View Full Version : C6 Tech/Performance
  1. Vibration under hard acceleration ?!
  2. AGM Batterys, we'll see!
  3. ZO6 H-Pipe on A6 car
  4. Speedometer vs. GPS 10 mph off at 65 on speedo
  5. torque specs
  6. c6 vette universal turbo sts build why hasnt anyone tryed this cost or complication?!
  7. Noisy brakes
  8. New to forum and looking for advice for parts
  9. Cam swap. What's really necessary?
  10. LS3 dry sump
  11. Double Sided Tape
  12. NPP Install- Factory Vaccume or EZ-Tap Location????
  13. Help!!!! Will z06 npp exhaust fit on a regular c-6
  14. LS2/3 Fuel Rail Covers
  15. Springs/Pushrods for Spin's 224XFI/224XFI
  16. Cooler line fittings
  17. differential differences between '07 and '08 6spd?
  18. Lifter choices???
  19. Line Loc
  20. Need 2 rear tires asap...
  21. diff to trans seal??
  22. Cheeter Slicks
  23. Tire pressure??
  24. Kooks Racers Net Sell
  25. Texas mile question
  26. Stock Clutch
  27. Fast precision flow fuel injectors - discounted!!!
  28. SALE!!!: FAST 102mm Manifold - Free Shipping
  29. Bridgestone Potenza RE-11
  30. SUPER SALE***RPS Clutches***FREE Freight & FREE Remote Clutch Speeder Bleeder Kit!!!
  31. •► ► Chuck CoW Tuning In Wichita, KS ◄ ◄•
  32. F 55 Sims
  33. Hot Rod Mag Cathedral Head Test
  34. 2006 Clear Instrument Panel Lens
  35. A6 tranny differences?
  36. Thinking about EFI Tuning? Watch TV!
  37. 100% synthetic oil filter for Corvette engines [VIDEO]
  38. Free Procharger Install & Dyno Tune Special !!!
  39. Need help flycutting pistons.
  40. CG Racing Pedals - Satin Finish - GP
  41. Talent MotorSports Free Labor on THE ECS SUPERCHARGER KIT "First 3 VETTES IN LINE"
  42. Where to buy 1/4" wheel spacers?
  43. Replacing TPMS Sensor?
  44. Air Intake....LS3 OEM or Airraid
  45. Rim Fitment ?
  46. texas mile...lots of fun
  47. Traction control/active handling
  48. C6 Z51 brake replacement help
  49. Another lowering question
  50. Speedometer
  51. Engine noise when listening to AM radio C6 coupe
  52. Mopower's Texas Mile results / experience
  53. C6 Corvette American Racing Headers on Sale at CCA
  54. Why I bought the Harrop Intake
  55. targa rear storage make alot of noise
  56. Killer Bee II on LS3s
  57. Help plz: How do you remove right rear cargo compartment lid?
  58. New Personal Best
  59. NXT Step Performance C6 exhaust
  60. How do you replace outer seat covers?
  61. info need on C6 painted Targa Top dates?
  62. Z51 Brake upgrade Question
  63. c6 computer problem, help
  64. Nitto Invo or Kumho ecsta ?
  65. Mr gasket 160 issues
  66. FS 2008 Convertible
  67. Need a good, cheap set of C6 tires -- brand?
  68. Clutch has me frustrated.
  69. Norris Motorsports VMax CNC 2005-2011 Throttle Bodies Available - $149 Shipped
  70. Need Help! Hot Wiring The Cooling Fan...
  71. flowmaster exhaust filler plate
  72. any regrets on going 19-20 on base c6?
  73. Blown vs. Naturally Aspirated
  74. *** FINALLY! A New HD Differential Carrier for your C5/C6 Only from ECS!!! ***
  75. RPM's Needle bouncing all over the place.
  76. Corvette Z06's Dominating Homestead Speedway 10/23/2010 with ERME
  77. Whats the difference? LPE Heavy Duty or C5R Heavy Duty timing chain.
  78. oil cooler
  79. TPS C6/ Z06 Stainless Steel Brake Lines-$89 FREE SHIPPING/ USA MADE/Lifetime Warranty
  80. stroker build
  81. 2005 C6 z51 tranny issues
  82. Katech Coil Relocation Kit - IS it a DIY?
  83. No FOB detected
  84. Main drive pully came off?
  85. Can it be done and is it safe to drain oil from the Z06 oil cooler
  86. Anyone have an EE catch can on an LS# with stock intake?
  87. 2010 C6 1st gear rubbing sound
  88. Electric clicking noise behind stereo... driving me nuts!
  89. Volt Gauge reading
  90. 2008 LS3 topside removal?
