View Full Version : C6 Tech/Performance
  1. VSS on A6
  2. Bypass BAP?
  3. LS3 heads on my LS2
  4. Automatic to 6 speed conversion
  5. dead batteries and parasitic draw
  6. C6 Gas Leak.HELP
  7. A6 downshift lag whats normal?
  8. hey forum
  9. Best place to buy the carbon interior?
  10. Nitto DR's vs Torque Management
  11. Here are wheel & tire weights
  12. Wider tires on stock wheels
  13. Big thanks to Fran @ RPM in DE!
  14. Help would like to lower
  15. Track Day Suspension Setup C6 and Z06
  16. what is the limit of 6L80E ?
  17. STS Turbo... One year later...
  18. Help! C6 Hard to Start
  19. What is the best track tire with a treadwear of 200 or more.
  20. Z06 Brake upgrade or not??
  21. Thermostats 180 or 160 ?
  22. Need Advice: 3.42 rear or Supercharger?
  23. Corsa or Band B fusions? for c6 Z..advice plz!
  24. Diagnostic readers, which one?
  25. New build, which cam?
  26. Fender Flares
  27. DI (Direct Injection) Fuel System
  28. LPE ZR1 + 20% Clutch / Steel flywheel track tested with 700rwtq – GREAT clutch!
  29. How many sensors?
  30. Front tire wear
  31. Is a Head swap easier than a Cam swap.
  32. FAST 102 or 92 ? Mod advice?
  33. Thinking of supercharging.. some questions.
  34. Widest Rear Tires 18 Inch Wheel Stock Fenders
  35. Cam, Headers, Ported Intake & Throttle Body
  36. **500 RWHP LS3 with LG Street Series and G6X3 cam**
  37. New Owner~~~~~Service?
  38. Best allignment shop
  39. GM Accessory Splash Guards $91.95 - www.PartsTaxi.com
  40. Help- Installing Autometer Shift Light
  41. K & N performance intake kit # 63-3073
  42. ACDELCO Rotors
  43. Can you remove the radiator without removing A/C condensor???
  44. After Battery Replacement?
  45. QA1 shocks???
  46. EVAP Monitor
  47. PowerLabs' Battery Relocation!
  48. LS2 Stroker Dyno Results
  49. Redlined for longer than usual!! HELP!!
  50. ABACO Digital MAF
  51. Please need help with H/C stalled A6 car
  52. Fast 102 intake and throttle body (worth it)
  53. ••••Formato Fasterproms Gettysburg PA April 16th Through April 24th••••
  54. Corvette Shop Philly for Widebody Conversion Help???
  55. Bilstein Shocks
  56. Help with Power Driver Seat
  57. Clutch Problem on '08
  58. Question on Kooks longtubes.....
  59. Corvette Billboards
  60. EnglandGreen Whiplash II cam + 2009 LS3 =
  61. Header bell house mounting bolts
  62. Remove The Glue from windshield
  63. Stereo speaker issue?
  64. Rubber Cement
  65. JSB- WideBooty Conversion MT 345's!
  66. intank fuek pump upgrade, shrink wrap and wire fuel proof?? fire hazard????
