- C6 Underhood dress up bolt caps. Where can I find them.
- LS3 Single Cam Bolt Torque Value???
- Reduced Engine Power- Service Traction Control
- January 2012 C6 Corvette GM Parts Specials - www.gmpartshouse.com
- Hawk Brake Pads Available - Lowest Price Guaranteed By 10% - www.gmpartshouse.com
- GM Widebody Conversions - Also With SLP ZR1 Front Fenders - www.gmpartshouse.com
- Bad clutch or...?
- Halltech Super Bee 24 hour Sale-10% OFF
- Halltech Carbon GT2 Hood on the Halltech ULZ700 -14 lbs
- C6 convertible. New black carpet install
- 3.42 Gears
- Brake Question
- Service antilock brakes dic message
- installed lg long pro tubes but idles to fast now?
- Installing Curb Alert
- C6 REAR BLACKOUT PACKAGE 5 Piece Kit $79.99!
- A6 Transmition shifting Question
- A&A supercharge
- January 2012 C6 Performance & Aftermarket - Vararam Bilstein QA1 SLP Koni FAST McLeod
- Need a lil more advice guys, heads,e-85 and exhust???
- C6 Heads Up Display Install Kit - New Low Price & IN STOCK - www.PartsTaxi.com
- local shop for upgrades
- anyone running 10's with m6 ls2 h/c
- Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
- ABS, TC, AH lights on
- Headers free shipping and msd.. Arh, LG Motorsports
- Spark plug/Wires recommendation
- Female needs help - Shift sticks at times
- wheel weights(yes i have looked)
- RPS Billet CarbonTriple Disc clutch & steel flywheel kit for C6,Z06,ZR1 Corvette's
- FOB programming hints
- Free Shipping on ALL C6 LG Long Tube Headers @ JWM!
- Fast intake painting w/letter removal
- Electronic door handles
- Help please!
- isn't there a shift indicator in the hud unit for 2012
- Kickoff 2012 Sale! LG Motorsports World Challenge Wheels-$1299 FREE SHIPPING!
- Tire Pressures for the track
- 2005 no start few ?
- For those of you who have painted their track wheels
- ---Ceramic coated LS3/LS2 Headers--- **Group Buy**
- January 2012 C6 Specials - www.PartsTaxi.com
- B & M shifter with stock hardware?
- LS3 Dry Sump Hand Built Engines
- Upgraded heads on full bolt-on ls2?
- Ragin Racin's new LS7 Sleeper cam!
- Headers install + tune = $$$$???
- How strong and durable is the Cianci fiberglass zr1 splitter and reinforcement
- Elite engineering catch cans on sale
- Horizontal spring removal to install coilovers
- Questions on running 18in rim on rear.
- Question on 1.7 rockers
- C6 bolt on cage advice
- what is this? what does it do?
- 460rwhp CAM ONLY ls2 speedo pull
- New clutch and cruise control
- *** New promotion for 2012...Cartek line lock special ***
- Permanently removing the fobs from C6
- Can i replace just the release / throw-out bearing ?
- Home made alignment toe check tool for $20
- Houston Area Vettes
- header install
- LMB C6 Tan to black convertible top. Help me decide. PICS
- Headers installer in Saint Louis, MO
- arp head stud torque senquence?..
- Best cheap/affordable brake upgrade for track?
- is there anything i can do to make the steering faster in my 2012 coupe?
- low voltage to rd?
- 2009 Drivetrain changes???
- Dynapad VS Block-it Review
- Does all aftermarket gears whine????"4.10's
- interior part weights
- Gps
- Dual Mode Exhaust
- Electrical Issue? HELP!
- 05 corvette no dlc communication
- Special Paint?
- Car problems
- Quick Question about rear fitment
- Gas mileage
- 2011 Grand Sport Dyno numbers...questions
- battery terminals
- LG GT2 Coil over shocks
- best drag rim for z51
- Bilstein Sport Shocks for C6 Corvette
- Corvette specliast in Austin Area?
- Body Control Module (BCM) and Sticky Brake Lights
- hedders and cam or supercharger
- S. Fla PBIR 1/4? Weather Looks Great
- road dirt build up near rear wheels
- Changing oil in GS dry sump: Does it have to be level?
- Z06 exhaust on a GS
- "New & Better" Mobil1 for our Corvettes!!!
- ★★ ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! - SALE ENDS TODAY!!! ◄ ★★
- **Experienced Advice needed Re:Cam Question**
- Newbie question
- ### New Colors for the HUD ###
- Genuine C6 Corvette Accessory Christmas Special - Below Dealer Cost @ GM Parts House
- Cam Selection
- Mass Air Flow Sensor damaged by SLP Batwing?
- ATI Intercooled ProCharger + RPM Transmission
- Happy Holidays From VBP!
- best supercharger for daily drive
- G7X4 cam
- Need 2010 Grand Sport Convertable Brake & Running Lights Wiring Diagram
- RHS Pro Elite GM LS7 Cylinder Heads
- Passenger low beam out
- Help! 05 driver window not sealing after closing?
- A6 on dyno
- Strange one... spark plug wire came off.
- Buzzing sound from left of ignition button
- LS2 setup: cam, intake, exhaust thoughts
- 2012 Model Comparisons
- US Petition for smog and modified cars
- Best gear ratios for LS2/LS3 to optimize acceleration (long post)
- Cam Install Special at HorsePowerAddicts!! (Delaware)
- Brake fluid C6??
- 2009 wiper blade assembly part number?
