View Full Version : C6 Tech/Performance
  1. spark plugs and wires
  2. What is the correct idle?
  3. Exhaust/Intake/Headers Installed (Noob with Pics/Vids)
  4. Lookin' for advice, words of wisdom from my C6 brethren....
  5. Why The Fuss Over Aftermarket Shifters?
  6. C6 over heating w/no fans coming in
  7. Z05 caliper distance from rotor to wheel spoke?
  8. Z06 will not idle
  9. Where can I track my car in PA
  10. P0700/P1825 codes '07 A6
  11. Polished or chromed Alternator for 09 C6
  12. MGW Shifter Installed WOW!
  13. B&B Bullet Twin Tips...How they look on C5
  14. FAST intake, cover & fuel rail mods.
  15. stock cd changer sucks
  16. Cleartastic..DIY people
  17. Introducing Stage 2 Intake Porting
  18. help please
  19. $8000.00
  20. service active handling message
  21. HUD just quit
  22. Are the C6 and C5 alternators interchangeable?
  23. Gumby wheel fasteners
  24. What headers do I have?
  25. Popping noise in front end
  26. Need help deciding what to do...
  27. Help me build a mean N/A A4
  28. Need help fast
  29. Launch control in pre 2010 C6s
  30. Emission Inspection - my '05 computer not detected
  31. Eliminate Oil in the Intake Manifold
  32. What is widest rim I can put on front?
  33. Installation of Under Hood Light
  34. New exhaust install-2006 C6A
  35. ORB Fittings
  36. HORSEPOWER FOR '05 - '07 at Corvettes of Dallas
  37. Need Clarification on endlink install
  38. Engine code?
  39. What could be wrong?
  40. Dyno #s restated! Bolt on LS3 454 RWHP
  41. How many hp/tq for +140 trap speed??
  42. C6 coupe and a '00 gt
  43. shifter disassembly help please
  44. Anyone make a device to cause the door LED to blink?
  45. c6 oem radio help
  46. CAGS Eliminator which one to use?
  47. Dyno Results - LS2
  48. Where are you guys mounting you Auto tranny coolers?
  49. Does it pay to put in a Z06 oil cooler ??
  50. Long Island, NY Dealership
  51. If you swapped cams in your ls3 COME IN!!!
  52. ***question about throttle bodies***
  53. Please, need help with a suspension question
  54. Front Lower Control Arm Replacement
  55. Brake Line What type flare?
  56. Toyo R888 or Nitto Invo
  57. Steering Wheel Play / Slop
  58. Removing Plastic Engine / Coil Covers
  59. ABS problem is displayed after steering gear replacement and turning left...
  60. Ticking with wheel turned
  61. change the oil or not?
  62. Busted parking brake??
  63. racing a heads and cam ls1
  64. LG "Street Series" vs "Pro Series"
  65. Any before/after dynos and slips of stock auto LS3's with tune?
  66. Need help with mods.....
  67. DIY: properly change the color of the interior accent LED
  68. Looking for Advice on C6 Issues
  69. Good tuner in Houston area?
  70. How difficult is it to replace the rotors
  71. Finaly got her dynoed!
  72. ** New best - 11.1@123.5mph in my CARTEK bolt ons only LS2 **
  73. HELP I get Service Active Handling/Traction Control after hard acceleration
  74. Confused by this CEL code!!
  75. Oil Pressure - How high is Too high?
  76. Top End in a Convertible
  77. CEL, stuck in third
  78. Low speed low acceleration Lag when shifting
  79. Really showing my age now (ignorance too)
  80. Headers or Z06 manifolds?
  81. Do not buy from Ecklers Corvette PArts or Carolina Clutches
  82. Breathless is open for Business in Bowling Green
  83. Catalytic Converter on C6
  84. Fog Light Adjustment
  85. Change your clutch fluid
  86. ZR-1 Body kits????
  87. headers/o/r x-pipe w/slp loudmouth or powerflo??
  88. Ported stock LS2 vs FAST 92
  89. Need Help!!! Fuel pump went out!!!
  90. Shift linkage connection at transaxle on C6
  91. Help choosing Cam to my modded LS2
  92. Clunking from rear (new endlinks didn't help)
  93. Stock Shock Question
  94. 2008 z51 dual mode
  95. Intake AND MAF??
  96. Who has added dry-sump to LS3?
  97. Your thoughts on 4.10s
  98. S. Fla - PBIR Corvette Challenge & All Day Open Test Day 9-12-09
  99. Top speed
  100. California emissions on a C6
  101. Mobil 1 Racing Oil Technology
  102. Thank you to all at Carlisle
  103. Problem??
  104. Cooling water flow
  105. PFADT coil over question ....C6...
  106. Carlisle Night Header install in the hotel parking lot... (lotsa pictures)
  107. Guys that have lowered on stock bolts
  108. 2005 interior rear view mirror loose
  109. Think I lost my tune
  110. Best LS7 Street Cam and Header????
  111. Looking for LS2 Tuner in So FL
  112. SS Lines For Z06 Brake Upgrade
  113. Is there a trick to removing a C6 fuel line
  114. Gas Cap Light
  115. Trickflow Cylinder Heads $5.00!!!!!! EVERYONE STEP INSIDE FOR DETAILS!!!
  116. "SERVICE COLUMN LOCK" Updates?
  117. 2009 tpms
  118. Killer Canyon Run with new B&M Shifter!!! no vid...
  119. fitting c5 z06 sized rims on a base C6
  120. Line Lock switching install
  121. Need some help with control are bushing.
  122. 2008 Auto transmission shifting problem
  123. Crank pulley bolt backing out
  124. '08 style console on an '06?
