View Full Version : C6 Tech/Performance
  1. Holley LS Fest
  2. mod / tune sequencing
  3. for the LS2 Cam only guys in the longblock...
  4. LS3 cam ?
  5. Need help with a squeak
  6. need to cut a tenth or more off my et!
  7. Got my headlamps changed
  8. Show me...
  9. Shifter box bushings.
  10. Can You Help??? 07 ls2 Vararan W/TB Spacerm A6 - spark knock - need help
  11. Ls3 air cleaner
  12. Temp bouncing around... Water Punp?
  13. Exhaust sound vibration
  14. Steering wheel problems
  15. CCP/HKE LS3 416 an 427 Engine Pricing
  16. best tire/rim size for c6 wide body conversion
  17. Calling all Corvette's to GTGP Laguna Seca Oct 22-24 No Sound Restrictions.
  18. "Research Rocket"
  19. More Katech LS9x Clutch Kits Available
  20. Weight
  21. Broken left plastic tank Corvette C6 radiator
  22. Hawk brake pad specials!-free shipping! Lowest shipped price!
  23. C6Z Air Conditioning Issue
  24. LS3 A6 Guys with Cam and Stock Stall
  25. Widebody conversion
  26. brake caliper and hood swap
  27. Morel Lifters Best price anywhere!
  28. Which Tires for Drag Racing and Street?
  29. K&N Air filter question?
  30. Can a water pump have too high a gpm rating?
  31. Stall Converter
  32. S. Fla - Corvette Challenge this Saturday 9/11/10
  33. Z06 vs GS composite springs
  34. Vengeance installed Tick Performance Adj. Clutch Master
  35. New Seat Covers
  36. 05' T56 & Diff to 06/07' T56 & Diff -
  37. c6 snow tires
  38. First oil change questions????
  39. Nt05r vs a6
  40. oil pressure sending unit
  41. Free Crate and Cradle on LS3 Stroker Engines at Texas Speed
  42. Possibly buying a 2011 grand sport. Some questions.
  43. Loud Vibration at high speed on 2010!
  44. Where is the turn signal flasher on the C6????
  45. New 2010 DTC format
  46. AFR 230 vs TFS 225
  47. Relay Click when Brake Applied
  48. What causes chatter?
  49. 1/4 mile C6 auto launch at track?
  50. 2005 C6 reverse problem-HELP
  51. E-force on the GS with dry sump - got some info on "extra parts"
  52. Reprogram BCM
  53. Pic of install of Katech Carbon Fiber Splitter with Undertray & Brake Duct Kit
  54. Reverse light
  55. Memory Seat Problem!
  56. # of washers on upper controls arms
  57. Lamar/Walden Automotive
  58. 05 vette dyno numbers
  59. California Emissions
  60. Headlights: heavy humidity inside!
  61. 08 exchange ARH for Z06 headers system
  62. Noisy Targa Roof Panel REPAIR!
  63. WTB hood and brakes
  64. Help fire in the steering wheel.
  65. Bolt on???
  66. Just installed npp on my 07
  67. emission label
  68. C6 MN6 reverse troubles
  69. Anyone know how to swap in an A4 on an M6?
  70. C6 tpms
  71. C6 brake cooling kits
  72. Who has replaced their own springs/shocks?
  73. Mayhem 2 cam results on C6 LS2 (2007)
  74. Help with new transmission popping out of 2nd gear
  75. fast 92 vs fast 102 lsxr ?
  76. cleaning throttle body bore/relearning throttle position
  77. Need Air Sensor Help
  78. Need help pulling Z06 engine
  79. does a c6zo6 ported intake manifold work with the LS3 motor?
