View Full Version : C6 Tech/Performance
  1. Lowered the car...now the passenger side rear squeaks.
  2. GT2 Carbon fiber Rear Diffuser For Stock or Aftermarket Exhaust
  3. 02 sensor wiring (universal?) what color
  4. Clutch Install
  5. Where to buy front skinnies for my Z06
  6. LS 376/480 cam in LS3 under warranty?
  7. Need More power ls2
  8. C6 Corvette Exhaust Systems
  9. Oil pan gasket leak
  10. Maintenance Cost
  11. harmonic balancer weighted?
  12. Fuel pump upgrade choice?
  13. 2 Piece Rotors..For 08 Z51...
  14. Ordering an engine soon...
  15. Which gear to Dyno in for A6 with 3.42 gears?
  16. Jet Hot coatings
  17. c6 open headers?
  18. Hot Hot Hot - New Red Jake Floor Mats
  19. 2nd gear t56 grind 06 c6m
  20. ati damper
  21. Cartek is so good, I'm shipping my car 1500 miles
  22. April 2011 C6 Specials - www.PartsTaxi.com
  23. Header gaskets
  24. Caliper Reassembly
  25. Transmission/Clutch problem
  26. ARAO 32 valve heads
  27. Are LS3's faster than LS2's in 1/4 mile??
  28. Got my full exhaust on!!! (pics inside)
  29. New Michelin Pilot Super Sport Opinions?
  30. Fuel System Question
  31. Questions on my build up - Clutch & Flywheel choice?
  32. Anybody used IPS Motorsports in Columbus Oh?
  33. manual tranny
  34. Emissions testing center near Atlanta
  35. 10.480 @ 134.07
  36. Where is the stock computer located at??
  37. what belts for SLP 25% underdrive balancer
  38. Rear Brake Calipers??
  39. Problem: not getting past 4500 RPM's
  40. Will the C6 ZO6 lower chin spoiler fit on a C6?
  41. Dead car with inoperable rear hatch release
  42. Z06 Factory Exhaust Manifolds
  43. Update to AR Header to Z06 exhaust switch
  44. Heads goin' on today
  45. >>>> St Jude Auction #29 MSD 8.5mm Superconductor wires w/ NGK Plugs <<<<
  46. Factory Air intake box
  47. Outside Temp Sensor
  48. Help!!! Bilstein Sport shock: is this wrong one?
  49. advise - looking to tune a 07 A4
  50. *Patriot gold extreme warning*
  51. plugs/header install, now CEL blinks
  52. Interesting article about aerodynamics!
  53. What are the 3 inch catback options for 08A6?
  54. Torque for Oil Lines on Z06?
  55. Latest LS3 build dyno numbers
  56. New 2011 GS... when should I change break-in oil??
  57. Which should I do - cam or SC
  58. 2007 c6 z51
  59. Easiest place to get 12 switched power
  60. cam gurus please help
  61. FS: 2010 Grand Sport Suspension parts
  62. C6Z06 Not Charging Battery Electrical Gremlin
  63. NGK spark plugs
  64. Grand Sport sway bar size .. same as Z06?
  65. HP numbers LS3
  66. Corsa Sport Exhaust - Westchester NY
  67. Installing headers, need questions answered please!
  68. Help with 02 extensions LS2
  69. FAST 102's $819 shipped! TODAY ONLY!!!!!!!
  70. Tune + Calloway CAI + 160 stat
  71. How long to Innovate Wide Band sensors last?
  72. r888's or nitto invos
  73. 2nd Gear grind
  74. High comp 418, which spark plugs & what gap?
  75. Vararam intake broken!!!!! Help!!!!
  76. Poly Sway Bar Bushings
  77. Headers or cat-back exhaust?
  78. Squeeky Tires
  79. Waterproof breathable fabric?
  80. Diff Fluid and Tranny Fluid Change!!
  81. Opinions needed on headers!
  82. What Headers to get I want it LOUD!!!
  83. Stock ZR1 Wheels on Stock C6 Coupe?
  84. Easy question for some...Will the C6 shifter fit our C5s?
  85. check engine
  86. Supercharging. What's enough?
  87. Vararam VR-SC1R $379 Shipped
  88. **FREE TICKETS** to Phoenix Firebird Raceway with LG Motorsports
  89. Idle Speed w/ aftermarket cams
  90. which headers, LG or AR?
  91. What's a choppy LS2 cam?
  92. Gutting Z06 cats on LS3.... track or Horsepower gains?
  93. Help Needed -Suspension Tuning for Non-Runflats
  94. Rack and Pinion removal (easier way?)
  95. Abs light comes on after driving fast
  96. Bed in Procedure for Hawk PC Ceramic Pads on GS
  97. Issue in 2nd gear when cold
  98. Z51 vs. F55... differences?
  99. Bought some American racing headers
  100. Driving with coupe roof open and AC on
  101. Rear brake duct insert on C06
  102. **RELEASE** DP3R Wheel from ForgeLine
  103. no start service columm lock
  104. *** St Jude Auction #27 AWESOME AutoGeek Pinnacle Complete Detailing Kit! ***
  105. TPMS and Traction Cotrol
  106. Vette-Air big cams + good tuning = Fast times with great drivability
  107. Anyone swap trans output shafts to run a Z06 diff?
  108. **LMR TX Mile 222mph Vid**
  109. wide band 02 sensor
  110. ZR1 Cam and heads dyno numbers LG Motorsports
  111. 09 exhaust fit 08s ??
