment.....
- What is the max boost
- just bought vette and want it sound good
- Higher octane
- Need install diagram for CrazyCowboy insulation kit C6...
- Wheel Widening
- car going nuts!
- LS9 (ZR1) crate motor in your C6?
- EBC Rotors ... Z51 BLANKS (no slots, no holes)
- Dyno Tuned Today. How are the numbers?
- Help I have NO Fuel Pressure
- !!!Avoid Mullis Race Cars Rev Extreme!!!!
- Rotors under warranty?
- Factory Bitch Clutch?
- Active Handling
- Faint squeak/whistle from front of LS7
- ADDCO Sway Bars
- Elevation Boost Drop Formula?
- I pulled 185 MPH in my C6 against a Z06 on the Runway!!
- Why do ls1 and ls2......?
- Headers - Coated or Not
- C6 Z06 supercharger or NOS
- GM Parts House June 2009 C6 Specials.
- Genuine Corvette Accessory Splash Guards Available.
- Major Price Reduction On C6Z51/C6Z06 Sway Bars.
- Poor hot start - injectors? tune? or ?
- gearstick hitting plate
- A6 tranny operating temp?
- Intermittent start problem after cam installation.
- !!!!Corvettes of Westchester- Phones & internet service down temporarily!!!
- Replacing OEM bolts with ARP
- Whats up with my shifter?
- C6 2006 keyless key 2 not option programmable
- I am down to 2
- Injector Recommendation
- 2008 C6 coupe Tach signal?
- Should I machine rotors?
- help wanted with cooling fan
- Need a tune with converter?
- CHECK GAS CAP on D.I.C.
- Brake Calipers: Base vs Z51
- Rear o2 sensor question
- Valve cover oil breather impact on tune
- What happened to vendor ReveExtreme?
- Hud install question.
- Brake Questions
- Beat the Heat Summer Header Sale- @ MarylandSpeed - Kooks (Free Coating), SLP, SW
- Vararam, Halltech, and SLP Intakes on Sale + Packages!
- how much hp is lost on dyno due to high stall and gears?
- 1/4 mile time 2009 a6
- Reverse?
- atco raceway tonight
- Next mod?
- Need answers - Comparing C5 to C6Z06 Shifter+ bases...
- npp on ls2 vette?
- Installed MGW shifter
- Best Track Break Pads and Fluid?
- ??? PIP4395_Flare or Harsh Shifts 2-3, Bump Delay TSB performed
- Comments on this lightweight battery...
- Troubleshooting ABS?
- best oil for Vette
- ANY Z06's w/ SELECTIVE RIDE CONTROL F55 Package custom done??
- 07' vert, 7k miles, rough engine w/ P2176 and B2AAA
- Have GM Racing lifters #88958689 changed
- First track day in my C6: comments, questions, etc.
- gasket for mgw shifter
- 2009 C6 LS3 is too Quiet
- Hawk pad noise?
- Fixed brake squeal!
- ***LG Cam Installation Specials***
- *** LG Street Series - Still the Best Value in Headers! ***
- Hatch power close question
- accel. pedal resistance (ohms)
- ForgeLine, more than a pretty picture!
- My Brakes are squeaking like crazy...
- What would this cost... and how much power would it produce?
- Power coat Question PART TWO
- Anti-lock troubleshooting procedure?
- mod-newbie
- Disappearring act - 2006 C6
- 07 C6 vs 04 C5 Z06 - 1/8 mile results
- 05 A4 Lower Gears
- Clutch problem?
- What exactly is in the Z51 package?
- How to get better top end??? 600rwhp c6 vs. 550rwhp N/A z06
- couple of qusetions : nitto 285/30/19 and traction system active ..TR-6060
- Mild cam ?
- c6 with Z06 exhaust??
- question: Cats and Horses
- My transmission T-6060 went out
- 09 a6 rough idle when cold
- 07 A6 3-4 clutches toast....again.
- looking to buy 4- 15" stop tech or equivalent rotors
- How can I tell which differential ??
- Intake manifold options for an 09' LS3
- Wheels
- Need mod ideas
- Need opinions about PFADT engine and transmission mounts
- Squealing Sound underhood 05
- Headers, camshaft and exhaust.......
- DTC P2135 throttle position sensor problems
- Question on clutch pedal
- Drilling for Wideband O2 sensor
- ZO6 Exhaust
- Heat damage with Headers
- Will '08 Z06 inner wheel well panels fit an '06?
- Rear end
- Mysterious "C" clip
- Nav System
- Anyone running DR's up front on the street?
- Side repeater lamps are blown
- Ported TB for 09
- 100mmMAFmonster: Increasing MAF Resolution for Various Applications
- Traction Control Light/Switch
- What To Expect To Pay? Replacing Clutch
- Could this be a Problem?
- Custom tune VS Diablo
- SERIOUS Steering Alignment Issue
- Z06 exhaust
- Header swap?..... Will they swap between ls2,3,7?
- Anybody interested in a DIY LS7 engine swap guide?
- Help with Mods Please !!!
- wheel alignment
- 1/4 Drag Shift point for best MPH???
- Engine rev anomaly
- NEW! Comp Cams LS1 Rocker Arm Trunion Upgrade
- A thought for Z51 owners....
- 1/4 mile run with targa off ?? full tank of gas or 1/8 of a tank ?
- Vbp summer sale 15% off through june
- Ceramic brakes
- Launch control for LS3 A6
- exhaust fuse on 2006 corvette coupe
- Heating Up
- Car wont start after clutch install.
- transmission
- ***Ragin Racin Specials- Cams, Chargers, Clutches, APR Products, & HP Tuners***
- solved the rattling sound..
- Chuck cow
- 08 A6 upgraded with 3.42 gears, 1\4 improvement?
- Les Stanford Chevrolet Grand Sport Launch Control Video See it here!
- Heading to track...what should I bring?
- How to patch a header pipe?
- Where can I find C6 diagrams?
- Could someone please help me out with a part number? (LS3 radiator shroud)
- Help with BFG 295/35/18 tire diameter
- Tires-Mich. PS2 ZP Runflats!
- C6 tpms
- B & M Sport shifter for C6
- I don't believe it.
- Need your input (hp rating):
- Finding TDC on LS Engines
- Did my transmission go out???
- Optima Tips
- Vararam is a piece of JUNK!
- Tint shop - Bradenton,Fl area
- boiling brake fluid
- 2007 Z06 Speedo
- Royal Purple oil?
- Stock ls3 valvetrain question
- Heads and Cam Question on LS3
- Blue Connector help
- New Best Time 10.57 @ 134.15
- Predator U7194 question
- CD MECH ERROR Display
- Data logging - Accelerometers - HPTuners MPVI Pro
- DMH cutout wiring into car A6 2006?
- ContiComfort
- Shop in stalling clutch wont shift into 1-2 or Reverse?
- New & Stronger LSX belt tensioner now available from MTI Racing!
- Manual Trans Lube?
- C6 Z06 Spring Rates
- Warranty work
- After engine detail, horn went off and didn't stop.
- Inexpensive Z51 rotors?
- Z06 springs on an F55?
- Anyone try T1 bars on Z51 suspension?
- zo6 cam for my ls3
- Need help with optima battery
- need a snell 2005 helmet..where to buy?
- Headers ?
- Difference between Z06, Z51 and stock rear leaf springs?
- Opinions on "Ultra Torque" camshaft
- Does anyone sell "TRACK" insurance?
