View Full Version : C6 Tech/Performance
  1. Question on balancer swap
  2. C6 steering column lock question
  3. best ls2 oil filter?
  4. 2006 Auto Transmission Problem
  5. ++++ ST Jude Auction # 7 Get in Gear! B&M Ripper Mod#45044 Shifter for C5/C6+++
  6. HE HE our c3s dont have thi problem, joking.
  7. euro tail lights
  8. Stock LS2 vs. Bolt On's
  9. Widebody experience
  10. LG c6 z06 Radiator in 05 z51 manual....
  11. MGW and Callaway shifters compared
  12. Chuck Cow mail order tune
  13. Best aftermarket shifter - opinions wanted
  14. B&B route66... too loud?
  15. LS2 Cam question. Piston clearance?
  16. Cam install started today...couple questions
  17. DeWitts set up with HO Spal fan(s)
  18. Passenger window won't go UP
  19. side fender screen install
  20. Help with MGW Shifter Issues
  21. Ported TB for a cammed LS3
  22. Where is the LS7 oil bypass valve?
  23. Eureka!!
  24. **** EnglandGreen New Years Specials! ****
  25. do '09 tire pressure sensors fit in '05 wheels?
  26. Need Education on HP@RPM & TORQUE@RPM for fifferent car comparison
  27. Performance clutch/flywheel???
  28. Supercharger vs. N/A...... LS2
  29. Brake Install
  30. Basic Supercharger Questions
  31. Happy New Year from CMI 10% off
  32. Cold Startup knock
  33. New Prothane "SIX SHOOTER" Driveline Couplers now available
  34. LS3 air pump ???
  35. Am I just not seeing the DIY section?
  36. Anyone here had your forged wheels powder coated?
  37. Prepping a base A6 for the track
  38. charging problem
  39. How much power should I make ?
  40. need exhaust help
  41. What are bone stock LS3 powered C6s getting with dyno tune only?
  42. C6 wheels all the same size?
  43. MGW Shifter questions
  44. Bummer!!
  45. New here & have questions!
  46. Need C6 pricing help
  47. Another Active Handling question
  48. CAI questions
  49. First oil change - torque question
  50. Stroker LS3 dyno results!
  51. Another Roof Recall?!?
  52. •••> CHUCK CoW's HOLIDAY MAIL ORDER TUNING - ONLY DAYS LEFT!!! <•••
  53. LSX Tall Decks blocks in stock at SDPC!
  54. Need detailed instructions on replacing all 4 rotors & pads on a base C6
  55. 1 3/4 or 1 7/8 kooks headers for ls3 ???
  56. Starting/Charging sytem problem finally FIXED!!
  57. Do you have to reprogram FOB with Battery change
  58. Measured Tq & HP deltas for my mods + tune
  59. What are cam only ls3 a6 running in the quarter?
  60. 2006-2007 Top Recall
  61. best C6 catback exhaust
  62. Fuel pump failure symptoms?
  63. Wiring Diagram
  64. **LG Motorsports January Install Specials**
  65. c6 fuel tank help
  66. LG 'Street' header/catted x-pipe vs. ARH header/catted x-pipe
  67. Base model owners that have put Z06 exhauts on.
  68. HELP? surging after intake?
  69. Setting on CTEK3300??
  70. Stainless Steel Brake Line Guidance
  71. What's the difference between '08 and '09 NPP exhausts? (header/x-pipe compatibility)
  72. tranny
  73. Louis @ LGM - Solution to no place to mount AFX wide band
  74. A6 trans cooler install
  75. Any body use AcT clutch
  76. Decided to go H&C, need your opinions
  77. Corrosion
  78. ZO6 exhaust vs aftermarket exhaust
  79. GM issues 2nd recall for Corvette roofs
  80. Cats?
  81. rwhp and rwt specs?
  82. C6 LS2 ARE 3 stage dry sump system installation & battery relocation - lots of pics
  83. Convertibles with roll bars - please step in
  84. What's on my spark plugs?
  85. 05 Air Tight window problem...
