View Full Version : C6 Tech/Performance
  1. OBD11 scanners or code readers?
  2. dash differences
  3. Least invasive way to 500rwhp? (LS2)
  4. MAMBA AIR INTAKE - Any Info
  5. Dead Battery
  6. what's the best 60' w/ ls7 clutch?
  7. Tips on adding 20-25 HP
  8. Brake Pads
  9. Anyboby Who's thinking of doing a wide body,,,
  10. Deisel Powered Vette
  11. The New Key Fob ( Hidden Key)
  12. Brake/Rotor/Caliber questions
  13. Rear hatch release button-Replace?
  14. Looking for Reputable mod mech in Lexington KY
  15. Looking to fix my DRL/Blinker driver side.
  16. Apsis' Waterfall+Armrest in Premium Italian Nappa Leather...look FANTASTIC...pix
  17. Tune out Service active handling???
  18. For those who didn't see it....**vid**
  19. clutch fluid
  20. Hurst or b&m?? Or what?
  21. ls3 RPM limits?
  22. Re-posting exhaust question
  23. What is the RWHP/RWTQ limit for stock Z06 2007 Trans &diff ?
  24. LS3 Oil plug
  25. Managed to catch this one on video! - 10.451@134.734MPH
  26. 08 seat removal help !!
  27. 1/8 mile drag advice
  28. fast 92 on ls2 stock heads??
  29. Max tire size on C6
  30. Roof air leak at high speed, delamination?
  31. 2years 7months, still having battery issue
  32. Optima Battery Users...Question.
  33. Reusing Piston Rings
  34. Have BB Fusion Exhaust but...
  35. Removing dash and console
  36. Dyno Sheets - SAE vs. STD Correction
  37. G6X3 - Tell me about it
  38. help
  39. **LS3 M6 Corvette with 1 7/8 Super Pro Header Results**
  40. Power Steering goes "dead" for a Second @ idle
  41. Manual trans fluid recommendation
  42. Torque Management on C6 Auto not there
  43. ls3 clutch questions.
  44. Bare rotots
  45. Harmonic balancer LS2 (2006)C6
  46. swapping out seat skins
  47. An itch for headers
  48. Differential Matters
  49. Rear end noise
  50. **FREE SHIPPING** on all web orders!!!
  51. DTE Powertrain Corvette Differential Sale! --->
  52. Wanted to buy
  53. New Build - 1.7 or 1.8 Ratio Roller Rockers?
  54. AiRaid + Vette-Air
  55. NPP Exhaust question
  56. lowering 09 c6
  57. I installed a clear bra on my C6
  58. Questions on comparing Z51 Brakes vs Z06
  59. Educate me on cams for my purchase please
  60. Tire pressure sensor question
  61. hot engine air conditioning off DIC message after air intake install.
