View Full Version : C6 Tech/Performance
  1. instaled intake but canceled vacuum pressure
  2. Aeroforce fuel pressure ?
  3. Let's talk about that annoying fuel tank crossover tube for a second...
  4. Corsa Touring or Z06 muffler mod with NPP ?
  5. Need to say Thank You
  6. C6 Column Lock Bypass (Draft Design)
  7. What type of battery for a car rarely driven?
  8. >*>*> St Jude Auction #73 "Stop Draggin' your car around"...Frame Savers C5/C6 <*<*<*
  9. Where is the G Meter Sensor Located
  10. Part 2. work by supporting vendors. feedback requested
  11. Looking for someone with a moderately cammed C6 in the Tampa, Fl area for a test ride
  12. light weight 18x12 wheel options?
  13. BPP End of Summer Diffusor Deal $995.00
  14. Suspension/Say bar
  15. Alignment Tool needed for clutch change????
  16. Need New Shocks (any suggestions?)
  17. Borla Exhaust Looking for Two 2009+ C6 Display Cars @ Carlisle – Want a Free Exhaust?
  18. Tick & Monster Complete Clutch Swap Packages - $100 OFF until Aug 26
  19. 15% off all Breathless Performance Airboxes
  20. 08 Z06 Exhaust on a 06 C6 Coupe ??
  21. ProCharger Price Increase Coming August 22: Order Now and Beat the Price Hike!
  22. inquiry on redline motorsports or cartek
  23. LS3 injectors on a LS1 rail ?? yes, I searched
  24. Dry oil sump
  25. ~*~* St Jude Auction #72 Stainless Steel Brake Lines for C5/C6 ~*~*~
  26. Before i head back to the track question
  27. Dynoed my 05(manual).Take a look.
  28. Please help... 225 Trick Flow heads issues
  29. Best brakes for C6 coupe
  30. The Official GM Parts House Corvettes @ Carlisle Discussion
  31. Dynoed my LS3 vette manuel
  32. Took the 2011 Grandsport to the track today.
  33. speedometer jumping
  34. fuel system interchangability ??
  35. Eibach vs. Hardbar
  36. California Legal Mods
  37. need differential installed pittsburgh area??
  38. Modified C6 (Ls2) Will a muffler hurt the motor?
  39. check oil? metal shavings
  40. GM Upgraded Rear Sway Bar End Links
  41. C6 trailer hitch
  42. Clutch issue
  43. LS3 cam change
  44. High-comp 416, L92 heads, perfect-street-manners cam?
  45. Fixed roof c6
  46. TPS help
  47. Reverse Light Bulb Replacement
  48. Noise in rear of car while parked!
  49. Tips for Avoiding Wheel-Hop at Launch?
  50. Just installed 1 7/8" ARH headers WOW!
  51. got the headers on. few questions
  52. NPP Exhaust Override
  53. C6 LG Super Pro Header in 2 1/2"???
  54. New Vararam Snake Charmer Quality?
  55. ****St Jude Auction #71 Adam's Judges Detail Kit ****
  56. MTI Racing - "FLAT OUT FRIDAYS" - (8-12-11) Full Throttle Video
  57. Sticky Tires
  58. Micro Switch...
  59. 2006 Corvette forced swerve AH/TC Error
  60. Changing Differential ? How Difficult ?
  61. Tranny out, what else?
  62. ABS engages suprisingly often over uneven pavement. Will shocks help?
  63. shifter button
  64. ECS Torque Tamers - Great Drag Part! On Sale
  65. Katech independently test BER ported LS3 intake
  66. Great deal on our Daytona seats
  67. Need 160 Stat part number
  68. Need 160 Stat part number
  69. installing AVIC120BT HELP....
  70. Corvette Repair Manual?
  71. Bought a Headlight that needs work - Help Please!
  72. cam choice for my new 402ci
  73. Airaid intake vs Vararam forced intake
  74. 2.5" full exhaust, is it worth going up to 3" with headers??
  75. Brake bleeders ??
  76. 2005 C6 convertable roof problem
  77. Halo Prep & Finish Options
  78. Why does 3" exhaust neck down to 2.5"?
  79. Hood Liner Information
  80. Lightning Strike
  81. Has anyone added 5" tips to their exhaust? CF?
  82. Oil Pressure Issue
  83. Anyone have a picture of a 19" front CCW rim on the car?
  84. Another 230/234 114+2 cam result
  85. Verdict is in - camming
  86. StopTech Big Brake Kits
  87. dyno numbers?
  88. Help with annoying squeak after shock install
  89. Turning Z51 Rotors
  90. Changing Manual Transmission Oil?
  91. Just received my cam sheet from Pat G!-thoughts/opinions/performance expectations?
  92. z06 mufflers on a ls2?
  93. *** St Jude Auction #69...Time to get lubed up! Case of Royal Purple and K&N filter
  94. Going to E85
  95. engine noise in the radio
  96. Any aftermarket gear sets for stock LS2 diff?
  97. Z06 rear diff questions
  98. BRAD PENN oil
  99. '11 GS Strg Vibration
  100. Exhaust Advice
  101. Replaced all 4 lift supports today
  102. invo's vs ps2's
  103. going to the track soon how fast?
  104. Need a list of bolt ons = 475rwp
  105. thinking of upgrading my awesome 05 diff
  106. arp main studs, rod bolts, head stud torque specs?
