View Full Version : C6 Tech/Performance
  1. Automatic transmission cooler for 2005
  2. Clunk & Sqeak in Rear End
  3. C6 Clutch Slave Cyliner Boot Question
  4. Vented hood
  5. Just installed headers, x-pipe, npp and npp in a box!
  6. Should I be worried?
  7. Tinted Windows
  8. Complete (mostly) HUD commands and symbol sets document
  9. Strange issue with my new to me C6??? Help please.
  10. What's the difference between the LS3 & L76/L92 intake manifold & heads?
  11. Need cam and longtube suggestions for LS2
  12. 1 Day 4th of July Special
  13. Why do engine and trans temps increase at higher elevations ?
  14. Ride Height
  15. 2005 C6 cut rubber hose for transmission cooler install
  16. Z06 clutch on an LS3??
  17. LS3 vararam mod to work on LS2, MAF to MAS, etc...
  18. lunati valve springs?
  19. Sprint Booster Throttle Control?
  20. Thoughts on header coating???
  21. will this fit come on smart people help me out
  22. widebody installation in New York.. Help?
  23. I almost lost my finger. [ VIDEO INSIDE ]
  24. Engine Belt Issue !
  25. Help....2005 C6 Total Electrical Shutdown
  26. C6 electrical gremlins
  27. LS2 E-Force and CAM?
  28. July 2010 C6 Specials @ GM Parts House
  29. Z06/ZR1/GS Conversions @ GM Parts House
  30. Ceramic Pad Super Special @ GM Parts House
  31. July 2010 Hawk Pad GP (Least Expensive Price On The Forum)
  32. C6 Z51 Sway Bars With Free Poly Bushing Upgrade @ GM Parts House
  33. Vararam Experts Chime in Please
  34. Any detailed install posts for FAST install?
  35. overheating issues
  36. Lets take a guess at what my 1/4 will be..
  37. FYI GrandSport wheel / tire weights
  38. supercharger
  39. Anyone do before and after dynos for ported TBs and IMs?
  40. Discounts for our Military Personnel from MTI Racing
  41. 2.56 to 3.15 gears swap a6 07?
  42. zo6 clutch
  43. Where does the XM ant in mirror connect
  44. The New Edelbrock E-Force Supercharger System
  45. K & N air induction
  46. who is the best supercharging vendor on west coast?
  47. ACT clutches???
  48. HPDE at VIR problem
  49. ><>< St Jude Auction #46 "The Man Knob Exhaust Switch" ><><
  50. who is the best supercharging vendor on east coast?
  51. Hard starting, a lot like vapor lock
  52. Need some ideas on trans cooler install on 05 A4 with FI
  53. Cam is in, videos inside
  54. intake manifold removal
  55. Rocker arm wear....Normal?
  56. vette air surging
  57. A6 Transmission PIP 4395
  58. Nav system Info needed
  59. Speed by gears
  60. N/A vs. S/C MILEAGE ?
  61. What will lift be on Z06 cam with 1.7 rockers?
  62. 12.23 @ 119 - intake/exhaust/tune LS3 6MT
  63. 86 Roadster - Water Pump Replacement Guidance
  64. 2007 C6 Cruise Control Quit
  65. What is required to do a C5 differential in a C6
  66. Cam experts - nice advice on piston-to-valve clearance
  67. intake Question (intake not manifold)
  68. **GRANDAM/LG Motorsports Corvette Corral New Jersey July 16-18**
  69. How to install '09 npp's on '05.
  70. LG Motorsports Summer Cam Specials!
  71. LS3 Veraram Pics Please!
  72. Total Oil Capacity for '07 Z51 w/ Z06 Oil Cooler
  73. So it's time for some pads...
  74. Z06 Oil Change
  75. Help: Quantum Spindle Ducts
  76. Gasoline ?
  77. Code P-0171
  78. Looking for best deal on rear differential oil and
  79. 5.5L 440 HP Next Gen Base Vette Motor Info!
  80. oil analysis 09 LS3
  81. Who does the C6 mod for FAST intakes?
  82. i cant take this any more !!!!!!!! this clutch issue the dealership didnt help out !!
