View Full Version : C6 Tech/Performance
  1. Efficient, Clean, Light and Cheap Transmission Cooler install.
  2. Eliminate that pesky annoying skip shift!
  3. Who makes a 725HP super charger kit?
  4. C6Z Howling noise
  5. Flowmaster American Thunder exhaust
  6. Flowmaster
  7. 2012 GS Coupe 2,000 miles, auto
  8. Z06 Wheel Question
  9. Z06 Track Conversion - My first questions
  10. Front bumper removal
  11. Thinking about reversing E-85 upgrade and going back to 91 octane
  12. Katech Track Attack 2012
  13. Can engine run lean?
  14. HELP, suspension c6
  15. Lingenfelter Gauges
  16. Speedinc
  17. best clutch for the dollar
  18. Magnetic Ride Delete?
  19. NPP - "Troubleshooting"
  20. Problem starting manual 2008. Battery and power good.
  21. TORQ Performance Engines, Now Available
  22. Front License Plate and Air Flow
  23. ABS Light Help
  24. Price match guarantee
  25. Experience with Torq (Miramar, FL)
  26. For anyone considering meth..
  27. Service Column Lock
  28. LG G6X3 Cam or Patrick G Cam????
  29. volant air intake
  30. shocks inop
  31. sway bar tightening
  32. Need assitance with darn upper control arm
  33. Clutch return spring
  34. Borla S-Type and Longtubes - anyone with this setup?
  35. Lg adjustments?????
  36. Question about Base Brake vs Z51
  37. McLeod Clutches @ Unbelievable Deals @ KY SPEED
  38. LS9 vs LS9R vs LS9X - what are the differences?
  39. C6 Brake bracket bolt size ???
  40. powerbond pulley install help
  41. Superchips Cortex ls2 a6 questions!
  42. C6 GS LS3 Upgrades?
  43. Photo shopped side skirts on my C6. What do you think?
  44. Pulling slightly to the right when accelerating
  45. Input Needed on Alignment
  46. Window operation after a dead battery
  47. 2 for one Techron at autozone
  48. feedback needed on a PowerForce harmonic damper
  49. Do you have a pic with 345/35/r19 ?
  50. feedback needed on a PowerForce harmonic damper
  51. Dual stage exhaust
  52. Halltech Carbon Fiber HivePort™ NACA duct Replacement
  53. Vette Doctors Performance New Years message
  54. Z06 air intake on LS2
  55. Best price for ATI Dampers
  56. Nick Williams 102 throttle body vs FAST Big mouth 102 throttle body
  57. how much
  58. could somebody give a newbie a lesson on cold weather and wheel hop
  59. C6 Z51 brakes
  60. **Tax Season Special on Chrome Z06 Style Wheels**
  61. Mayhem II Install at RPT
  62. Will ls7 long tube headers fit on a ls2 with ls3 heads?
  63. Diablosport tune
  64. Check Engine Light - P0442
  65. my horn and alarm lost power
  66. B0040? Any ideas what this means?
  67. Post pics of paintings or decals on top or bottom of hoods
  68. How much hp increase with headers and catted x pipe?
  69. Header and Exhaust Sizes
  70. LS2 AFR 205 Heads, LG G5x3 Cam Dyno Results
  71. Awesome Performance
  72. Small cam/hp question
  73. 500WHP NA-- OBX 1 7/8 or ARH 1 3/4?????
  74. 08 A6 won't upshift from 1st
  75. Where is my thermostat??
  76. Multiple Handling related lights going off! PLEASE HELP!!
  77. 14.6 volts too much?
  78. Johnny O'Connell and Pfadt team up for National Corvette Museum race track donation!
  79. Front hub bearing replacement...DIY?
  80. LS3 Cam-Only guys, check in...
  81. Active handling
  82. Hennessey Grandsport HPE650 Engine Upgrade
  83. LG Motorsports Super Pro Long Tube Headers-FREE SHIPPING!
  84. Mid-pipe flanges on c6 vs c6 Z06, are they the same?
  85. C4 Distributor
  86. ZO6 air intake
  87. Advantage to removing cats-ET/MPH
  88. new ride need advice
  89. 2 questions, TPS and Thermostat
  90. Body Kit
  91. DYi differential build
  92. LG Motorsports Headers @ Unbelievable Deals!!!
  93. Tsp vs kooks
  94. 100 octane fuel?
