View Full Version : C6 Tech/Performance
  1. Late Model Racecraft's 09 C6Z Slayer 630hp Dyno and Idle Vids!!
  2. best clutch fluid to use?
  3. Strange clicking coming from dash + some other issues
  4. What is the best Muffer/Exhaust for my 08 C6?
  5. Late Model Racecrafts Warhawk 440ci C6Z Vids and Pics!!!
  6. Aftermarket LCA ?
  7. ? how hard is it to change output shafts?
  8. Quarter Mile times
  9. 500 rwhp?
  10. What did it take for you A6 guys to run 11.5's or better with stock internals?
  11. Can someone confirm oil pressure numbers???
  12. 2005 auto trans brake release question please
  13. How I fix brake squeal?
  14. HVAC codes B0184, B0189 and B2646
  15. What size is differential drain plug?
  16. Guys what tire pressure
  17. Oil in intake manifold
  18. c6 Z51 TRANNY FLUID REPLACEMENT: WHAT AND HOW???
  19. LS7 cam on an LS3 engine?
  20. CMS Phase 3 LS3/7 Pricing
  21. what intake?
  22. Will these fit?
  23. Blank Z51 Rotor
  24. LS3 intake vacuum connector questions
  25. state inspection
  26. Upgrading an '08
  27. CMS Phase 3 package results
  28. Brake pad suggestions?
  29. What all do you do to prepare for the drag strip?
  30. c6 z51: setting up for track days
  31. Which Intake System Mod?
  32. driver door will not open
  33. A6 Stuck In 3rd Gear - 07-07-30-006A
  34. Group Buy Wide Body Rear Quarter Kit www.PartsTaxi.com
  35. 19170234 C6 Splash Guards $91.88 www.PartsTaxi.com
  36. Spring stop/lowering bolt suggestions?
  37. Bummed out....
  38. Rust inside wheels
  39. LS3 Air Filter
  40. Rear Rotor Removal
  41. How often should I clean my Vararam?
  42. *** Cam Install Special from LG Motorsports ***
  43. help w tire choice/size
  44. rear Z51 caliper X rear base caliper
  45. Need help putting a transcooler together for my Voreched A6 line size etc..
  46. Recommendations for operating temps on engine & trans what tstat?
  47. low fuel pressure...
  48. Question about bleeding the brakes
  49. Are the C6 and Z06 cradles interchangeable??
  50. C6 will not shift
  51. Heads/Cam/Intake or Supercharger
  52. tires
  53. Temporary low voltage
  54. Do LS3s take a special thermostat?
  55. C6 Trans Vent
  56. launch control
  57. Service active handling
  58. Nav sucks! Why?
  59. can i fix the zo6 K&N in my ls3
  60. Lg Super Pro 1 7/8 headers
  61. Air Filter instalation tips
  62. kooks vs lg headers .....????
  63. Thinking of moving to a stroker block
  64. Modded Ls2 - Peak HP guess
  65. Mild@Wild Question
  66. LS2 LS3 Brake Differences?
  67. Best place for a tune in FL. on my '08 A6
  68. Bullets drone issue
  69. how long would this last?