  67. Please help with PCV system routing
  68. Odd Electrical Issue
  69. Rear tire size opinion for 19/20 combo
  70. Heads Up Display Sale! - Back In Stock For Immediate Ship - www.PartsTaxi.com
  71. New Straight pipes, sputtering and check engine light
  72. FAST 92 Intake-Still a few out there!
  73. Z51 Sway Bars Now Available with Pfadt Poly Bushings - www.PartsTaxi.com
  74. Oil/Fluid Change Question?
  75. Anyone installed LG supercool Radiator
  76. Anybody know if you drive a 4spd. auto like a manual
  77. Drag racers : TPS with non TPS wheels?
  78. #### Gainesville - March 19th - Formato Fasterproms Tune Session ####
  79. Seat Skin Replacement
  80. comp cam?push rods?ls2
  81. Will C5 wheels fit on a C6?
  82. Good sticky rear tire's for stock size wheels...
  83. Yella terra ultralites which is best ?
  84. Busted rear end
  85. Aftermarket corvette seats!! Need more cushioning support for z06
  86. Installed OEM Z06 headers/cats/midpipe modified w/ 'X' on my '09 NPP car (pics)
  87. Ethanol Fuel
  88. Corsa Xtreme
  89. LS3 v Porsche Turbo
  90. OK HELP WITH MODS 2K to spend.
  91. Paper-based air filters vs. non-paper based
  92. Methanol kit help
  93. Which C6 to buy for strictly performance? Pre '08, or '08+?
  94. tire/rim concerns
  95. C6 Exhaust
  96. I just got my corsa extreme exhaust installed.....
  97. Best hand held Tuner for a 2006 A6 car
  98. Attn: Cf vendors...wtb...
  99. Anyone flow tested the FAST LSXr 102mm intake?
  100. Ragin Racin-Sale-AR Headers/HPTuners/EFILive/Corsa/RPS Clutches/Chargers/B&B Exhaust
  101. Replacing Squeaky Belt on C6
  102. Any tips FAST, TB, CAI install?
  103. Best street / strip tire
  104. Rear End Gears?
  105. wheel hub
  106. Hud upgrade
  107. The Man Knob NPP Exhaust Controller
  108. Nashville Area Performance Shop???
  109. Lowering bolt thread size?
  110. Buying a used SprChgr and a few additional ?s?
  111. Optima Red Top Battery Tie Downs?
  112. Please 2005 C6 coolant capacity
  113. GM PAL ... Battery Drain Issue
  114. After airbag
  115. Traction control and supercharger?
  116. CEL codes on first ride of spring / NPP won't close
  117. Competitive Driving Mode
  118. Navigation disk not recognized
  119. Any guess what this noise is?
  120. Color Code for Z06 Calipers
  121. First track pass w/ nitrous....
  122. Best Price on Dexcool?
  123. Your tune and your warranty
  124. Car shut down but something in spinning
  125. Fuel pump/pickup issue or ECU?? Help.
  126. Why use sodium or solid exhaust valves?
  127. Is it possible?
  128. Auto meter gauges
  129. Rough Idle?
  130. Torque Converter
  131. Xtreme Motorsports Phoenix AZ?
  132. Right Front Running Light-R&R
  133. Different radio
  134. More 2010 Service Manuals have arrived!
  135. 2005 C6 where to install flush tee Replacing thermostat
  136. What antifreeze should I use in my 2005 C6
  137. Humming noise coming from behind dash vents
  138. Loose Air filter Cover, Is this Normal?
  139. March 2010 C6 Specials @ GM Parts House
  140. Ceramic Pad Super Special @ GM Parts House
  141. 2010 Service Manuals Available @ GM Parts House
  142. GS/Z06/ZR1 Conversions @ GM Parts House
  143. Exhaust Super Sale @ KY Speed: Kooks, ARH, SLP, Magnaflow
  144. Sensor Locations 2005
  145. Fuel injectors
  146. Tr6ix ngk 3689 in ls3 plug gap?
  147. 2006 z51
  148. Po455 evap leak help
  149. GM Performance Cams Now Available! - www.PartsTaxi.com
  150. Press Release MTI Racing Machine Shop
  151. Any Tuners in Canada ???
  152. unbolted rear lower inner A arm bolts vs. outside bolt... questions
  153. Looking for a camshaft that delivers a particular "noise"
  154. Good cam article...
  155. 08 vs 09 & later throttle bodies
  156. patriot golds or comp 921 valve springs..
  157. Exhaust melting O2 connections
  158. •► ► CHUCK CoW TUNING in CORAL SPRINGS & MIAMI - MARCH 11th - 15th ◄ ◄•
  159. Tune, headers and warrenty question.
  160. Virginia Speed 656hp 427
  161. Too Cool... Purple Ice?
  162. Please Help! What is this?
  163. C6 Drilled/Slotted Rotor Sale - www.PartsTaxi.com
  164. NT05R's are here!
  165. March C6 Specials - www.PartsTaxi.com
  166. Bad set of Invos?
  167. any codes on drag radials?
