View Full Version : C6 Tech/Performance
  1. need help
  2. Is anyone dyno tuning at carlisle ?
  3. New Shocks-Koni FSD/Pfadt Inverted/Bilstein Sports
  4. The next step to that perfect sound?
  5. Building an LS3?
  6. Any Bendpak 4 post lift owners?
  7. Thanks Chuck COW
  8. run flat is flat
  9. Cams Cams
  10. Just Got My Car Back With Cam Installed
  11. Troubleshoot Ticking Sound
  12. StopTech Brakes, Quantum Motorsports Spindle Ducts Installed. Pics and weights inside
  13. 224/228 cam in LS2 - did I mention 3.90 gears?
  14. Help!!! At shop right now. End link issue.
  15. Need Tire Advice/Suggestions
  16. QM550 vs QM580 in an LS3 Dyno #s
  17. FAST intake special offer for your LS2 Intake
  18. What's your highest g-force on HUD?
  19. WTB: Intake Manifolds L76, LS3, LS2, LS7
  20. Ported Intake Manifolds: All models LS2, Ls3, LS7, L76
  21. Lingenfelter CAI Owners
  22. 16" Wheels
  23. Escort 9500xi issues ?
  24. Kenne Bell
  25. help;auto trans pan bolts???
  26. Make Headlights Brighter ?
  27. My First DVD {RUNWAY TITAINS: WOT!} Look inside for trailers...
  28. HELP! 224 cam is a disappointment!
  29. Cam Position Sensor
  30. Headlights Peeling?
  31. LS3 Cam only dyno numbers - G6X3
  32. MN6 shift issue, ON THE TRACK bog/lag/hesitation ONLY when going to 4th
  33. 09 Bluetooth problems
  34. Seat belt Question.
  35. MN6 shift issue, bog/lag/hesitation ONLY when going to 4th.. active handling? TCS?
  36. Spoiler vs Splitter
  37. 1st Come 1 Winner for a LG GT40 Exh. Deal
  38. sway bar end link noise
  39. What would you buy?
  40. Changing Spark Plugs.. Input Please
  41. Z06 mufflers too quiet????
  42. Big Pfadt Sale on coilovers & inverted shocks - with free shipping!!!!
  43. To those have heard both...
  44. 2008 Z06 Potential Issue?? Help
  45. Nav problem
  46. Help with TPMS
  47. Apsis' C6 ZR1 Style Carbon Splitter....installed...pix
  48. Have there been any accelerator problems?
  49. CF ZR1 Roof fit 09 ZO6?
  50. Rear O2's question.
  51. Z06 Brakes on C6
  52. grinding into reverse
  53. Tpms ?
  54. Active Handling issue after new tires, broken axle & dealer alignment...
  55. Powder Coating Spokes of Chrome Wheels Black - Can It Be Done?
  56. Transmission Adaptive Values And The Transmission Quick Learn Adaptive Values
  57. Looks like it will be awhile for Z51 sways, in the mean time ...
  58. Porting stock C6 exhaust manifold
  59. Anyone use UPF48R on their LS3?
  60. GM Parts House August 2009 C6 Specials
  61. Genuine GM PAL (Personal Audio Links) Available
  62. Genuine Corvette Accessory Splash Guards Available
  63. exhaust install re-visited
  64. brake pads or fluid???
  65. radar detectors
  66. Calibrating the NGK/AFX Wideband O2
  67. C6 Vert and the Quarter Mile
  68. August Specials www.PartsTaxi.com
  69. Z06 brakes on coupe
  70. '09 LS3 stock dyno
  71. What to do with 2k
  72. **Pfadt and IPS end of summer stimulus** deep deals!
  73. 1st Gear issue on 05 MN6...
