View Full Version : C6 Tech/Performance
  1. C6 Adjustable Clutch Master Cylinder?
  2. gas cap c6 zo6 problems
  3. Mgw 08c6
  4. Ebc pads c6zo6 4 track??
  5. Here is what they do in NJ !
  6. Is this normal?
  7. Suspension question 4 c6zo6.
  8. Dot 3 Dot 4 question fluids
  9. *** how to make your a6 corvette truly amazing ***
  10. ***Mail OrderTune and Vararam Holiday Special Pricing***
  11. Converting C6 into a FRC
  12. DIY Battery Relocation on a C6 *Pics Inside* (non Z06)
  13. Need a clutch that will handle 700hp and 580 tq
  14. A/C Shuttering or Vibration at start up??????
  15. LS7 in a A6
  16. Dealer in Southern Cal who does Warranty work on a modded vette
  17. Quick Help
  18. Failed Timing Chain and Cleaned Piston pictures
  19. C5 Wheels/tires on a C6?
  20. speedo and lockout
  21. Standard trunk key
  22. LS2 Intake options?
  23. '08 Convertible wiper problem
  24. C6 owners w/ZO6 rear wide body, how much did you pay to get it painted?
  25. DTE Differential Fluid Help
  26. 3.90 & paddleshift anyone?
  27. Which Mobil 1 oil ?????
  28. 2009 Twin Turbo LS9 Z06
  29. Deltarn Tender Junior
  30. locked out
  31. Wheel Click Issue
  32. Checking horn function
  33. NEED HELP! Header install on C6 Z06
  34. Hi Flo Cats go bad?
  35. Brake light problem
  36. traction control problem
  37. brake upgrade, best bang for buk?
  38. Replacing header gaskets?
  39. Odyssey battery in C6
  40. Whine Update!!
  41. Corsa Exhaust! FREE Shipping through December!
  42. Brake question
  43. Bulletin on rock/sand blastin of panel just behind doors?
  44. 1/4 1st time
  45. Where to buy LS1 injector O-rings for FAST
  46. LS3 Ragin Racin Ported Intake and Calloway Gains
  47. 7.4@97.5 ls3 bolt on
  48. does ARP make intake bolts for the LS7?
  49. Anthony and LG Motorsports do it again!
  50. South FL final 2008 Corvette Challenge at the new PBIR 12-20-08
  51. on the fence....4.10..or.. not.
  52. Replacement Z51 Brake Pads?
  53. A6 shift points are ?
  54. Sway bars for 05 C6.
  55. No traction above 4000 rpm
  56. need info on clutch
  57. Seat belt retracting very slowly..any suggestions?
  58. ?? on checking piston to valve clearance
  59. HOUSTON, we have a traction problem!!!
  60. Breathless Holiday Special...Package Deal $$$
  61. Newest Product- GT2 Style Diffuser Designed for Stock or Aftermarket exhaust systems
  62. Amsoil Oil Filter for LS3
  63. what shifter to get ?
  64. Lowering a C6 ZO6
  65. Tire size question
  66. Abaut Flowmaster
  67. westcoast corvette wheels...
  68. HP to Weight Ratio?'s
  69. LMR 440ci 07 Vette with 360 Forged wheels Dyno Vid!
  70. 15% OFF All Labor Untill New Years!!!
  71. Pavlock Performance 08' Procharged and baby Cammed Vid!
  72. Treat Yourself For The Holidays Porting and Tuning Special!
  73. The great header debate continued. 1 3/4 vs 1 7/8
  74. Powder coat calipers?
  75. Z06 Exhaust on an '08 LS3
  76. Flycutting soon? Better find cutter now!
  77. New clutch
  78. Need Quick advice on Intake Manifold
  79. Stock Air Filter is HOW MUCH?
  80. Frt end noise
  81. Exhaust Commander "Electro" 100% electric NPP bi-mode retrofit kit On Car Demo Video!
  82. 2 cut wires by the rearview mirror
  83. The Jet Powr - Flow mass air sensor
  84. Pfadt trans+engine mounts vs Dte brace for drag racing?
  85. LS3 Style Timing Chain Tensioner/Damper
  86. Help on PFADT Sport Shock install
  87. Anyone know where I can buy a Callaway (C16) hood?
  88. This is true driving skill here; AMAZING!
  89. Shift kit / gears?
  90. Alignment issue? (T&P)
  91. oil Temp??