  168. need advice on brakes
  169. Clutch pedal issue
  170. Center Section Exhaust Options
  171. How wide of a tire can fit on front OEM Z06 wheels?
  172. Can I resurface my flywheel for new clutch???
  173. 454 LS7 Engine Setup For Wet Sump Available!
  174. what is the average cost to pull and reinstall an A6 trans?
  175. TSB for Oil Leaks
  176. Oil Change advice....
  177. Ported L76 vs Ported Fast 102
  178. Ipod ???
  179. Intake Shroud Removal
  180. Pfadt coilovers for c6 z06
  181. Tuner near Virginia International Raceway
  182. 50# Fuel Injectors? Really?
  183. Do all LS2s call for synthetic?
  184. a good bolt on N/A combination. biggest hp #s
  185. how dumb is this ?? or is it???
  186. 22500 mile shock!
  187. Shipping----Satin Pedal GP
  188. Funny business stock LS3 heads
  189. Best place to get a short throw shifter?
  190. vetteDoctors Install American Racing Headers& dyno tune For 1899.99
  191. LG Motorsports Rolex GT Corvette heading to Homestead
  192. LG G6XE vs G6X1 ????? SPECS?
  193. Help with Viper 5902 installation in '06 Z06
  194. Do I need a big MAF on an LS3 w/ 102mm TB and 102mm Intake?
  195. Borla Stinger- X-pipe or no X-pipe
  196. Ordered tire
  197. Those with timing chain failures: What valve springs were in the car?
  198. ** HELP on Long Island ** Dealer Service Recommendation
  199. Maryland Tuner !!
  200. Installing Z51 suspension on a base C6? Can you do it?
  201. Trans fixed by dealer, but not sturdy?
  202. ported intake/TB without headers/cam?
  203. LG Supercool Radiator
  204. Z06 muffler on Base C6 swap-Jackstands?
  205. Z51 brake rotors
  206. 3/2 - 3/8 Block Pedal GP
  207. •► ► AMERICAN RACING HEADERS - ON SALE @ CoW ◄ ◄•
  208. Breathless G-Force Wing in action at Homestead speedway
  209. Disappointed in Hella xenon bulbs
  210. Header coating or not?
  211. Header Choice?
  212. •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
  213. Inside temp reading above 120
  214. 08 corvette ls3, 2nd gear issues
  215. •► ► Chuck CoW A6 -REAR END STIMULUS PROGRAM- A DEAL YOU JUST CAN'T BEAT! ◄ ◄•
  216. to lower or not to lower the Vette?
  217. New product for the C6Z, also testing a C5-C6 product
  218. eibach prokit springs for $60
  219. 5% tint or not?
  220. ..........GHL March Madness..........
  221. Borla Multicore Installed
  222. Switched back to stock mufflers with headers.
  223. Check out these cross ram intakes
  224. Vengeance built C6 LS3 A&A SUpercharged 648/590 Videos/Graphs inside
  225. NPP Fuse Removal
  226. bi mode or NPP
  227. Oil in intake track help?
  228. how many inches from rear fender arch to ground maxed out on stock bolts w/ bushings?
  229. Finally hit the 10's!!!!!
  230. Lifting your vette?
  231. What's your best 60ft with stock A6?
  232. Maxton
  233. Rev limiter issues assistance needed.
  234. Shark Bar vs. Brey Krause Harness Bar?
  235. 2010 Grand Sport Brake Rotors
  236. Can wheel studs be re-used?
  237. Throttle response
  238. Keyless entry drivers door problem
  239. Won't start - Not DBS
  240. 2006 ls2 auto with full boltons resutls
  241. NPP Muffler Retrofit??
  242. Any rotor gurus in the house?
  243. question on 18X10.5 rim
  244. Corsa Xtreme on A6 Paddle?
  245. Magnetic Ride and Z51
  246. Best place to get NPP wires and instructions
  247. Homelink won't program
  248. Blowers?
  249. Can I go to a Cam & Headers?
  250. michelin pilot
