View Full Version : C6 Tech/Performance
  1. Rattle makes me crazy, what is it?????!!!!??
  2. Question: B&B Fusion & Killer Bee CAI
  3. Make the clicking stop
  4. Cutting hole in my hood- crazy?
  5. Tie Rod Ends
  6. advantage of adding a x-pipe?
  7. Air Induction Kits - What is the best?
  8. Wheel widening questions, all with expy, please look.
  9. Help me understand My alignment specs
  10. Re-Index Windows?
  11. sts corvette needs tune.
  12. Z06 exhaust manifolds on an LS3?
  13. 87 4+3 to 700R4
  14. For those dealing with cores + core charges
  15. What is a LS2 engine worth....
  16. Drm wheel studs
  17. Broken Engine Mount
  18. Transparent Roof Question
  19. Vredestein Sessanta tires
  20. Ride heights?
  21. Anybody have Diablo Sport Predator?
  22. Just got my BB Bullets installed
  23. NPP exhaust picture
  24. Has anyone here installed an ASP Balancer
  25. OBX Header/Exhaust Kit
  26. 2008 audio problem - HELP
  27. Need valve springs
  28. Stock Exhaust
  29. Removing oil filter
  30. automated bleed vs manual bleed
  31. Any negatives on Amsoil oil filters?
  32. OPINIONS PLEASE! Pull off NPP or B&B Fusion New for non-NPP 07?
  33. needs help in re-building my engine !!! vendors and members
  34. •► ► CHUCK CoW - BOOKED in ORLANDO this THURS 10th - SUN 13th ◄ ◄•
  35. ** Another bolt ons only Corvette LS2 in the 10s - thank you Cartek! **
  36. c6 vert wide body conversion
  37. H/C Z06 & Bolt on C6 Play on Roadcourse/Dragstrip! {HD Vid}
  38. Hoosier 18" DOT drag radials or MT ET street radial??
  39. Fishtails when I punch the Pedal
  40. Help me identify this clutch! Is it an LS7?
  41. new nav disk
  42. Proper Shift Technique on a C6
  43. C6 headlight lense
  44. HUD Display differences in '05?
  45. Car wont start when warm.....sometimes (FRUSTRATING)!!!
  46. Ryan's Modding Adventure!
  47. **LG Motorsports Single and Triple Louver Hoods IN-STOCK!**
  48. Changing Brake fluid for track...
  49. **LG Motorsports Dyno Tune Special $399**
  50. HELP! can't turn off AH and HPDE coming next week!
  51. 160 Thermostat
  52. stock maf the same as stock ls1 maf??
  53. Rear vibration after wheel stud swap
  54. CF Spliters
  55. Insubordinate gauge cluster.
  56. **Rear Diffuser removal DIY**
  57. Z06 Exhaust Install - Rear Cradle Drop???
  58. Total capacity of power steering fluid in 2005 Corvette?
  59. ** Cartek cam only LS2 new bests! **
  60. Manually shifting an Automatic A4
  61. Grinding noise when making a right turn...
  62. L92 heads need some info
  63. Difference GY F1 Supercar and GS2
  64. Race Proven Motorsports H/C LS2 10.66@133
  65. Traction Control vs Launch Control
  66. Transmission/Diff fluid, help a new owner out.
  67. tire pressure monitor
  68. 2 Step question...
  69. 2009-2010 C6 Corvette 160 Degree Thermostat
  70. Cam Input
  71. Part number for tail housing?
  72. traction compound additive for tires...
  73. Does GS have Z06 rear diff?
  74. Run Flats
  75. RR World Warhark ECS2200 Full Build Up with Pics
  76. ls2 cylinder head upgrade
  77. '10 Grand sport convert exhaust ideas...