  125. High Octane fuel??
  126. highest redline
  127. 08 A6 programming question
  128. Sept is almost here...where is the LS3 FAST?
  129. Please help,, Brake Question..
  130. 2008 C6 Overheating issue
  131. C3 guy needs C6 cooling system help
  132. LG motorsports spindle ducts
  133. Question about California Emissions
  134. Who has the best CAI? Real gains??
  135. Fixing a wrecked c6
  136. Cleaning coolant overflow tank
  137. clutch & install, who's has the best prices in SoCal
  138. 5 & 6th gear problem
  139. Sway bar end links
  140. P0170 after manifold install
  141. Amsoil oil analysis results
  142. Tires for c6
  143. K&N Aircharger for LS3
  144. 410 Gears?
  145. Wheel Offset Chart (covers high offset & wide wheels)
  146. "Service active handling"
  147. AH(Active Handling) vs. VSES(Vehicle Stability Enhancement System)
  148. cam installed at Vette Doctors
  149. Stage 1, What to get?
  150. Exhaust Cut Outs
  151. Ceramic Brake Pads for C6
  152. Wheel tech question
  153. Made a little video Stage III LS3
  154. AFR heads CARB legal
  155. Strenght and weekness
  156. 07 Check Engine Light Help
  157. Need a Cheap Wireless Remote Trigger ala Invisicord?
  158. P0335 "Crank sensor error"
  159. Bang for the buck bolt ons...
  160. Oil Drain Plug Nut Size? 09-LS3 05-LS2 & 00-LS1
  161. C6 LS3 NRP Cam Package 467rwhp - Video
  162. Supercharger bling on a Friday
  163. Friday obliteration pictures
  164. Any difference in 2005 Nav?
  165. Decision time and still undecided, ADVISE!!!
  166. American racing headers SALE for c6 corvettes
  167. Service Column Lock
  168. Rear tire pressure
  169. need a little help, confused...
  170. Greg Banish Book
  171. OEM LS3 intake manifolds and TBs sold out?
  172. Lowering Question
  173. New differential break-in?
  174. Z06 exhaust on C6
  175. z06 Header Install Help
  176. Adding bluetooth to my '09???
  177. What width rim for a 19" 345 ps2
  178. PHADT Coilovers Setting?
  179. Oil Leak TSB 1406822??? BS to me
  180. Feedback on Pfadt Motor/Trans mounts install
  181. Factory engine break-in?
  182. A/C Vent Technical Question
  183. wiring in Autometer Nexus gauges (12v switched question)
  184. L92 LS3 Heads where to buy
  185. My review of Pfadt Coilovers, camber kit, and bushing kit!!!
  186. Best way to remove rear view mirror from mount?
  187. Targa weather stripping maintenance
  188. Exhaust Woes
  189. New MGW shifter installed
  190. Parking Brake Adjustment?
  191. Changing 2005 Z51 break calipers for the larger ones?
  192. LS3 vacuum line diameter for NPP
  193. Radiator troubles
  194. Lets play: Name that part!
  195. If I use the stock crank can I just replace rod and pistons with upgraded ones?
  196. Drilled AND SLOTTED rotors
  197. Stupid lug nut question
  198. What is the best RPM for fastest launch!
  199. Fixit solution
  200. What am I doing wrong LOL
  201. ms4 cam on c6 05 stick
  202. Aerodynamics question
  203. QTP Cutout Switch Install
  204. You REALLY should get a CHUCK CoW TUNE @ CARLISLE!
  205. Tires for better traction?
  206. 06 Auto exhaust
  207. trac/act hndling Problems
  208. 2007 F/I LS2 swap to LS3 will it work with LS2 computor etc?
  209. High tranny temps,,
  210. Want to make my exhaust louder!
  211. Fast clicking noise from engine?
  212. Pfadt Suspension Upgrade
  213. I found a broken spring. Need some help.
  214. '09 LS3 21st Century Stage III Cam results!!
  215. Back Up Lights
  216. C6 & Headers in NH?
  217. Corvettes at carlisle is this weekend
  218. 08 NPP VS 08 Z06 Dual mode
  219. nitto invo's
  220. Has anyone upgraded their A6 Transmission
  221. Dealer cannot program remote
  222. Throttle body exchange
  223. • • • HID HEADLIGHTS & FOGS INSTALLED @ CARLISLE by CoW • • •
  224. Anyone running a RPS organic street twin?
  225. Sunday is the best day at CARLISLE! at the CoW BOOTH!
  226. Tuner shop in Phoenix
  227. Upgrading my fuel system, need help.
  228. high gear at low RPM giving a larger amount of throttl
  229. '09 C6 Z51 6spd manual drivetrain
  230. 427CI to 440CI why?
  231. who mounts their own 18" and 19" tires?
  232. **HUGE-HUGE-HUGE giveaways at the ECS Carlisle booth!!**
  233. Apsis' C6 Nappa Leather Door Panel finally installed......got to see.....pix
  234. Another clutch problum ?
  235. Whats up j??
  236. Billy Boat Performance Exhaust is looking for a few cars
  237. T/B Spacer
  238. Just broke my rear. Need advise.....
  239. ***LG 1 7/8 SUPER PRO HEADERS HUGE Special at Carlisle
  240. Right Side Rotors
  241. Hoods for TVS2300 magnacharger?
  242. 09 LS3 Low Speed Bucking with Manual Trans
  243. LS2 - LS3 Crankshaft
  244. Throttle Response??
  245. Did a search but did not find......
  246. z51 Ceramic Pads. What? Where?
  247. z51 Ceramic Pads. What? Where?
  248. 02 sensor spacer? Engine light on after installing LG Headers
  249. Cam info please
  250. *** NEW - CORVETTES of WESTCHESTER - WINDOW DECALS ***
