View Full Version : C6 Tech/Performance
  1. LS2 tune up
  2. Katech independently tests FAST LSXR LS3 manifold vs two ported LS3 manifolds
  3. Diff gear change
  4. Jeremy Formato tuning & porting in FL & PA
  5. Window Regulator Pulley Replacement
  6. Where to buy Z06 half shaft loops?
  7. Noise rear suspension!
  8. Valve Spring Replacement - Broken Bolts!
  9. Killer bee 2 intake how much louder than stock intake?
  10. Notchy trans shifts
  11. Line loc
  12. May 2011 C6 Corvette Specials @ GM Parts House
  13. We Sell Complete & Fix All GS/Z06/ZR1 Conversions @ GM Parts House
  14. Hawk Brake Pads - Lowest Price Guaranteed By 10% @ GM Parts House
  15. Jacking up a C6
  16. Went 10.40s yesterday at track..
  17. Cooling Grand Sport Convertible A6 2010
  18. Corvette Battery Charger
  19. Daily Driver & Racing seat ???
  20. ZR1 wheels size
  21. Check Engine Light
  22. Predator tune ?
  23. Getting info from the ECM, what do I need?
  24. planning suspension
  25. May 2011 Aftermarket Specials list GMPARTSHOUSE.COM
  26. Pin Diagram for C6 power driver seat?
  27. Pulled a fuse, now engine misses bigtime
  28. Base C6 fog lights same as Z06 ?
  29. Tuner in Detroit area
  30. Sourcing a Starter Solenoid
  31. Michelin Advice
  32. A6 pressure and cooler pics?
  33. Is Corsa Extreme the right choice?
  34. Telescoping Steering Wheel Stuck
  35. 2008 Roof Latch Creak Question
  36. Does anyone have install pictures of the Volant CAI
  37. What is missing in these pictures? 07' Z06
  38. Chiptuning LS2, LS3, LS7 and LS9?
  39. Quarter panel protection
  40. Fob and Power problems
  41. Water box at the track Question
  42. Aftermarket Nav/HUD
  43. 2005 Z51 diff and manual tranny capacity
  44. Seat Cover Upgrades - Something For Everyone - www.PartsTaxi.com
  45. MSD Plug Wires
  46. Circle d 1.48 on nitto 345/30/19
  47. May 2011 C6 Specials - www.PartsTaxi.com
  48. EVAP Solenoid Function
  49. Am I screwed??
  50. Z06 - cage requirements?
  51. steering response
  52. C6 Corbeau seat installation
  53. Help With a Possible Condenser PAG Oil Leak
  54. Your Opinion....first mods
  55. New clutch, new slave, new master and still!
  56. what Headers/X-pipe will go with SLP II cats?
  57. Suspension Upgrades for Z-51
  58. Exhaust (Yes, another exhaust thread)
  59. Pics of the new Weld RST's black face on my 08C6Z06
  60. Loud Poping/backfire!
  61. Stock header to HPipe studs
  62. P0803
  63. Lunch at Horsepower Sales - Pompano = PORNO PICS (car porn)
  64. ABS / Traction light on (Help)
  65. LSX 454 or ERL 454
  66. Reprogramming Key Fob HELP
  67. G.s. Crankshafts
  68. Corsa Exhaust Sport Installed
  69. C6 Base/Z51/Z06 Brake specs?
  70. 05 Z51 rear big tires?? NT05R
  71. 2010 vs. 2011 paddle shifter
  72. Possible to only use header o2 sensors?
  73. Halltech Super Bee Long Term Fuel Trims vs. stock LS3
  74. Lifters
  75. KOOKS 1 3/4 headers Don't fit around my tranny lines!
  76. Livernois 1C cam
  77. A quick question please
  78. Covercraft Blowout - Save up to 38%
  79. Speed Inc./ C6 A&A SC Results
  80. $874 for a waterpump install
  81. Vararam worth the money?
  82. LG Super Pro Dyno #'s
  83. Dyno----c6 stock mufflers
  84. The Worlds Smartest Battery Charger, From CCA
  85. ***RSD is selling the "VetteZilla" Suspension package....CHEAP!!***
  86. LG GT2 Coilover Noise - New Install
  87. Spark Plugs color and reading
  88. LS3 intermediate pipe on LS2?
  89. FI GURU's...what cam do you recommend in ls2??
  90. Put built 05' diff in my 07'...should I change before its too late???
  91. 325's and 275's on a standard body C6, Photos.
