View Full Version : C6 Tech/Performance
  1. Questions for guys with the A6
  2. Torque Wrench Accuracy ?
  3. '09 ECU reset itself??
  4. Options Menu Problem
  5. You guys know how to remove this screw?
  6. Accident - advise needed!!
  7. Open exhaust vs. Corsa Xtreme
  8. Best Runflat Tires that is best for Wear & Comfort
  9. need help with oversize cam
  10. OEM Z51 vs Bilstein Sport
  11. GM Accessory C6 Splash Guards www.PartsTaxi.com
  12. Sway bar bushing bolts
  13. Got my TIPS tool today (the green one)
  14. Texas Speed & Performance Fall Engine Sale
  15. Another popping suspension thread
  16. Where would you get a fly cutting tool?
  17. Wheel size selection: any good reason not to run 18"s at all 4 corners?
  18. Headers, Cam, Vararam installed, short vid
  19. Telescopic Function won't work
  20. Rear alignment adjustment range
  21. How to repair cross threaded brake line nut?
  22. How/ Where to resize stock injectors?
  23. Corvette only track rental - Smackdown at MIR
  24. Brake pad questions
  25. LG pros 2 1/2 moded to 3'?
  26. *** ATTENTION A6 OWNERS !!! - CoW A6 -REAR END STIMULUS PROGRAM- STARTS TODAY! ***
  27. Broken DTE diff!
  28. Radar detector
  29. why not G6X4 cam??
  30. Looking for Ideas...
  31. Micro Camera Shows the Workings of a Combustion Engine....
  32. How to install the visor?
  33. Exhaust system upgrades WITHOUT added noise
  34. Strange TPMS problem
  35. Leak, what is it?
  36. 345 rear tire is rubbing in tight turns :-(
  37. Help identify these harnesses for me?
  38. 2008 z51 c6 clutch question
  39. tourq Converter question?? help
  40. Do these dyno # seem to high for LS2?
  41. Need Brainstorming Session - Hi-Speed Fishtail
  42. Exhuast Sound
  43. Black is Beautiful, but...
  44. Injectors, can you go too big?
  45. AR Headers
  46. Question about doing a carb'd LS3
  47. Carbotech Now Offers Brakes Pre-Bedded!
  48. Battery Cable Quandry
  49. Wider tires, possible wide body conversion needed.
  50. Injector removal???
  51. Tuning question
  52. steeringwheel shakes?
  53. ls7 clutch info
  54. New to the car, new to the performance, help
  55. EnglandGreen Whiplash cam, 2008 LS3, 475rwhp - stock heads
  56. Spun my Crank Pulley questions
  57. Headers 1 3/4, 1 7/8, and 2 inch with aftermarket Heads
  58. 17" wheels for drag radials...will these ones work
  59. low speed squeak from rear of car
  60. which throttle body would you want on your vette ?
  61. what is this ?
  62. 05 Z51 -how to remove FRONT rotors
  63. NAV -XM1/2 Display Issue
  64. C6 A4 & Drag Radials = KABOOM??
  65. R/R rear wheel stud advice??
  66. Drag testing LS3 fast intake
  67. Is timing retard at shifts killing my MPH?
  68. Tire Wear/Alignment Problem
  69. Help with C6 Rims
  70. C6 - A6 with non factory gears
  71. Grand Sport Brakes
  72. LS3 PCV Valve?
  73. PCV Dirty Air Hose
  74. Any 16 inch rims available for C6?
  75. Scanner tool for a 2005 C6
  76. Evaporative Emission System
  77. Please Help: UD Pulley and Reduced Engine Power
  78. Torque Tube Problem
  79. Ls3 ?
  80. Baer eradispeed brakes make loud clicking sound
  81. Finally cut apart what I consider to be a failed end link
  82. Free Shipping @ GM Parts House
  83. GM Parts House Comes Back (October 2009 C6 Specials)
  84. Supercharger and cam tune
  85. cam and spark plugs change interval
  86. Oxygenanted or Ethenol(??) Gas
  87. Need Help on Bilstien Shock replacement
  88. Lifetime Oil Filter ???
  89. Rim Question: Z06 verses stock
  90. Power top issue
  91. New K&N cold air intake for LS3
  92. Address for COW Tune in SC?
  93. Any LS2s with Trickflow heads out there?
  94. Do you have an England Green cam/tune? Step in.
  95. Any difference between C5 an C6 front clip?
  96. 2005 C6 + double din?