  95. help please k&n air filter kit
  96. DTE Tax Sale Blowout
  97. Daily Driver Drag radials-what works best?
  98. rear Alignment
  99. Will a converter void my warrenty?
  100. How to remove the Shift Knob on 2005 M6
  101. No TPS
  102. just bought a 2007 C6
  103. Alignment Specs Question
  104. exhaust with or without cats
  105. Jack stands
  106. Engine Damage Opinions, please help
  107. Corvette LS2 vs G8 LS2
  108. TIRES, which are BEST all around (winter)
  109. Crank pulley(damper)
  110. 2012 Speaker Upgrade (convertible)
  111. C6 convertible top install HOW-To is done. Check it out
  112. Differential Strut Brace
  113. Vararam Install, noticable difference
  114. C6 HOW-TO INSTALL a convertible top. It's easy. Pics
  115. Baer Extreme big brake kit Question.. replacing the rotors.. where do I get them?
  116. Headlight assy seal
  117. service manual on ebay
  118. 2008 A6 replaced due to stall converter?
  119. Stock wire too close to header
  120. A6 Diif Question
  121. Kooks Headers Installed Special
  122. A6 transmission upgrade
  123. Eliminate that pesky alloying skip shift!
  124. 2012 A&A Supercharger Installed Package
  125. Preseason Exhaust Sale @ MarylandSpeed! (Borla, Corsa, B&B, Magnaflow, etc)
  126. Wiring A6 to T56 Swap help needed.
  127. milky oil help!
  128. 2006 cai
  129. best heads
  130. C6 REAR BLACKOUT PACKAGE 5 Piece Kit $79.99!
  131. Spent the day at LG yesterday - thanks to Anthony, Bobby and the guys
  132. TKO Carbon Fiber Diffuser
  133. Brake Disc Cross-drilled and slotted
  134. KB Boost pump question
  135. Looking for options on new Wheels.
  136. American Racing Headers Now Available Through GM Parts House - www.gmpartshouse.com
  137. CAI - 2 Questions
  138. Side marker lens removale
  139. Cammed Corvette reliable?
  140. RPM Built 1020RWHP TTIX C6Z
  141. You have installed HID's, What brand, quality? Feedback!
  142. tunnel plate do it yourself
  143. <<C6 Tech HELP>> Have header install questions?? clutch?? suspension?? step in.......
  144. EVAP Delete
  145. Best Cam for stock stall A6
  146. Have you seen the LSX 32-valve heads
  147. I'm famous for getting wupped
  148. Lifter preload cross reference
  149. Guess my 1/4 gains from Fast 102 mod.
  150. Picture Request
  151. wiring diagram / pinout for hvac system?
  152. 135mph Traps possible on h/c/i LS2?
  153. Grandsport alignment #'s same as base C6?
  154. Header install tip
  155. F/S RSD Snap Shifter
  156. 86-88 VATS question Nevermind. Please delete.
  157. Gauge of Positive Battery Cable?
  158. Slave cylinder problem
  159. Opinion on magnacharger with 11.5:1 compression 421 stroker
  160. 05 C6 LS2 tuning problems
  161. Opinion on built 421 stroker HP
  162. Convertible Top Lid Rattle
  163. C6 Front Air Dam
  164. FS>RSD 5pt bolt in roll bar BRAND NEW in PA.
  165. what does a C6 differential weigh?
  166. steps to replace cowl/window seal
  167. Wheel widening
  168. Lingenfelter Heads/Cam/Air Intake Mail Order Package
  169. Awesome increase in power and mileage
  170. 408 iron block N/a in c6...opinions welcome!!!