  78. How hot do cylinder heads get?
  79. Need advice about the intake manifold
  80. **Performance Friction Brake Solutions from LG Motorsports SPECIAL OFFER INSIDE!!!**
  81. FAST LSXRT 102mm Intake Manifolds (4.8/5.3/6.0L Truck) in stock!
  82. Brake Upgrade Specials - www.PartsTaxi.com
  83. Mustang Dyno Settings?
  84. GM Accessory PAL Personal Audio Link $139.58 Holiday Special - www.PartsTaxi.com
  85. Va Speed. We'd like to apologize.......
  86. GM Accessory Splash Guards $91.88
  87. High Performance Wires
  88. air intakes
  89. Changing Coolant- 2008 Z51
  90. LG guys need clarification here ???
  91. Is It My Starter? Somebody plz help!!
  92. Exhaust opinions please!
  93. Got a new PB today..bolt on m6 ls2 11.34@125.78
  94. Holiday Special on Diablosport Predators!
  95. F55 on '05
  96. Front Air Dam / Spoiler
  97. NEED OPINIONS PLEASE! To cam... or not to cam, tis the question!
  98. Engine Knock...ideas/opinions anyone?
  99. Powering up the seats without the car
  100. Hoe do i adjust PFADT coilovers for regular street use
  101. Battery Tender Question
  102. Heated Seats
  103. Met Mike Norris and Now a Ported Throttle Body
  104. aftermarket piston !!! help
  105. clutch shim
  106. Hurst Billet Plus
  107. Engine Oil
  108. C6 25% Pulley
  109. GM Parts House December 2009 C6 Specials
  110. Magnaflow cans for C6
  111. How to remove axles from diff?
  112. Diff. lube question....
  113. Help with tire.
  114. Am i the only one with oil in my intake?????
  115. need help with inspection
  116. Is this a busted hi beam bulb and if so what is the PN for a new one at a parts store
  117. Some Info To Help With Clutch Pedal Issues.
  118. Who has LS3/L92 heads that have been ported, CNC'ed, valve job, Results?
  119. How Much for USED Front Caliper Brackets From a Base Model?
  120. accessing high beam bulbs
  121. Any updates on the NT05R
  122. How much abuse??
  123. How to check trouble codes on C6
  124. C 5 Heightlight Doors-Need Help
  125. Best line lock kit
  126. Tpms and wheel swap help
  127. B&B Bullets from an 08 to 09?
  128. *** POLISHED LS3 Maggie Sale (while supplies last) ***
  129. 427 or 418 LS3 shortblock ???
  130. bought a used Z and found a discovery underneath (PFADT)????
  131. Corvette and C6 get a friend near the top.
  132. C6 cluster into '69 Camaro with LS7/T56 Retrofit
  133. QTP at Performance Racing Industry Trade Show Dec 10-12 Orlando Florida
  134. **EFI-Live Scan & Tune w/LC-1 Special**
  135. TT cam
  136. Help finding Squeaky Pulley
  137. hi beams not working HELP
  138. *American Racing Headers*
  139. c6 ls2 a6 3.42 anyone
  140. What's the best TPMS tool to purchase?
  141. C6 Paddleshift Corsa Sports to Extremes?
  142. Billie Boat bimodal exhaust
  143. upgrading to zr1 brakes?
  144. **** 8th Annual Corvetteforum St Jude Fundraiser****
  145. slight steering wheel vibration at 70mph
  146. Z06 differential question
  147. •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
  148. Weighin and first dyno. Completly stock, base LS3 M6
  149. Another Version of the C6 vs Z06 track video!! {Music}
  150. More engine noise after headers??
  151. What are C6 Z51 front rotors worth w/pads?
  152. Is the Slave Cylinder PN Same for ALL C6's? (Including '05)
  153. December C6 Specials - www.PartsTaxi.com
  154. LG G6X3 w/ bolt ons.
  155. 08 Z wire question?