  97. Shift Light with RPM Switch Installed
  98. Trans cooler
  99. Jacking car while on lift question?
  100. which air induction system?
  101. Installed MGW shifter
  102. My C6Z dyno vs my old cam'ed LS3 dyno
  103. LG Street's vs TSP 1 7/8's?
  104. ENGINE HOT/AIR CONDITIONING OFF in DIC!!!
  105. Two Big Questions
  106. October C6 Specials - www.PartsTaxi.com
  107. Lookin for inexpensive way to eliminate drone from hatch area of C6. Have SLP LM 2s
  108. Michelin Pilot Sport PS2's
  109. Vbp is driven
  110. Anyone changed door lock LED?
  111. Et vs mph
  112. Potential Rear Suspension Damage - advice?
  113. 2008 Corvette Z06 Factory Exhaust
  114. 2008 C6 Wheel Stud diameter & pitch???
  115. Questions about tunnel plate install
  116. Which Way to Go?
  117. Changing redline (max RPM) for engine
  118. SLP Resonators Muffler Question
  119. Twilight Delay - What's The Scoop?
  120. Good Shop Near GAINESVILLE, FL????
  121. Oct 1 is date for more oxygentated ethanol % in gasoline
  122. Billy boat xpipe
  123. A Pretty Ported Throttle Body
  124. Which Gears Do You Suggest For a Modified LS3
  125. Best 1/4 mkile times on Toyo r888
  126. Anyone Have Their Vararam Suck in Leaves
  127. headers at a decent price
  128. Race with a moded Terminator
  129. Stealerships SUCK!!!
  130. Who is running a 345 MT on a forged 18x12 or 18x13 Z06 fitment?
  131. American Racing Headers Sale!!!
  132. Vacuum Leak ??
  133. Dash speaker cover removal
  134. C6 Best tire size
  135. PM-FL DART 225 Heads & Cam Special!!!
  136. C6 Z51 Rotors- Can they be turned
  137. Traction Control
  138. My car is almost done!
  139. Throttle Body Porting
  140. Want to get my ls2 a6 up to z06 power. What's the most cost effective solution?
  141. C6 towing
  142. Ceramic Break Pad Advice
  143. 17" or 18" drag radials?
  144. How To Change C6 Brake Fluid *Not Clutch*
  145. A&A Corvette does a Wilwood Big Brake Kit
  146. interior pieces??? help
  147. Brake Squeal
  148. Lowered car, need to raise back, where to buy bumpstops?
  149. FAST LS3 Intakes Still In Stock @ Texas Speed
  150. 05 / c6 mirror upgrade
  151. Ngk afx wideband
  152. NPP Reprogramming?
  153. 800rwhp - Nitto Invos/MT ET Streets - What can i expect?
  154. Track Event - Oil Temp seemed to get a bit hot?
  155. Engine Number for C6
  156. false oil change notice-how to rest
  157. C6 Wiper switch schematic and connector
  158. Where does this ground wire go by the horn?
  159. How to decipher revised Vararam vs. old type
  160. MN6 T6060 problem? Synchros?
  161. Instructions for replacing the Balancer Pulley?
  162. F55 suspension question ? Mrc
  163. Strange thing just happend help
  164. 4.10s - Value as a mod
  165. Cam'd 08 Z06-Spark Plug Question ASAP!
  166. Small cam better for Ls3???
  167. Bluetooth problems
  168. Clutch engagement rough with new 6-sp.
  169. Tune question with fast install??
  170. Got a retune at EnglandGreen and picked up more power LS3/headers intake
  171. Wideband Install Help
  172. 2006 targa roof PICS of start of DELAMINATION, any DIY suggestions?