- ls7 clutch problem
- 4 months Later
- clutch fluid dissapearing mysteriously
- Retrofit C6 with NPP servos
- Halltech Carbon Super Bee CF102/Carbon Beehive Pak
- Halltech Carbon Fiber Hive Port (GS only) Onsale through New Years!!!!!
- NOOB 101 When should I change my oil
- Full bolt on cammed ls3 with 4.10 gears or Full bolt on Procharger with 3.42
- Design Idea for my 2005 C6 seats.
- chipped clutch disc
- Raising Front end
- Where do you buy your tires?
- Speak up! New products
- 2005 Steering Column Lock Issue
- Creaking door panel... advice?
- How can I find out what type of gearbox do I have ?
- Lets talk clutch options for a juiced ls3...
- Bad Gas?? Car dies after it fires up
- Problems Continue - 05 C6 No Start
- Drag vs Mile Engine
- My Winter Mods
- If you don't have Fangs yet, now is the time! Sale ends January 2!
- Clutch issue
- New to the forum have some questions
- mystery coolant leak
- UPF44 oil filter in a C6?
- Looking to put dual mode exhaust on and need the exhaust
- Hennessey C6 Supercharged Upgrade
- •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
- noise
- ★★ ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! - WATCH THE NEW VIDEO ◄ ★★
- Lethal Racing Night Fury Cam - 495hp/455tq
- 08+ b&m shifter $189 free shipping
- Source for rubber boot at rear of alternator?
- 2005 LS2 dual mode exhaust
- 2009 Z06 Tire Options
- T-56 Manual Trans Rebuilder in Chicagoland?
- BOOSTA PUMP ISSUES Yes/NO/Maybe???
- HELP!!! Factory X-pipe removal
- Could use camera advice at track
- Could this be the real fix for brake squeal?
- Dangerous C6 Suspension?
- Clunking from rear when turning
- LS3 A6 w/EPS cam dyno results
- *** Headlights removed in just 2 hours ***
- End of Year Sale-A&A, Edelbrock, LG Motorsports, B&B, Pfadt, APR, McCleod etc....
- Can I make a factory Nav unit work in a non-Bose Vette?
- 11s bolt ons plan
- witch cam for my ls3??
- LS 3 Dry Sump Engine Cover Options?
- story of 15k invested total for 10 sec c6 need advice
- Lowering Magnetic Suspension???
- Merry Christmas everyone!!!!!
- Ram air horsepower
- Halltech GT2 DRED Hood for sale
- ++++++New Halltech Beeline™ Carbon Package++++++
- Changing filter element in Callaway Honker
- Best platform to start with?
- Coolant issues
- Big thanks to speed south in Birmingham!!!
- ★★★★> The Chuck CoW - CoW BOOSTER! COUNTDOWN CLOCK - COOL FREE DOWNLOAD <★★★★
- How to: Ls2 and zo6 mild to wild switch
- Help me build the best motor i can! lsx376?
- Any GM "Updates" available for 09 A6 Transmission?
- Battery Truths
- Broke my 08 Differential Case, What all to make a 08 Z06 Diff. work?
- Question for those that have replaced the pilot bearing.
- Pfadt Winter Holiday Sale is coming... MONDAY!
- The FINAL VIDEO of the 12 Days of Christmas - (VIDEO INSIDE)
- 2011 Grand Sport Dyno Results w/ Video
- JDP Pfadt Holiday Sale!!!
- Head swap (LS2) with Dyno results
- Merry Christmas from all of us at LG Motorsports
- Diablo Sport Predator tuner
- Happy Holiday From VBP!
- zr1 shortblock with afr ls2 heads
- DTE Vs. RPM Rear Dif
- **forum input needed**
- Great Experience With Hinson Motorsprots
- Passenger seat sensor
- Need Advice
- A6 Cam Install - Need Higher Stall?
- JUST IN>>>>Halltech Super Bee MF103, Headers and exhaust A6 dyno results
- Exhaust Question
- C6 removing seats. Disabling SIR / disconnected battery
- (Day 11) - The Twelve Days of Christmas Savings - a New Sale Everyday!!
- Another wobbly Harmonic Balancer
- Will a 2008 C6 NPP fit a 2011 C6 Grand Sport
- Need advice/suggestions re: cam or converter
- What repairs/replacements should I focus on first
- Ls2 to +/- 500whp
- run flat vs spare
- pro charge vs turbo charge kits
- This seem right
- Halltech Super Bee MF103 Super vs Halltech Killer Bee II and I
- Rear Hatch Alignment
- how do you get the air filter box off a 2012 LS-3
- Z06 sway bars and links
- Happy holidays from vbp!
- "Mini-Fuse Add a Circuit" Warning.
- removing mufflers
- Alignment equipment?
- Coolant Temperature after failure of belt tensioner
- how to get garage door opener to work?
- Headers: 1 3/4" vs. 1 7/8"
- Question regarding starting car
- I got bored...
- factory radio returns to am
- ~~~ St Jude Auction #1 Bare Essentials Racing billet catch can kit~~~
- Questions about flexplate.
- 15W-50 in a built LS2? Anyone done this?
- A6 transmission fill hole and fluid check hole
- 2009 relacement tires
- ** OVERSTOCK Sale ** Corsa 14108 2009-12 Sport Systems
- Oil filter heat shield
- Halltech Carbon ZR1 style Roof and Pillar
- Alignment
- Who manufactures the Attack Blue filter?
- Lowered my car...I have a couple of questions
- 2005 Z51 Starting Issues
- Procharger?
- Biggest size tire on stack rim
- Katech transportation special. $500 off! Get your car to Katech for less.
- Fast 102 intake on ls2 ?
