View Full Version : C6 Tech/Performance
  1. >>>FAST 102's On Sale! Super Low Pricing!
  2. Fuel injectors LS3
  3. 305 35 18 MT or 315 30 18 MT
  4. change fog lamps on grandsport
  5. Differential output shaft seal
  6. Super Chips Tuner LS-1
  7. tuner needed close by...
  8. Moving wheels out of wheel wells -- maximum?
  9. Ls3 oil capacity?
  10. Possible to Eject CD's after removal???
  11. Need help with Identifying tranny!
  12. need new tires on c6. Your thoughts
  13. Do C6 Z and GS share the same shocks?
  14. 2005 C6 Clutch question
  15. How soon does the Hydraulic Clutch Fluid turn dark?
  16. Vehicle speed sensor on an A6
  17. led lights help 2011 grand sport
  18. 2006 power top dilema
  19. Headlights Inexplicably Turning On
  20. Headers and '07 A6
  21. C6 Bolt in Roll Bar
  22. Wheel pitting
  23. HUD Install questions
  24. New rims for c6, will 18x12 fit on the rear?
  25. rear tires on 19 "rims
  26. How to 2005 c6 exhaust dual mode
  27. C6 - 2005 Key Fob - Not Working - Help Please
  28. BRAND NEW C6 HUD Display-$649.99 Installed
  29. NPP question
  30. Borla or Corsa exhaust? Which one is better?
  31. Top speed C6
  32. 17" wheels on Z51??
  33. Finally made it to the strip yesterday
  34. 1/4'' wheels spacers
  35. Bolt in C6 Roll Cages??
  36. F55 question
  37. Popping sound rear of 2008 coupe
  38. Is there a problem with my car? (video)
  39. Vehicle shudders when decelerating from 60 mph
  40. LS7 swap
  41. rim/tire question
  42. Cags
  43. Borla Stinger Install
  44. Numbers from new cam (LS2 M6)
  45. Underdrive pulley
  46. Torque cut module for faceplated and other dog engagement type MT gear sets
  47. Any pic's of aC6 W/CCW SP510
  48. Has anyone - B&B Fusion NPP Muffler MOD??
  49. **Late Model Racecraft RHS 427 and F1R Initial Start Up**
  50. Results from 1.8 yella terra rockers
  51. ported fast 102 dyno results...
  52. 2010 Grand Sport Supercharger Video
  53. 05 mods
  54. Removing Fuel line
  55. A/C question
  56. fusion question
  57. A&A Vortech Superchargers!-$6599.99 INSTALLED!
  58. what meth kit for h/c/i c6?
  59. LG Motorsports Long Tube Headers-$1999 Installed & Tuned!
  60. Grand Sport X-Pipe Diameter Size?
  61. LS3 shift point?
  62. Service abs light on after pothole
  63. Low Oil pressure indicator
  64. Hit pothole now service abs light is on.
  65. one other issue with this 2008 coupe...window.
  66. Remove 2008 Z06 battery
  67. NPP on 2008 seems to be disabled...how?
  68. Easy to change fog light covers?
  69. DBA Rotor Durability/Cracking
  70. Check Engine Light AGAIN!!!!
  71. Throttle body and Intake manifold
  72. Speedometer hookup
  73. Paddle shifter F1-mod DIY?
  74. Need assistance asap....
  75. E-Brake Question
  76. 2005 belt routing problem
  77. H/C/I C6 LS2 dyno #'s
  78. Cut your Brake Dust, keep your performance Bobcat 1521
  79. display gear position on the DIC
  80. $10 OFF - Add NPP (bi-mode) exhaust to any C6 with "NPP in a Box"
  81. Engine harness question
  82. Gas pumping advice
  83. Oil Pressure - Question
  84. Octane boost
  85. Convertible snaps
  86. HP Tuners in C-Springs?
  87. ls2 q's
  88. skinnies???
  89. LS3 Predator tune
  90. 2011 GS w/ F55 lowering question
  91. ** BCP Inventory Closeout ** C6 Polished Billet Valve Covers are On Special @ $565
  92. Billy Boat Exhaust Spring Sale! Full Kits & Cat-Backs **HUGE SAVINGS OF LIST!!**
  93. Pfadt Racing announces release of Featherlite Double Adjustable Coilovers
  94. eng oil
  95. More Spring Specials from DTE
  96. Reviews of LG Short Shifter
  97. Odd discovery changing oil first time
  98. Dyno #'s for LS3 with headers then Z06 exhaust
  99. My 1st Vette! - Need some advice
  100. Complete 08 Z06 Exhaust on 08 A6 Coupe?
  101. 20% UD pulley and hi flow oil pump on cam install
  102. Should i leave my factory tunnel plate in place?
  103. Installing Cam; Rockers Yes or No
  104. Cam only LS2 goes 11.24 at 123mph
  105. LS2 Assembled Heads Part #
  106. what's the combination to remove these battery terminals?
  107. ** First Mods..opinions ? **
  108. Dealerships and wool
  109. gas smell in garage
  110. '08 A6 Torque Mngmt Upgrade GM Software
  111. Stock 2010 Grand Sport Dyno
  112. 383ci makes 537rwhp with a TR stroker cam-
  113. Wheel Problem
  114. *NEW* RR-Stage 1 Twin In-Tank Fuel Pumps
  115. blown engind and transmission
  116. Interior lights not working
  117. Mystery part found in engine bay. Where does it go? What is it?
  118. Air in the steering rack?
  119. injector help needed..
  120. Which fob frequency to buy???
  121. Please help me decide between these two mods
  122. Third Brake Light
  123. Got a P1153 code last night (suggestions)?
  124. Brake Pads
  125. 07 Vette max horsepower rating for stock clutch???
