- Cost 2 replace tire pressure sensor?
- Huge savings on STAINLESS WORKS or AMERICAN RACING HEADERS for the month of June at S
- 2005 Nav disc?
- Vengeance Racing | Ported FAST Intake Sale!
- LS3 Fuel Pump Verses Z06 Fuel Pump
- header difference for ls2 to ls3's ??
- GM Performance Exhuast anyone try this system
- Working on my shifting
- V1 to HUD interface progress.
- zo6 conversion what do u think of the deal???
- *** Fidanza Light Weight Flywheel Issues with 4.10 Gear ***
- how to recall DIC errors
- Parts needed to complete bi mode exhaust
- 2006 c6 with 2009 Z06 Exhaust will it work?
- CAI questions.
- Anybody have one of these?
- Breathless New One Piece Carbon Fiber Bridge a proven winner again and 10% off
- ECM Location
- Need Help with my C6 FOB !
- Best Spirited Driving/Around Town suspension setup
- On Sale NOW, the new Killer Bee II and Super Bee CF!!!
- 2010 GS fog lights
- Window tints and your 'vette
- Anything to be gained from a Aluminum Flywheel ?
- Transmission
- How to tell if clutch fluid was drained?
- Need a dual mode exhaust
- killer bee 1 for a 08 z06 the same for a 08 c6 ?
- Short throw shifters.
- Water in the center console storage area.
- '09 Factory X-Pipe vs Corsa XO-Pipe
- Fuel Mileage
- Service traction light on :(
- Keyless entry problem
- 2008 Dual Mode Exhaust Question
- Intermittent computer issues
- C6 Z06 Caliper Issues, Need Help!!!
- P0030 and P0135 Error codes
- NT05r 315/40/18 Anyone use these yet?
- Wiring Harness Diagram
- 355 mm StopTech for C6
- Does anyone know how to remove the power steering pulley?
- Cooling Fan Failure
- Beat the Heat Summer Header Sale - Kooks with FREE COATING or SAVE MORE!
- Help - where to mount Revxtreme catch can on '09 LS3?
- Dual mode exhaust install?
- 2005 nav unit SW update went wrong..
- 2010 GS rearveiw mirror airbag light/message.
- Z51 and Z06 Rear Calipers
- Ticking that soinds like its coming from under front 1/3 area
- Tire %
- New air filter; :re-learn necessary?
- What Octane for LS2 or LS3
- C6 ride height & rake optimum?
- Short shifter rattle solution!
- Paddle Shifters - Reverse Shifters
- drivetrain fluids change
- 2009 with Dark Clutch Fluid?
- C6 LS2 the best Headers,Exhaust! Size,Make,etc..
- Will Billet Exhaust Plate Fit With B&B Bullets
- Need Help
- Blown rear any advice?
- Can we add the OEM 09'+ Bluetooth Nav and Steering Wheel Controls?
- Has anyone done the AC evaporator core coating DIY to fix the musty AC smell?
- LS2 vs LS3 Valve Covers
- Quality Motorsports 25% off Labor Special!!!
- HUD Install, need some help!
- My A6 tranny cooler install! Lots of pictures
- Am I there yet? 7.9@96mph
- how accurate is the DragTimes DA 'correction' calculator?
- Sprint Booster
- Z51 Sway Bars Still a Good Idea - for a 2010 C6?
- Carbon Fiber GS stripes
- Carbon Fiber Vinyl Wrap
- Callaway Honker or Killer Bee II w/ Beehive?
- Traction system active displayed
- **LG Motorsports World Challenge Hoods and special inside! **
- 08 C6: DTE brace?
- spec twin install
- **LG Motorsports Memorial Weekend Sale**
- Replacing Cooling Fan
- Clear Top Problem
- B&B Performance Exhaust Identification ??
- Dome light Staying ON
- Escort Passport 9500ci C6 Convertible DIY Install Guide
- asks to be put in PARK when it is already there
- Transmission Problem 2010 GS Stick 2000 Miles
- Statistical data on a C6 drive train?
- DIC codes on a C6?
- Newbie Question on expected costs (Perfomance Upgrades)
- Gear Swap 08 A6
- I've been reading a lot of threads, still no answer.
- AIRAID Cold Air Dam Intake System SALE (2005-2010 Corvette & Z06)
- Break Fluid Questions
- Need Help With Brake Noise / Caliper noise - Dealership can't fix it
- PRC Memorial Day Head Sale!!
- How to remove steering column covers?
- Bose question...????
- Pad upgrade for street/track duty?
- ~~~ St Jude Auction # 38 *Plug n Play Interior LEDS for the C6~~~
- Bilstein Owners please: Do Bilstein Shocks Ride Stiffer / Firmer than Z51 Shocks ???
- OBD II Lamp steady - ideas?
- Titanium Intake & Exhaust Valves for LS3 Heads
- Dyno tuned my LS3 on a new ECU and made the same power as untuned on prior ECU
- Do Previous Gen 17" Rims fit C6Z06
- what size injectors will work for 600 rwhp?
- Hawk Pad GP (Revised) @ GM Parts House
- JetHot on Headers... is it worth it?
- Steering Wheel position sensor
- Lowering a F55 Suspension?
- C6 window switch panel prolem
- Tuning in South Florida
- LG Headers, SLP Loudmouth, GrandSport
- Spraying Meth in front of the MAF
- 325 on a stock 19x10?
