View Full Version : C6 Tech/Performance
  1. Do I need a Stall or a new Gear? CAM INSTALLED!
  2. Are Z51 Hub sizes the same as Z06?
  3. water on the floor
  4. Why do my brakes squeak so bad?????HELP
  5. ***RSD Line Loc for sale***
  6. is ls2 and ls7 slave and master clutch cylinder
  7. Help in identifying headers
  8. Difference in LS3 and the 6.2 in my 2010 Denali.
  9. Ported throttle body worth the price?
  10. Anyone know the CFM of the stock radiator fan?
  11. Side vents
  12. 1st time Dyno
  13. Cooling fan not working
  14. Denver Area front end alignment
  15. Before tuning your A6 to fix the transmission....
  16. Alternator on its way out?
  17. anyone run spins 230/230xfi 115+3 in auto ls3?
  18. Ls-3. Ls-7
  19. Optima YellowTop D35 for 2007 C6
  20. Went to the 1/8th mile track
  21. WTB: CF Side Skirts for 2008 Z06
  22. c6 tall valve cover installation
  23. coilover shocks with 1" HIGHER/LIFT than stock ride height?
  24. WYB: Brand New Chrome Plated Alernator
  25. dyno'd my bolt on 06 A6 and almost got 400 RWHP
  26. Tremec 6060 ?'s
  27. 245/30/20 vs 255/30/20
  28. Dyno question
  29. <*> St Jude Auction #52 2 C6 Armrests <*>
  30. ~~~ St Jude Auction # 51 LG Motorsports "Zipper Door'" Car Cover ~~~
  31. 2005 A4 Drivetrain Question
  32. Anyone with pics of the left fueltank internal connections ?
  33. Lug Nuts
  34. AC Idler Pulley Replacement
  35. Clutch Pedal to the Floor ?????
  36. Question about ls2 & ls7 parts compatibliliy
  37. "Clunk" caused by play in drive train
  38. Reverse Went Out
  39. •► ► CHUCK CoW gives you CASH @ CARLISLE!!! ◄ ◄•
  40. New rotors
  41. Vinyl "cast skin" on a pillar bubbling
  42. will this make at least 400 rwhp? please chime in!
  43. Are there long tubes that bolt up to a stock h-pipe?
  44. August 2010 C6 Specials @ GM Parts House
  45. GS/Z06/ZR1 Conversions Available @ GM Parts House
  46. Hawk Pads Available (Lowest Price Guarantee) @ GM Parts House
  47. C6 Transparent Top - 12499572 - Super Special @ GM Parts House
  48. Shifter Problem
  49. Is This Flare?
  50. Air cleaner change help
  51. ls3 hesitate, buck and stutter at around 2-3k rpm
  52. C6 1LT owner...looking for flatter ride
  53. need help choosing headers
  54. Where does this thing go? "Air Intake Housing Cover"
  55. manual question
  56. Steering wheel shakes at high speed after brake pad change
  57. Electric fan terminal
  58. Weep Hole
  59. Check Engine Light
  60. Speed Bleeders...
  61. Pics & Advice On 265/35/18 & 305/30/19
  62. How Dangerous Are Summer Only Tires In the Cold?
  63. Eforce = lose the Fast intake? or not?
  64. Air intakes
  65. Aftermarket Exhaust Fitment w/ Z06 Diffs?
  66. •► ► THE OFFICIAL TUNER OF 2010 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER ◄ ◄•