  80. Brake fluid leak??
  81. tire size
  82. C6 MSD wire/ NGK tr6 issue?!
  83. Loss of power all of the sudden...no codes.
  84. Winter Projet Plans
  85. S. Fla - Top Speed 1-Mile Run 10-10-10 Collier Airport $150
  86. September 2010 C6 Specials @ GM Parts House
  87. Z06/GS/ZR1 Conversions Available @ GM Parts House
  88. Hawk Pads Available (Lowest Price Guarantee) @ GM Parts House
  89. FOB related to Battery drain?
  90. A fix for the Vararam!! Well, it at least works for me!
  91. How much difference in weight? 1lt/2lt/3lt/4lt
  92. Relacement End Links for C6
  93. Painting center Console, need assistance..
  94. Painting center Console, need assistance..
  95. 05 Z51 rear end
  96. New Sway Bars after wider tires
  97. Mile of the Vette??? Concern!
  98. Not sure about a ram-air mod...
  99. Halltech C6 Venom II
  100. Can't seem to win
  101. How much hp/tq can the '10 GS stock A6 handle? E-force being installed.
  102. Dyno tune a c6 z06
  103. New GS break-in
  104. Brake switch circuit
  105. battery life on C6
  106. Intermittent starting problems, 44k 05 C6
  107. **RSD Bolt In NHRA Legal Roll Bar**
  108. Casper's Hi Lo fan controller
  109. Bar pics please
  110. Finaly got the evilone home!
  111. Finally dipped into the 11's :)
  112. help fast ( fob problem
  113. 402 ls2 stroker questions
  114. Changes to Fan Settings
  115. Corvette Summer Tuning Results at Carlisle August 26th - 29th
  116. HUD Projector Blocked
  117. timing chain cover problem
  118. Will C5 headers work on a c6?
  119. Which Rotors to Get for 2008 C6?
  120. 05 Diff drain plug difficulty
  121. Difficulty downshifting!!! Help!!!
  122. Blowout sale on Innovate LC1 Wideband & DB Gauge Kit!!
  123. Interchangeability c5/c6 rear wheel liners????
  124. Heads for my 2008 Cam Only LS3
  125. Z06 fuel pump in 6.0-liter coupe?
  126. E-Force almost installed...rear tire replacement question - 2010 GS A6
  127. Need help with lifter/valvetrain diagnostic
  128. Halltech's Carbon Z07W Hood-Need help
  129. >>50 RWHP Gain with exhaust and mild cam pacakge from LG Motorsports<<
  130. Sway Bar Kits Available - GM, Eibach & Hotchkis! - www.PartsTaxi.com
  131. Big Brake Kits - GM, Baer, Brembo, Wilwood! - www.PartsTaxi.com
  132. Hawk Brake Pads - now available from www.PartsTaxi.com
  133. Differences between stock C6 and Z06 Shifters?
  134. List of gm pid codes & values ?
  135. September 2010 C6 Specials - Tons of New Product! - www.PartsTaxi.com
  136. ramps/jacks for changing oil/filter etc
  137. Air Intake
  138. My Vette Hates me (or my installer does :( ) need major help!
  139. Tck from Left Bank after dyno runs.
  140. Got Corvettes? It's Just Carlisle, PA.
  141. Steering column making popping sound
  142. Proper Header Advice
  143. Flowmaster or custom Magnaflows
  144. Correct Oil Pressure at Idle
  145. cruise control
  146. Draining fuel tank(s) - How do I force the tanks to crossover?
  147. Draining fuel tank - How do I force the tanks to crossover?
  148. •► ► IN STOCK! - AMERICAN RACING HEADERS - ON SALE @ CoW ◄ ◄•
  149. Mast Motorsports Fully Ported Custom Cast CNC Intake Manifolds
  150. Seatbelt Light Will Not Go Out?
  151. •► ► Chuck CoW -After CARLISLE -A6 REAR END STIMULUS -A6 ATTACK PACKAGE ◄ ◄•
  152. Labor Day Sale on Precision Race Components (PRC) Heads
  153. Steering column lock recall?
  154. DIC reboot
  155. Corvette Story too Good To Be True ……..BUT IS TRUE !
  156. 2010 Grandsport acceleration problem
  157. •► ► THANK YOU CORVETTE FORUM and CORVETTES @ CARLISLE!!! ◄ ◄•
  158. Throttle body cleaning?
  159. PORTED Fast102 Intakes @ Ragin Racin $999 Shipped
  160. Mast Motorsports LS3/LS7 CNC Ported Cylinder Head Lower Pricing!
