View Full Version : C6 Tech/Performance
  1. 2005 with A/T need help
  2. Just Dyno'ed my C6 LS2
  3. Grinding noise
  4. 08 z06 potential problems
  5. Cant get my Oem grill to go on
  6. Mobil 1 High Mileage Oil
  7. Folks running rear 345/35/18, please step in..
  8. C6 Z06 Electrical issues...
  9. growling noise in rear
  10. Rear sway bar slipping
  11. Help! How To Remove The MAF On My '07 C6
  12. something to prevent hydrolocking??
  13. Do I need a different chain for this cam???
  14. Corvette Radiator Cooling Help Info - LG Motorsports
  15. Tire time again I'm looking for a deal
  16. Maximizing LS2 airflow, the little things...
  17. Question about headers
  18. Best CA SMOG legal setup
  19. Dyno results
  20. Z06 exhaust on base?
  21. Inside the Performance Build Center
  22. Brake Rotors left & right cooling vents
  23. Something is digging into my cam sensor
  24. Airflow to Rad: Suggestions for Dropping Temps
  25. NEW! KATECH High capacity LS oil pump
  26. HUD and NAV Install? Will pay for someone to install it in my 08
  27. 102 lsxr Fast for Ls2
  28. Free Shipping returns!
  29. ABS Brake light on & hard to steer
  30. LS2, G5X3-114 lsa, AFR 205 heads 59 cc. Flycut or not?
  31. Clutch Screech
  32. vibration at 1800 rpm
  33. 93 octane w/10% ethanol or 91 octane ethanol free?
  34. Custom Headlight Painting at DD...
  35. I'm Done with Redtops!
  36. Halltech's Super Bee MF103 now in stock at Jerry's Chevrolet
  37. torqueing heads
  38. How screwed am I?!
  39. Propped Shroud
  40. 05 Crank Pulley Bolt Failure
  41. What are these called?
  42. MTI Racing 454 Engine for Sale 650HP
  43. Whats the trick to get the rear rotor off?
  44. Ported TB and hissing sound?
  45. Mystery Paint Defect
  46. Zo6 headers?? Help
  47. C6 Fob Long Procedure, display different-no 10 min countdown
  48. Odd Front Tire Wear??
  49. Can you guess what this is for?
  50. Oil coolers / temps
  51. How much to chrome my wheels?
  52. Over wound under shifted.
  53. Too many miles for cam package?
  54. What do you think? Baer Pro Plus 6-Piston BBK kit for C6
  55. Converting Fuel Line at Firewall to -AN
  56. Dyno numbers.....And confusion
  57. Mixing Toyo and Nitto Tires for Track Days
  58. Big July SALE Stainless Works SALE with FREE SHIPPING
  59. Everyone with 2005 - 2011 C6 Z51 Z06 Harmonic Damper (Crank Pulley) Defect
  60. Updated MONSTER CLUTCH Website!
  61. Oil Pressure?
  62. Engine Quits - No Codes
  63. Stainless Works Headers & Exhaust on Sale! Lowest pricing ever offered!
  64. Changing headlamp bulbs
  65. Halltech Super Bee™ MF103 Stage 1 Package
  66. Trans cooler update
  67. Brake question
  68. Trans Cooler install help
  69. People with access to factory info on the C6
  70. need help w/ reverse lockout solenoid
  71. Window indexing issue
  72. Gas Cap Fix?
  73. check fuel system and check engine light
  74. A/C or Heat fan doesnt blow air
  75. Modifying an ls3 m6 questions
  76. Halltech Beehive cover on Airaid intake
  77. Is there a required transmission service for a fluid change to be done?
  78. Performance Tires in Stock Sizes
  79. Problem with garage remote
  80. Right rear tire flat!
  81. LS2 to LS7 MAF upgrade VERY strange..
  82. Occasional brake grind sound help
  83. Milling TFS Heads and PTV
  84. ECS Stage II Package Install and Review!!!
  85. Cats vs no Cats??
  86. Trouble getting shifter in park
  87. TPMS sensors....
  88. Tech 2 Owners
  89. LG Header Collector Rubbing
  90. Fast intake & Nick Williams 102 Special
  91. B&B exhaust special
  92. LS3 & Hot cam or Not?
  93. C6 Parking lights
  94. First Time Here
  95. similar track tire question
  96. What cam / valve springs for LS2 with LS3 heads?
  97. OK Newbie question
  98. Penske Vs Pfadt Coilovers
  99. what is this noise??