  86. Caliper Braket Bolts
  87. ***no fobs detected***help
  88. C6 won't go in gear HELP!!
  89. how much hp needed to go 140 mph
  90. G meter on c6
  91. Traction light is on what to do?
  92. Kooks Install Today: question about oil line clip
  93. My fob is not working at all its not being detected
  94. starter comes on while car is already running!!!
  95. strange codes after dragging bottom of car
  96. SKF Bearing install
  97. Questions About Seats
  98. New Engine startup
  99. after-market clutch opinion
  100. Building an LS3 engine from scratch?
  101. Help with Vlave Spring Change NC
  102. What brand of ATF are you guys using??
  103. LS2/LS3 Heads
  104. rear gear change for a6 ?
  105. DOT Tire Codes
  106. Toyo R888 question
  107. shift boot plastic ring part number
  108. tranny clutch or diff problem???
  109. iPod connection without Nav?
  110. C6 warm up time
  111. Ready to add dewitts!
  112. •► ► Merry Christmas & HAPPY HOLIDAYS from CHUCK CoW & Corvettes of Westchester ◄ ◄•
  113. Jesus's birthday
  114. Help Issues w/stock Navigation system
  115. JJFormato intake manifold & TB mods
  116. Ls2 n Ls3 tech...
  117. Tpms
  118. C6 Z06, 552rwhp, EnglandGreen Mayhem II cam only
  119. Z-51 Springs
  120. Headers
  121. Merry Christmas from all of us at LG Motorsports
  122. Happy Holidays From Xtreme Motorsports
  123. Aftermarket Rims for 2007 C6
  124. Happy Holidays From East Coast Supercharging
  125. TVS 2300 on C6 LS3
  126. Keisler dog ring T56
  127. F55 Shock Problem Need Advice
  128. Powerstop Brakes
  129. F55 owners - caution & cure for shock connector
  130. Race Proven Motorsports 551RWHP Cam Only Through an AUTO!!
  131. Exhaust too loud
  132. tire size on 18 inch.
  133. Rim width question
  134. Question on front balancer LS2
  135. LS2 vs. LS3
  136. Too CHEAP; Vette-Air/Quality Motorsports Specials
  137. Rear widebody project with ?????
  138. Proper Prep for Painting Rear Valance?
  139. •••> CHUCK CoW's HOLIDAY MAIL ORDER TUNING - TIME IS RUNNING OUT!!! <•••
  140. OK I must have a Bear Claw (not the donut) for a hand. Installing Vac tube for NPP
  141. m6 tranny t56 or 6060
  142. What type of tranny is in the 08 C6?
  143. BPP 11th Hour Sale Xmas Free Shipping Plus 10%
  144. z06 calipers
  145. sts oil leaking out of exhaust.
  146. Fuel delivery question
  147. Texas Speed Holiday Schedule
  148. F'n LG Motorsports..
  149. Tires
  150. Livernois VS. LG---Cam/Heads
  151. Z06 burnout technique w/o line lock (video)
  152. AFR 205 vs Trickflow 220
  153. Cai
  154. "How to calculate",,,
  155. corsa exhaust
  156. Grease Type for lower control arm joints
  157. My car has lost its mind!!!!
  158. C6Z Burnout
  159. Reverse Lock-Out
  160. 2005 corvette
  161. Clutch Upgrade?
  162. Spark plug question
  163. First newbie question...shifter issue
  164. Spark plug indexing
  165. Replacing front brake pads
  166. O2 sensor torque..
  167. Similarity in fast C6 and C6Z drag strip runs?
  168. Water Pump Replacement Help
  169. Timing tricker and tach wire?
  170. aftermarket exhausts...
