View Full Version : C6 Tech/Performance
  1. thread lock caliper bracket install
  2. Quick Wheel ?
  3. Door Panel Removal - Need Info
  4. Performance Inductions 275cc catherdral port heads(real world results)
  5. how to set up auto meter gauges ?
  6. M6 owners come in please...
  7. Borrow TPMS tool?
  8. Kooks Headers Shop Tour- See How Stainless Headers are Made!
  9. C6 Z51 Down...Will not start...thoughts?
  10. !!!!Corvettes of Westchester- Phones & internet service down temporarily!!!
  11. 09 exhaust difference??
  12. Recommended Maintenance?
  13. Show me pics of your engine bay (Please)
  14. Mounting CTEK
  15. Will a Diablo Predator log info without tune installed?
  16. Weird question?
  17. how much does and tires size plays in gearing?
  18. double roller on LS3
  19. firmware reflash question
  20. Guys running Mickey Thompsons, what's you're 60'
  21. C6Z upper control arm bolt torque specs
  22. FAST Logo Removal
  23. New nav dvd for c6 corvette ???
  24. Anybody running FAST 46lb injectors?
  25. VENGEANCE PORTED FAST 102mm LSXR Intake Picks up 42RWHP/36RWTQ!!!!
  26. Should I upgrade my injectors?
  27. problem need help!!!
  28. C6 exhaust question
  29. Dyno tune
  30. 2005 Corvette interior center console romoval
  31. Helms manual vs Chevrolet manual
  32. New Exhaust Idea
  33. Identify this Halltech?
  34. Z06 Wheels and tires on a C6
  35. Auto tranny
  36. Good Performance shop in Tampa area??
  37. If I add trickflow heads, how much hp?
  38. Chevron Techron fuel injector cleaner
  39. Twin turbo 427!!! How much installed????
  40. 42lb to 58lb Injectors Can I drive to get tuned?
  41. Need help w/clutch line restriction
  42. Aspirator fan noisy
  43. Any one use this exhaust system??
  44. gearing down to 4:10s
  45. Disabling rear o2 sensors w/Diablo sport
  46. to cut or not to cut
  47. Billy Boat Fusion Exhaust
  48. ECS LS3 "Devil" Cam - 484/448, With Great Diveability
  49. Brake Pedal Noise
  50. Corsa Extreme's (Z06)
  51. Wide band?
  52. Emmissions Limits
  53. Come RACE at the Black Hills Corvette Classic! July 13-18
  54. LG Motorsports Street Series Long Tube Headers w/ Catted X-Pipe!-FREE SHIPPING!
  55. Technician
  56. A6 slight chatter at idle
  57. Sucked up some water through my Vararam air intake!
  58. Car acting funny
  59. Does CAGS affect Launch Control
  60. Here's My Mods...What plugs please?
  61. Line lock activation switch
  62. fuel pump question for the professionals in c6 corvette tech...
  63. Dead battery 2006
  64. Any issues with not tuning after kooks header install
  65. Good Dyno in orlando FL
  66. Grid Finish Pedal Set...Group Purchase
  67. How large of a tire can you go on a C6 without rubbing?
  68. OnStar Bluetooth Replacement Module
  69. electrical problem?
