View Full Version : C6 Tech/Performance
  1. 08 LS3 clutch
  2. Z06 oil changes
  3. The bloomington gold show coming this weekend 20% off
  4. Drone reduction trick
  5. "captains choice" exhaust system BB Fusion or QTP Screamer
  6. New PB
  7. L G Super Pro Headers-Free Install & Tune
  8. C6 Daytime Running Lights Override??
  9. Tune vs Smog Testing
  10. Clear check engine light
  11. Service fuel system - guage error
  12. Cut Front Bushing ???
  13. When is the best time to get tuned? Summer/winter
  14. A-pillar part number?
  15. AIR INTAKE...BEST NUMBERS WITH TUNE? Looking!!!!
  16. Quaife Upgrade
  17. 82 crossfire door locks won't work!!!
  18. Can input shaft be bought separately?
  19. rpm trans t56 level 5
  20. Quick Paddle Shift Question
  21. See DeWitts at Bloomington Gold
  22. 'Service Active Handling' - Can I fix this myself?
  23. Need help with RAPTOR Dual Mode Shift Light Wiring
  24. Ideas please
  25. C6 Guys, Thanks for the Opportunity
  26. DIC Message - Soft Boot 7.5
  27. Engine Knocking loudly: need ideas
  28. Headers and warranty question
  29. Concerningly low dyno #s
  30. Vararam Replacement Question
  31. The bloomington gold show coming this weekend
  32. Exhaust question.
  33. any idea about G6XE camshaft??
  34. A6 Thinking GEARS
  35. Quick guess at numbers
  36. Easy HP add-ons for C6?
  37. Who wants a Tunnel Plate!!!!!
  38. 07 Z Cooling fans not working after dead battery
  39. I need torque specs for ls2
  40. How to check auto trans fluid
  41. Help!!!! Tuner said my pcm is locked...?
  42. Looking for an LS3 Cam and Tune.
  43. After market seat options??
  44. Stock C6 A6 Torque Converter Stall Speeds
  45. pontiac ls3 gxp a6 CAI
  46. Pfadt Coilovers at 10,000 miles
  47. Anyone help with removal of door panels?
  48. gas gauge needle flopping around????
  49. What kind of numbers should I expect!
  50. Help! C6 will not start or turn over
  51. adding h.p.
  52. measurements ?
  53. What should it cost to instal Long tube headers and full exhaust
  54. Maybe this isn't even tech... but, technique for shifting to 6th ?
  55. Front End Noise - How to Diagnose?
  56. pre/post LGM tune numbers
  57. mgw shifter
  58. Lowered the car on stock bolts....question
  59. Meth Injection Octane?
  60. lg super pro longtubes
  61. tire sensors settup
  62. Cracked rotor or heat checking?
  63. Latest on warranties and tuning . . .
  64. Transmission Problems?? Strange
  65. C6 exhaust identification
  66. Match for Toyo R888
  67. **LG GT4 and GT2 3" catback systems IN-STOCK!!**
  68. predator custom tuning
  69. IL Emissions
  70. Z06 stalls at idle. HELP!
  71. 3:15 or 3:42 gears, that is the question??
  72. cold Air induction 08
  73. Front & rear z06 brake conversion kit blow out www.partstaxi.com
  74. Everything you know about subwoofers
  75. FAST LS7 intakes are HERE! LSXR!
  76. Finally have a soundclip for you of the ebay headers
  77. Wheel Bearing?
  78. Rear End Noise
  79. Damage to AC Condensor?
  80. careful of used Pfadt sways
  81. C6 Wheels ..... are these OEM or Reproductions????
  82. LS7 clutch limit
  83. HELP! Changed clutch fluid, now pedal is stuck to the floor!
  84. A6 rebuild and 3.15 gear install
  85. A different TPMS tool choice
  86. Sway bar end links question
  87. Congrats to GM Racing /Pratt & Miller
  88. Can you buy a TVS2300 s/c?
  89. *** New GT2 Track Wing from LG Motorsports! ***
  90. Vengeance Racing introduces new RPS Organic Street Twin clutch for C6/C6Z06
  91. Brake Fluid Change and Bleed
  92. Need some gear help please
  93. Junk got past Vararam....now what?
  94. Stock 09 A6 (2.73) shift points?
  95. *** Group Purchase: LG Carbon Air Intakes for LS7 & LS3 - $495! ***
  96. [Video] Interview with Jason on what's new at Katech / Customer testamonial interview
  97. A6/6L80E Research
  98. Need help on what size head for my car
  99. Apsis will be in Bloomington Gold Corvette Show next week.... welcome to visit us
  100. *NEW* Steering Wheel Shroud wrapped in Alcantara..... pix
  101. Vacuum Switch
  102. Shift issue. Need some help please!
  103. LG Transport to Austin TX area
  104. New Billet Power Steering Pulleys
  105. motor/tranny mounts bad???
  106. Free Cold Air
  107. Just got my car back!! 433/403
  108. offered deal on cam
  109. Whistling alternator?
  110. 08 vet supercharger??
  111. Fluid Change - Time to see your DR!
  112. Need help with heads
  113. Newbie Oil Fill Mistake on Z06 - Quick question
  114. Apr rear wing
  115. Headers & X-Pipe for PERFORMANCE
  116. LG headers install waiting a week or 2 for a tune?
  117. Wiring request 07+ steering wheel
  118. VIN range for magnetic TPM sensors?
  119. Slotted or Slotted and Dimpled
  120. CF VENDORS: Limiting muffler movement: harder mounts?
  121. Z06 vacuum actuated valves?
  122. Now that Ranger has proved there's a clutch hydraulic problem, what's the perm fix?
  123. Headers NEED tune?
  124. Vararam Customer Service Experience
  125. Z06 Brake Pad
  126. Need Brake Help
  127. Clutch Slam at Disengage
  128. Lowering Bolts for C6
  129. Normal or brake problem?
  130. Key Fob and Tech 2 question
  131. After installing z51 sways on my base 07...
  132. manufacturing dates and differential
  133. Anyone Added a Shift Light??
  134. BI-MODE Change out
  135. worth it?