  62. new top
  63. LS3 Engine Question
  64. Weiand???
  65. PS2 or NT05 or Sport Cups
  66. RR-STRIKER CAM - Check it out(Vid & Graph)
  67. Is it bad to replace front rotors, but not rear?
  68. A question about Koni shocks
  69. Breathless Performance Huge Carlisle Pre-Sale
  70. At the risk of sounding stupid...
  71. Dumb S/C question
  72. Disappointed in A6 shifts
  73. SUPERCHARGERS!!!! What is best BANG 4 BUCK SYSTEM?
  74. Paddle & 1st Gear
  75. Thermostst question for LS2
  76. Stage 3 Monster Clutch Review - Part II (post breakin)
  77. Metal Shavings + Engine Out of Vette = ???
  78. switching seat controllers
  79. A "Little" Help
  80. updates to reprogram ECM and TCM
  81. 2005 a4 g90 3.15 rear diff questions
  82. Reading oil level on dipstick?
  83. PS2 Versus Kumho Ecsta XS
  84. Intake Air Temp
  85. Had a pretty good day at the track with the new cam - 10.486@129.95MPH
  86. Free TSB fix out of warranty?
  87. My new dyno pulls LS2 with all the fixins and a 2 stage
  88. LS2 forged rotating assemblies
  89. A6 - Best mode for drag racing?
  90. Help! smission shifting problem
  91. Specs on stock '08 torque converter
  92. low oil pressure light
  93. Beat The Heat Porting and Tuning Special
  94. wheels and tires Need Help
  95. H/C/I Questions for N/A and F/I
  96. Strange Car Problem, Need Help!
  97. Engine temp. help
  98. Noise after I rev in neutral????
  99. Bolt on 08 C6 + LG SUPER PRO 1 7/8" headers results
  100. ZR1 Motor
  101. Best way to turn the motor over by hand?
  102. Hot Rod Magazine Cam test
  103. 2006 c6
  104. **Cencal's 2005 C6 Forged LS7 build.. PICS Inside**
  105. Flashing check engine light
  106. VIDEO==EMCO Sequential Transmission for Vettes-LG Motorsports
  107. oil temp sensor location
  108. Timing chain for LS3 cam swap...
  109. do i have z51 suspention and a 3.15 rear ratio?
  110. *NEW* Painted Jake Skull & Chicklet...... pics
  111. Cold air intake
  112. AR Headers
  113. Bulletin #07-07-31-001B Clutch Hydraulic System
  114. WB O2 Sensor in Kooks Headers
  115. **Offical LG GT2 Corvette Rebuild Thread**
  116. Magnetic select ride...worth the $$$ ?
  117. First oil change in 2009 Z06
  118. Getting H/C/I this next week!!!! YAY!!!
  119. Adding bolt ons without adjusting my tune
  120. Issues with driver door rubbing on front quarter panel
  121. Wheel Widening
  122. [DIY] How to talk to Ricers at local car meets
  123. Easiest Way to Remove O2 Sensor - header swap
  124. Any local store carry 160 degree thermostats
  125. Has anyone ever broke the......
  126. Bent wheel, what are the options?
  127. Code C0196 ???
  128. Little help with boost pump
  129. Need advice
  130. MT Street Radials or Nitto/Toyo for mixed drag / street?
  131. Replacement Bulbs - 2006 c6
  132. STS= heat!
  133. Check Gas Cap Message
  134. Race Proven Motorsports 10.4 Cam Only!!
  135. 20 in rims
  136. squeaking noise from a pillar started after i changed my battery
  137. What headers would best compliment my new Borla exhaust
  138. c6 heads up not right
  139. Lowering Question
  140. Need a great trans tune in Maryland area
  141. How much louder are
  142. hypothetical ECU question.
  143. Zo6 removable top ?
  144. Service fuel system/low fuel
  145. Active Handling
  146. Race Proven Motorsports 580rwhp 520Tq CAM ONLY!!
  147. Service Bull. #3474 erratic fuel gauge
  148. RR-STAGE 5 LS2 ECS Kit
  149. Best Predator pricing?
  150. Just got my Airaid yesterday
  151. Can I Do This to My Exhaust??
  152. Headlight Issue
  153. Going Autocrossing Need Advice
  154. just bought a 2005 would not start
  155. 450 rwhp and up
  156. I want my c6 to sound super loud...Cam question's?
  157. info on catback selection
  158. How to stop weight transfer
  159. C6 Exhaust
  160. Need cam suggestions...
  161. its been a while
  162. Manual tranny differences
  163. 05 Waterpump Swap
  164. 2005 4 speed auto - gears ?
  165. What is Reasonable Cost For Cam Install?
  166. DTE Stage 3 A6 Rear End with 3.15 Gears
  167. C6 Cooling Fan Issues
  168. 2009 C6 Corvette Possible Clutch Damage?