  161. How Much Tire Does One Need?
  162. Z06 Wheel Help
  163. c6 wiring information
  164. HPS CNC PORTED Throttle Bodys..
  165. Hps cnc ported heads..
  166. Water Leak
  167. Transmission fluid lines touching my AR headers?
  168. EBC RedStuff, Akebono Street Perf or Hawk Ceramic Pads?
  169. Exhaust question
  170. Professional installs/tunes
  171. Typical LS2 Cam Upgrade
  172. A New LS3 A6 Trans - Does it Actually "Learn"??
  173. Katech Valve cover installation
  174. replacing rear side marker
  175. Passenger Power seat
  176. members with 10 grand sport vert, please read
  177. 4 - wheel alignment questions
  178. What is it for?
  179. squirrely rear end when accelerating...
  180. ??? - 08 radio/console bezel removal - how-to - ???
  181. Pulled battery now car won't start!!!
  182. Is the DRIVERS DOOR MODULE in a C6 the same as C5
  183. What will it take to get my LS3 A6 below 10?
  184. 408 ls7
  185. Header question.
  186. Broke Plenum tap installing NPP & dual mode exhaust
  187. check engine light, help
  188. LS-7 and 90 Octane?
  189. Fuel level sender wiring terminals
  190. What's New @ Precision Race Components!! New Cathedral, LS3, LS7 & Specials!!
  191. Front Splitter on Base Coupe - Z06 vs. ZR1
  192. brief gear grinds when speed shifting at high rpm?
  193. What tire size should I have up front with 345/30/19 rears?
  194. RPM Transmission Daleville Indiana
  195. Which vendor/sponsor is selling
  196. Very disappointed with Diablosport and wrong info from their website
  197. Creaking noise from under or behind the passenger side seat
  198. Mast Motorsports now has 14 different fully ported CNC Cylinder Heads
  199. OEM Plugs? What model & best price?
  200. A6 with 3.15 gear
  201. Comp mode issues
  202. High Pressure Coolant Caps
  203. Tool to disconnect A6 trans oil cooler line
  204. A6 Tune
  205. Remote Starter Button, Compression Test
  206. Removing Navi Antenna
  207. 2010 gs tire size
  208. Calling CHUCK COW!!! Eureka Springs OCTOBER
  209. Just flooded the parking lot with coolant...
  210. Replacing base C6 shocks with Z06
  211. ?Compare MGW shifter to New Hurst Shifter?
  212. Rewiring interior lights
  213. Caliper Paint - G2 or DupliColor
  214. Blew a tranny cooler line. Did I damage anything?
  215. click noise in rear end
  216. A6 60' trouble
  217. C6 Coolant Fan Temps
  218. Help on installing HUD
  219. billy boat exhaust info
  220. Anybody know for sure? Oil filter #'s
  221. Preperation for Supercharger
  222. What brake pads will fit the 2011 Grandsport?
  223. A&A Vortech Superchargers!-$6599 INSTALLED!
  224. HP tuners has gone bananas
  225. •► ► EDELBROCK E-FORCE - on display @ CARLISLE ◄ ◄•
  226. MGW shifter question
  227. >>> St Jude Auction # 57 New C6 Armrest/console cover (Titanium)
  228. sprint car racer in worlds unknown
  229. Place to speed on long island
  230. fast 92 vs fast 102 lsxr
  231. cooper
  232. Corvette overheating on 75 degree trip to Carlisle today
  233. Hey guys got Q about trans/rearend in 05
  234. New mods and some thank you's.
  235. Texas Speed Twin Turbo Corvette - 1040 HP!!!
  236. Programming C6 Z06 Key Fob
  237. dome/courtesy lights do not go off
  238. Borla, Billy Boat, Corsa, SLP, etc Exhaust Systems
  239. No/Low Oil Pressure
  240. 18" c5 z0 wheels on c6 z0 or z51 wide body?
  241. My car is possessed with electrical issues!
  242. X pipe question
  243. Looking to Gain 25 HP on stock 07 C6
  244. Want to install 2010 NPP on 07
  245. K&N 57 and 63 Series Intake Systems...at CCA
  246. Pictures of inside NPP muffler
  247. Rocker Arm ?
  248. Ls2 C6 Limits?!
  249. HID High beams
  250. Window Tint - Florida