  70. Clicking from left rear
  71. C6 Tire Size Upgrade?
  72. Cracked headlamps ??
  73. Cow tune
  74. Exhaust question
  75. What ported oil pump on an LS2?
  76. FAST 90 w/ Vararam spacer need help?
  77. Need Torque spec
  78. Race Seat Options/ Complications?
  79. Comparison of Z06/Bilstein shocks
  80. Spec Twin Disk?
  81. AMSoil questions and fluid capacities
  82. Need some quick guidance
  83. How to get a reliable 700-750rwhp on ls3?
  84. Lockpick 360 and Window Valet
  85. LS1 vs LS2 Alternators? Differences.
  86. 345 mickey thompson ET street drag radial
  87. Loose gas tank cap
  88. speed in gears
  89. c-6 Auto Trans fluid chg
  90. Belt adjustment / replacement C6
  91. Rotor min. wear mesurment?
  92. Will a C6 engine cradle fit a C5?
  93. New sway links
  94. All you exhaust vendors out there...
  95. C5 Stock Exhaust Removal Question
  96. Wheel clearance dimensions for Z06 brakes
  97. What torque on lug nuts
  98. ** 516 RWHP 402 cu from LG Motorsports **
  99. ** 605 RWHP Z06 from LGMotorsports **
  100. Quaife ATB Differential + RPM
  101. Differences in Z06 Mufflers
  102. Exhaust Question
  103. Has anyone found a online service manual?
  104. Brake pad replacement help!!!!
  105. 06 Coupe, Body Fit and Door Rattle - Pls Help
  106. Thanks again Ranger !
  107. where to find 18" rims??
  108. air bag reseting
  109. Emissions testing
  110. Opinions on the TrickFlow 550hp LS2 Kit?
  111. Track performance of Goodyear EMT's
  112. LS2 vs. LS3 Engines--Resale differences?
  113. Front rotors seized on....any suggestions?
  114. New Rattle After Sway Bar Install?
  115. some Q's about my tune...HELP!
  116. HELP-Brake Pipe Connector Stripped
  117. ~~~~ St Jude Auction #34 mail order tune for C5 / C6 from Chuck Cow ~~~~
  118. Help needed with a C6 - AUTO
  119. front bumper, fenders and what else...
  120. 2.5 vs 3 inch exhaust
  121. LS3 A6 w Borla Stingers - to x-pipe or not to x-pipe?
  122. Automatic Transmission Fluid DEXRON-VI in A6 Experiences ?
  123. 2005 Battery Replacement Question
  124. Supercharger costs???
  125. Homelink on 2009 C6
  126. Employee pricing is back for a limited time!
  127. 08-09 Carbon Center Console & SuperDeluxe Carbon SW new shipment just arrived *PIC*
  128. WTF!!! The 3rd an 4th gears are going out.
  129. Strictly Corvette Special: ZR1 Splitter, Side Skirt & Spoiler for C6 *PIC*
  130. Paint code
  131. Braciole 11.63 @123.18 VIDEO!!!
  132. SwayBar Install in Houston??
  133. Change a 6 speed to an Auto?
  134. ill-fated road trip
  135. What size cam should i go with on an ls3
  136. Need help with my diablo predator!
  137. O2 Sensors - Check Engine Light on new SLP Exhaust
  138. Rear tire size for a 20 rim
  139. LS2 recommendation
  140. FAST intake install
  141. Easy Question
  142. 100 Octane pump gas
  143. Holiday Weekend Specials www.PartsTaxi.com
  144. Engine noise help!!
  145. How do I relplace turn signal flasher?
  146. What are the next steps for more HP?
  147. Corsa Sports + long tubes
  148. Re-align after suspension adjustments??
  149. ****Poly Bushing Replacement Service****
  150. Can I use same Shocks for C5 and C6
  151. Chuck CoW What's your schedule for the next few months?
  152. Windshield fogs during 1/4 mile runs
  153. Fittings for transmission to run external trans cooler?
  154. Roll Cage for C6 convert Help
  155. **New Best 10.844@125.83mph**
  156. Z06 oil cooler and temps
  157. It's ALIVE and running: Dyno # inside
  158. drag strip times
  159. Maybe i'm crazy but... (head/cam guys step inside!)
  160. Threw a evac code
  161. C-6 Tire recommendations
  162. OnStar vehicle slow down disable
  163. Thanks CARTEK!!! Braciole another new best!!
  164. Please help, traction dilema!!!
  165. Grounds?
  166. Exhaust Question-Please Help
  167. Brake life?
  168. TPMS pressure canister - Why WON'T this work?
  169. Service active handling system
  170. Need tips on removing the spring from clutch pedal
  171. What's your favortie clutch fluid?
  172. What are the best replacement rotors for non z51 C6's
  173. Group Buy Z06 Front & Rear Brake Upgrade Kit
  174. Anyone install a gm hot cam in their ls3 yet??
  175. Group Buy ZR1 Front Body Conversion www.PartsTaxi.com
  176. adding z06 manifolds, cats, hpipe...worth it to upgrade the catback, too?
