View Full Version : C6 Tech/Performance
  1. Jeremy Formato is Da Man
  2. First trip to the strip2008 LS3 a6,CAI and ported throttle body only
  3. Apsis' New Elbow Saver w-double stitching..... pix
  4. When changing clutches....
  5. POOR RESULTS with LS3 Mods: LG,Spin,ETMC, etc. your thoughts???
  6. C6 o6 after cat o2 sensor orientation ??
  7. Rear end gear chatter with Ram 90-2100 Clutch
  8. Spec clutch for LS7
  9. BPP Direct bolt on 4 Tip Diffuser unveil at Carlisle
  10. 07 clunk when full turn?
  11. Using Aftermarket Converters with a 6L80!
  12. Backlight Door Sill ?
  13. scanner
  14. Drill Hole in Throttle Body
  15. 07 Z51 MN6 tranny fluid R&R
  16. Vararam Install Instructions (with pre-cut shroud)
  17. My experience at LG motorsport
  18. Cracked my rotors in 1 stop!
  19. BB Billy Boat Fusion PICTURES WANTED: Oval and Round Tips!
  20. Any tips on installing long tubes without a lift?
  21. Bought a c6, a couple of ?'s
  22. Any results with Comp Cams LSR lobes for LS3?
  23. Runway Titans: Wide Open Throttle! Release Trailer...
  24. 08 c6 z51 mn6 tune etc..
  25. LS2 clatters at 2500-3000 rpm. Any Ideas?
  26. Pizzed Off!
  27. Best oil pump/dry sump setup for stock LS-7?
  28. Post up pics of your 18" drag radial setup....
  29. Where are all the naturally aspirated big motor guys?
  30. mass air question
  31. Opinions on STS Turbos
  32. Carlisle Show specials from LG Motorsports
  33. KW Suspension on my c6 zo6
  34. Wanted Vet Technician
  35. Trouble code
  36. Need help finding an 18x11 wheel with a 79 MM offset for a C6
  37. Apsis' C6 Carbon Rear View Mirrors...........pix
  38. C6 Corvette Hi/Low Speed Fan Control Module
  39. Check Oil Level...Message?
  40. BPP Direct bolt on 4 Tip Diffuser
  41. LS3 heads - should I port/mill? Need more HP.
  42. Replaced Battery-Now Window Problem
  43. C6 A6 Torque Converters
  44. LS2 Cam selection Livernois, LG, Other?
  45. sway bar problem, i need help
  46. Some new Redline Oil Viscosities
  47. Street, Drag, and Track Modes !!
  48. TPS values 0-19 and 81-100
  49. Tools for rear Z51 brake job?
  50. LS2 CAM ONLY is 461rwhp/432 reasonable expectations
  51. Weekly specials and sales
  52. Biggest Bang for your buck?
  53. atco raceway tonight
  54. LS3 Engine Dyno Testing @ Texas Speed!!!
  55. Rear sway bar diameter
  56. 2007 seat connectors and schematics?
  57. Accessory overstock blowout sale!
  58. Billy Boat BB Fusion Exhaust - What supplier has best price? Forem Vendorss? Special
  59. === carlisle, here we come!!! ===
  60. Help "service charging system"
  61. Thinking about a C6 in the Future. Need some advice
  62. supercharger for 07'C6
  63. Weird A6 trans issue HELP!
  64. Removing mufflers..
  65. *low* oil pressure - help!