  92. Just how strong is the A6 Automatic
  93. lowest operating oil temp?
  94. MSD Ignition Coils
  95. Header gaskets
  96. Hey guys need some advice on heads????
  97. Ignition Switch Collapsed into Dash
  98. Need stock lifter height
  99. Comp Cams adjustable pushrod question?
  100. Ka boom
  101. Wheel Studs
  102. Dynojet vs Mustang dyno
  103. possible to shift into reverse when trying to shift into 5th [c6]?
  104. C6 Tranny trouble shoot
  105. Another CAGS eliminator question
  106. 07 C6Z06 Rear and trans in 07 C6 1LT?
  107. Whats the proper break in for new Gears?
  108. Burnout
  109. Specter Werkes GTR Hood now available
  110. New Sheet Metal/Carbon Fiber Intake
  111. Tune
  112. For those with Maggies...
  113. New best 11.07 at 127 mph!
  114. Year End Blow Out Sale
  115. 2008 LS3 Timing Chain Failure.....:(
  116. *** Time's Almost Up for Specials at LG Motorsports ***
  117. Cam Done: Straightline Performance Review
  118. New best 1/4 mile time!!
  119. Diablosport Lowers their MRP Price for the Holidays- Get a Predator for $319!
  120. A little help explaining this one to me
  121. ZR1 Spoilers In Stock 12/14/08
  122. Attack of the Clones? (New best time of 11.056@124.385)
  123. flush clutch fluid
  124. Fan Start Up Temp
  125. what fuel system should I go with
  126. Solar Battery Tender
  127. '05 Using Oil
  128. Corvette still wont start - Help
  129. Z51 Alignment and Tire Wear
  130. Best place to buy a cam kit?
  131. Is there a breakin period for a cam ??
  132. C6 Wont Start - No Electrical - Help !
  133. Z06 vs Z51 whats makes steering different
  134. Help w/installing 08 C6Z Shifter
  135. B&B Fusion with Headers Installed...finally!
  136. corsa
  137. A/C Problems
  138. 550rwhp
  139. Soft Clutch Pedal
  140. LG headers and 3" Z06 catback fit an A6?
  141. I May Have Scewed Up My Z06 NPP Exhaust
  142. New NPP muffler bi-mode retrofit system! Electric actuators! No vacuum lines needed!
  143. New clutch installed....it now slips
  144. weird noise
  145. GM Parts House Genuine Corvette Accessory Free Shipping Weekend.
  146. Need input on what supporting mods to do
  147. Does A6 tune have blip downshifts?
  148. [Press Release]**New StopTech Track Caliper from LG Motorsports** [Press Release]