  171. Best cold air intake on market available here
  172. What Is Up With The Brake Calipers On Standard C6s?
  173. Having idle issues. Any advice??
  174. Does heat soak cause negative fuel trims?
  175. ***RSD NHRA Legal Bolt-in Roll Bar***
  176. Battery replacement
  177. Coolant Problems
  178. Cam Install Question
  179. Anyone know about this??
  180. power steering lines
  181. ls3 cam specs
  182. I changed my C6 convertible top from Tan to Black
  183. Cracking Around Gas Cap
  184. Dual Pillar Pod?
  185. Ultra Copper RTV + Stock Steel Header Gaskets?
  186. Grand Sport Tires: Daily Driver
  187. Airbag Light/Impact Sensors: Problems Caused By Intake Dealer Says
  188. Just ordered lg street series headers but stiil confused ?
  189. Carbon Fiber Splitters and Chin Spoiler IN STOCK
  190. 2014 C-7 anyone seen this article yet ?
  191. blackstone oil analysis
  192. removing ECM from C6 Z06
  193. wire loom bracket behind passenger side head
  194. ***RSD Line Loc FS***
  195. 2007 z06 ecm location
  196. Automatic and HP
  197. Not often you find a Corvette product for only $50 that is so beneficial!
  198. Presently 436 HP
  199. Difference in A4 and A6 rear ring and pinion
  200. We now carry halltech
  201. Difference between LS3 and L76 Intake Manifolds
  202. Garage Engine Swap: Top or Bottom
  203. Base coupe on 265 & 305s with Z06/GS wide body quarter panels?
  204. '05 SOLD Thank God
  205. **Tax Season Special On Chrome Gumby Style Wheels For 2005-2012 C6**
  206. flooding here in houston, was moving car, heard a weird sound
  207. ~~~ St Jude Auction #4 Bare Essentials Racing billet catch can kit~~~
  208. Head gasket sealing issue........new build (opinions requested)
  209. Odo ?
  210. Flowmaster mufflers...
  211. ok thinking on a auto swap for my z06 but just got a price quote...WOW
  212. GT2 Coilover Shock Install
  213. Corsa Exhaust Question
  214. "Check Coolant Level"
  215. PCV Oil Catch Can -C6 Corvette
  216. C6 side cove screens $24.99 shipped!
  217. 2005 Z51 and MM6 transmission interchangeable ?
  218. January 2012 Aftermarket Specials at GMPARTSHOUSE.com
  219. Thank You CF Members: Our Killer Valve Covers are Featured in Vette Magazine –
  220. 2008 c6 replica different, is this normal?
  221. C6 six speed grind? 1st gear
  222. C6 Underhood dress up bolt caps. Where can I find them.
  223. LS3 Single Cam Bolt Torque Value???
  224. Reduced Engine Power- Service Traction Control
  225. January 2012 C6 Corvette GM Parts Specials - www.gmpartshouse.com
  226. Hawk Brake Pads Available - Lowest Price Guaranteed By 10% - www.gmpartshouse.com
  227. GM Widebody Conversions - Also With SLP ZR1 Front Fenders - www.gmpartshouse.com
  228. Bad clutch or...?
  229. Halltech Super Bee 24 hour Sale-10% OFF
  230. Halltech Carbon GT2 Hood on the Halltech ULZ700 -14 lbs
  231. C6 convertible. New black carpet install
  232. 3.42 Gears
  233. Brake Question
  234. Service antilock brakes dic message
  235. installed lg long pro tubes but idles to fast now?
  236. Installing Curb Alert
  237. C6 REAR BLACKOUT PACKAGE 5 Piece Kit $79.99!
  238. A6 Transmition shifting Question
  239. A&A supercharge
  240. January 2012 C6 Performance & Aftermarket - Vararam Bilstein QA1 SLP Koni FAST McLeod
  241. Need a lil more advice guys, heads,e-85 and exhust???
  242. C6 Heads Up Display Install Kit - New Low Price & IN STOCK - www.PartsTaxi.com
  243. local shop for upgrades
  244. anyone running 10's with m6 ls2 h/c
  245. Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
  246. ABS, TC, AH lights on
  247. Headers free shipping and msd.. Arh, LG Motorsports
  248. Spark plug/Wires recommendation
  249. Female needs help - Shift sticks at times
  250. wheel weights(yes i have looked)