  70. Tire spin....no
  71. RR testing AH+TC off / on
  72. New Brakes Squealing
  73. Needed: DYI replacing front bumper clips
  74. Any TSB's for 08 AT?
  75. Advice on Supercharging a C-6 stock coupe
  76. Thoughts on a VIS Report
  77. Callaway filter oiling?
  78. Anyone test the new FAST 102 on a LS2?
  79. Professional Products Intake
  80. 2008 with 15k on it - Check Engine light is on
  81. Intake Shroud Removal Hints
  82. Adjusting tune for new manifold
  83. Will stock used 08 NPP fit an 05 C6 Z51 6sp
  84. LS3 Cam Recommendations Needed
  85. LS3 Fuel line removal
  86. Recomend 2005 performance upgrades?
  87. Track days cause suspension/chassis squeaks?
  88. Brake bleeding question
  89. Trans Brace or not??
  90. Do they make a Blackwing CAI for 2006 C6 Z06?
  91. Hankook Ventus V12 evo K110
  92. What does it take for traction control light?
  93. Intake Mods Complete....GOOD RESULTS!!!
  94. Strange grinding and clunking noises when car is hot
  95. Road racing tires
  96. Traction Difference when going from a..
  97. Guys that have lower gears only please // need help choosing gears
  98. Lingenfelter 403 timing chain break – update
  99. Wheel Balancing question
  100. 2010 Service Manuals have arrived!
  101. A6 convert to M6?
  102. Anyone ever run a Nitto NT-05R?
  103. LG Motorsports Products @ KY SPEED w/ FREE SHIPPING
  104. Z06 manifolds/cats on a C6
  105. Catch Can Install (bolt size for head)
  106. Ordering Wide Body Kit
  107. How to Support the Engine?
  108. Stall converter? What's it do? Educate me.
  109. Hemi engines
  110. Where to Buy DOT 5.1 Brake Fluid
  111. **LS2 Vs LS3 Intake "Help"**
  112. LS2 upgrade to LS3 air intake?
  113. 06 Vette vs SRT8 Challenger and Charger????
  114. KenneBell BAP isnt enough for 620 rwhp on my 2010 grand sport...
  115. My LS3 dyno results after adding stock ported intake and Halltech intake
  116. Brake pad thickness
  117. Horizontal Coilovers
  118. Intake porn.
  119. LS3 C6 Clutch Pedal on the floor EXPERTS come in...
  120. c6-2008-manual shifter
  121. C6 Track Day car gets cage by Katech
  122. A6, 3.15 or 3.42 that is the question.
  123. New PB 11.04 @125.7
  124. c5/c6 Engine Cradle
  125. Problems with FAST 102mm manifold
  126. Z51 Cooling?
  127. Z06 diff pump removal, how???
  128. alignment specs for 09 z51?
  129. LS3 VS LS7 Heads
  130. 01 Fuel Question
  131. Professional Products Fuel Rails
  132. 2nd guessing my Cam Choice....help appreciated!!
  133. C6 Corvette Convertible Custom 4 Point Bolt on Roll Bar
  134. I just bought a TORX 15 screwdriver...and it doesnt even work wtf?
  135. First pictures of LG Motorsports Rolex Grand AM GT Corvette
  136. Group Purchase - Satin Finish Pedal Sets
  137. Can somebody please help me!!
  138. Driver's seat improvement
  139. Column lock in C6?
  140. Update on NT05R
  141. How to access the C6 DIC Codes ??
  142. Ragin Racin Stinger Cam Review - Dyno & Track Proven
  143. Caliper Covers
  144. 1st to 4th indicator light
  145. how to change HID bulb and DRL on c6
  146. Oil Pan Replacement
  147. Tires blistering from track use
  148. c5 vs c6 rear cradle?
