- LS3 in the 10's???
- oil capacity
- bad cat? need some trouble shooting ideas
- Any more ideas to stop my brake squeal???
- So freakin close to 11s :(
- C6 clutch change.
- any problem with installing 102mm intake manifold??
- temp readout problem
- Active Handling question
- Loss of hatch pull down
- Do I need to change shift points on 09 A6 if I run drag radials?
- Negative DA? We don't need no stinkin' negative DA - 10.045@138.65MPH
- What is your ride height on your car
- What CAI to replace Vararam
- how difficult is spark plug change on the c6?
- Time for a roll bar and dreading it
- Back by popular demand!
- 05 FOB's Will Not Program
- GM Parts House Conversion Headquarters
- GM Parts House November 2009 C6 Specials
- Check engine light in 09
- Ported LS3 intake/TB pics
- Mod question... Requesting your opinion!
- Opening Doors w/Dead Battery
- Is NPP Exhaust Programmable?
- 1/4 guess time
- Personal best today at MIR
- DIC won't go in to keyfob program mode.
- Magnaflow Exhaust
- Vette Friendly muffer shop Sarasota, FL area
- Gas cap issues???
- 243 heads? small cam?
- 2008 automatic shifting issue
- Are Z51 brakes an upgrade?
- 2010 Grand Sport Bluetooth will not receive
- shifter problem (need help)
- CAI 06-C6 ** BBK VS Halltech-Venom **
- 2007 MN Rolls Backward on Incline
- new mods are on
- virginiaspeed.com......new online calatog
- Need help please!!!!!!!!!!!
- ported manifold, is getting the TB worth it?
- Just got an 06 Velocity Yellow C6---- Some Questions..
- *Ragin Racin Sale-Best Prices- Cam Packages/B&B Exhaust/Chargers/HPTuners/RPS Clutch
- Clutch pedal sticks to the floor
- Will a tune help? Ziptie mod?
- 08 MN6 Fluid with 6350 miles, Pics inside. Lifetime Fluid, I think not...
- Used Tire(s) Risks...?
- Question regarding OEM base 07 brake pads
- Stock tires (runflats) on FRONT and KDWs on REAR?
- More power through camshafts
- Brake pedal "pulsing"
- LS2 1.8 rockers, spacers needed? where to find
- Creek when turning all the way left at standtill?
- CFM for 102mm FAST TB
- sway bar help
- Drive train noises
- c6z06 output shafts
- Highest n/a c6 ls3 vette numbers please
- *** EnglandGreen's CRAZY November Drivetrain SPECIALS!!! ***
- Fall Specials in Ma
- Changing oil: LS7 vs. LS3
- Thanksgiving Gobble up the power Sale on all BPP Products
- Active handling kicking in for no reason?
- In dash radio
- z06 brake ducts
- fluid level sensor of the transmission (6spd)
- Man Knob Exhaust Switch Christmas Sale Early :)
- LG Motorsports GT2 Qualifying Laguna in car one lap
- Quick 100hp mod
- need fast help plz ???
- Squeeky clutch and break pedal!
- Stability Control system service
- 2010 grand sport bolt ons
- Monster Clutch Co. Holiday Sale!!!
- Some changes at Monster Clutch Co.
- Brake Master Cylinder Upgrade Recommendations
- Help "Please" Low Beam light out
- Pinging
- 2009 Valvetrain Noise
- trim panel / seat-belt replacement issue
- **Cobalt Pads** No Bedding Needed!
- Cam or headers???
- TSB's etc?
- Fuel Door release sticks
- A horrble odor in my car
- Radiator Fan Shroud Removal
- 07 Corvette paddle shift gets stuck
- What hood fits ?
- Underdrive pulley pros and cons
- Need some definitions, exhaust upgrade
- Paint Scrape Removal Help
- Help post Airaid install
- Those with C6Z oil cooler installed
- Finally did the 1/4 mile drag strip
- Inching ever closer to the 9's - 10.233@136.512
- Specs of the ZR1 cam?
- sts twin turbo
- Vararam install
- Some kind of spring ?
- Can front lowering bushings be cut??
- 08+ m6 diffs?
- stock c5 air box mod
- GHL C-6 Exhausts Ready to Ship
- ACP World Challenge Louvered hood
- Ready... Aim... Misfire!
- Comp Cams rocker arm trunion upgrade
- EGR Valve question
- x-pipe on 05+ C6??
- Which headers and cam would go best with....
- Dead Battery on an 08'
- front inlet hole
- Would I need a tune for this setup????
- Cam Question
- Help!!!!!!!!
- Any benefit to drag radials on stock A6 LS3?
- New MPH PB
- ls7 short block/whats it worth?
- Rear breakage: Street tires vs drag radials
- GMPP LSX 454 Crate Engine
- slower than last year!
- 453RWHP LS2 Cam Only
- When to replace valve springs with high lift camshafts
- Took the car to atco, very disappointed...
