- Wheel spacer question
- B&B Bullets DIY in your Garage...
- A6 Paddle Shifting Question
- Bird stuck in radiator...help
- RPI Design Air Filter Element
- 08 ZO6 to LS3 Exhaust swap
- Have any of you had clutch problems?
- How long to change brake pads on a C6 Z06?
- Upper shock bolt tq spec?
- Air intake for 2008 C6
- Lifting the car
- Istalled my Cam this weekend.
- Need Roll Pin Solution
- Squeeking sound when engaging clutch
- Transparent roof panel
- Window regulator/motor: GM or aftermarket?
- good clutch that won't break the bank..IDEAS??
- Ideas/Suggestions on following header/intake setup??
- C6 exhaust configs explained?
- Trailer tire hauler
- Power Seat Noise
- Can You Wear Out A Lug Nut ?
- Changed clutch, no speedo.
- Headlight Fogged and it Won't Clear
- Z51 Brake Rotor Size VS Base Brakes
- Z06 Oil Cooler in Z51
- i think my vette has a problem please help
- idle issue MN6 - revs not coming down
- Performance shops in south
- Priority start - automatic battery protector?
- Seat Disassembly
- HELP!! RUBBER fell in engine
- Track tires
- Pioneer AVIC x910bt installation
- False message "Left Front Tire Flat" on a C6
- Windshield Wipers Stuck
- Trick flows are here, do i have enough cam ?
- Where to mount fire extinguisher???
- Need more leg and foot room 2008 C6
- Rsd line lock install on z06
- 06 ZO6 Pushing Coolant Issue.. Need Info...
- How much lightening needed to shave .2 from my 1/4 mile time?
- SLP Diablo Predator
- 08 MGW shifter install HELP
- Anyone know how to remove seat module?
- Setting fan speed on my 08-Z51
- Active Handling Issue
- Can "active handling mode" default in "compatition mode?
- Best Tune for C6 Z06?
- Need help with tire selection
- Looking for aftermarket couplers
- Best Intake for Z06???
- Rear hub/spindle question
- Clutch Help Needed Please
- Harmonic balancer NOT covered by 7 year powertrain warranty?
- Introducing our 457/460 CID upgrade
- Building a 408 LS2 Stroker
- Can aggressive driving wear inside edges?
- how accurate is dynolicious?
- Is 225 degrees oil temp too high?
- What Year Z06 NNP for a 2009 C6
- LT's: Kooks vs. LG
- **LG Motorsports a Edelbrock Official Install Center**
- XM Satellite Radio - Can It Be Added With Ease?
- Power window issue. Advise needed.
- •► ► AMERICAN RACING HEADERS - ON SALE @ CoW ◄ ◄•
- •► ► Chuck CoW A6 -REAR END STIMULUS PROGRAM- 3.42 A6 ATTACK PACKAGE ON SALE!!! ◄ ◄•
- Need advice with RevExtreme catch can install
- Engine worth anything?
- Nick Williams 102mm Throttle Bodies
- Squeeking Brakes
- Corvette C6 Titanium Akrapovic Exhausts In STOCK at Speed Merchants
- HELP!!crank pulley bolt broke off ..
- Can I use different oil for procharger p-1sc?
- 402 stroker motor have to add oil often
- Who has installed the Z51 Brake Rotors Upgrade Kit?
- top three???
- Heater core swap?
- Going Wide Body
- Purchased Used Vette with Magnacharger - but finding myself a bit lost...
- Radiator removal / transmission oil cooler lines?
- loose driving light
- My track times before & after COW tune
- **NEW** LG Drivetrain coolers
- GT2 Rear Diffuser For Stock or Aftermarket Exhaust
- **ZR1 Body Work at LG Motorsports**
- Mti Racing Open House Dyno Day Saturday April 3
- DIC buttons not working on my 2006 Z06
- Hinson Motorsports now stocking PRC EHT .675" Dual Valve Spring Kits
- Dumb Patriot sping question
- Bought something from Lingenfelter, does this sound ridiculous?
- Opinions Needed on 2005 vert
- Will sound improve with tune?
- Coolant temp guage intermintent???
- Big thumbs up for spins traction mod
- oem nav unit locked
- Dyno'd OEM Z06 manifolds/cats/3" X-pipe w/ NPP
- Dyno tuning
- documents for this wheels available?
- FAST 102 - 2 hose connections in back?
- ***STILLEN CorvetteForum Brake System Upgrade Package***
- One Last Request! Batt Disconnect Switch
- C6 Code display
- Engine Light On
- npp/zo6 mufflers question vs. cutouts
- anyone running 345mm tires on standard C6 19's?
- NGK AFX Wideband Kit - Now comes with upgraded NTK sensor at no additional cost!
- Will a 2008 z06 NPP exhaust fit a 2005 Coupe?
- Ghl race series special
- Factory Brake Question
- New end links but new noise
- 413 rwhp & 425 tq ??
- Max power and pass Calif smog?
- Prestone Synthetic DOT 4 Brake Fluid
- RR-Stage 5 LS3 A6 570rwhp
- Engine Oil
- Fuel smell from right rear wheel well: evap canister normal operation?
- H/C or Supercharger for a Modified LS3
- LS2 Heads can you use studs as alignment Pins
- anyone know the gm part# for the stainless braided 3/8 fuel line that connects to the
- Z06 Muffler Mod Question
- Update - Whining coming from rear speakers when radio on or off VIDEO included.