  74. Will OEM Z06 wheels bolt onto C6?
  75. Callaway Double D exhaust
  76. Final Dyno Nos. Looking Very Good!!
  77. Is it possible to over charge your alternator
  78. Newbie bought 2005 C6 with Superchips-Should i return to stock setting??
  79. Vararam+npp+Kooks LT& catXpipe+Tune= oregon Emissions ?
  80. flowmaster
  81. LS2 heads-porting or milling improve them?
  82. New EMCO Sequential Video at 1/4 mile-stock engine 10.86 - 127
  83. How much HP loss to drivetrain on a c6 m6
  84. Complete DIY's on starting, charging, engines, trannys, etc.
  85. How Much Is A Good Torque Converter Worth?
  86. Exhaust Install
  87. How much RWHP should I expect from a procharger
  88. 174 MPH blast thru the desert
  89. Engine work in Central Florida
  90. Auto trans swap questions....?
  91. Formato Tuned and Texas Speed H/C C6 Z06 586 NA rwhp
  92. MN6, rubber mount blow out...HELP!!!!
  93. Best Suspention for
  94. Rocker Arm Modification?
  95. AirAid Intakes On Special @ Texas Speed!
  96. Is the LS3 padding/cover necessary?
  97. Dual mode exhaust
  98. BEWARE: Broke my leaf spring today!!!!!
  99. Power steering shudder on 2008 A6
  100. Review of Corvettemods oil catch can
  101. Heads up
  102. LS3 C6 With NPP any HP gain With axel back?
  103. GY vs FS Widths...?
  104. My chances of running a 10.99?!?!
  105. 09 Vert Top
  106. 3.73 Gearing in a Z06
  107. NEW CNC'd TRICKFLOW 235's 6 Bolt Heads ONLY $2298 Shipped in Lower 48 States
  108. LG Motorsports backs it up....big time !
  109. code p0102/p0103
  110. Katech Carbon Fiber Rear Spoilers IN STOCK - and: Update on Katech's aero development
  111. Rear Diff Question
  112. Stock LS2 FRC's on a FAST 92
  113. BPP Floor model shifter your choice 75.00 only one of each left
  114. Question on 09 Z06 exhaust?
  115. *NEW* Apsis' Airbag Cover preview..... pic
  116. I found "THE" Ext Cooler!
  117. Which rear end?
  118. Need interior ground location for Nav in a C6
  119. Strange grinding/sprung spring sound from engine
  120. Automatic shifters
  121. Wing or Rear spoiler
  122. C6 corvette z06 shocks oem gm zo6 05 06 07 08 09 10
  123. 224/228 cam in LS2 - dyno results -->
  124. Texas Speed & Performance FAST 92mm Intake Sale!
  125. How to fix dtc code po455 and po833
  126. Apsis' Waterfall & Armrest half perforated/half solid Nappa....just finished...pix
  127. Achieving HP and Torque
  128. a6 tranny or diff noise?
  129. FOB #1 and #2 Question
  130. rear suspension height difference
  131. Question for the motor experts.
  132. Nav Disc Question
  133. Need Help - Dyno Sheets Show Huge Loss of Torque
  134. Bang for the Buck Questions
  135. St Judes Fundraiser
  136. Forgeline ZX3S 19/20 full polish
  137. Brake Hardline Size?
  138. Corvettes of Westchester the "Official Tuner" at Corvettes at Carlisle
  139. how much air when autocross ?
  140. Has anyone run out of gas in a Corvette C6?
  141. Bartech trackside tpms tool
  142. Hp at the crank??
  143. manual trans atf
  144. Melted intake maniford c6 2008
  145. LG Cam Installed + Dyno Numbers to Share
  146. has anyone tried theses end links from corvette central?
  147. Clutch rating???
  148. Best NON BOTTOM BREATHER Intake for LS3??
  149. Corsa Exhaust On Sale 25% Off!
  150. NPP In a box question
  151. 650 Crank HP. Who and how?
  152. '06 ZO6 no start issue no one can figure out
  153. Installing vararam system on c-6, is that spacer they sell worth getting ?
  154. Steering wheel squeak
  155. Faster 0-60 Time
  156. New ARP Rod Bolts - Resize a "cracked" rod??
  157. Gears Changing Rear Wheel Dyno Nos.
  158. Can I glue a split in the C6 FRONT DEFLECTOR
  159. Trans Cooler Options for 09 C6 A6
  160. C6 exhaust
  161. Suspension
  162. Best lauch method....
  163. Ceramic pads? questions
  164. MAF relocation question
  165. Exhaust
  166. Any vendors wrenching at Carlise? (headers intake, cai)
  167. Lowered the c6 and added some Bilsteins
  168. C6 car died today - maybe out of gas...not sure
  169. Those with Kooks LTs w/3"x3" question
  170. Changing Z51 to Z06 Brakes: Which Rotors?
  171. Trans cooler
  172. Base ECS SC600 Kit - Stock LS2/ARH/METH = 800+ HP
  173. 2008 Z06 Dual Mode Exhaust Question
  174. How many inches for custom X-pipe on stock 05 LS2?
  175. Airbag Light Came on...
  176. Effects of running catless exhaust
  177. *New Column lock problem??
