- Installing just a 160 degree stat in 2010 LS3
- MSD Coil Packs
- When Adjustable rocker arms needed?
- installed chrome gumbys today...
- white noise with radio off, driver power seat not operable?
- Cam Question
- LS3 Catch Can Installation with Air Intake Silencer
- if i change to msd plug wires, do i need to put the oem heat shields back on?
- is there a trick to removing plug wires?
- Couple Easy Question From New Corvette Owner
- Who has the best price on a Corsa Extreme Exhaust?
- LS-2 Intakes
- Ranger Clutch Fluid Clensing Not Working For Me
- Adding Launch Control for 2009 C6
- DIY - Weekend Project - All the Fluids
- **ATTN Vendors * Need Corsa #14108
- Slight Change to my PCV Delete
- Looking at purchasing a C6... What do you think about this?
- Question about disassembling calipers????
- Optimal setups - C5 and C6 with Trickflows
- LS3 + FAST 102 Intake = ?????
- Halltech Killer Bee II + Beehive install/dyno today
- Windows don't go up all the way ?
- Service active handling Recall
- ***Houston Dyno day/Car show - May 22nd
- Borla and Haltech make a great combination
- NICE!!! Aftermarket Wheels that fit??? C6
- Any Powder Coat Experts?
- LS2 to 3 Vararam
- LS2 Drivetrain loss
- Filter, Header and Exhaust - Recommended Brands and Approach?
- Self-Maintenance Fluids - Would someone verify these?
- Race Proven Motorsports H/C/I C6Z 10.38@138
- how to remove and install wheel bushind ??HELP??
- Trapped 130 mph last night!
- No Power to Home Link and Visor Mirrors
- Best tune for a 08 LS3 A6 NPP
- •► ► Chuck CoW A6 -REAR END STIMULUS PROGRAM-A6 ATTACK PACKAGE -SALE ENDS SOON!! ◄ ◄•
- Airbrushed fuel rail covers!
- •► ► EDELBROCK E-FORCE -AVAILABLE- @ CORVETTES of WESTCHESTER ◄ ◄•
- comp cam swap
- C6 Fender Removal
- E3 plugs on Z06
- Good LS3 tuner in South Florida?
- Brake Caliper Bolts
- Gear change from 2.73 to 3.42
- Gear Change Code
- LS3, Oil blowing out the intake?
- Horn Part Numbers
- Please Help: Seat Wiring Question
- Factory reproducton wheel - help!
- Need Help Guys
- K & n air filter
- EMT Tire flat
- Line wrench size for brake line install
- Fuse to pull to open bi-valve exhaust?
- Throttle body coolant bypass
- Wheel weight fell off
- additional service items - thoughts
- LG G6X3 cam
- Will I be adding or losing wheel/tire weight?
- Corsa Extreme / Vararam installed WOW!
- 2010 GS Onstar Removal
- Need Ram Clutch opinions?????????????
- Genuine GM C6 Z06 LS7 Clutch Kit installed in an 2005 C6
- Dropped Car off at CoW today!
- C6 issues...try these 3 fixes before going to the dealership
- FAST 92 HP results!
- considering splitter install
- **Kooks Header Sale- Get Free Coating or Save More!
- Porting the FAST 102 (Cathedral Port LS2 Version)
- Power Steering Flush: How To?
- TBmonsterRepair: Fixing the Hole Drilled in TB Plates
- ARH LT's and Fast 102mm going on tomorrow~!
- LS3 to LS7 Similarities
- Need advice on a body shop in Austin, TX
- Telescope wheel not working ................
- wheel offset questions
- New clutch/ Now no 5th 6th or reverse
- CAI/tuning questions
- FAST ethanol WB and pid for HPtuners
- Continental ExtremeContact DW
- 2007 A6 Boot Replacement
- Help with Clutch issue and a good shop!!
- Just broke a piece off of my glass top
- Just got 05 C6 and already problems with transmission... HELP!
- 1/4 mile weight tests
- SLP loud mouth and K&N intake on a 09
- Brakes grabbing some at low speed stops...
- Chrome Wheel Issue
- 1 to 4 Shift Lockout?
- Driver Power Window Meltdown
- effect of different front to rear tire diameter
- Lug nut torque.
- Help on Vert top please?
- Teeth Stripped Clean Off Dbl. Roller Cam Sprocket!!
- First Mod for $1,000 or less
- Who to work on car? Wrong, wrong, wrong.
- power top issue
- cam install tools
- Questions on Mini-tubbing and widened wheels
- Wiper Motor
- Steering Felt Really Hard
- Exhaust cutouts right after the headers?
- LS2 With Boltons. $5k to spend. H/C vs Blower ???
- what size NT05R for spinmonster modded 18" wheels?
- Ace Wheels being widened?
- R & R rear diff
- NPP Wild to Mild Controller Left in On Position
- drone vs. sound deadener
- fuel problem?
- Replace Fan or go with Dewitts
- My Experience with MTI Racing of Atlanta $42,000 later…(Part 1 of 3)
- Gears
- How to remove headlamp??!!!
- EnduraCool Header Coating Sale!
- BlueSTAR 2010
- Trickflow 225s/FAST 102 on a LS3
- Wheel alternatives? (18x12 in rear)
- Noise under slight throttle ~62mph help!
- Drill mod for clutch slave????
- Must jack to swap exhaust?
