View Full Version : C6 Tech/Performance
  1. Hello Katech !
  2. My LS3 Modded Results...
  3. air bag warning light on
  4. New Best 11.132@125.03mph**Video`s**
  5. My 2005 stopped today....
  6. Had a Pro Torque Stall Converter installed
  7. Skinnies worth it?
  8. Anyone try Michelin Pilot Sport A/S Plus, 500 wear rating!
  9. Question for those that have installed Kooks headers on an LS3...
  10. Borla Stinger..............FITTED!
  11. Got codes and back story..now what's wrong..
  12. LS3 vs Z06
  13. Meziere Electric Water Pump Wiring?
  14. 12 pound supercharger what size injectors
  15. Awesome Deal on Borla Stinger w Quad Round Tips (3 systems only!)
  16. XM Low Volume
  17. Z06 LS7 Air bridge/MAF on an LS2?
  18. Panel (IPC) Warning msg on DIC (new car)
  19. Accessing Cigarette Lighter fuse
  20. Part number for 07 passenger cabin filter door retainer clips
  21. Katech oil pressure pump shim now available
  22. Help! How do I remove the interior trim piece along the rocker panel?
  23. Which Clutch Fluid?
  24. enigine to hot shuts off a/c
  25. How much were my pistons notched?
  26. Track Times
  27. Fuel rail lettering
  28. *** ECS takes the C6 NA record with a 10.66 @ 131.68 mph ***
  29. GM Performance catback exhaust
  30. [Craftsman] Floor Jack
  31. Road Race Oil Pan Header Clearance Issue
  32. NAV System
  33. Blower info request
  34. interior removal
  35. Check engine light is on
  36. Louder exhaust
  37. Blown Heaader gasket - normal?
  38. adjusting fenders
  39. 10.3@ 152 Speed Inc. APS TT ZO6
  40. Are re-indexed windows adjustable?
  41. mid pipe to remove cats with stock headers?
  42. Fire ext.
  43. Experienced Corvette technician around MA
  44. Erratic idle after full PCM tune
  45. Another Great Miller MP Track day for me...:)
  46. 2008 LS3: Lost Engine Power and Got CEL, Any Ideas?
  47. 2005 C6 Dead Battery or FOB issues - NEED HELP!!!!
  48. Fan temperatues
  49. Any AUTO LS2s getting 400rwhp/tq with only bolt-ons?
  50. Black wing question
  51. Ls3 427
  52. C6 Z51 front brake measurement question
  53. FYI new MA. emissions test
  54. Headers for bassani catback
  55. Interested in a 465hp pkg. for 06-07 C6?
  56. Change Wheels w/out Reseting Sensors ???
  57. exhaust question
  58. Car won't start syndrome...SOLUTION!!!
  59. C6 headlight swap/install
  60. New product!! Vortex V2 Ram Induction 2008 & Up LS3 and 2006 & Up Z06
  61. What do you REALLY think of Patriot heads?
  62. Review on My New Ram Twin Plate Clutch Install. If you need a clutch hope this helps.
  63. Awesome Deal on Borla Stinger w Quad Round Tips (3 systems only!)
  64. 19k DIY maintenance suggestions?
  65. Etching Stainless parts
  66. Gauge Wiring
  67. MGW Install and Opinions so Far
  68. What tires are available for the rears (Z06)?
  69. Help! Weird clicking sound coming from car....
  70. 1/4 mi question
  71. MAF end seperated from center
  72. Michelin PS/2 ZPs in C6 coupe/vert sizes delayed until Spring?
  73. Is it safe?
  74. 20" Drag Radials/Slicks?
  75. REALLY hard to put into reverse on MN6
  76. Having BB Fusion System Installed, Quick Questions...
  77. How good is stock C6 Z06 bottom end?
  78. Clutch Time!
  79. F55 and wheel hop
  80. Mr. Gasket Thermostat Took A Dump
  81. Strange happening....HELP!
  82. Opinions on 1/4mile times im getting with nitrous...
  83. Killer Bee installed....RPM's now fluctuating, any advise?
  84. Exhaust system?
  85. Harmonic balancer ??
  86. thermostat
  87. A6 muffler removal - CAREFUL!!!!!!
  88. What mod should i do???
  89. I'm Ready to Throw In the Towel w/my C6
  90. LS2 w/vararam + kooks + FAST intake VS. LS3 w/vararam + kooks
  91. C6 Alternator Charging Solution
  92. convertible 1/4 times
  93. Help with making exhaust pipe round again
  94. Need a little tech help please!!!
  95. What has the advantage in a mile run
  96. nitrogen
  97. 2005 W/O Tire Pressure Sensors???/
  98. Went to the Track. BOOOO
  99. Vararam + Kook's Headers/X-Pipe + Fusion = ?
  100. Coil Relocation Re-Visited
  101. Passenger Air Bag Threshold
  102. Plug Wires: Any Opinions?
  103. How to re-program C6 cooling fans?
  104. WTK:How hard to replace C6 air dam on 08
  105. Held off a GT500?!?
  106. Why is my 05 Inconsistent at The Track
  107. Ported Fast vs Ported Stock intake
  108. Koni FSD question
  109. Installed Yella Terra 1.8 rockers
  110. Where Is The Reverse Lock Out Solenoid
  111. Is 19/19 possible instead of 18/19 or 19/20?
  112. Question about removing the starter.
  113. How to check if clutch position sensor is working?
  114. Callaway Shifter issue
  115. New intake
  116. Anyone here with 500+Rwhp with 20" wheels?
  117. C6 Vararam VR-SC1 Gen 2
  118. fuel rail painting
  119. Need help! Car won't start!
  120. What do I need to look for swapping trannys between two cars?
  121. Where to buy wheels?
  122. SLP header install
  123. will c5z wheel fit on my c6 with rear z conversion?