  83. Sometimes push "start" and it won't crank...
  84. Service Electrical System
  85. Timing chain difference.
  86. New Heads and Cam (long)
  87. waterproofing my vert
  88. TPMS rebuild kits & Tire Warranty
  89. Help my battery died
  90. whats up with all these for sale adds in the tech section !!
  91. Looking for a change (WTT Bullets for NPP)
  92. Track Wheels
  93. couple tune up questions ??
  94. Correct Mounting Orientation for Z06 Oil Cooler - asap
  95. Any Reviews for GFORCE
  96. Z06 Trans and Diff in an 05 Z51
  97. About to by Longtubes, few questions.
  98. Oil change
  99. Alright, Who's Catch Can is Best?
  100. Stuck Shifter?
  101. FREE Crate and Cradles On All Stroker Engines @ TEXAS SPEED!!!
  102. MGW shifter adjustment
  103. Screw size info needed for roof panel weatherstriping
  104. C6 Power Steering(PS) Pump swap taking PS pump alternator bracket off car
  105. Trans Fluid Brand ????
  106. Need help getting 12 volts from inside mirror
  107. 2005 Differential
  108. AC condensate dripping on header
  109. C6 won't always gate out of reverse
  110. Anyone have actual results from using the trick flow 220 as cast heads?
  111. A6 Lock Up Torque Converter Chuggle
  112. Effect of cam lift on HP?
  113. NPP + LG Headers = GREAT
  114. ~*~ St Jude Auction #44 LG "Zipper Door" Car Cover Fits C5 /C6 ~*~*
  115. Do You Have a 102mm FAST Intake & A 90mm TB? New Item Available Inside
  116. SICMSP Z06 bumper - upper moulding?!?
  117. Base or Bose ???
  118. Improving Shift function
  119. any tansgo for c6 a6 2008 ?
  120. headers and burnt cluch tube
  121. *** Edelbrock E-Force LS3 Install Special [PICS] - Pre-Order your LS2 Now! ***
  122. AC problem need some help!
  123. Will a ZO6 radiator fit a Z51
  124. -- Flat-Out Friday at MTI Racing 6/25 -- [VIDEO INSIDE] --
  125. Z06 Dif Cooler in C6?
  126. how fast should my vette run ??
  127. HOw many Miles from your NIttos?
  128. Fan full load amp draw????
  129. T-stat housing location
  130. Dead TPMS Question
  131. Power top not working
  132. c6 to the track
  133. Clutch Fluid
  134. Looking to upgrade your A6 transmission? Well the wait might finally be over!
  135. Need info on straight pipes
  136. Vararam pcv issue
  137. DMH electric cutout problems
  138. DMH electric cutout problems
  139. C6 Exhaust
  140. Help! Failed NJ Emissions Inspection multiple times
  141. September Issue of Corvette Magazine
  142. Need NPP exhaust for 05 conv
  143. How to improve cornering of C6?
  144. Eforce supercharger or Trickflow heads?
  145. Z06/GS alignment spec's
  146. Question about recall
  147. what type of crank and rods do i need for stock ls3 427 build!!
  148. Halltec killer bee install question
  149. Carbotech Performance Brakes
  150. Any problem using ATE Super Blue for clutch fluid?
  151. Looking for a shop in the Midwest
  152. LS3/L99 CNC Cylinder Head Porting Video INSIDE!!
  153. HELP please.... Torx size needed
  154. Rear speakers barely work
  155. Need help choosing heads
  156. Hoosier A6 or R6?
  157. Corvette Wheel Spacers
  158. M2W question
  159. Ported fast 102 beats ported fast 92
  160. Song List Button
  161. Best intake, and why?
  162. Airaid Intake Systems...at CCA
  163. Question on '05 reverse shutdown
  164. Non Factory Nav unit install
  165. question on zip busing pads
  166. Clutch pedal no feeling stays to floor C6
  167. *Quick Question Regarding Tires
  168. Purchasing Exhaust...
  169. Power loss with slipping clutch?
  170. Dented Headers, would you buy??
  171. HUD G-Force Maximum Value
  172. The loudest c6 exhaust
  173. FACTORY AUTHORIZED - Color Matched VetteNet V2 Clearance...from CCA
  174. warranty friendly performance upgrades?