  112. Active Handling questions
  113. question about Z06/Z51 brake clearance
  114. Good Corvette Mechanics
  115. Throwing code P0355
  116. Front Rotors Turned ??
  117. Anyone have a do it yourself Clutch change thread?
  118. Lift on Lift
  119. LS2 damper
  120. >*< St Jude Auction # 26 HID Kit C5 or C6 Winners Choice >*<
  121. nitto 555R
  122. Who's running 160 degree thermostats?
  123. Daytime idiot lights
  124. **LMR TX Mile 239mph Vid**
  125. Drastic Decrease in Braking Performance
  126. Trunk Button not working
  127. Strange Sound when letting off the brakes
  128. Right side speakers shut down during a left turn
  129. Head Unit
  130. Windshield Washer Relocation Kit?
  131. 165 MPH Mojave Mile shakedown pass! {Video}
  132. Slicks for my C6 Supercharged Corvette
  133. 2005 Corvette Horn won't stop blowing
  134. Is 75w90 the same as dexron 3 atf???
  135. LS3 oil pressure
  136. GS wouldn't start....4 months of storage.
  137. Edelbrock water pump
  138. Squeaky Brakes
  139. Brake Replacement
  140. Options For 16 More rwhp..
  141. C5 vs. C6 Trans Electrical Switches
  142. Vararam Intake installation, questions, and question about extra accessories needed?
  143. how to replace battery in keyfob
  144. PFADT Free Shipping
  145. Sorry to hear about the Hinson vette at the mile...
  146. Head bolts
  147. Spark plugs recommendation
  148. A6 shifting weirdly?
  149. Best Price on 08 Z51 rear Goodyears
  150. Back up lights
  151. plug wires keep popping off while driving
  152. Mechanical Inspection on Used C6 Tomorrow
  153. Getting headers this week
  154. Brake issues
  155. anyone running a lingenfelter GT2-3 cam
  156. Passenger Windshield Wiper arm attachment
  157. Cam Spec question 2006 Z06
  158. MGW Shifter Impressions
  159. cam position sensor replace question
  160. can you put headers on a california car and pass smog
  161. How well can a stock A6 tranny handle a supercharger?
  162. Grand Sport need a roll bar to race HPDE?
  163. oil temp to high?
  164. Trivial little annoyance
  165. E 3 plugs
  166. Recommend me a good street pad?
  167. engine idle speed
  168. LS3 Cam + Bolt On's. Low HP?
  169. Valvetrain noise after cam swap?
  170. back in plastic after 17 years
  171. Can anyone suggest the best.....
  172. snap,crackle - POP!
  173. Cam sound
  174. ls3 ls7 exhaust manifold gaskets
  175. silicone coupler for NW 102?
  176. LS3 intake manifold removal problem..need help
  177. Service Active Handling Message 2007 Vette
  178. I think I have a clutch issue?
  179. \\\\ C6 Xtreme CORSA Exhaust System $1073 +FREE SHIPPING ////
  180. Fast 92/102 on an LS2
  181. A special Spring message from the crew at The Vette Doctors
  182. Billy Boat C6 Corvette Exhaust Systems - Now at CCA - On Sale
  183. Tall Deck C6/ZO6/ZR1 Headers From ARH!!!
  184. LSX TWIN TURBO, need some help here!!!
  185. Broken Valve spring repair in So Cal?
  186. how much would a ls6 cam help a ls2
  187. Exhaust Suggestions
  188. C6 owners with Ace Slick Wheels
  189. whats the lift on a ls2 cam? .500 or .525
  190. To balance a straped twin disk clutch assembly or not?
  191. wheel adapters?
  192. FNG question
  193. Fuel Pump Back Order?
  194. 3.42 to 4.10 gear swap dyno results...
  195. Top Problem
  196. front license plate
  197. SLP 160 deg thermostats avaialble at GMPARTSHOUSE for 1997-2011 LS
  198. 325 30 19 on a non widebody C6
  199. service charging system warning - VICTORY
  200. A6 rear end options
  201. Steer and shift into neutral w/o battery?
  202. 2005 with headers has 4 o2 sensors in the collectors
  203. 2005 C6 - 30K Miles
  204. Brake job question
  205. Tune for E85
  206. Cam/Headers installed, Dyno numbers
  207. Gimme the bad news
  208. Boost gauge
  209. Bored = Black Wrinkle
  210. Lowering bolt install on rear?
  211. 04 z06 mufflers on c6
  212. Tires
  213. If you had a choice...
  214. Thermostat
  215. electrical connectors..
  216. Top problem follow up
  217. Top problem follow up
  218. TPS does not update
  219. Injector Sizing
  220. hp upgrade
  221. Widebody + Wheel + tire combo?
  222. C6 and Z06 Wheels
  223. Clutch/Pressure plate issue
  224. LS2 Dyno Results
  225. Erl 454
  226. 05 Hood Struts won't stay open
  227. Headers and vibration.
  228. Aluminum Flywheel
  229. 2011 C6 Cross-Drilled Rotors (option J55)
  230. My solution to Reduced Engine Power
  231. Tire won't take air
  232. New to the 6spd manual, need advice
  233. getting ready to port my 102. What am I,
  234. Exhaust Question
  235. Check out the new RSI C6 Fuel Systems
  236. Completed H/C/I on 05 M6
  237. VMax ported & flowed LS2/LS3/LS7 intake manifolds!!
  238. VMax CNC spiral ported Throttle bodies!!!!
  239. quarter mile time to expect?
  240. Need Some Part Numbers For My Spring Upgrades
  241. Oil Pressure XXX
  242. 2008 LS3 MN6 Quarter Mile with Slicks Only
  243. Question about swapping halfshafts...
  244. Tadge Juechter & Harlan Charles presentation at Sebring 2011 (Video)
  245. WCC heads and cam package
  246. Cam only or heads only...for more power?
  247. Horsepower upgrade question.....
  248. Running higher temps
  249. Tire type and size for quarter mile
  250. Yank 3200- most amazing!