  149. window problems
  150. Q on swapping 05 NAV for 08 6-disc
  151. Seats
  152. A6 reprogramming
  153. PVC system Need advise
  154. Adjustable Koni Shock & Bar Special
  155. *** MTI Racing & Pfadt = BIG 11-day sale ***
  156. Radiator protector screen?
  157. Z06 exhaust on a ls3 -hp increase?
  158. Getting the SpinFast Next week
  159. LG World Challenge or TKO Carbon Fiber High Rise?
  160. HELP!!! Notchy shifting in ALL gears
  161. ??? - part number - ceramic brake pads - Z51
  162. Replacing passenger seat c6zo6
  163. Clicking sound from rear axle
  164. Best mod for my dads 07 c6 vette
  165. New Exhaust Gasket Design from GM...
  166. Automatic NPP Actuator retrofit for $25!
  167. [PRINTS]FINAL CHRISTMAS SALE! Corvette Christmas for 20$[PRINTS]
  168. Charged S2K vs LS2 C6
  169. **Race Video from Road Atlanta**
  170. Minor 6spd manual transmission problem
  171. Looking for assistance with Flowmaster exhaust
  172. details of modification required for Z06 rear quarter panels on a vert
  173. *** Look to LG Motorsports for HRE Wheels ***
  174. Cleaning Pistons
  175. *** The coolest Christmas present for less than $200 ***
  176. Junping out of gear
  177. C6 Carbon Fiber Headlamps just in time for Christmas
  178. Problem with electric rear hatch?
  179. How much of a difference does the TBS with a Vararam matter???
  180. 2008 ls3 factory tune off?????
  181. Timing Chains
  182. Clunking from the front end...
  183. Question on Headbolts
  184. failed end links how do I kmow?
  185. adding memory seats and mirrors
  186. Any suggestions on source of "snapping" sound?
  187. Plug WIres
  188. Quick question
  189. Why won't ls7 manifolds work on my car?????
  190. Where can I tap into 12 VDC? (08 C6 Coupe)
  191. 335 35 17 with Zr1 rim
  192. **LG Motorsports Christmas Wheel Special**
  193. Dyno funny
  194. Z06 manifolds to 2.5" exhaust
  195. intake system upgrade give me a car length?
  196. ***WCC C6/Z06 Brake Sale***
  197. Holiday Header Sale @ MarylandSpeed - Kooks w/ Free Coating, SLP, & More!
  198. Tune after CAI installation
  199. Are these torq specs the same?
  200. Anyone using the SPEC Twin w/ Organic Disks?
  201. IPS Holiday "Private-Message" Sale !!
  202. Happy Holidays, Gift Idea #1
  203. Transmition fluid for A6
  204. Srt-10 vs. C6
  205. Kook's Specials at Corvettes of Dallas
  206. Exhaust and F/I
  207. Question on clutch/flywheel housing removal
  208. ls2 fast intake install....NEED HELP!!!!!!
  209. Performance difference between 2.56 and 2.73 gears
  210. Does anyone have a picture of 275/35/18s and 305/30/19s on stock rims?
  211. code throttle position sensor
  212. Need Help With Widebody Concerns
  213. Able to identify Z06 shafts in differential?
  214. Throttle Control Problems - Seriously
  215. Clutch Fluid
  216. Great experience with a Houston Tuner
  217. Disable auto headlight feature?
  218. 06 07 Differential for 05
  219. Spring Mountain has ZR1 Driving Experience available
  220. Drag time comparison
  221. Texas Speed - Closed Dec 11th & 12th for PRI!
  222. 1/4 mile videos from MIR rental 12/3/08
  223. WHo knows how to add fluid to an A6 transmission?
  224. While watching Jay Leno and his ZR1...
  225. LSX vs. LS7 head Video
  226. Issue removing drivers side head
  227. where to buy front wiring harness for drl
  228. Output Shaft Install
  229. Head / Intake recommendations for a G5X1?
  230. Need your help
  231. HELP!! Double Roller Chain/Oil Pump/Cover Clearence Issue
  232. Question about tire size and mileage
  233. Accelerator pedal position (APP) sensor wiring diagram - Anyone help?
  234. *** Racing in icy conditions ***
  235. afr 205 heads vs gm's l92 heads
  236. Torque tube bushing
  237. C6 noisy at start up
  238. Bog during boost
  239. tire recomendations
  240. Service Active Handling issue
  241. Right turn signal flashing fast
  242. New N/A best and a CEL
  243. HELP: 06 A6 and Tranny Fluid Leak
  244. In Honor of the Tech Forum.....
  245. wheel widening
  246. FS Under drive pulley
  247. air intakes
  248. I can't leave the LS3 alone... *Dyno Pull Video*
  249. Z06 Battery Charging Questions???
  250. need help installing zex wet kit...