  91. Michelin Pilot Sport AS Plus - Inflation Spec?
  92. Changed the tires
  93. Crap!
  94. 224XFI/224XFI 115 +0 or +2 for A6
  95. Corvetteforum on facebook
  96. Electric pass seat wiring diagram?
  97. Tire Sidewall Aspect Ratio question, is 40 OK?
  98. I need a good repair shop in s. Florida to change my clutch on my c6
  99. Champion Motors Newest Addition
  100. Sometimes GM really disappoints me - service call
  101. Starting over
  102. Steering Intermediate Shaft U-Joint (Rag Joint) Busted
  103. Will LS7 aircleaner assembly bolt right on an LS3?
  104. What is next for my LS2?
  105. [PIC] How do I remove this disk off the steering column?
  106. LS3 / LS2 injectors
  107. another set f Daytona seats and steering wheel for a Z06
  108. Anyone install MadMat ?
  109. Front end broke?
  110. Kooks Long Tubes....02 extension wires?
  111. Wheels for my 2010 GS
  112. C6 Z front wheels and tires on standard C6?
  113. Help!!!!!!!
  114. mgw shifter
  115. What is GM going to announce at SEMA? Stop by and Find out!
  116. Katech LS9x flywheel weighs ~12.5lbs
  117. SS Brake Lines causing ABS/AHS/TC Problems
  118. Pass door window doesn't work ????? Pls help.
  119. Race Proven Motorsports Twin Turbo 4L80E C6Z06
  120. Think an LS3/LS7 CAI will help performance? Umm...not so much (track results inside)
  121. Wheel Offset ?
  122. My PB 1/8 mile time base model 2008 A6 with 2.56 gears
  123. Strange electrical behavior...
  124. Frustrating Tire Moments
  125. DIFF removal and replace DIY? Also can i do it without lift?
  126. Heads up ..... Production ending this week on "Tall" Billet Valve.
  127. Dexron ls gear oil
  128. 2009 C6 Maximum wheel & tire sizes?
  129. QUICK! How do I remove the steering column cover?
  130. will prestone flush and fill kit work 06 vette?
  131. Cam choice? How do i look...?
  132. Installing Bilstein shocks
  133. 2005 z51 hard to downshift when hot
  134. SAH, Service ABS, STC fixed
  135. How hard is it to add NPP dual mode exhaust
  136. Seat Recall Gremlin
  137. Another set of Caravaggio Daytona seats
  138. Exhaust question
  139. Rear Swaybar Getting Loud
  140. 2005 sqeeking breaks
  141. 217deg ECT normal on cool days? (at idle)
  142. 2005 C6 Personal Options Menu says options unavailable
  143. Possible to bend output shaft if rear diff only cracked and didnt explode?
  144. Installing Headers
  145. ***2011 GM Comp Grey Grand Sport Wheels In Stock Lowest Prices On the Forum***
  146. Sway bars
  147. NEW! Proform LS Valve Spring Compressor Tool
  148. 305/30/19 Tire Fitment?
  149. Which AC Delco Oil Filter?
  150. Need Advice -- Transmission Issue?
  151. SEMA is around the corner...if you're going stop in
  152. 2010 to 2005 radio install
  153. LS2 Crank & Rods, how strong?
  154. Muffler baffle noise
  155. cam gear specific to LS 2 motor??? Help!
  156. C6 Headlight Wiring Harness Question?
  157. Wider rims for drag racing?
  158. catch can question
  159. Who revs their motor up to 7,000 rpms ???
  160. Need To Raise Front on 2005
  161. Please put a clearly stated base issue in thread title
  162. which would you do?