  67. RPO codes fe3 and j55
  68. CORSA Super Sale...Exclusively at CCA
  69. 0-150mph times
  70. Vararam Industries at Carlisle with CoW!!!!
  71. tires
  72. HVAC controls gone crazy!
  73. C6 Edelbrock Supercharger Upgrade
  74. fuel door lock actuator assembly question
  75. LS-3's need to worry!
  76. New tire info help
  77. AC problem
  78. Hydraulic Lifters
  79. Sharkbar Install
  80. P0430 Catalyst System Low Efficiency Bank 2 Code Back
  81. master cylinder upgrade
  82. Trans Cooler on A6 07
  83. How can you tell if a C6 has/had mods?
  84. LS2 E force
  85. Mobil 1 or Mobil 1 Extended performance..
  86. Squeek & Rattle from Z06 Roof - Chevy Dealer Horror Story **VIDEO**
  87. FREE SHIPPING on PRC Aftermarket Casting Heads!
  88. Lets talk clutches
  89. LS2 413 and LS3 427 SALE! @ SDPC
  90. Power steering problem
  91. Muteki forged lug nuts - any problems?
  92. C6 after market mufflers
  93. EnglandGreen Whiplash II breaks 460rwhp in an LS2 with stock heads!
  94. Corvette Summer at Carlisle August 26th - 29th
  95. Installing airaid intake!! Now what?
  96. Hockey pucks...
  97. Window Switch will not work
  98. RPI ZR1 spoiler
  99. Conversion Question
  100. Can someone post M2W visor program?
  101. Advice on catch can
  102. exhaust question
  103. 2007 LS2 Clutch replacement HELP!
  104. what rpm do i launch at??????????
  105. Track virgin
  106. Heads Up on A6 Lock-up
  107. XM Manual
  108. 05 C6 Gear Ratio 2:15 or 2:56 ?
  109. Active Handling Off - but still on!?!?!
  110. Tire question for those with 20" rims outback
  111. best brkae pads for non-z51 C6
  112. What is the Best Spark Plugs for C6?
  113. Shift Light Wiring
  114. Help picking a platform...
  115. Can't get air out of cooling system, HELP
  116. MT hard shifting when hot
  117. LS7 Clutch Kits In Stock - $419.52 - www.PartsTaxi.com
  118. Temp sensor problems
  119. Key in car chime.....shut it off?
  120. Drag radial question.
  121. C6 T1 Suspension Specials - www.PartsTaxi.com
  122. Need a good tire and wheels combo
  123. 2005's with Transmission Swaps (wtf?)
  124. August C6 Specials - www.PartsTaxi.com
  125. 1000hp ZO6 gets Penske's & Brembo's
  126. FE03, FE04, and FE05
  127. Maf / throttle body cleaning - ???
  128. Tunnel insulation. Any ideas???
  129. I need Your Help
  130. RPO Z16 vs. FE3 or FE4
  131. Katech Performance GEAR on SALE!
  132. Diablosport Predator Flash Tuners - ON SALE FOR $279.95 SHIPPED!
  133. Plug Wires
  134. Mobil 1 vs. Royal Purple
  135. F55 and Coils
  136. >>>> St Jude Auction #50 LG Motorsports World Challenge Wheels <<<<Redux
  137. PFADT 1/4 in. spacers installed
  138. Trunk won"t open
  139. Shifter won't ingauge?? Plz help
  140. Who run 2 peice timeing chain cover?
  141. 2005 mt z51 shutdown problem: wont recognize it is in reverse
  142. 150 miles and my clutch fluid is dirty.
  143. Magnachager?
  144. What's the best supercharger?
  145. Is a damaged Vacuum Canister the cause of no low-end torque?
  146. What Brakes do I got with?
  147. Replacing battery tray
  148. Slicks/"removable top"?
  149. What Oil is best for a tuned LS2 engine
  150. Fuel gauge senders replacement time
  151. Tpms
  152. Best solar power trickle charger?
  153. •► ► CARLISLE is COMING SOON! ◄ ◄•
  154. Fidanza 7.6 twin plate clutch kit available at GMPARTSHOUSE Rated to 900lbs of torque
  155. New LS3 FAST 102 (ported) unique opportunity
  156. backup light loose
  157. Terminology
  158. Grease fittings
  159. How hot is it supposed to run?
  160. Do u use injector cleaners?
  161. LS-2 Air Filters
  162. header/cam/intake swap on l92 408
  163. what fog HID's to match stock
  164. toyo r888 traction
  165. alternator pulley??