  177. 2009 Blade Silver Callaway Corvette
  178. Heads for a C6 coupe
  179. Navigation unit install ?
  180. Gainsville Dragstrip TONIGHT!!!
  181. Direct injection??.....Be careful what you wish for...>
  182. Should the converter be set to lock in 4th at w.o.t.?
  183. Halltech Killer Bee PCV Fix for the LS3
  184. 600 RWHP Am I on the Right Track?
  185. cryo treatment of aftermarket diff gears
  186. St Pete GP incar video ALMS GT2 inside
  187. Hey guys, new to the forum, quick question
  188. '08+ manual trans and first gear
  189. Problems with Ram Dual Plate Clutch&release bearing
  190. tire Q
  191. Running Nitrous Line???
  192. Best Way to INCREASE Burble & Pop?
  193. C6 Rear End Problems
  194. How much they can handle? LS3
  195. Stock wheels???
  196. Another successful Corsa Xtreme install
  197. Superchargers roots vs. vortec?
  198. Upgrading brakes.. Z06 or better...
  199. Changing clutch fluid on a C6
  200. Lt1 2008 help
  201. Drag Radials on 18" stock wheel?
  202. Oil and Tranny Temps
  203. tips on removing valve springs on LS2
  204. Will a differential from a 07 Z06 fit in a regular C6 with an A6 transmission?
  205. HUD questions, info
  206. Alignment Question
  207. Z06 exhaust to a non z06 car?
  208. 600+ RWHP from LS2
  209. Stock LS3: Idle and Off idle bucking
  210. Power Bleeder / ABS
  211. LSXR™ Composite 102mm Intake Manifold-LS7/LS3/L92
  212. Need Battery Help
  213. Speedbleeders....
  214. Can Drilled Rotors be Turned?
  215. Wheel weight
  216. >>> St Jude Auction # 33 C6 Corvette Z06/ZR1 Front License Plate Brackets <<<
  217. Third Brake Light & Back-up Lamps Don't Work
  218. CDSP Alignment
  219. SPACERMONSTER: Running spacers on the rear wheels...
  220. Video of Dennis50nj's 10.62 pass / Cartek Racing brings it all together!
  221. How much & where to get wheels widened?
  222. c-6 lug nuts
  223. 2005 C6 rear hatch won't hold in open position.
  224. Question Regarding Z51 Rear Toe-Links
  225. Service Traction / Reduced Power Issue
  226. Anybody run 4.10's with 6 speed? Opinions
  227. reinstalling the factory tune before bringing it in for service....
  228. Cam = Ordered, Any good writeups?
  229. LS3 Dyno Result
  230. Does a LS3 + Vette Air + Killer Bee + Bee Hive = Surging ???
  231. Where to start
  232. Call me a sissy-man, but...
  233. Throttle
  234. DFW 1/4 mile Drag Strip ?
  235. Audio question? This is strange
  236. Roller rockers vs. Cam
  237. I dont like the new "quiet" intake manifold on my ls3
  238. Belt - nope, Idler - nope, Balancer - nope
  239. Emissions inspection
  240. Any power increase with GM Performance Exhaust (Borla Touring)?
  241. traction ABS handling system problem
  242. Clutch fluid not as dirty this time
  243. 0w-30 weight mobil one
  244. What floor jack to buy?
  245. Hp Tuners question.
  246. Programming Mode
  247. Spinfast-Re-install
  248. Boost and fuel pressure gauges
  249. Traction control service
  250. VIR NASA May 29, 2009 Movie
