View Full Version : C6 Tech/Performance
  1. Wheel Hop!!
  2. removeable top question
  3. Will C5 wheels fit C6?
  4. little help
  5. Need help with exaust
  6. Windows won't go up when door shuts?????
  7. clicking noise coming from hazard switch??
  8. Can I turn my Vette into a 4 or 6 Cyl and Save Gas?
  9. Brake upgrade ????'s
  10. Speedo not reading on hp tuner/WOT.
  11. Rainy day (Time for a youtube video)
  12. C-6 torque converter question
  13. Halloween Sale on all BPP Products
  14. Mobil 1 LS ok to replace GM Dexron LS Gear Oil?
  15. Shocks worn out?
  16. Horsepower Sales
  17. Hurrican CAI Owners- Did you throw a light?
  18. Air Intake Temp. Test... Part 2
  19. High HP, improving stability
  20. Suspension Gurus... a few questions.
  21. Z sways installed .. centered???
  22. Stainless Steel headers polish/refinish
  23. Mustang GT beat me up!!!
  24. Va Speed install specials, part deaux---->
  25. A6 Sloppy Shifts
  26. but how *high* is the center of gravity in a C6?
  27. Z51 vs Zr1 sway bars
  28. What 17" rims fit the back of a C6??
  29. Think he can get away with it??
  30. FINALLY...A C5 to C6 diff conversion write-up.
  31. Z51 Greaseable Rear Toe Link Seal Lost
  32. **$149** Man Knob Special from LG Motorsports
  33. Performance mods 101
  34. Sold the C6
  35. One More Stab At Catch/Breather Cans & PCV System...Please Chime In...
  36. Engine revs - but doesn't go any faster...
  37. After market tune voids warrenty ?
  38. Need advice on pads and rotors
  39. Z06/LS3 Maf Anyone install it on a LS2? How? What did you gain?
  40. Cold weather = low tire pressure
  41. Squeaking/rattling sound?
  42. Differential Question
  43. Fan Shroud replacement?
  44. Pulled the trigger at LG Motorsports
  45. transmission oil temperature is above 102c is that normal ???
  46. What makes the C6 tranny so much smoother than the c5 m6?
  47. 2005 C6 Recall List?
  48. Best Clutch for the buck thread
  49. stock 05 a4 vs a6 0-60 and 1/4 mile
  50. Cat delete/testpipes??
  51. 11 second c6 a6 ls2 2.56
  52. Broken targa latch
  53. Granatelli
  54. C6 Oil Filter
  55. Tail lamps wont come on. Relay or comp issue?
  56. Black Magic adds 39 HP question
  57. Car running hot!
  58. MGW Short Shifter
  59. TPMS config.
  60. Valve seal removal tricks??
  61. LSX Shootout 2009
  62. Anyone had problems with Pfadt end links on stock (Z51) sways
  63. EnglandGreen's $1400.00 Giveaway Winner Announcement!
  64. Factory Replacement ARP Wheel Stud
  65. Ait Filter Oil
  66. **LG World Challange Wheel Sale $1395/set!!**
  67. K&N Filters or Whole CAI?
  68. Time for a new Battery
  69. Plug wires causing tune issue?
  70. 4000 Miles and Rotor's Need to Be Turned
  71. plenum mod
  72. Do cooling fans turn off at highway speeds?
  73. Torque specs on Pfadt Endlinks and Sway Bushings
  74. Yellow "O" ring. Where does this go?
  75. Ls2 - ls7 rocker upgrade
  76. How much hp with these options?
  77. 2007 z06
  78. Z06 Clutch ?'s
  79. 2009 2 tone replacement seat covers
  80. Rough 1 to 2 shift in cold weather
  81. Chuck COW Tune....just Awesome
  82. New Vette Upgrades.. Your opinion!???
  83. Radio button dont light up??
  84. 0-60 4.3 ??