  124. Pfadt adjustable street bar front clocking?
  125. install time for headers?
  126. Spark plugs????
  127. Where to buy gears for self install?
  128. FAST power brake fitting for LS2
  129. Need help with deminsions
  130. Parts compatability
  131. Weird speedometer problem while racing...
  132. Race Ramps
  133. Service Dept's aways amaze me
  134. Baer Decela Rotors
  135. New BCM Now No Cruise Control
  136. Thermostat
  137. Texas Speed Now Offering Wiseco Pistons!
  138. Vararam on Sale for the Next Month! (You don't wanna miss this!)
  139. Halltech Induction Systems Now Available @ Texas Speed & Performance!!!
  140. Help, dome lights stay on?????
  141. Looking into Buying a 92mm TB and 92mm Intake form FAST
  142. Improving Shifting in a 05 C6???
  143. Need advice on how to strip clearcoat from my z06 wheels
  144. which direction to tps sensors face
  145. Appologies and Thank you's
  146. What kind of power will this make? 402 Stroker
  147. Corsa ZO6 on a C6
  148. GM Factory Manual
  149. Stock pushrod length?
  150. One more time - MAP hole in front of FAST 92?
  151. Retard question.
  152. Can someone please tell me how to use the fuel line removal tool ?
  153. Possible problem?
  154. 200 mph pics
  155. Which Mod = Most Horsepower?
  156. how will the 4:10 s hold up on a procharger c6
  157. Need Help: Rear hatch glass replacement
  158. ACDelco UltraGuard Gold in 2008? UPF44
  159. A6 Dyno question
  160. Who makes a glass or carbon body kit conversion to a z06 look?
  161. Advanced Dyno Inc.
  162. Need some Nitrous facts and advice
  163. Put 402 in and no oil pressure!
  164. 4.10's or fast for 10's
  165. Ace Slick wheels & C6 Z51 brakes
  166. Battery out During Storage
  167. Going nuts need help
  168. New Product what do you think GT2 Style Side Skirts for C6 and Z06
  169. Console question - Please help!
  170. Want to Replace Stock Rotors.
  171. Are LG coil overs...
  172. What clutch should I get? LS2 Twin Turbo.
  173. Got "Active Handling recalibrating"
  174. Does anybody have speakerbox carpeting experience?
  175. Anyone using the PFADT C6 Seat Wiring Harness...?
  176. Is Advanced Dyno Inc. still in business?
  177. 06 TO 09 Exhaust Question
  178. C6 APS Twin turbo installed package
  179. Apsis' C6 Side Air Vent Now Ready To Ship, Carbon & Stainless *PIC SHOWN*
  180. What is the facotry headlight intensity?
  181. Whats the point of picking up x-pipes without cats vs with cats?
  182. Help me decide next mod
  183. Traction Problem Need Help
  184. putting on my procharger, do i need a new balancer?
  185. budget intake - which one for 08/LS3 specifically?
  186. Hurst shifter
  187. Rear hatch opens
  188. Another oil leak question
  189. Throttle body spacer on Vararam
  190. Drag Wheel Setup
  191. dynolious 1/4 mile
  192. Any sugestions on source for "in-dash/console" Exhasut Control Switch (no remote)
  193. New LG's now rattle/ HELP
  194. disabling traction control
  195. Difference between just changing shocks vs complete C/O??
  196. shock recommendation
  197. Slave cylinder needed for a new clutch?
  198. Empty C6 cats. Gains?
  199. M6 gear speeds
  200. New to the forum
  201. oil cooler question
  202. Can headlights/driving lamps be polished?
  203. do the engine covers keep heat in?
  204. Mod an LS2 or pick up an LS3?
  205. Dyno Results *Video*
  206. TPE is Now a Pfadt Dist..HUGE Sale
  207. HUD unit now vibrates in my C6
  208. C 6 Grill Screen purchase
  209. Help me decide: Callaway or MGW shifter?
  210. Thanks to Ragin Racing and LG
  211. Adding a harness
  212. Put your thinking caps on
  213. 1.8 roller rockers on LS3?
  214. No FOB issues
  215. Fluids for Stage V a4?
  216. C6 to Z06 aftermarket body panel kit
  217. less traction w/ wider tires? is it the tire type or no sensors?
  218. Help tps wire?
  219. Which heads to drop compression ratio on LS2?
  220. ZR1 rear spoiler
  221. Service Charging System
  222. Trick Flow 225 vs. L92/L76 Dyno Graph
  223. C6 HI/LOW fan controller
  224. New Vette Owner
  225. I want to hear exhausts in person...
  226. My window quit working!!!
  227. Were did u order your
  228. Headers
  229. Top speeds of each gear with 4.10
  230. Where to get a pillar pod?
  231. Help with Baer brake rotor detailing
  232. Clutch and brake fluid upgrades?
  233. Valve covers
  234. AC Compressor running, but I'm getting hot air?
  235. Next step
  236. heyper tech for the ls3
  237. Removing the Cat Question?
  238. ***Bolt on LS3 Hits the Roadcourse with some Z06s!!!*** (VIDEO)
  239. Slave cylinder for Z06 fit a c6?
  240. So pf46 and pf 48 delco filters...
  241. How Expensive to change from perf axle to stock
  242. Anyone using the Textrailia X-Grip?
  243. ZR1 and MILD2WILD = WOW (video)
  244. Engine Missing After Prolonged Downtime
  245. Need advice on tire pressure
  246. ls3 cam advise
  247. Headers and O2 sensor code sollution.
  248. VSS/Open circuit when the car is moving. Ideas?
  249. Torco- shelf life?
  250. Mag ride switch controls DME