- 100Lb Injectors for LS3 LS7
- Need Repair Advise on Slave Cylinder
- 432rwhp & 390rwtq without headers and CA smog legal
- which head gasket with L92 heads
- ethanol vs non ethanol
- New C6 owner..looking for exhaust system
- 475rwhp - EnglandGreen Mayhem Ii cam only
- HID,were located..inner or middle lenses?
- Transmission Carnage pics
- cam specs?
- L92/L76 Conversion
- Headers & NPP Exhaust
- 2006 HT window problem
- Need a quick varification
- C6 clutch pedal adjustment?
- How to change the LS3 air filter(s)
- CAM specs ?
- c6 reproduction wheels ?
- Man I love my INVOs. 1.7 60ft times!!!!!
- Help! Almost went into the wall at the drag strip today.
- Put the 2009 trans tune in my 2008 a6
- C6 LS2 Ported Intake and TB Help
- Can the paddles be temporarily turned off???
- Z51 End Link Lube??
- Cool video of Zr1 and Grand sport www.corvetteking.com
- Race Proven Motorsports 520RWHP H/C LS2
- Opinions on drag racing tires
- Hello from Advanced Composite Products (ACP)
- balancer pulley advice
- '08 Z06 diff in a '08 Z51 convertible
- >>> CHUCK CoW TUNING in VEGAS week of SEMA <<<
- *** Chuck CoW TUNING in WICHITA, KANSAS!!! ***
- Are C6 A4s interchangeable with C5 A4s?
- Can a tune cause oil temps to be higher?
- How long is a front shock?
- F55 sway bar change?
- Z06 conversion
- How is the manual shift knob help on?
- **LG Motorsports Sway Bar and GT2 coil over package $2290**
- Throttle sensor error
- Free cold air and rain
- Stock 06 A6 - 1/4 mile pointers..
- Heading to atco friday, any guess's?
- The 1st 19" drag radial..........
- gear by gear boost for centri
- Clutch bleeder line from Charlie at RPM Motors is a great design..
- Tire pressure monitors info
- First time @ track. I'M HOOKED!!!
- Suspension setup on C6?
- timing on 2005 vette
- Illustrated How To: Stop Metallic Pop/Click from the Rear Wheels
- Your thoughts on VA Speed rec
- Lateral "G" Meter Question
- **RELEASE** Double Adjustible Bilstein package from LG Motorsports
- new owner of a cts-v six speed needs help
- Need some help with F55!
- another service charging system thread
- EnduraCool Header Reconditioning Sale!!!
- uncontrolable shake
- Rear left tail lights
- Is there anything that will stop rubber from sticking to wheel wells???
- 675 RWHP C6 1/4 mile?
- help 05 corvette service traction control,service active steering,service anti-lock
- Serpentine belt tearing apart after SLP
- Question about cooling intake with ice.
- how to remove bolster under steering wheel
- ZR1 video 10.85 @ 130.12
- Rotor Hub Covers
- Header question
- Toyo R888 noisy whine 70-75mph
- reduced power mode..help
- Will worn parts cause more wheel hop?
- How hard is it to change stock leaf springs ?
- Good shop in Tampa, St Pete, Clearwater area?
- Oil Change at 3,700 miles?
- A/A Corvette Supercharger Bracket/LS7 questions!!!!!!
- 2008 tsb list
- "Burnt" Headers... (pics)
- 2010 Grand Sport A6 shifter Problem
- will 305/30/19 fit on c6 ?
- check engine light after header install
- M6 or A4 for high-hp street driving and autocrossing?
- Heads and Cam
- fan help
- ? Need P/N for Z-51 Rear Caliper Rebuild kit ?
- Is there a mod to add a6 paddle shift to console shifter??
- Wilwood Brakes
- Looking for vinyl fabric
- Throttle sensor error p2138 - Reduced engine power, Service traction system
- Show me your superchargers!!!
- Name that Spring
- Look at this clutch!!!
- Xylene (Xylol) + 93 Octane makes Race Fuel?
- C6 Billy Boat Header back exhaust
- Problems opening door...what's the deal...
- Programming a FOB
- Brake options for a 05 z51
- battery dead again
- Florida tuner - Gulf side
- Front end "clunk" noise?
- transmission identification
- Power programmer to scan check engine light codes.
- Question on spacers
- rear diffuser question !!!
- C6 Heated Seats
- Wong's Performance LS3 Bolt on/tune...awesome!
- Gauges
- Halltech Bee Hive question !!!!!!
- trifectaperformance.com mail order
- **457 RWHP LS2 w/o heads from LG Motorsorts**
- Replacing the front driver side lower spoiler?
- Track Rental Next Wed. MIR. Need 2 people.
- MTI Racing Six Shooter Shifter
- Adding NPP to an 08?
- Bilstein Shocks Questions.....
- Is a tune necessary after intake install?
- Z06 Headers vs Aftermarket Headers on Base
- Anyone install their own clutch??
- 180 Thermostat for 2009+ LS3?
- I hate leaks!!!
- Wide Body Kit Total Cost
- Can Nitto INVOs be rotated?
- Quick question?
- **RELEASE** LG Motorsports new Sway bars for C5/C6/C6Z06/ZR1
- c6 problems
- Part #'s for wide body kit???