- Removal of Airbag/Service Column Lock
- Increase Gas Mileage?
- Oil Filter
- What does cb abbreviation stand for in this forum?
- Using Diagnostic Scanner, Car on or off?
- Driver side window switch
- 2006 C6 New battery Voltage Drift?
- Cost?
- Remote starter for setting valve lash
- c6 base shock upgrade?
- Penske coilovers, Pfadt comp sways, AP racing BBK, A arm poly bushing upgrades
- LG Executive Cam
- seatbelt warning system problem
- Stock exhaust with no mufflers
- Need a 2007 seat control module schematic
- Power Steering
- Engine Dies During WOT
- Tuner in Tampa Orlando area.
- Any probs waiting to tune w/ my mods
- Changed my rear in A6
- OEM Coupe VS: Z06 H-Pipe Differences
- Does camming your Z reduce the cars reliability?
- Anyone powder coat a TB or ALT
- Popping/Crackling sound at Startup??
- Probably a stupid question but... (Cam Install Experts)
- Hurst Short Throw Shifter
- Question re: removing calipers & brackets
- Options Not Available message in DIC -Why?
- Red Line oil- need a fair priced vendor?
- Intermitent Telescopic Column
- Anyone know how to repair Seat Module?
- Alignment machines???
- replacing the fog lights ...but how ??
- 2005 Vette remote access inopperative
- Gains from cam? MPH & ET.
- Code PO315
- Installed 2009 Z06 NPP on 2006 LS2
- 2007 Exhaust Install Before/After Dyno+Video
- Fuel Pump Questions.....
- Add-on Gauge wiring.
- Is adding the NPP mufflers to my C6 enough?
- Anyone else have LS3 engine seals leaking?
- Need help: Battery REplacement Where to buy stock battery and install help
- Fuel Rail Cover Question?
- straightline performance
- Halltech Venom open hole? See Pic
- Which exhaust to buy???
- Performance Package
- diablo tuner help!!!please!!!
- HELP! Battery dead after winter storage? CAN'T EVEN OPEN HATCH
- **LG GT2 Coil Over Suspension Package**
- please help vette starts and dies
- valve seal tool and oil pump o-rings
- C6 Corvette RaceMesh Grilles... from CCA
- K&N filters (car louder?)
- whistle/howl from intake/ported TB/ported intake combo?
- Corvette Grand Sport Floor Mats from Lloyd Mats & CCA
- Help with Misfire
- SIS Flashing Misfire? Smoke in Exhaust
- Question about Mild to Wild
- If you love the refinement in the C6 over the C5, how do you mod with it in mind?
- 07 A6 Gearing
- product evaluation-slp powerflow #31079
- Best shop you would recommend in the MD area?
- Mixing runflats w/non-runflats
- Line Lock Install
- Fan still not working...
- Bragging Rights?
- 4.10 gears LS3 Las Vegas?
- Cam spec's let me know ls2
- Where's the site that shows what options you have by VIN?
- Do your own headwork?
- Help with stuck shifter
- Help with new high volume oil pump
- Will 08 C6 rims fit 98 vette?
- Alignment & tire breakin questions
- Anyone with Reproduction Wheels\Replica Wheels
- ** LG Motorsports C6 Street Series Specials**
- Blackdog Speed Shop featured in latest episode of Vette Garage, The Series
- LS3 Ticking Noise (sound bite included)
- LR Cv boot issue possibly
- Power Top Lockout defeat?
- PAC beehive valve springs, .650" lift
- Cam install gone bad.
- Cam only people, come talk to me!
- CAM Upgrade
- Buzzing sound coming from speakers when radio on or off?!?! HELP!?
- Rims fitting older vette...
- What tming set to use??
- ECU to coil diagram
- How did they do that?
- BAP question
- car is eating alternators.. DIod failure!!HELP!!
- Bilstein Shock Questions
- HVAC Control Module Replaced
- Needed, 3" high flow cats, Vibrant 300 cell good?
- Realign C6 mufflers?
- Fender Hash Stripe
- Fit of IForged 19X11s
- Anyone out there running the LG G6XE or G5XE cam??
- Amercian Racing Headers with free MSD and NGK
- Looking for two c5 front wagon wheels
- Taking Apart a Seat Positioner (Track)
- Instructions for spring and shock replacement?
- I need Someone who can tune my car!
- Anyone Else Dislike the Long 1st Gear?
- Timing cover part number
- Need torque tube asap
- Rotor Replacement
- installed borla stingers, now getting some odd behavior from car
- cam install
- Is it possible to have headers with no tune ?
- Has anyone used screamer exhaust
- Manual transmission replacement time
- Question: Easy Entry and Exit
- Wilwood Big Brake Kit fitment
- Widest 20in wheel with stock C6 rear fenders?
- Fuel Injector Upgrade?
- Help with pushrod length..
- 19x11 - 79mm offset, stock C6 fenders.
- TPMS question
- Philly header install??
- TPMS - right rear tire is continuously reading 10 PSI low..
- Anyone using O.Z. Alleggerita 18x11" rims OZ
- Crane Race Gold Rockers - C6 Install
- Me Vs. 2007ish Roush (closed course)
- Im so frustrated with my C6- wheel hop demons!
