View Full Version : C6 Tech/Performance
  1. 2006 a6 4-5 gear change hesitation
  2. Engine Coolant Sensors
  3. Head and Cam question
  4. If I wanna hook up a Z06 Diff, what do I need?
  5. Bolts VS Studs
  6. 07 15k and shocks leaking???? WTF
  7. Horrible Clutch Pedal Vibration ONLY When It's Warm Outside?
  8. RKT56 is now a sponsor
  9. Anybody in Miami has a tech 2 and a candy module?
  10. TPMS Learn Tool for under $50
  11. Best wide band wiring route
  12. Need a replacement LS2
  13. Wanting to go all Naturally Aspired...tips and advice?
  14. 2011 with coilovers????
  15. 05 internals in 06 + diff case
  16. B&B Exhaust Rattle
  17. 2008 Z51 Corvette 4 or 8 brake pads??
  18. CA Legal CAI for LS2
  19. Need alignment specs for Performance Street
  20. Chirp issue with the LS3's belt & HB!
  21. G6X3 question....
  22. HP Suggestions
  23. Is there a way to put a 2006 in diagnostic mode to check and see if any codes are pre
  24. Having BCM Problems I Think....Help
  25. Noisy bluetooth
  26. 4.10 wow and some side effects...I hope someone experienced this before
  27. Relocating battery...simply...what box/hold down
  28. MGW shifter today....4th to 5th ????
  29. Rear gear
  30. Early Model Z06 Differential Question...
  31. center consul removal
  32. LS3 Intake Manifold Bolts...Aftermarket
  33. Active Handling Issue - Still !!
  34. Weird Clutch Petal Issue
  35. Crazy BCM/ECM problem?
  36. Flat Tire Message, but no flat tire!!??
  37. ZR1, Z06 and NPP muffler diff?
  38. Best Tires
  39. Oil
  40. thermastat install LS3
  41. Lost FOB + Both Keys, how do i get a replacement key??
  42. F/I vs N/A with a $5K budget?
  43. is there supposed to be a gasket between the factory manifold and downpipe?
  44. Looking for experienced shop in South Fl. For SC Install.
  45. ~~~ St Jude Auction #43 Piloti Driving Shoes ~~~
  46. 2008 Z06 Red Oil Leak
  47. C6 coupe tires
  48. want to welcome great vendor BOXOLOGY
  49. Mushroomed lifter removal
  50. LS2 243 heads have the coolant plugs blocked off??? Help!
  51. ***RSD Has Pfadt Coilovers in Stock and Ready to Ship***
  52. Keep getting codes P2176,P2135
  53. magnetic ride control with second generation goodyear tires
  54. Clutch won't disengage
  55. LG or Kooks headers sound hp gain
  56. How It's Made - Ceramic Brake Discs
  57. DIY: ECS Trans Brace in a C6
  58. DRM bilstein or Sport bilstein
  59. E Force question
  60. Do C5 Kooks headers/mid pipe fit C6Z?
  61. Just bought a Z06.. quick question.
  62. Stainless Works - C6 Corvette Long Tube Headers from CCA
  63. Competitive Driving Mode - Option Missing
  64. C6 Z06 Tow Hook
  65. Fusion exhaust install and battery drain
  66. Diff internals swap
  67. need help or information
  68. Hand Held Programmers
  69. While I'm installing the blower...
  70. Rebuild Torque Tube???
  71. Tires......?
  72. Brake Fluid Capacity
  73. Full exhaust GS dyno
  74. need some help
  75. Modding - Intake, Headers, Cam, Exhaust
  76. Brake Pads for Corvette C6 with F55 and J55 brake system
  77. Need a ls3 fuel rail
  78. collector gaskets
  79. New Vette Warr.
  80. No air
  81. Homemade C6 Spare Tire Mount...only $30
  82. drive shaft shop axle seals leaking
  83. Brake light stays on
  84. B&B Headers/Xpipe/QTP cutouts.
  85. Machine Rotors? Say What?!
  86. Edelbrock E-Force installation
  87. Battery CCA question
  88. Fuel Problems!!!! Please advise....
  89. russell ss brake line install
  90. H/C LS2 holds it on.....
  91. What air pressure you guys running?
  92. Power by Cubic Inch
  93. Code for factory interior paint
  94. How much power from Z06 manifolds?
  95. Random Knock sound 07 z51 convertible
  96. Will dual mode exhaust reduce gas mileage?
  97. Pfadt's Johnny O' Connell package in action!! {Street/track HD Video}
  98. Paint code for comp gray wheels?
  99. Help, lifter noise, piston slap or wrist pin????
  100. simple brake pad question
  101. HELP with a weird oil pressure problem!!!!
  102. Manual Transmission Fluid Change
  103. Poll: Best LS Engine Builder/Tuner in TX
  104. Electronic exhaust cut outs questions/opinions needed
  105. I pod connection
  106. Speedo not working , looking for info and help...
  107. Squeekie Brakes
  108. C6 Spare tire mount.....any ideas?
  109. exhaust speculation
  110. Freq. Short Drives
  111. 07 GS Vette, Thanks Gene Culley
  112. coilover shock questions
  113. Oil Cooler
  114. Rear Wide Body Kit Blow Out Sale - www.PartsTaxi.com
  115. best tunner in Houston
  116. Making less power than expected
  117. electric cut outs on stock exhaust hp gain or loss??