  136. How to change trans oil in a manual
  137. 230 + duration cam guys......
  138. Some Clear Bra Questions and Paint questions
  139. Name that Price....
  140. CEL: Engine banks lean
  141. When do you need to upgrade/change your sparkplugs?
  142. Surging... used the search....found the answer!
  143. Goodnight, and goodbye!!!
  144. service manual info
  145. Spark plug 06 A6
  146. Who makes the BEST rocker arms for the LS7?
  147. Remove steering wheel spoke caps
  148. shift points
  149. HELP... Door panel disassembly hell.
  150. Last breath performance!!!!!!!!!!!!
  151. Asorted Leather Armrest & Waterfall.... many pix
  152. ATI Superdamper steal or aluminum?
  153. Introducing the LS9X twin disk clutch for LS2/LS3/LS7
  154. My EVAP system ran incorrectly??
  155. c6 convert. owner question?
  156. Just got new clutch installed, something loose or tires breaking loose?
  157. procharger or vortec?
  158. {Sale} Pfadt Race Engineering Inverted Sport Shocks {SALE}
  159. Wideband Controller/ Meter
  160. 2009 Service manual constant mistakes
  161. Bolt ons
  162. IS this a bad idea?
  163. **RPS Organic Street Twin Factory Sale**
  164. Huntington Chevy Closed LI NY Dr Drew
  165. fuel injector question
  166. HELP!!! 08 MN6 9k miles, transmission & suspension troubles
  167. Anyone Get a New FAST 102 Intake Yet??
  168. Anybody out there interested in in providing track support for 2 C6 Z06 Corvettes at
  169. Congrats to Chuck Cow and Welcome2Try on a great build
  170. help adjusting the hood please
  171. Internal engine upgrades vs. buying a shortblock
  172. Bad ignition switch
  173. Exhaust pipe expansion
  174. Add Differential cooler to C6
  175. a4 tranny
  176. "Single" A-pillar gauge pod
  177. LG G6X3 cam available
  178. Tuning books available
  179. Changing Vararam for Callaway
  180. UD pulley on 08+
  181. HPtuner VCM suite - MPVI Pro and AFX WBO2
  182. DIY oil catch can
  183. traction control, again
  184. Sway bar torque
  185. LS7 swap for an LS3
  186. Safe mode
  187. LS7 swap for an LS3
  188. A6 problem
  189. New PB
  190. Check Engine Light Question
  191. Schematics/info for Show-n-go (retractable-plate) receiver box?
  192. New LS2 cam video
  193. m2w question?
  194. Shop abuse!!
  195. apr carbon fiber rear wing
  196. halltech killer bee
  197. Stock exhaust manifold removal question
  198. Need spec's for z51 road course alignment
  199. ls2/ls3 oilpan are they the same?
  200. 3.90 gears
  201. Need to change EVAP?
  202. is my clutch slipping????? new ride
  203. Misfire
  204. well i went to the track tonight
  205. What is the difference between ceramic honeycomb and metallic cats?
  206. Vararam replacement??
  207. C6/ZO6 Stainless Steel Braided Brake Line Kits Only $89.99 a set!!!
  208. Need Help cars takes 10 seconds shut off
  209. LG header leak
  210. Tune in Louisville???
  211. What a let down....
  212. Valve Float or Tuning Issue?
  213. Anyone know what P0690 root problem would be?
  214. How does one pick a clutch? There are so many options, which are the good ones?
  215. DTC Codes, HELP!
  216. Roll Hoop installed on c6 vert
  217. *** Get Ready for the Track with Brake Upgrades from LG Motorsports ***
  218. New suspension car riding higher?
  219. Help! Will C5 rims fit on C6 with Z51 pckge?
  220. Got a Question about your Corvette? 10,000 Private Messages
  221. Track rotors and pads for 2005 Z51
  222. Bad harmonic balancer
  223. Supercharger vs turbo charger vs heads/cam looking for advice.
  224. Looking for Club or Group of "Enthusiasts" in Atlanta
  225. Getting new brake rotors soon...Need Advice.
  226. LS2 Engine Cutting Out
  227. car on jack stand pics
  228. Nitto Nt o5
  229. A4 DIY service?
  230. Tire question.
  231. Looking for Bottom End Performance
  232. Quick PTV/DCR question
  233. What performance to expect? LS2+Header+Intake+Exhaust+Dyno Tune
  234. Power convertible top
  235. magnetic ride control question....
  236. Doing a Z06 brake upgrade from base... do i need new brake lines?
  237. Kooks Header Super Sale @ KY SPEED
  238. Add a gauge to your dashboard - - -
  239. Awesome Deal on Borla Stinger w Quad Round Tips PT# 11744 (1 system only!)
  240. CLOSEOUT- Kooks Off Road X-pipes (Aluminized) for 239.95+ Shipping!
  241. Need header information please
  242. Installed you own headers? I have a question for you!
  243. Cannot turn interior lights off!!!
  244. how to clean LPE filter
  245. Z51 A6 Differential ring/pinion swap - what's needed?
  246. Can someone please explain to me the gear ratios in each gear and final ratio
  247. Wheel jack dolly
  248. >>>Chuck CoW ~ Mail Order Tune<<<
  249. Horsepower auto performance center
  250. 440 & 454 guys come on in!