  175. clunk
  176. opinions needed
  177. •► ► Chuck CoW A6 -REAR END STIMULUS PROGRAM-A6 ATTACK PACKAGE -SALE ENDS SOON!! ◄ ◄•
  178. LG MOtorsports ZR1 heading to Spectre 341 Virginia City Hill climb
  179. •► ► SATURDAY JUNE 26th LUNCH @ CoW ◄ ◄•
  180. •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
  181. Fast 102 gains 28rwhp & 25rwtq over ported LS2
  182. location of starter?
  183. burnt oil on dipstick??
  184. Need help with driver's door
  185. Dumb ls3 cam instal questions
  186. Hot start (after 30 min) problem????
  187. Z06 clutch setup
  188. New C6 Owner with many questions.
  189. ckt code need help
  190. Will Z06 exhaust install on my standard c6
  191. Fuel not siphoning from second tank
  192. Engine cover paint help
  193. 07 c6 Z51 oil capacity
  194. Help removing clip from parking brake (inside car)
  195. ACE wheels from West Coast Corvette
  196. Please need help my car wont start....
  197. Question for Dallas Corvette Owners
  198. ~~~ St Jude Auction #42 "The Man Knob" Exhaust Switch ~~~
  199. GPS/On Star antenna fell off
  200. ls3 crate motor;pedal will not work the throttle body?
  201. Just ordered cam!!!
  202. Removing lower center console need instruction
  203. Removing steering wheel painted covers (caps) Need help!
  204. What bolt size and thread?
  205. Replace Rear Leaf Spring
  206. LS2 Dipstick Tube Bolt Size
  207. need exp advise
  208. NPP Exhaust Question
  209. If you own an A6 car and would like some FREE longtubes, come in
  210. **Final Dyno #s on H/C LS3: 506 RWHP!!**
  211. Where does Part # 25873838 & 20772013 go?
  212. replacing 87 stock wheels for Z06
  213. A/C Not Taking a Charge - A/C Techs Step Inside
  214. How to learn to rebuild a diff???
  215. Ignition switch pushed into dash
  216. Ignition switch pushed into dash
  217. How to install a z06 diff in a 05 m6
  218. Who Has a C6 Z06 and are using 2 Piece Rotors Front & Rear...What Brand..??
  219. Dash control lights not working HELP.
  220. Do Knock Sensors throw codes?
  221. 2008 Reduced Power Message, etc
  222. dipstick hole on LS3 engine?
  223. Stronger Half Shaft for C6 Z06
  224. Corvette Brakes - Pads and Rotors
  225. air conditioning blowing warm
  226. SIP "Street Enforcer" LS2 install...
  227. change 5th gear for standing mile ?
  228. header and exhaust dillema ...
  229. Holley 4779 with boost reference
  230. vararam throttle body spacer causing connector to hit idler pulley
  231. anyone have a pdf of the vararam snake charmer C6 LS3 instructions
  232. need help with belt size on procharger
  233. For those of you making 500rwhp+
  234. LS3 Kenne Bell
  235. Changing interior color?
  236. Vibration in front wheels.
  237. Delayed Door Opening
  238. Dads 08 has repeated service traction control warning
  239. Rotors
  240. So do they make TVS2300s for LS2's?
  241. New rotors, old pads?
  242. EnglandGreen Whiplash cam + A&A Vortech =
  243. •► ► SATURDAY JUNE 19th LUNCH @ CoW ◄ ◄•
  244. Which Thermostat, or does it matter
  245. COMPLETE CAM kit install and Tune SALE; only $1,695 out the door!!! Details inside.
  246. Magnetic Suspension Control/wheel balance question
  247. C6 locks it's self---Mystery ??
  248. Where to buy NW 102 TB?
  249. Does Full Length spoiler adversely affect drag at speed?
  250. Service Active Handling Q's