  100. ALL NEW Monster Clutch Pricing at Tick Performance - Check it out!
  101. EnglandGreen is recruiting!
  102. Surging after modding radiator shroud with stock intake
  103. Radio display flickering and "Service ABS" message while braking?
  104. supercharging 2008 stock Z06
  105. LS3 WRHP dyno numbers
  106. Problems with DIC
  107. Help with removing Brake Rotors!!!??
  108. 08 ls3...!
  109. Kooks headers,catless x installed.Strange noise while driving.
  110. Brake bleeding best to Push or Pull
  111. 2011 LS3 Grand Sport "front air scoop"?
  112. Active Handling systems problem in conjunction with transmission locking
  113. 2008 ls3 with procharger running hot HELP
  114. Two LS3 Mods I Gotta Ask About
  115. Taking front sway bar off, advantages/disadvantages?
  116. Emergency Brake Actuator/Switch?
  117. Brake Pedal Clunk
  118. Weight penalty?
  119. Same size tires & wheels F/R ??
  120. New Vette Owner tech questions
  121. C6 auto shift lever locks up
  122. Exterior LED light install
  123. Roll bar specs
  124. p0327 and p0332
  125. Help: Where can I buy this tensioner pulley?
  126. Will the Drivetrain go into a Subaru?
  127. z51 springs and F55
  128. Vengeance built 05 C6 goes 623/555 with VRX5 cam/A&A Supercharger..Pics/videos inside
  129. Is anyone discounting CCW wheels for forum members?
  130. smaller diameter water pump pulley for better water flow at idle
  131. Stoptech Big Brake Kits-FREE SHIPPING!
  132. Gas Mileage Changing
  133. npp switch next to fob slot
  134. July 2011 C6 Corvette GM Parts Specials @ GM Parts House
  135. GM Widebody Conversions Available - Also With SLP ZR1 Front Fenders @ GM Parts House
  136. PFADT Racing Johnny O'Connell Signature Series C6 Shocks Available @ GM Parts House
  137. Looking at Wilwood BBK kit. What do you think of this kit.
  138. Bigger brake kit for the rear?
  139. July 2011 Aftermarket Specails at GMPARTSHOUSE.COM
  140. 05 mn6 and procharger.....personal reviews
  141. Recomendations on rims
  142. Any recomendations on clutch?
  143. Which model Odyssey 925 battery will fit in a C6
  144. Battery wont fit in right rear cubby hole
  145. Targa Top Problem
  146. 402 under 400 rwhp help.
  147. should I get the cross-over pipe with the new exaust
  148. My Review of the Sprint Throttle Booster
  149. LS9 intake?
  150. Halltech Super Bee onboard Katech's Highest HP Z06
  151. Transmission questions
  152. Question on VSS on 06 rear diff case in a 05
  153. anyone running X pipe & dumps?
  154. Lingenfelter C6
  155. removing cats?