  66. Stroke my LS3 or switch to an LS7
  67. www.PartsTaxi.com Grand Sport Wide Body
  68. Tune up?
  69. 05 C6 Won't Start
  70. Only 1 More Week For Carlisle A.R. Header Installs
  71. Anyone have the Borla multicore system?
  72. Mobil 5-20 vs 5-30
  73. Shift Boot Removal
  74. G-Force suspension
  75. LS2 TB actuating motor removal?
  76. Rev matching on downshifts
  77. Vettes racing at Road America
  78. Who has the hottest LS2 that's California lgl?
  79. Casual Sunday Mountain Cruise!!! High Def Vid! Pics of Amber!
  80. LS2 Oil Filters
  81. so close to the 11.3s but got shut down for no roll bar
  82. Grease Spotted Wheel
  83. Links to old Tech Tips & hopefully some new contributions, too
  84. Telescoping wheel mod??
  85. Problem with engine oil system in 06' Vette HELP!
  86. Z06 wheels on a stock C6 coupe.
  87. Big hp guys, grooved hoosiers-any traction??????
  88. Front Brakes Squeeling?
  89. Modifying NPP quiet side??
  90. Diablo Performance & LS3 Gains + Does it Tune A6?
  91. Is there any benefit to tuning a bone stock c6?
  92. Changing Bulbs in Dash
  93. Kooks at carlisle
  94. Drag Wheels Spacing Sizing
  95. front rear rims c6 18x 9.5 offset???????
  96. What is a "Service Brake"?
  97. c6 headlight wont come on HELP!!!
  98. Alternator plug wiring?
  99. who makes a C6 triple gauge pod that fits perfectly?
  100. Anybody using the SLP Powerflow exhaust?
  101. CAI least likely to hydrolock?
  102. Trouble Codes
  103. What Twin turbo kit is this? C6Z06???
  104. service active handling, abs, brake, and check engine lights on!!!
  105. Traction System Activates - Dry Highway
  106. Chrome Rear Roof Panel on a C6 Coupe
  107. Whats a good 12 volt switched power sourse
  108. Bunny Hop Worries Continue !!
  109. DIC Prompt: "Service chargeing system"?
  110. Clutch fluid stubborn ??
  111. 09 a6 showroom 1/4 et
  112. rattle - could it be brake pads
  113. Cost to Widen a Wheel???
  114. LS3 & LS7 on the Roadcourse!!! {HD VIDEO}
  115. "Pin holes" in factory chrome wheels
  116. 21st Century Muscle Cars News
  117. Doesn't feel as fast as I thought it would
  118. 2005 corvette z51 stock
  119. Koni Shocks : Update
  120. Gas Pedal Removal
  121. Which Sponsor has the best price on a LS2 shortblock for FI?
  122. which brakes to get..
  123. C5 visor mount for escort on c6 retrofit
  124. Goodyear Supercar question
  125. MLS Gasket for LG Pro Long tubes
  126. window will not roll all the way up
  127. Dyno Results!!!
  128. Installed the Diablo Performance tune today!
  129. fuel level sensor
  130. DIC oil change
  131. Once again.. LGM = THE WIN!!! 08 C6 with LG G6x3
  132. Window washer tank
  133. Best Headers with Magnaflow15884 exhaust
  134. Is my 6L80E giving up?
  135. 2008 Z51 vs F55
  136. YANK converter sale for August
  137. H/c/i results!!!!
  138. Question about Vararam and heat
  139. Tricky gremlin !!
  140. C5 vs C6 1/4 Race ROUND TWO!!!!
  141. Minor Issues With A 2005 C6
  142. cam position sensor help
  143. Tires Rubbing. Idea's??
  144. Dropped the car off for the TVS 2300....
  145. Newbie with a couple more paddle shift questions on 2007
  146. 08 Vortex Rammer filter upgade?
  147. '08 C6: Track day and weird whining "gear" type noise
  148. Service Active Handling...After Procharger!!
  149. 6L80 PIDs
  150. Are my times at the track ok
  151. What part number is this??
  152. Help with twin disk clutch
  153. Normal oil psi?
  154. Please help quick question!!!!
  155. clunk from rear when stopping
  156. Spinfast92 #'s.. You tell me if it's worth the $$$
  157. Question for HP Tuner Pros
  158. Weird Key Fob Issue.
  159. How to Race?
  160. *GROUP BUY* Apsis' Overlay Matching 08 Carbon Parts...first time, don't miss it!!!