  85. Brembo Big Brake Guru?Sport Cups, Pirelli Corsas
  86. Anyone install a mild cam without headers?
  87. Quarter mile / slow 3rd gear shifts
  88. 05 flood damage..
  89. Question About Tune
  90. 12.36 @ 122 (sigh)
  91. Anyone having problems with rear O2 sensors removed
  92. Air Intake Temp Test...
  93. Matte Black 05'**Cammed**VIDEO
  94. Battery drain/ starting issues
  95. Trailer Wiring Question
  96. New PB 11.53 m6 bolt on ls2...
  97. Are the front and rear O2 sensors different shapes?
  98. Play in steering
  99. new pb bolt on LS2 11.19, look out LS1LT1 here i come
  100. Driver's side mirror lights work, Pass doesn't...
  101. Anyone running headers, no cats and stock exhaust?
  102. Wheel width
  103. Which front fenders are the lightest?
  104. Oil temp 232 high?
  105. Where to splice in side repeater lamps for widebody (T90)
  106. FINALLY 17" SLICKS!!! Was I the last to know?
  107. In Gen. Disc. forum I'm an idiot, so I'll try my question here
  108. ***HELP****....question about Crank reluctor wheel
  109. Vbp is driven
  110. Bad vibes
  111. Does the C6 243 head fit the 5.3 liter engine?
  112. Installed my SLP 160 t-stat today
  113. **New CenterLock wheels from ForgeLine and LG Motorsports**
  114. Rear end noise...replace bearings? easy?
  115. Where can I order a rack & pinion other than the dealer?
  116. RPM Transmissions 2008 C6
  117. rear end noise- C6
  118. Antilock Brakes (ABS) Grabbing at Idle
  119. Sways swapped-Tunnel plate or shocks improve??
  120. Need Help On How To Set Up Ventilated PCV System..
  121. Gear swap on 06 a6
  122. m&h 17" front runners...(weight)???
  123. Need help on some acceleration tables
  124. Help me figure out if my T56 is a Z51 oil cooler lines
  125. Mod for low end power
  126. Calling all Wixom engine builders! Anyone know of 2 Camaros w/ LS7s installed there?
  127. Calling all Wixom engine builders! Anyone know of 2 Camaros w/ LS7s installed there?
  128. Another 500RWHP C6 From Vengeance Racing
  129. 4 Point Roll Bar Sale from MTI Racing
  130. A/F meter cable
  131. Tuned with headers
  132. Horsepower sales service.....
  133. Clearance issues with 3/8" tunnel plate and 3" longtubes?
  134. What exhaust do I have?
  135. Vengeance Racing Stage II LS3 Camshaft Installed in C6/A6... Pics/Video/Dyno Results
  136. advise on cai
  137. LS7 Installed in 2008 LS3 C6 by Vengeance Racing... Pics/Results Inside
  138. **HPTuners Special** Free Shipping on Standard or PRO plus LC1 for $129
  139. Rear Wide body conversion help
  140. **FREE Plugs and Wires with Purchase of any LGM Long Tube Header Package**
  141. headlamp covers
  142. Trade Head lights????
  143. time to try out my new spinfast..