  156. Anyone used Powerstop brake pads?
  157. ls3 intake maf on ls2
  158. New Texas Speed & Performance Engine Machining Center!
  159. Byunspeed catch can/dry sump
  160. need to know torque tube spacer thickness
  161. Overall length of 8Qt Dry sump tank?
  162. 2005 a4 w/52k miles, no full throtle 2-3 shift
  163. •► ► CHUCK CoW TUNING in HAWAII !!! - July 22nd - July 31st ◄ ◄•
  164. Tuning on a hot day - C6 Z06
  165. fan connector burned up ( three pin )
  166. C6 ZO6 short throw shifter ?
  167. Sway Bar Install
  168. Have a listen to my strange engine noise.....
  169. c6 z51 skinnies
  170. **** Last Chance - BCP Sale Ends 7-13-11
  171. Z06 Manifold
  172. new rpm lvl 5 3rd gear wine
  173. Wrapping catalytic converters
  174. Swaybar adjustment question
  175. Thinking about an '08 Vert
  176. spoiler template needed
  177. Race Proven Motorsports Facebook
  178. Should I Switch my Intake
  179. speedo goes blank at WOT
  180. O2 sensor problems
  181. MN Transmission question....
  182. Ring job but without honing - anybody ever done one?
  183. Base c6 suspension- mag ride conversion question
  184. In transition performance modifications...
  185. what size threads on ls7 crank snout/for homemade install tool
  186. Holley EFI - Dominator System - Anyone used it
  187. BIG thanks to Kevin at Parts Taxi
  188. DIY Tranny & Diff Fluid Change
  189. LS2 H/C People - What Injectors?
  190. C6ZR1 use a rear wheel bearing up front like the Camaro5???? PIC
  191. Rear Wide Body Kit Blow Out Sale - www.PartsTaxi.com
  192. July C6 Specials - www.PartsTaxi.com
  193. DTE Diff strut sale
  194. fuel economy after lg headers and vararam???
  195. Will larger front tires cause oversteer?
  196. Need Mich SP2 ZP Inflation Targets PLEASE
  197. c6 Corvette Healights dont work! HELP PLEASE!!!
  198. Fuel pump signal wire??
  199. 09 sway bars
  200. Transmission or electrical?
  201. Front Air Splitter
  202. Service Traction Control/Active Handling
  203. TPS worked until reprogrammed
  204. Need help asap!
  205. Trans line: Replacing Quick connect w/ flare
  206. Pafdt installation.
  207. @@.....DART heads vs. LS3 or LS7 ported???..............................
  208. HELP...Where does this wire connect? (Pic included)
  209. 0psi, low oil pressure
  210. 4th Of July Sale From Lethal Performance
  211. Ls2 fast 102
  212. Battery replacement?
  213. LS2 Camshaft
  214. Advice Appreciated
  215. Cam Break-In Period
  216. Traction Control...Speed Related?
  217. Horn???
  218. performance throttle body spacer 2008 ls3
  219. NPP install
  220. new exhaust questions
  221. Opinions before I go to the Dealer
  222. air bag light stays on
  223. SCT handheld update error, disconnected, now won't connect to computer?
  224. check gas cap
  225. Powerbond Balancer
  226. Help plz -C6 possessed after tuning? ECU bad?
  227. These Big brake kits any good. Looking for more then C6 brakes
  228. FAST 102 with Supercharger and head work?
  229. what is the drivetrain loss on ls3 with 6 speed manual?
  230. front curb senser
  231. supercharger=blown engine
  232. broken timing chain on LS2
  233. check engine light on car idels rough
  234. Help with P0101 Code
  235. Throttle Body Porting Special
  236. July 4th Sales at Tick Performance: Master Cylinder Kits, SPEEDbleeder Lines, Shirts!
  237. Reversing 2007 A6 paddle operation
  238. MT E/T Streets bias ply on stock trans/diff/clutch
  239. I want to improve my top end power (top speed), what would give more effect??
  240. GM sucks when it come to gas caps!
  241. COMFY lightweight race seats?
  242. whinning sound at 60-62mph only when on accelrator??
  243. Supercharger info
  244. Bigger injectors with heads?
  245. First trip to the track!
  246. Obx header system questions
  247. Can a loose gas cap cause a hiccup?
  248. The-Blueprints.com - MUST SEE!!!
  249. Bare Essentials Racing Performance Results
  250. Apsis D Stlyle Steering wheel