  126. Oil cooling vrs Coolant cooling
  127. B&M shifter
  128. 2010 & muth signal mirrors don't MIX
  129. Engine Light ? / Interior Lights
  130. Brakes hard to stop!
  131. To go or not with Z16 Performance Package
  132. Chrome manifold/intake cover
  133. C6 Exhaust Systems .. Lots of Brands .. What to Choose?
  134. C6 Steering Wheel
  135. Driving on a a Flat "run flat"... Damaged?
  136. Question on what brake rotors
  137. New Battery
  138. removing the panel below the steering column
  139. Ls2 Valve Spring Specs
  140. dyno numbers!
  141. Need some insight on GS header install...
  142. Sticking on 4th
  143. 4.10 Gear Upgrade - Best Mod to Date
  144. Should I do the TFS heads?
  145. Daily Driver LS3 Cam
  146. Auto torque tube noise
  147. 2008 with 44k miles
  148. Non oxygenated fuel for Corvette LS3 engine
  149. Po171 PO174 Why?
  150. HELP got tune now timing belt SHRED
  151. New lifters with cam?
  152. Please Help - 2006 A6 Transmission Stuck in Drive or Neutral
  153. Clutch(es) To Handle 700+ RWHP??
  154. Key Fob battery change issue
  155. Cam change necessities
  156. NPP Exhaust Conversion
  157. Amsoil Dominator Coolant Boost & P.i. Performance Improver Gasoline Additive
  158. A6 Transmission Service
  159. Header Coating
  160. Window Regulator Replacement Help
  161. How do I remove steering column cover
  162. Aerogard polyurethane Protective Film - Thinking about it
  163. Gas smell
  164. Inside Auto Dimming mirror ???
  165. C6-Zo6 COMPLETE! 660RWHP - 605RWTQ N/A
  166. 2 or 4 post lift???
  167. LG Superpro's Install Question
  168. Installed Vararam Tonight
  169. C6 LS3 Z06 Exhaust upgrade question
  170. Torque Specs
  171. Can I use a C6 radio in an older vette?
  172. Best Slave Cylinder
  173. Driving without air intake ?
  174. Torque Management Software 2008 A6
  175. New LS9R Clutch kits finally available
  176. Lend a hand?
  177. Crank pully wobble
  178. Shakes and vibration on cold start
  179. Header Brand Choice
  180. New 07 LS2 A6 E Force Plus Plus install !!
  181. Hatch Area Buld Numbers?
  182. Adding ZR1 cam, couple questions?
  183. •► ► INCREDIBLE JOURNEY ACROSS THE COUNTRY for an E-FORCE SUPERCHARGER! ◄◄•
  184. What is wrong with Removing the Hydraulic Clutch Fluid Reservoir Cap?
  185. Exhaust vacuum fuse pull question
  186. Feels like a new ride
  187. Vette Doctors begin Championship Defense
  188. stock ls3 pump plus 40 amp BAP limits? fuel gurus come inside
  189. driveshaft coupler bolts part number needed, torque tube?
  190. G Meter
  191. Shakey rearview mirror
  192. S. Fla PBIR TnT 3-11...last cold front of the year???
  193. 2005 Bi-mode retrofit
  194. Ls2 valves
  195. Follow along as Vengeance Racing assembles an RHS 427!!!
  196. Rims/tires trying to plan ahead.
  197. Simple Newbie Questions
  198. Losing alignment?
  199. SLP Loudmouth II Just Sick
  200. Hydraulic Clutch Adjustments???
  201. I challenge you to a PIC OFF
  202. Alot of new guys here
  203. What is the best Battery for the Dollar and Durability?
  204. Starting the Engine while still connected to the Battery Tender
  205. no fobs detected
  206. Any Supercharged 402s out there?
  207. LS2 guy looking for Spin's advice on a cam
  208. Service Light ?
  209. Check coolant level notice in traffic
  210. Air Filters for 2005-2007 C6
  211. ? About lowering
  212. deal on OBD-II reader w/ CAN
  213. Sway Bar Insulators for Z51 Coupe
  214. ZR1 hubs part number needed
  215. auto to manual
  216. got some 1000ft. times!!!
  217. Gmpartshouse.com
  218. How Much Boost Can a Stock LS2 can handle?
  219. Car squeaking after lowered
  220. Engine Cuts Out on 2009 Coupe
  221. FS: 2010 Grand Sport Suspension parts
  222. '08 and '09 Skid Plates Interchange?
  223. LS2 vs. LS3
  224. Fast Advanced Race Control & Self Tuning XFI 2.0
  225. All 2008+ C6's are TR6060: different output shaft?
  226. wheel offset question
  227. clutch fluid cap part number
  228. Header Comparisons
  229. Brake pads...what to buy
  230. Underhood Light Help
  231. Has anyone reflashed for 3.90 gears on 06?
  232. Air Bag Sensor Connections Help?
  233. procharger with 11.8:1 cr
  234. Need GM part number
  235. CANNOT Remove Manifold - Please help
  236. Headers rubbing frame
  237. stock ls2 springs
  238. new personal best 1/8th mile 7.67 at 94.37 mph
  239. Pfadt Featherlight Coil Over Install
  240. Parking Brake Adjustment
  241. Z51 sways on C6 F55 supercharged widebody/ Should I
  242. Z51 Question
  243. Cut outs,performance, engine damage?
  244. March 2011 C6 Corvette Specials @ GM Parts House
  245. 2011 C6 Corvette Service Manuals Available @ GM Parts House
  246. Hawk Brake Pads - Lowest Price Guaranteed By 10% @ GM Parts House
  247. bb prt
  248. Looking for quiet HP
  249. Convertible top motor burn-out
  250. 1300rwhp C6