  149. Magnuson granted CARB EO for TVS2300 supercharger kit - California owners rejoice!
  150. Removing Bumper Facia or Lower Defuser
  151. Installing Headers on Jackstands?
  152. Clutch pedal stuck to floor,
  153. Exhaust question?
  154. Brake ducts for front rotors
  155. GHL Race Series Sound Clips
  156. Brake switch
  157. LS7 A Good Blower Cam?
  158. C5 Z06 differential in C6?
  159. Stock Cooling fan Question
  160. Motivation
  161. New Guy Needs Info
  162. Harness Bar Options/Opinions Needed
  163. Hard decision -help!!
  164. Radiator Slit/Cut prior to assembly?
  165. Suspension Softening
  166. Diagram of PCV and valve cover breather setup in an '09?
  167. Brakes squeak during backwards stops
  168. Does the "Sprint Booster" really work?
  169. Why are LS7 heads so good?
  170. Changing Trans FLuid Help Please
  171. Can I start car with open headers?
  172. HELP!? Car overheating, I think fans are shot!
  173. Arvin Meritor Dynamic Height Control suspension(How much)
  174. Tire Question! Need Help!
  175. Kooks and Vararam Setup
  176. Click click click click click click click click click click
  177. Converting to a 2 Master Cylinder Brake System
  178. Buzzing sound in my dash, LS3
  179. Need input on H/C packages
  180. Anbody Used Zip Corvette in Virginia Stage 3 0r 4 Package
  181. Remove Glove box
  182. Headers/Drone update!!!
  183. 2006 A6 Dyno Numbers (382HP/376TQ)
  184. Wider Rims with Bigger Offset
  185. Tinted Tails\Side markers
  186. Intake manifold covered in oil (880 miles on the motor)
  187. Header Install - Need tips and best wishes
  188. Fuel tank question
  189. Frame Shop Request
  190. are all C6 roofs interchangeable? roller vs non roller years
  191. ***TPS Sound Deading and Heat Reduction Project on C6 w/ Pics
  192. Anyone use this hood pad instead of a new hood liner?
  193. where is shift lock control solenoid located?
  194. 05 not wanting to shift out of park
  195. C6 Zo6 Wheels on stock C6
  196. Need help installing Airaid on a LS2 C6
  197. beware...zzp 9mm ignition wires don't fit
  198. Fast 92's. Anybody still sellin em?
  199. Mike Norris Motorsports - VMax CNC Ported LS2, LS3, LS7 & LS9 TB's $149 Shipped
  200. Cam question for turners/shops/vendors
  201. Window got frozen, now it won't roll up/down
  202. Help with trunk key and lock on 2005 c6
  203. E85 isnt all or none-using E85 as Octane Boost
  204. What is "Normal" for the DIC to read?
  205. FAST 102mm / fuel rail covers
  206. Brake pad question
  207. Advise about gauges
  208. TPMS Installation
  209. New C6 Owner.....Help
  210. Messing with the aerodynamics of our cars
  211. Lifter failure cause determined!
  212. HELP! grinding heard when accelerating slowly from idle
  213. need help matching tire/wheel sizes on my C6 Z51
  214. Spin's A6 LS2 CAM - VS - LG's G5XE
  215. Common C6 Issues
  216. can anyone please help cause chevy ha no idea whats wrong
  217. UPDATE: On first time corvette owner CODESSSSS
  218. Advice On Drone/Hum at 70mph
  219. 2005 Battery Issues?
  220. Battery Problems
  221. *** February Specials - Pfadt Free Shipping! Brakes! Great Deals! ***
  222. trunk lid won't open..
  223. 2010 grand sport throttle body problem! Procharger...
  224. header and cold air ?? s
  225. z51 ride quality
  226. Charging System Fault - Battery Not Charging
  227. DMH Low Profile Electric Cutouts $399.99 shipped
  228. Talent Motor Sports 454 Warhawk Project
  229. c6 ZO6 brakes
  230. Rims and Tires recommendation for '08 C6 convertible
  231. Volant Intake..Anyone have one yet?
  232. Water/Meth Injection - NA Application
  233. Service lock out??
  234. Where to find a tune near Phila PA
  235. Help: o2 sensors
  236. 18x10-11 wheels
  237. Anybody used Zip Corvette's PM523 Package
  238. **LG Motorsports Street Series, most complete header system, REDUCED PRICE**
  239. Two piece rotors Front and Back
  240. Nav info
  241. OBDII display?
  242. Class 2 serial data components
  243. New Ragin Racin Camshaft & Video Section
  244. Which of these (TIRES) is the best value?
  245. bov
  246. A6 Transmission & 1200rwhp
  247. New PB Saturday. (1/8mi)
  248. 2009 Z51 badge??
  249. What length o2 extensions for LG Pro?
  250. Sticking Clutch Pedal (At top)