- Catch cans Ca. lagal?
- ? about Wilwood big brake packages...
- QI45 Install. Need help with firewall...
- more help on active handling please
- Cylinder head advice
- need help with an injector question
- Tunnel plate torque #
- Upgrading Stock C6 Suspension
- Clutch pedal stuck!!!!
- OnStar Module
- Auto to manual?
- transmission tuning
- Cruise Control Problem
- Any Idea on how much $$
- Power lumbar fuse keeps blowing
- forged wheels...
- GM states my rear wheel vibration is from my Borla Exhaust - really??
- Need 4 or 5 point harness for C6
- Woven Grill Mesh for Callaway Honka
- Shift-I Progressive Shift Install in HUD
- Yella Terra Roller Rockers
- RPMs fluctuating when off the gas
- Outside Air Temp Guage Not Correct All The Time
- Launch Control? Oh yeah, I’m a fan
- “Put up OR Shut up” FREE Super Bee and Killer Bee offer!!!
- How many miles u get off RPS carbon double or triple clutch???
- Glass top coversion
- 2006 Z51 Tranny strength T56
- Fuel injection "o" rings
- Vette air results
- Clutch or burning smell under hard acceleration
- Expected HP gain versus MPG loss??? FAST 102 and dyno tune
- No Spark
- HP gains, if any from removing cats..
- Has anyone actually had a crank pulley come off?
- A-pillar removal
- C6 and battery tender
- Callaway DD?
- SLP Powerflo with Square Cast Aluminum
- What is the best (most HP Gain & safest) TRUE cold-air intake
- C6 Z06 cam and Launch Control questions inside...
- Torque specs for Hpipe and Roll bar from exhaust removal???
- A6 repair
- 2010 GS Baseline Dyno Results
- Penny method queston: Tread depth measurments
- C6 Z06 BiModal vs. B&B Fusion Exhaust
- Do you want to BREATHE sale is here; details inside!!!
- what time of tire is best for c6
- Question about check engine light?
- Which Headers
- Headers Installed, expected CEL but not these codes...
- Mod friendly Service department
- Opinions: LS7 for LS3
- Tool sizes for brake pad replacement
- HELP: Removing z06 exhaust, how disconnect valve control?
- does running an '09 base coupe w/o TPMS cause a dash light/error code?
- Tuners/service in Southern California
- Under hood light install / Cut out hood liner?
- Hurst or b&m shifter????
- Problem tire sensor
- HOTTEST C6 MOD EVER! DMH ELECTRIC CUTOUTS WELDED ON C6 STOCK MUFFLERS-video & pics!!
- Warning! FAST fuel line adaptor ( PN 54028) Failed on my C6Z.
- next mod info please
- Another Problem. One Step Forward One Step Backward (Telescope wheel)
- Really BIG Rear Wings, Why?
- Water From Dehumidifer?
- Best way to wire a fan switch?
- HELP -- Memory Seat Problem
- Changing Power Steering Fluid - How much is needed...
- Nitto Invo vs Nitto NT-05
- Upgrading to a 3 spoke steering wheel from a 4 spoke?
- Brake Rotors cupped?
- Question for those that port throttle bodies???
- Caddy Video CTSV in Japan
- Electric connection on starter????
- C6Z Front Shim affect on camber?
- Aviad oil pan baffel problem
- Stock fuel pump
- Results of a dumb mistake
- Transmission Oil
- Anyone out there running the LG G5X1 Cam?
- A4 to A6
- TC Intervention
- •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
- stock LS2, street tires 1/8 time
- C6 Windshield wiper problems
- Will Headers & a Tune Make an C6 LS2 as Powerful as a C6 LS3?
- Coil relocation kits?
- Spring is a great time of the year
- HUD/DIC out of sync on MPH
- ZR1 Style Carbon Fiber Front Splitter for Z06 in stock for immediate delivery
- Barber Grand Am GT race video LG Motorsports
- Vararam intake
- Minimum distance fobs must be from car to prevent battery drain?
- Track Wish List Z06- FEEDBACK NEEDED
- End Links Popping
- cutouts or after market Mufflers
- 2007 a6
- removable top issue
- Quick Time Exhaust on C6
- Active Handling issues
- Comp Cams Trunion upgrade installed!!
- buzz in dashboard
- clutch release problem?
- phantom tire pressure loss HELLLP!
- Jacking a C6 on a 4post lift
- Corsa Exhaust Discount 33% off MSRP
- Corvette version of 510 cu. in. LS motor finally finished!
- Leaky coolant hose a common issue?
- HELP HELP Shot in the Dark...Coolent temp tables and others FRUSTRATING!!
- Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
- Crank Pinning Cost
- Need to bend oil cooler lines
- Corsa Axle-Back on A4 Question
- Passenger Door, Window, and Mirror are not working
- Anyone have the Ragin Racin Stage 3 Package?
- Fresh LS3 H/C dyno #s! {501 RWHP}
- Need solid advice my friend is being taken for a coine ride
- New PS2 ZP
- Torque Management 2005 Z51 6speed
- Rotor and brake pad Combo?
- **LGM and ForgeLine Center Lock wheels**
- Difficult To Get Into 1st Gear
- Next mods..wondering HP gains (guesses of course)
- offset for 2005 coupe with Z51??
- 160* thermostat
- >>**LG Motorsports Spring Install Specials**<<