  92. Speculation on mods for a C6 Coupe (LS2)
  93. hp
  94. GM to invest $100M in the Corvette Plant!
  95. Stabalizer bar bolt threads
  96. Middle headlight burned out
  97. Middle headlight
  98. Coil Relocation Kit
  99. C6 DND... engine is fine... Thoughts?
  100. dewitt radiator for C-6-Z51 auto
  101. Making a LS3/LS7 MAF for my LS2 Question
  102. Shifter Locks in Park
  103. Drivers side head removal HELP
  104. Reconnected Battery, Radio does not work
  105. S. Fla Tower Shops Vette get together 5/6/11
  106. Lifter question
  107. HELP! What is missing from my car?
  108. Brake Squeal / Life Question
  109. How to measure header size?
  110. MONSTER Clutch 2011 Tax Season Sale!!
  111. Was anyone at Bandimere yesterday?
  112. Denver area vette shops
  113. New Products!
  114. Bluetooth OBDii - iPhone tools anyone using them?
  115. NEW Katech High Capacity Scavenge/High Capacity Pressure dry sump oil pump
  116. How hard is it to change fuel pump?
  117. Service Tire Monitor
  118. Lingenfelter Performance Engineering
  119. Osama Bin Laden is DEAD !!!!!!!
  120. New GS what mods to do?
  121. dead battery with keyless entery
  122. Ya another alignment question
  123. Nitto NT05R 345/30/19 Track Test
  124. Z06 / LS7 Water temprature??
  125. z - sudden erratic issues. Please help.
  126. 2006 Z06 cranks and no start.
  127. Trick flow heads for the LS3
  128. S. Fla - Corvette Challenge Saturday 5/14/11
  129. Vendors: Best deal on A&A S/C Kit installed in the Southeast? New or used.
  130. Tie rod / ball joint question??
  131. Superchargers for dummies....
  132. Mcleod RXT is amazing!
  133. Who paints your aftermarket hood?
  134. Help?? Will a c5 rear bumper fit c6 coupe
  135. Engine light help
  136. 2000 RPM Squeal
  137. ChampionMotors A6 C6 N/A goes 10.3@134
  138. 2005 base corvette, loosen crank pulley
  139. clicking/knocking sound over speed bumps
  140. Natural Gas Powered LS2
  141. AFR230's on LS2
  142. Question about a proper Diablosport tune??
  143. RPS Street Twin Carbon + Tick Master, first time out.
  144. Easy to install a full-width spoiler?
  145. Do all C6's have TPMS "limp home" feature?
  146. Cheapest way to install Foglight Brake ducts?
  147. AMSOIL Dominator Coolant Boost, Red Line Water Wetter Tested
  148. corsa sport install question
  149. Are c6/c5 sway bar and endlinks same tq specs?
  150. Electric Cutouts on my C6...QUESTIONS
  151. Opinions on F1 style paddle shifter mod
  152. kooks headers do i need an x pipe
  153. ahh @#$% need a new dif
  154. High Performance Alternator Charging Voltage
  155. The Tuning School Charleston,SC Seminar Pictures
  156. I love my 4.10's
  157. LG long tubes missing rear o2 extensions
  158. Help with code P0030&P0135
  159. Will LS3 intake fit LS2 Motor
  160. NPP question
  161. Just purchased NPP system, requesting assistance
  162. More fuel fun
  163. what LS2 mods
  164. New dyno numbers n/a and spray
  165. Baby Soon To Be Home.!
  166. Can you run headers on a stock tune LS3?
  167. Check engine light, code help
  168. Cold Air Intakes
  169. Install "Man Knob" npp on 05 w/ b&b Fusion
  170. LG Motorsports on TV this weekend **CIRCUIT BATTLES Episode #1** This Saturday!!
  171. Running / Parking light out intermittently
  172. Effects of wider tires
  173. drag times with HP
  174. Ghetto Bypass of Busted Fan PWM Controller
  175. 08 Auto Issue With Pulling In Reverse?