  173. C6 W/ Cloudy Brake/Clutch Fluid
  174. anybody pull fuse Fuse #5 is for the ENGINE CONTROL MODULE - MAIN
  175. Differential casing vent
  176. 2005 throttle sticking
  177. Header install
  178. Tapping in engine
  179. Water Pump
  180. hesitation on WOT
  181. Patriot Gold Dual valve springs...when to replace?
  182. Will I have problems if my intake manifold/throttle body connection isn't 100% sealed
  183. Throttle position sensor?
  184. FS: '07 Z06 Chrome Speedline split spoke wheels
  185. Best dyno and track numbers with bolt on only LS3
  186. Intake help needed please
  187. car surging fixed.
  188. exhaust manifold torque specs
  189. Engine Dyno Testing LS3 Intakes INSIDE!! LS3 vs Ported vs FAST
  190. Dynomax mufflers
  191. New dyno results 383/370
  192. Where do I look ???
  193. Can I hot 400+rwhp with......
  194. Request Info on HALOs
  195. Clutch Pedal Sticking :(
  196. Bras, covers, battery tenders and ......
  197. Let say I install my H/C myself, can I then drive and get a tune?
  198. Finally Done!!! - No, Serious.
  199. Heat Cycling MT ET Streets?
  200. METHheadMONSTER: Using Meth Injection for non-boost applications
  201. Fusions
  202. New rims..and lots of weights
  203. theft-deterrent system lockout? please help
  204. 09 Vette cold air intake and exhaust
  205. HUD not working after being rear ended
  206. Need some advice
  207. Flywheel to Rear Wheel loss
  208. Opinions needed
  209. Heated seats
  210. MP3 CD's don't work
  211. Knocking sound in rear when I do slow turns and/or bumps/dips
  212. Carlisle Header Parking Lot install, Dyno, and Drag Video
  213. Reason to use a high stall converter with a 3.42+ rear
  214. O2 sensor mounting advice wanted
  215. CAGS disconnect plug installation video
  216. Will Z06 Exhaust Fit on non Z06
  217. Who has installed Corbeau A4 seats...
  218. My Z51 Brakes are TERRIBLE !!!!
  219. Need Help with TPMS Sensors and Drag Radials
  220. Screw in tire but not leaking.
  221. Ported my spare LS2 Throttle Body and stuck it on my 06 Coupe
  222. DTE Brace 05 fit an 08?????
  223. Disconnect battery to charge affect the security system?
  224. question
  225. 2005 C-6 Shift to reverse
  226. How to get collapsed lifter to pump up?
  227. Oil cooler
  228. clutch spring fixed, now pedal issues!!
  229. 2005 Dead Battery Syndrome .. my findings
  230. How to get 500 WHP from C6 07?
  231. Is anyone's Innovate XD-16 wideband gauge getting hot?
  232. Awesome Deal on Borla Stinger w Quad Round Tips PT# 11744 (1 system only!)
  233. Did the DIY for active service handling..but.....
  234. Making a widebody... how to remove front inside wheel well?
  235. Is there a vendor selling this exhaust?
  236. Anybody used these ramps?
  237. Collapsed LS7 lifter?
  238. Is there an LG rep kickin around here?
  239. Drag Radial Solution...
  240. Another Widebody Conversion Thread..
  241. GM changes powertrain warranty!!
  242. BTU Ratings of Oil Coolers
  243. NPP rattle
  244. c6 2007 front speaker shot
  245. Fuel System Cleaning???
  246. Track day
  247. FAST LS3 102mm Intake Manifolds IN STOCK @ VENGEANCE RACING!!!
  248. Recommend a Gear Change / Tuner - Alabama
  249. American Racing Headers Rock!!
  250. Can a c6 zo6 brake system fit on a c6 with stock c6 wheels?