  166. Do I really need to bleed the brakes if I never opened the system?
  167. Help! P0175 CEL Code!
  168. My alternator is shot, was told that parts are not available, help?
  169. Racetronix web store
  170. 1st Gear Grinding
  171. caliper removal
  172. Kooks Headers
  173. Anyone have promlems with their door latch??
  174. Front in Popping when turning
  175. Warning - Count washers when replacing shocks
  176. Vibration under hard acceleration
  177. need opinions... will my 05,c6,a4 have problems w/ a cam and heads?
  178. 2008 C6 Suspension Noise
  179. hot running c6, no known reason, did everything.
  180. sizzling exhaust normal?
  181. HELP! HELP! Active Handling & Brake Lights
  182. need part function identified for Grand Sport, rubber cover under nose
  183. Suggestions on Deep Staging?
  184. Is the AC Delco Gold Oil Filter Worth the Xtra Money?
  185. Fitting on clutch bleeder line?
  186. Transmission Fluid Change
  187. I did burn 3 and 4 gear in T56 transmission!!
  188. air intakes?...Does one really give a huge gain over another?
  189. True Custom Exhaust
  190. Cammed LS3: TSP 1 7/8 or LG 1 3/4 ??
  191. Manuals to Reverse
  192. Slave Cylinder
  193. EnglandGreen Mayhem II + LS2 surprised even us!
  194. Mobil Dexron-VI ATF
  195. A really simple question
  196. Exhurst problem with Corsa touring with long tube headers
  197. Gain with a Fast 102 intake and nick williams 102 TB?
  198. PM-FL DART Heads & Cam Package Sale!!!
  199. Charging problem...
  200. What trans fluid would you put in your A4 auto?
  201. alternator shaft
  202. Brake Options
  203. Transmission question
  204. EradiSpeed+2 Stock Wheels?
  205. STS tubro & LS3 Edelbrock Supercharger
  206. dyno numbers
  207. C6 corvette tires
  208. Help With 2-step
  209. 20 inch wheels all around??
  210. Question about C6 A-Pillars
  211. LS3 418cid stroker?
  212. Timing chain suggestion
  213. Performance for dummies
  214. Big Brakes & Spacer - Pics and Help Needed
  215. Am I just search incapacitated? How to pull heads?
  216. how much rwhp can i expect?
  217. How much brake fluid is needed for a flush and question on ABS flush.
  218. Whining Clutch
  219. FOB Issues
  220. No Display on Nav Unit
  221. Which thickness tunnel plate to get?
  222. Need help deciding on intake - FAST has got to go!
  223. Dyno Result 06 LS2 A6
  224. Question about CCA?
  225. tach stopped working
  226. Tunnel plate Question
  227. What kind of sealer on trans filter seal C6 A4 auto
  228. ZR1 Slave Cylinder
  229. Looking for the easy way!!!
  230. Battery tender hook up
  231. Z06 or C6 stock bi mode system???
  232. LG pro headers installed, my 2 cents.. :)
  233. Need input on MGW.
  234. drone
  235. LS3 intake rocker arm problems?
  236. What is the best way to get under your car?
  237. Dyno results. 08 base m6
  238. Any interest in a Forum Drag Strip Meet at MIR this fall?
  239. How is the stock LS3 Manifold compare to others?
  240. OEM Radio
  241. O2 Sensor Exhaust Question Help?
  242. Just installed a complete Z06 Exhaust on my 2008 Base C6
  243. Disregard front impAct sensor. B0101 code
  244. Any good shops in the DFW area for a cam install?
  245. HUD speedometer showing '0' or random numbers
  246. Calling tire Exports - quick question
  247. Mobil 1 Synthetic ATF
  248. Anyone on now what diagnostic code P0449 is?
  249. EASTCOAST PERFORMANCE C6 Headlight Lens Replacement Service!!!
  250. Why do cars dyno higher with stock gears?