  144. Z06 mid-pipe adapter to regular C6 does anyone make one
  145. Z06 mid-pipe adapter to regular C5 does anyone make one
  146. Convertible roll bar fabrication and installation
  147. Need service manual for TR 6060 and diff
  148. C6 Z51 Sway Bar Specs
  149. Gear change for paddle shift
  150. What is best stall speed for street driven A4?
  151. Wideband install question
  152. DeWitts CF Group Purchase SAVE!
  153. Side to side sway
  154. Throttle Body Maintenance / Cleaning...
  155. The right tires and wheels?!
  156. Choose the correct X-PIPE
  157. Does this horse power table look reasonable?
  158. NGK Spark Plugs
  159. Sway bar swap write ups??
  160. Clutch Pedal Stop
  161. Do I really NEED these for a cam swap?
  162. Vararam Help
  163. Exhaust Odor?
  164. The Tuning School's Advanced course is now shipping w/1 year phone support!
  165. BCM in Euro mode results in DTC B2907 error "Steering wheel lock"
  166. Custom made exhaust system for 427 LS3
  167. Z06 problems
  168. If you've got a Hurricane CAI or have installed one chime in
  169. Thinking of changing my rear gears!
  170. Transmission noise in '07 Z06
  171. LS2 Radiator Drain
  172. Car developed miss after CAI
  173. Question about the C5 Diff
  174. cooler pictures
  175. So many cam questions.
  176. Significance of power-to-weight ratio
  177. Jba headrs
  178. i have Nitto tires in my ls3!
  179. Is The Long Awaited FAST 102 A Bust??
  180. Va Speed install specials---->
  181. Replacement Z51 Rotors
  182. C-5 to C-6 differential adapter kit
  183. GS 1/4 mile times?
  184. Battery options for 2006 C6 Convertible..
  185. ZR1 Transmission Housing
  186. Underdrive Pulley Belt?
  187. Is this blown code important?
  188. 05 dif broken
  189. Potenza report
  190. Need tune help, Posted in tuning as well...
  191. Looking for the right cam
  192. Stock at idle, but loud at throttle
  193. Brake Upgrade Specials www.PartsTaxi.com
  194. C6 Headlight repair
  195. Gears for the street?
  196. What's needed; Cam instal
  197. High Mileage Corvette
  198. New RHS Race Blocks have arrived! In stock at Hinson Motorsports!
  199. b&b bullet or slp loudmouth
  200. transmission Overhaul Kit required
  201. *** Chuck CoW TUNIG in IOWA @ IOWA SPEEDWAY !!! ***
  202. Z51 Sway Bar Kits Available (Some With Poly Bushings)
  203. Anyone try Yella terra 1.85 rockers in an LS3?
  204. Center Air Dam Removal
  205. Turbo recommendation
  206. FOB error
  207. COW Tune in Tabor City, NC.
  208. "Shorty" headers for a C6?
  209. Brambo or StopTech and how does the EBrake work?
  210. Can't locate low beam replacement DIY
  211. MCM Hood with clear center any pics?
  212. Cold Air Intake???
  213. Shifter install
  214. Which engine?
  215. Dead passenger seat
  216. man switch solution?? help plz
  217. SS hoses/brake bleed
  218. Goodbye, but not forever..
  219. do i buy an 08 mod c6
  220. Average life span of TPMS???
  221. High heat plugs wires?
  222. 08+drag wheels what to do?
  223. Z06 Aluminum frame
  224. My new auto shift knob C6
  225. How much does colder weather increase power?
  226. Is there a difference? C6 vs C6 Z06 shifter
  227. Where to get O2 syms??
  228. •• LS3 FAST 102 Intake Flow Results ••
  229. What are my options for sway bar end links ?
  230. FAST Injector Adapter O-rings
  231. What can I use to fill up the gaping hole in a cut radiator shroud?
  232. Will someone tell me how to order the rear wide body kit from Gene Culley pleaee?
  233. Custom Fender Badges
  234. LS2 Bolt ons = 400rwhp 384 rwtq
  235. ZR-1 Killer.....
  236. Long tube Headers
  237. Check Engine Light?
  238. Vengeance Racing Heads/Cam/Tuning package SPECIAL!!!
  239. Alternative Drive Axle Nut Fix
  240. LS3 Motor with a Twist!
  241. Press Brake To Start Engine
  242. Kooks Headers & Vararam Intake Package - Save a Ton of Money!
  243. slowest 1/4 mile ever?
  244. Spin's cam being dyno'd right now
  245. Can the BCM br reprogramed to prevent hyperflash?
  246. Tune test?
  247. Rattle after exhaust installed
  248. Cam upgrade information needed
  249. FAST mod and port October Sale
  250. 05 Z51 won't start, dealer is stumped... any suggestions?