  156. NPP Question
  157. How to remove side of steering wheel
  158. Battery & FOB dead, no master key, what next?
  159. Porting intake LS3
  160. Will C5z06 rear wheels fit C6 Z51 rear?
  161. battery problem
  162. NAV unit installation
  163. 2010 Grand Sport Mufflers vs. NPP
  164. Possible taker on SpinMonster's new high end cam...**SPIN PLEASE RESPOND**
  165. Alternate tire sizes?
  166. Headers Question
  167. Injector special due to overstock
  168. C6 ZR1 Corvette LS9 Power Package
  169. Air filter and polen filter question
  170. •► ► CHUCK CoW's HOLIDAY MAIL ORDER TUNING SAVES YOU CASH!!! 50% OFF! ◄ ◄•
  171. Dynocom Dyno?
  172. Stock exhaust heat shields WITH header install?
  173. Mild LS3 Cam, anyone have?
  174. Thermostats n Porting Questions
  175. Ghl... New forum vendor
  176. What brand of 305/18s do you use?
  177. Leather
  178. Brake bleeder valves
  179. Springs (part number)
  180. I need help in bleeding clutch after slave cyl. replacement.
  181. BPP Cyber Monday Month of December
  182. Gotta love these LS3s!!!!! 632RWHP/630RWTQ stock bottom end!!!
  183. Running rough P0300 Code
  184. 06LS2vette daily driver camshaft
  185. Would a C5 waterpump fit a C6 LS2????
  186. C6 Z06, 555rwhp, cam only
  187. Ragin Racin LS3 Stinger Cam Dyno
  188. 495rwhp launch = R888 or Hoosier slicks for stock C6 19" rear
  189. Heads LS 2 LS3 LS 7
  190. Please help me identify this
  191. Grand Sport Sway Bar Diameters
  192. C5 Diff same as C6 Diff?
  193. What is the best way to remove silicone rtv from a FAST?
  194. clutch slave line ruptured
  195. Squeaking Noise under Acceleration?
  196. PS2's on Widened Tires
  197. Tranny temp question
  198. Tail light conversion
  199. I need tire advice from those "In the Know"
  200. Check engine light
  201. LS2/LS3 swap
  202. Lowering the C6
  203. Maf screen
  204. what all do i need to install an electric water pump?
  205. headlight delay timer
  206. need LS3 intake and T-body
  207. LS3 ported T-Body? Where, what?
  208. 10% Discount Coupon - GM Parts @ GM Parts House
  209. '09 cammed LS3 picks up 16rwhp /25torq in colder weather!!
  210. Titanium Race/Street Parts
  211. SKF Wheelend Bearing Install
  212. Bolt on C6 tunnel flyby and 100-200km/h 7.7s video | Turkey
  213. Help Needed on Header install problem
  214. How much horsepower is this?
  215. RSI Black Friday Sale
  216. air intakes
  217. Tires slipping on dyno
  218. C5 Corvette wheel size on C6 Corvette
  219. Problem with my jack....
  220. 160* Thermostat identification
  221. ***LG Motorsports Black Friday Specials***
  222. Drivers window problems
  223. Electrical/Stereo Issue??
  224. Bolt on LS3 Hits the Roadcourse! *HD Video*
  225. Question...
  226. GS vs T1 swaybars
  227. BLACK FRIDAY SALE on Raptor Shift Lights @ KY SPEED
  228. High Beams Won't Turn Off. . .Help!
  229. New to modding.....
  230. Guys need help here??? Car went off
  231. Wheel Spacers
  232. XTREME Black Friday SALE
  233. Will C5 fitment wheels fit on a C6?
  234. heads up display crooked
  235. C6 front brake upgrade
  236. Spin's cam dyno results
  237. MGW shifter with Hurst Knob for c6?
  238. ECP-Corvettes HAS Monster Clutches $599 Remote Clutch SpeedBleeders $29 ARP Bolts $29
  239. Cams-i have pulled my hair out
  240. TFS-30602004 cam
  241. Check engine light for oil change?
  242. Lowest Pricing Ever onTextralia @ KY SPEED
  243. Help: fuel related supercharged c6
  244. grande sport 1/8 mile video 7.62 on stock tires
  245. Plug and Play?
  246. 06 C6 Ride Height Unintentionally Dropping
  247. First gear grinding
  248. Genuine GM Grand Sport & ZR1 Car Covers Available.
  249. Total Noob Grand Sport Question
  250. My car is freaking out!