  163. rpm limit of stock rods and crank
  164. Loud POP when I press the start button!
  165. Maggies TVS2300 vs H122
  166. Recommended C6 LS3 exhaust kits?
  167. Long Term Reliability Question??
  168. C6 weekend mod pics-
  169. Z06 Brake Upgrade
  170. Threaded shifter question
  171. Gear Question
  172. Question on Drag wheels...
  173. Buying tires this week.Need alaignment specs
  174. Magnaflow exhaust or stock with cutouts??
  175. Magnaflow exhaust or stock with cutouts??
  176. 325/40/18 M&H Drag radial fit C6
  177. what size nt05 R tires on Z06
  178. C6 with Z-51 Wheel Question
  179. Fitting Z06 Brakes on a Base C6
  180. What would you do? Clutch or Extended warranty?
  181. P0171 Lean Code just Popped Up
  182. 05 cracked rear case
  183. F'in lowering bolts
  184. vararam install question
  185. coolant loss
  186. C6 LG Motorsport Long Tube Headers- From JWM
  187. New exhaust for my vert
  188. Two #1 FOBs
  189. Service Active Handling?!
  190. The Original "LETHALZ" puts down 968rwhp/814rwtq - *Vid-Graph* Inside
  191. Qualification entry for catastrophic carnage contest
  192. Z06 Exhaust Manifold Question
  193. Dewitts Radiator Installation
  194. Timing cover seal replacment
  195. wilwood 6 piston calipers sticking
  196. Has the Vette line out grown the transaxle?
  197. Any way to make 05 rear stronger externally?
  198. Hard starting
  199. correct idle
  200. DIC buttons (light)
  201. Air bag lite!!!!!
  202. What dish will get compression ratio?
  203. Running LQ9 408 with L92 stage 2 P&P heads. intake ?
  204. BLOCKIT Sound Deadener / Simple behind seat (under carpet) instructions - Cool
  205. 08 Z51 Specs?
  206. Where can i buy c6 shifter pivot cup ???
  207. Where can i buy c6 shifter pivot cup ???
  208. No lock or unlock from FOB buttons?
  209. Blew the rear in my 05 today, what are my options?
  210. convertible top creaking
  211. Recommend a Speed Shop in Phoenix
  212. A&A Corvette's Newest Design Supercharger Kits Available NOW!!
  213. Replaced A/C compressor, expansion valve, and filter dryer
  214. nav. screen stuck on night mode
  215. Car Covers for for Vettes with Wings
  216. >>20% Off ForgeLine orders with LG Motorsports through 10-25-10<<
  217. HELP C6Z06 Tail Lights/Fog lights dont work
  218. Help may have blown my new engine.
  219. VetteNet Super Sale from CCA
  220. • • > CHUCK CoW TUNING in VEGAS week of SEMA < • •
  221. C6 Noob Questions
  222. Torque convertor and power transfer to rear transaxle????
  223. Bad rcdlr ?
  224. Speedometer off w/ new tire size HELP !!!
  225. Exhausts & Cutouts On Sale @ MarylandSpeed! (Borla, Corsa, B&B, Magnaflow, etc)
  226. LG pro headers VS LG street headers
  227. How would this cam drive? What increase in hp guess?
  228. Which SPeed Bleeders should i get?
  229. CAI / leaner fuel trims/K.S.
  230. Can I get just a midpipe?
  231. door lock
  232. Transmission Failure - Fixed Now but High Revs
  233. Which way am I going?
  234. 1 7/8" Header and full 3" exhaust on A6 automatic?
  235. c6 coolant flush
  236. Hop
  237. CF center console install
  238. Coming November: The Johnny O'Connell Signature suspension line
  239. Roller Rocker weight
  240. Can the reverse lock/shutdown be bypassed
  241. Carbotech Performance Brakes
  242. New products from Trick Flow
  243. Suggestions on tracking possible coolant leak
  244. CORVETTE magazine Coilover vs. Leaf Spring Article
  245. Is the LS2 throttle body the same as the LS3 TB?
  246. Supercharger vs Compression
  247. Forged/Cast Pistons - Good Read
  248. Hot wire lead
  249. HELP. Window motor removal & replacement???
  250. LS9zr6 Clutch System-The most Complete High Performance C6 Clutch Package Available!!