- vancouver canada
- heat insulation for headers
- Question on PAD possition
- Source for constant and switched power on driver side?
- For those with LTs & rear section exhaust
- Punched out injectors?
- Npp question
- Elite Tunnel Plate
- Smoother gear shifts, any way to lubricate?
- Rear Caliper Piston Size Z51/Non Z51
- Aftermarket Clutch??
- Head Gasket Failure C6, blew engine
- Flashing headlights and tail lights
- Service charging system
- Service column lock AFTER CLA replacement?
- Drive Train Annoyance
- Steering wheel position sensor recall
- Mother Lovin' SS Brake Lines
- Tire Sensors
- Key fob programming
- Cam install
- Vette Doctors Performance 2nd Annual BBQ June 26
- Leaking shock absorber
- Saikou catch can fitment issues on LS3?
- High Performance sway bar help?!!!
- Right Turn Signal Bulb
- quick exhaust question
- Upgrade options for base C6 brakes.
- ZO6 breaks
- Driver Seat motor & Gears
- Cost of A4 conversion to a 2005?
- Looking for the best mods for 5k
- i think i have a bearing problem with my alternator
- Thinking about changing shifters
- Whooshing sound while shifting?
- 19x8.5-265/35/19 ------ opinions? pics? flames?
- nick williams 102mm TB in stock?
- C6 Oil Change - Another how to for beginners
- Thinking about Borla Exhaust any help.
- Rear License Plate - prevent paint damage
- Clutch Pedal - No Feeling or Disengagement
- '06 A6 Transmisstion Problem
- Best tires for street 600 + hp.
- Magnetic Select Drive
- Why change the front bar on a F55?
- Why won't my driver's side door OPEN?!?
- Brake rotor and ceramic pad install
- Bolster and Lumbar motors work, but no effect
- Track day nixed by clutch hangups
- 102 mm throttle body
- 3.42 diff question
- Headers and exhaust bypass, worth it?
- Under drive pulley on 2010 gs
- new spec clutch won,t disengage
- HELP! ANYONE running a 255/345 tire combo with a 19/20 wheel combo!
- CEL after adding headers
- Hub centric or no?
- >>LG Motorsports NEW Drop Spindles **IN STOCK**<<
- Tire Selection Help, Bridgestone RE-11?
- Steering wheel effort has increased.
- Trans cooler for a a6?
- what is the normal running temp for an LS3?
- Battery relocation.
- Wobbly crank pulley - 2007 Z51
- C6 wheel tire combo
- Not when I lock, but 3 horn beeps when I exit
- New cam, heads and headers
- Flycutting was not as bad as I thought. {with the right tools}
- C6 `05 EBCM / brake bleeding
- Are there gains from a 100 MM MAF on LS2 ?
- Original Muffler pipes R & R
- Rizzo Performance ,C6 Exhaust
- Gear Swap from 2.56 to 4.10 - two diff swap
- Airaid intake systems
- How wide can I go on tires?
- Question on traction control
- Where can I find access?
- Started my header install today
- Best Mail order tune for C6 Z06?
- got my car back from a dealer service dept; wanna guess how much oil was missing?
- Exhaust "Valve" Question
- Performance Shop/Tuning on the Island of Oahu?
- Gas octane ?, Im in a different state
- 2005 Electrical Nightmare
- 2010 LS3 Gas Mileage Problem
- Any McLeod RST clutch owners?
- What the hell could be wrong?
- t56 gears and mph
- LETHALZ Cam H/C RR-Stage 4 582hp/536tq
- new grand sport/rough idle @ start
- LS3 track oil temps?
- CD Mech Error...CD's won't play or eject
- BBK CAI or Vararam??
- Alignment shop in So. Md
- Cam Install Numbers
- How much mph do you gain from the 1/8 to 1/4?
- What is "CORRECTED HORSEPOWER"
- too big lsxr 102mm intake manifold?
- Best Settings for drag racing
- Used C6 with mods?
- Installing my halltech venom this weekend.
- PO449 Evaporotive Emission Control System vent valve/solenoid malfunction.
- Kooks Nationals NMCA At the Grove June 4-6
- Performance shops in the NJ NY area
- LS2 Cam Decision...Split Duration or Straight Up?
- Dynoed my LS2 C4 today
- Z51 Rotors
- BBK cold air intake vs Vararam
- TPS life expectancy????
- Who to trust?
- Put in 402 shortblock with dual roller now crank pulley doesn't line up
- A6 software upgrade?
- question on spec super twin
- Advice on replacing Goodyear Eagle F1 Supercar OEM's
- Questions on tuning/headers
- What are my options for 18x12" Z06 Wheels?
- Help: window stuck half way down
- Rear Glass Trunk Release Mod
- Royal Purple "Purple Ice" Super Coolant
- Who should I contact for a C6 A6 Tune?
- Will upgrade intake Manifold-intake require better injectors??
- ***EnglandGreen Entry Level Mod Specials Through June 30, 2010***
- Need help reprogramed fob now vette is dead
- Dyno numbers 2006 A6 with mods
- C6 charging intermittent "Voltage Too High" - 17+volts - Ideas?
- cove screens
- Front tire size,Question
- Head-up display
- I need more power! Whats next??
- is there a 'cams for beginners' thread?
- LS3 preventative maintenance, check for vac connections etc?
- New time with DRs
- Where to look for LS7 engine?
- Can I use ZR1 cam in LS2?
- •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