  118. Service Active Handling System
  119. >>>> St Jude Auction #42 C6 Mobil 1 Corvette Racing Oil Cap <<<<
  120. Race seats???? Please help
  121. Please Visit The New www.gmpartshouse.com!
  122. NPP exhaust front Vacuum port location
  123. 1 stock spark plug wire needed
  124. Dual Mode Exhaust
  125. Took my 08 A6 to the track
  126. Torque converter
  127. Question about exhaust tips
  128. Can I put factory NAV in 2011 Vette?
  129. Spoiler Replacement
  130. PCM Replacement
  131. best year paddle shifting
  132. Back from Torq with 32 more RWHP
  133. Where to go....
  134. 2007 Coupe, Clunking noise uder instrument panel
  135. 2011 GS steering noise
  136. Using two sets of brake pads?
  137. CA Owners with Long Tubes on C6's Come on In
  138. Best tires which one out of these
  139. 15-20RWHP for under $300!!!!!
  140. C6 LS3 Owners - 32RWHP/26RWTQ for under $700!!!
  141. Cooling upgrade, how to plumb?
  142. Gmpartshouse's new site is online!!
  143. Headers
  144. Alignment time whats specs?C6 base or z06?
  145. O2 sensor question
  146. Help.....
  147. Pilot Bearing Change? Difficult??
  148. oil in the intake
  149. OBX Headers yes or no....
  150. Allignment, Tire mount & Balance in Maryland
  151. Lifts.
  152. Dead battery
  153. C6 Header question?
  154. LS3 Oil Pressure issues
  155. Question: Swapping 1LT Single-Disc Radio with OEM 6-Disc In-Dash Version
  156. does anybody have a 0-60, 0-80 or 0-100 video ls2 or ls3 automatic
  157. Dyno pull finally
  158. corvette track days: update
  159. TSB# for DSB
  160. Fast LSXr Manifold Question
  161. 215++ temp after water pump replacement
  162. Michelin Pilot Sport for C6 Rear
  163. Nitto 345/30R 19 Drag Radials
  164. Where to get work done?
  165. Fuel tank operating dynamics question
  166. New PB last night
  167. Changing Fan Temp on C-6
  168. Squealing Noise
  169. Ragin Racin's May Specials
  170. Performance mods for C6
  171. Properly Filling Tranny after Removing Cooler Lines
  172. Air Bag Light Comes every so often???
  173. cam install
  174. Hoosier R6's
  175. Corsa Touring Resonators
  176. c6 z06 injector
  177. Dyno Results. 1.8 Rockers, then Headers
  178. Shifter wont go in 1st or 2nd.
  179. Bose Radio
  180. Getting Tuned on Mon! Got some ??'s
  181. Heat exchanger
  182. Went to Atco last Night
  183. c6 intake
  184. Braking force translated to frame ??
  185. Dry sump upgrade for C6 Coupe
  186. Heads/cam mpg?
  187. Starter repair in Phoenix
  188. first mod LG street series headers on 2007 a6
  189. Anyone have an Original ZR1 cam removed from a ZR1 ??? (and same info for LS7)
  190. Procharger install?
  191. 2006 c6 tires & wcc chrome rims
  192. C5 Swaybars on a C6?
  193. lg passenger header help
  194. are forged/light weight wheels worth the money??
  195. Does Z51 Option use standard C6 wheels
  196. Does anyone happen to have a wiring schematic for the start button switch?
  197. First time painting flames today PICS
  198. Frustrated with your Pin Top shocks?
  199. Corvette GS break pads
  200. Cam chain tensioner on LS2
  201. 2010 LS3 Head Questions?
  202. tuner in the IL area?
  203. Battery quick disconnect or tender
  204. DRL problem
  205. Superior Dry Performance - Potenza RE-11 or Ventus R-S3
  206. LS2 Oil Pan questions
  207. ZR1 clutch installed...two thumbs up!
  208. Lingenfelter pedals
  209. Boost by gear sensor
  210. header coating flaking off
  211. C6 TPMS battery replacement
  212. Free Shipping!
  213. Passenger seat Airbag Light
  214. **Another 1000hp Corvette from Late Model Racecraft**
  215. G.s manual dry sump engine
  216. Dyno Results Finally
  217. zo6 npp
  218. Couchless Summer Header Sale @ MarylandSpeed Kooks with Free Coating or Save More!
  219. Drag Radials for a 2008 C6 coupe
  220. CAM Opinion Needed - Upgrading LS2 to LS3 Heads and Intake.
  221. ----Halltech Super Bee CF102 does it again!!!Video------
  222. Dropping the transmission to fix a leak, what to buy?
  223. 02 extenders?
  224. Off to Spring Mountain Tomorrow
  225. Recommend a stroker for me (LS2)
  226. 2011 Grandsport seems more of a handful 2008 Z51
  227. Just had car dyno tuned and now it doesnt charge!
  228. Z06 brake pads
  229. Loud engine clacking sound C6
  230. 2012 manuals matching rpm by computer on downshifts?
  231. Changing battery
  232. Well, it looks like my A/C is taking a dump.
  233. A&A Corvette Brings You: A Discussion About Belt Wear
  234. Intermittent CEL after servicing
  235. Removing broken power seat
  236. 05 LS2, bad rear O2 sensors = yank timing?
  237. Cartek.. HKE... or ERL
  238. Throttle pedal adjustment stop?
  239. Exhaust Question
  240. which suspension package is better
  241. Wheel Bearings - Need Some
  242. Torque Tube Bushings
  243. interior light stay on
  244. How to remove axles??
  245. Gears with no tune
  246. Exedy clutches?
  247. HUD brightness vanishing
  248. I have 2 questions for my C6 ...
  249. STS rear mount turbo giveaway?!?
  250. How often Differntial Lube Change?