  171. Full Roll Cage
  172. grand sport 11.34 1/4 video inside bolt on and run flats
  173. Best CAI along w/ basic mods?
  174. Surprized at easy spring change!
  175. New PB puts me on top of the "cam only" M6 list!
  176. Chuck cow tune!!!!! 12/18/2009 w/pics
  177. Helpful research to help you find the perfect LS3 Cam
  178. New H/C C6 LS2 record!!!!!!
  179. brake boost ?
  180. which tire has the better grip???
  181. Removing eletrical connectors on gauge bezel
  182. Well I FINALLY did it - 9.950@139.267 with a 1.425 60ft!
  183. So how many of you are still using the factory fluid fills?
  184. Gear Ration for the Base C-6 with Auto Trans
  185. When you gonna swap your plugs?
  186. Need pics of Installation of Side Skirts on a C6
  187. Simple and very effective mod to get tons of fresh air into the engine bay (video)
  188. Where can I get a crank pin kit?
  189. Painted and Ported TB
  190. **462 rwhp Cam only M6 LS3/G6X3 LG Cam Package, 502RWHP with Super Pro's!**
  191. Broken differential ???
  192. First time at the track with my stock 08 M6
  193. 485rwhp Cam'd LS3 tune help (surging)
  194. Shock absorber installation help
  195. warranty assistance
  196. Grand Sport Sway bars... measurements inside
  197. Need Part number additional help also
  198. Hawk HPS vs ceramic
  199. p446 code
  200. removing hush panel
  201. a6 3.42 in south jersey
  202. Clutch Question - Newbie here
  203. HUD MPH not working!!
  204. Which is better? Tuning using Dyno Pak or Track?
  205. Low speed surging and bucking
  206. A6 Shift knob problem?
  207. Where to find relays?
  208. A6 downshift 6to5 ?
  209. LSx V8 S2000 In the works!
  210. LSx V8 RX8 Coming Soon!
  211. Which Setup?
  212. **Repeated charging system failures – Need help**
  213. Clicking noise from rear when shifting into D or R fixed!
  214. LS3 Air Bridge/sensor issues?
  215. Check your brakes, rears wore out at 30,000 miles
  216. My Nightmare
  217. Interior Lights Short/Blowing fuses
  218. passenger door will not close
  219. Grand Sport Rear and Trans
  220. ***FYI Factory Forged Wheel Weights***
  221. 6 DAYS TIL XMAS SALE - www.PartsTaxi.com Z51 Bar Kit $180.25449.80
  222. Any feedback/experience with this exhaust?
  223. Virginia Speed...Holiday engine sale!!!!
  224. Pros or cons 160 degree thermostat?
  225. Kooks install/tune question on newly acquired LS2...
  226. Clutch issue 2006 C6 6 speed.
  227. LS3 to a toyota?
  228. Best drag set up
  229. new to forum and new vette!
  230. Oil Catch Can Questions
  231. 09 clutch issues. any input?
  232. Kenwood and Escort Wierd TECH PROBLEM! ! ! HELP
  233. 09 headers and x pipe to work with stock cb who has them?
  234. LSX-LS7 heads and intakes are here at SDPC!
  235. Another Key Fob Programming Question
  236. 7 DAYS TIL XMAS SALE - www.PartsTaxi.com Z51 Brake Kit $449.80
  237. Very frustrated
  238. Any experience with West Coast Muscle Cars?
  239. Corsa Sport & "Popping"
  240. Question...about Corsa exhausts???
  241. Even Deeper Discounts on Certain In Stock Short-Blocks @ TSP!
  242. What parts are needed for NPP/Z06 + M2W?
  243. Intake advice please
  244. Aftermarket C6 Mufflers
  245. Gasket between LS3 exhaust manifolds and cats?
  246. e85
  247. •► ► AMERICAN RACING HEADERS - ON SALE @ CoW ◄ ◄•
  248. *** Chuck CoW A6 -REAR END STIMULUS PROGRAM- HURRY!!! ***
  249. Hypothetical race vs. bike
  250. Brake Master Cylinder rebuild?