  176. Desperate For Help Tuning A 102 Throttle Body
  177. Is it safe
  178. coolant
  179. C6Z06 Dry Sump Tank Upgrade
  180. Sparco Racing Seat Question (headroom/sliders)
  181. Stock C6, adding Z06 brakes, what wheels?
  182. 3.73 gear install
  183. ~~~ St Jude Auction #37 Get your SHIFT Together MGW shifter package~~~
  184. Drive By wire 92mm Throttle Body??
  185. Halltech's Honeycomb Laminar Flow Straightener
  186. Let's all play "So just how long WILL subfloor's A6 last?"
  187. Is this a harmonic balancer problem?
  188. underdrive pulley install with leftover part??
  189. New headers rubbing frame, what would you do?
  190. Hinson motor mounts
  191. Maplight LED's and the glow...a fix?
  192. Occasional Hard Start
  193. Ported and Polished LS3 Heads??
  194. The dreaded cai question for a new ls3 owner
  195. new guy C6 help
  196. How to remove radiator?
  197. Please Help!!
  198. Track tips? A6
  199. 02 extensions interchangeable?
  200. Darton Liners
  201. Which roller rockers to purchase??
  202. Corsa sport question
  203. Single mass clutch and flywheel in c6?
  204. DOT 3 To DOT 4 brake fluid upgrade?
  205. need advice on tires and sizes
  206. FAST manifold porting special
  207. twin turbo kit for 1,100$?
  208. X-Pipes
  209. Ronal Wheels
  210. Stock 2010 Z06 Launch Control
  211. Anyone in the El Paso/Ft. Bliss area want to help do a head/cam swap
  212. Spring is here, up your braking performance cut brake dust.
  213. 2005 rear axle Paranoia
  214. max SAFE HP on stock LS3 FP?
  215. Need rear tire advice
  216. C6 Johnny O'Connell Shock and Sway bar review
  217. New vette owner, but no low end torque?!
  218. Any issues mixing brake pads?
  219. Engine Check light on, removed CAGS overrise, Light off, but no CAGS default returns
  220. Tpms
  221. Squeaking & Wobbling Harmonic Balancer
  222. Can you tap the throttle body coolant line into the heads coolant line?
  223. 2008 auto diff in 2005 manual?
  224. how many RPMs on a stock LS2 bottom end?
  225. Factory Launch Control - Can't get it to work
  226. Check engine light just came on.
  227. LS3 swap need a little help identifying a part
  228. When should I replace my shocks?
  229. Small Bore LS7 Heads - Available Now..
  230. Air filter replacement
  231. H/C bulid for LS2
  232. Blown Cats Questions
  233. Air Pressure reads Zero
  234. Rev Limiter
  235. Please look over our new Web Site - thanks!
  236. Pull codes
  237. Rotors
  238. Wilwood BBK
  239. db at 70mph cruise
  240. Odd lifter noise
  241. Lose HP from larger tires?!?!
  242. Differential fluid... no additive
  243. traction control plug help needed
  244. Air leak in roof panel at high speed?
  245. new wheels on c6
  246. 05 vette with a4 tranny is the diff the weak link
  247. Z51 Sway Bar Kits (Frt & Rr)
  248. Tuner in the Tucson/Phoenix area?
  249. Pratt & Miller C6RS Video Case Study
  250. Kooks Header & x pipe fittment