  161. TPMS question do I need to get it reset everytime?
  162. Check It Out... Original Pfadt Installed Is Back
  163. Invo's with around 500rwhp
  164. Innovate LM-2 “basic” group purchase
  165. Caliper dimensions on c6
  166. Paddle shifters - C6
  167. widest front rim on c6
  168. Burbling Sound
  169. how much do coilovers help with the 60'
  170. GM's LS3 "hot cam" and carb
  171. 09 Mobil 1 Oil Filter
  172. GM's circle track engines (CT525)
  173. Help with Nav & Heads Up display
  174. Aftermarket Seats - All The Things You Are Going To Lose
  175. Billet Rocker Arm Covers
  176. unknown upgrades....
  177. C6 Exhaust SPECIAL
  178. End of Summer Cam special
  179. Leave well enough alone?
  180. Brake Rotor Question
  181. homelink
  182. Problem with driver's side window
  183. Can a Car "Lose" a Custom Tune??
  184. 2005 stalling
  185. Service Column Lock do to new transmission?
  186. Updates on H/C/I install!! w/PICS!!
  187. Z51 sway bar upgrade
  188. Header install first time.
  189. I need a pic of the Convertible position switches
  190. T1 GM Perf. parts sway bar end links
  191. Transfer Tube O-Ring Seal Failure-Advice Please
  192. Optima Battery
  193. No first gear with A6 in "S" or paddle mode.
  194. Intake Torque Specs.
  195. On a Hot Day in Dallas - 534 rwhp
  196. MTI Racing SPECIAL on Pfadt Shocks and Coilovers
  197. MTI Racing 500ci Dominator Engine Assembly
  198. Vengeance Racing builds 496 Warhawk... Dyno Graph/Idle Video/Pics Inside
  199. MTI and LG... plus 100 hp
  200. Dropped the vette off this morning..
  201. No Dyno but...
  202. Bad rear shock @ 7900 miles ??????
  203. Need a Part HELP!
  204. Interesting Discovery (I Think)
  205. Help!! Service Fuel System Message
  206. buying new rims tires need help with sizing
  207. Intake & Exhaust Modifications
  208. can u install headers on stock hpipe
  209. Will a x-pipe make any difference in sound?
  210. Tune Question
  211. Power steering trouble
  212. oil pan systems
  213. LG SUPER RAM COLD AIR carbon fiber true ram air
  214. C6 No Electrical Power
  215. Pfadt Coilover Installation
  216. headlights
  217. Anyone have the LPE 616 package?
  218. Sunset Orange Creations.....Exhaust Commander
  219. High octane fuel question.
  220. Exhausts & Cutouts On Sale @ MarylandSpeed! (Borla, Corsa, B&B, Magnaflow, etc)
  221. Vararam on Sale @ Marylandspeed w/Free Shipping!
  222. Need help asap! Key prob..
  223. Skipping/hopping/bad shocks?
  224. LS7 Z06 goes 589/536 NA Full Exhaust.. Dyno/Idle Clip Inside
  225. Stainless Steel brake lines causing interference?
  226. Attending Corvettes at Carlisle?
  227. Quickie Cam Question..
  228. Do HPDEs trash street tires???
  229. Anyone know the thread size for the LF brake line on the Brake controller?
  230. Just Got My Car Back With Cam Installed PT.2(with video)
  231. Frontend Alignment at 14K Miles?
  232. New to Forum - C6 Airbag Readiness Light On
  233. Suspension grease points on 05 z51?
  234. FIRST oil change recommended mileage?
  235. Bullet-proofing the 2005 C6 Diff~
  236. Best racing wheels.....on budget
  237. Fog Light Assembly Replacement Question
  238. Code reader for active handling/traction control?
  239. Breathless Performance Huge Carlisle/Caravan 09 Pre-Sale
  240. Water leaking into the floor boards from above?
  241. Anyone go from one intake to another?
  242. Help with motor work, procedure.
  243. Finally tracked my car Cammed LS2 [VIDEO]
  244. "on car" welding
  245. What pressure to run with MT ET Streets 305/35R18
  246. Service Active Handling light comes on
  247. which heads for my ls3....
  248. Bullets and Active Handling
  249. L o w e s t . . P r i c e s . . E v e r !! MONSTER CLUTCHES
  250. Which port in the Fuse box???