  169. **LG Motorsports at Carlisle 2009**
  170. A6 max hp
  171. Cutting Out Rear Lowering Bolts
  172. Canned Response to Toyo
  173. z06 exhaust no non z06
  174. Tire size question
  175. New Rotors with new pads (Z51) ????
  176. Best C6 Z51 replacement rotors
  177. will c6 z06 wheels fit a non z06?and....
  178. Champion motors authorized pfadt dealer
  179. A6 Differential swap write-up????
  180. Supercharged A6 2nd gear slipping
  181. ls7 manifolds on ls3
  182. Toyo R888 UPDATE!
  183. Question about front deflector
  184. Point in the right direction for matching side,fog,head & interior white bulbs? Thx
  185. Can a TIPS tool be used to test a sensor before
  186. Send e-mails to Nitto for 555RII
  187. **Pfadt Coilover/Engine Mounts/Shocks/Chamber Kits Ect HUGE SALE**Limited Time Offer!
  188. Need help on Tire Size
  189. Trouble Shifting Into 5th at High RPM'S
  190. Low oil Temp?
  191. Poll To Gain Toyo Interest in the addition of OEM Size Tires.
  192. Poll to Gauge Interest of R888's in OEM Sizes
  193. Z06 Sway bar
  194. Broken TPMS sensor
  195. Toyo R888 prices?
  196. How to break-in brakes?
  197. TUne...What is the best HANDHELD for Z06 etune.
  198. Recommendation on lowest $ for Corsa Sports?
  199. Reommendation on lowest $ for Corsa Sports?
  200. Z06 bi-mode muffler on C6
  201. Help - '08 won't start
  202. Slow track times
  203. Stall Speed of Stock Converter
  204. Wheel Nuts/Locks in something other than chrome
  205. Sunvisors w/Homelink or Lear
  206. Z06 brakes Questions
  207. It Was Bound To Happen...
  208. Halltech / VORTEX RAMMER cold air monday
  209. What is this?
  210. Corsa Sport - Torque Values / Slight Resonance @ Idle
  211. Auto TCC Setttings
  212. Z06 Aftermarket Drilled Rotors
  213. $$$ VetteDoctors & Redline Motorsports PCM tuning @ Carlisle 125.00 $$$
  214. Stock Cam size????
  215. 6 point Roll Bar
  216. Is a meziere worth the $$$$?
  217. Post up your shift lights..
  218. Bpp hot new body design for rear diffusor and side skirts
  219. Moving stock rocker arms and pushrods around?
  220. Just installed Pfadt poly sway bar bushings... problem?
  221. ~~~St Jude Auction #53 Xcelerator Air Induction System (2005-2007 Corvette)
  222. New and Improved Bushing Kit
  223. Option Unavailable?
  224. Pfadt Pin Top Delrin Spherical Mounts for MOST Pin Top Shocks!
  225. C6 Head work suggestions
  226. Stupid question inbound
  227. Apsis' Italian Nappa Leather/Alcantara Pass Door Panel....look FANTASTIC...pix
  228. Pfadt Inverted Sport Shock Give-A-Way!
  229. *** brake bleeding help please***
  230. AirAid Intakes In stock & On BLOWOUT!!
  231. Factory Nav (Couple Questions on functionality)
  232. Need factory zr1 toe suspension settings asap help!!
  233. Cooling Fan Stopped Working
  234. Rear Tire Wear
  235. Vararam Intake Install
  236. Overheating
  237. Predator vs Warrantee
  238. Brake Caliper silly question
  239. Whats up with my vette?
  240. Looking for wisdom swapping LS3 for LS7 in 2009 C6 Z51
  241. 4.10s and MPG
  242. Quaife ATB Helical LSD differential
  243. how many other vettes were exactly the same as mine?
  244. Tranny / Shift to park message
  245. C6 suspension question - custom application
  246. Anybody use MAM Quad Cruiser exhaust
  247. Tranny question
  248. 2009 Cyber Gray Mods, Please Help
  249. New c6 What rpm should I shift?
  250. Real Paddle Shift Manual Available for C6?