  178. BPP Haltech Blow-Out Sale $140.00
  179. Removal of A/C compressor (with engine in car)?
  180. Procharger install
  181. LG street series rubbing...
  182. change HIGH Tire pressure Monitor setting?
  183. BPP Floor model shifter your choice 75.00
  184. Will 17s fit over the rear Z51 brakes?
  185. Help me Help my Dad
  186. Anyone Have Problems With A Cam Install?
  187. Need a wire near the BCM that is live when the engine is running.
  188. Looking for feedback on pfadt pure street alignment specs
  189. Palm Beach Int'l Raceway 8/09 Corvette Challenge
  190. window problem, had to reindex pass window
  191. Intake manifolds
  192. Corvette Rotor/Brake Pad Combo
  193. Track day -> +1quart oil ??
  194. Added TVS, now front too low
  195. swapping skins out
  196. FAST Intake is available now for LS3s?? Where have I been?!
  197. How many people have this, and how well does it work?
  198. Pfadt coilovers C5/C6?
  199. Apsis' Carbon ZR1 Style Spoiler installed on Crystal Red....many nice pix
  200. electrical wiring 101
  201. Electrical problems with my 05. PLEASE HELP!!!!!!!
  202. C6 Z06 2008 Factory Oil Cooler System $285.00
  203. Dewitts Radiator/fans
  204. Installing Corsa Sport Exhaust
  205. Steering Column Lock C6
  206. MSD ignition for carb'd ls2
  207. Porting problem?????
  208. I need Serious Help P0300
  209. Service Engine Light
  210. FINALLY FINISHED Corvette Vert - Tons of PICS
  211. Amsoil users step in please
  212. **New Carbon flat bottom ZR1 Splitter from LG Motorsports**
  213. What defines WOT?
  214. Two observations on my new 2009
  215. Need traction bad
  216. Instrument panel cluster ????
  217. Opinions from those in the know on Diff. Gearing
  218. Those with SLAMMED cars running Pfadt coil overs.....
  219. Help with '05 noise/vibration problem
  220. Trouble Code Help!
  221. Pic request - LS2 air filter shroud
  222. Z06 manifold/cats on car already with stock H-pipe????
  223. C6 for a track car
  224. Glass Top or Door creeking 07 CPE
  225. Apsis just got these pictures from customer for Leather Door Panel..... pix
  226. Wrist pin retainer removal
  227. No HUD...But mount radar inside HUD space?
  228. Camshaft for 403 stroker
  229. Got a good question
  230. Rear Brake Caliper Cover
  231. REDEUX ## St Jude Auction #48 American Racing Headers C5 / C6 / C6Z06 / C6ZR1 ##
  232. The clutch pedal stayed on the floor,
  233. Crank pulley install contradictory instructions
  234. Upshifts not happening as expected
  235. ZR1 5th and 6th gear swaps?
  236. Track day problems
  237. C6 Exhaust
  238. Nav/radio removal
  239. Apsis' Driver Door Panel in Premium Italian Nappa Leather...got to see...pix
  240. Gear shift lockup
  241. Which Vararam to get?
  242. Poll: Have you had anti-sway bar end link noises
  243. Installing Exhaust in driveway Quick Help...
  244. wides 19" wheel and tire on a coupe?
  245. Change brake pads for the track?
  246. Noise? Clutch or Tranny?
  247. **New ForgeLine DE3P Wheel Design Release!!**
  248. DOT3 or DOT4
  249. Va Speed H/C/I+05GTO=520 rwhp
  250. Apsis' Roof Headliner & Halo Cover in Alcantara...look FANTASTIC...pix