  107. Big shout out to RichieRichZ06, Thanks
  108. MN6 problem
  109. Think GM will step up for all the faulty clutchs?
  110. Where to buy NPP exhaust?
  111. have bad ring and pinion going to buy new differential question??
  112. Advice for my first vette
  113. rapid battery drain *HELP*
  114. Does JWIS ("C5R") chain have less slack that new LS2 chain?
  115. **Chrome Grand Sport Wheels For C6, Z06 & Grand Sport**
  116. Help, "NO FOB DETECTED"
  117. Will ARHeaders from a Z06 fit on a C6 LS2
  118. How important is dyno tune?
  119. PCM control settings for 160 degree stat?
  120. long 5th gear
  121. Need some tire help!!!
  122. Oil leaking under the car when running!!!
  123. A6 durability?
  124. 91 octane w/o ethanol or 93 octane with?
  125. map light bulbs -how get out
  126. What exhaust and how loud is it in your C6?
  127. Alignment
  128. Will stock c6 z06 exhaust fit on base c6?
  129. Z06 vs. Base question WIDTH OR CAR/WHEELS/Etc.
  130. Spacer Thickness for Rear Widebody with CCW's?
  131. Replacement for Hawk HPS Pads
  132. Exhaust Akrapovic Z06 = C6 Stand ??
  133. ZZ383 or Vortech heads under stock hood?
  134. Question for the guys with the dual mode exhaust
  135. Steering Adjustment?
  136. Just purchased a 05 c6 need some help !
  137. To cam or not to cam - that is my quandry
  138. Service Active Handling Message BUT I don't have a telescoping wheel
  139. Changed out rotors, pads, ran into a problem
  140. Rattle in dash, passenger side
  141. Place your order pickup at Corvettes of Carlisle
  142. HELP, I killed my C6. Frame rail damage
  143. Aftermarket EOC & TOC,,any oil coolers kit?
  144. Tune-up for top (stock) performance?
  145. Corsa Exhaust ??
  146. Kinda dissapointed with LG Pro + Borla sound..
  147. Easy header question
  148. Mirror Dimming Pass Side
  149. Few pics of my ERL 454
  150. Few pic of my ERL 454
  151. '07 auto has only neutral & drive
  152. How Do You Remove Driver Side Door Latch/Locking Mechanism
  153. Problem with brake job I just did - quick question
  154. C6 overheating controls
  155. o2 sensor problems
  156. Vararam Install on 08 LS3
  157. CAI & Exhaust for the Grand Sport
  158. Best vendor/place to buy a G6X3 cam/cam kit?
  159. inspection
  160. Clutch Question?
  161. 2006 Convertible trunk lid won't unlock completely
  162. Grand Sport clutch issue
  163. **~~** St Jude #68 C6 Mobil 1 Corvette Racing Oil Cap **~~**
  164. Fuel pump booster
  165. 150mph
  166. Oil analysis gurus; my first UOA on my '08 Vette inside....
  167. HELP *** Quick Disconnect *** NOT
  168. 1-2 shift gate preload spring adjustment
  169. Whats the difference? 1LT, 2LT, 3LT, 4LT
  170. World Challenge Hood **BLOWOUT**-LG Motorsports special
  171. ***Bad Vibrations***
  172. Edelbrock intake manifold instead of FAST?
  173. Can TPMS sensor be replaced at home?
  174. Clicking sound
  175. Sound System/ Tweeters
  176. Hud problem on 05
  177. Need SS brake line recommendation
  178. August 2011 Aftermarket specials at GMPARTSHOUSE.COM
  179. **~~ St Jude Auction #67 A set of the solid black Z06 style wheels for C5/C6 **~~
  180. Think i am going to buy no differential need advise..
  181. What is part number for TORX SCREWS FOR 2006 VETTE C6 NEED HELP PLEASE!
  182. 2010 GS Fuse Box Wiring Schematic Question & Help?
  183. ls7 cam in an ls3
  184. Codes P1516 & P2101
  185. Need Modding advise
  186. Zero Oil Pressure
  187. Varaham Throttle Body Spacer ?
  188. August 2011 C6 Corvette GM Parts Specials @ GM Parts House
  189. Hawk Pads Available - Lowest Price Guaranteed By 10% @ GM Parts House
  190. GM Widebody Conversions Available - Also With SLP ZR1 Front Fenders @ GM Parts House
  191. Stroker motor numbers
  192. Being haunted by a p0174 coded!! Help plzz
  193. Engine Block Digitizing at TSP!
  194. 05 vette will not start, help plz!
  195. Rear Wide Body Kit Blow Out Sale - www.PartsTaxi.com
  196. August C6 Specials - Preliminary 2012 Info Available - www.PartsTaxi.com
  197. my keys are locked in y 2006 corvette
  198. Which gaskets are necessary in a cam swap?
  199. instument clear cover removal?
  200. porter cable versus hand on detailing
  201. Quick Header install question
  202. Radiator Fan, burned out? HELP
  203. Left foot braking
  204. Carlisie, pa----corvette show
  205. Starting is labored for 1 of every 4 starts?
  206. No tails, but do have dash lights
  207. Best deal on NW 102?
  208. Fast Throttle Bodies or Nick Williams?
  209. Planning to put Spin's (146-000-11) Cam on 408 LQ9 (Advice)
  210. Header installation question
  211. Glass Top - Pros and Cons
  212. Steering Wheel Volume Controls Stopped Working - Any Ideas?
  213. Vararam - Do I oil both sides when cleaning?
  214. Question about the MAF Position
  215. Rear end gears
  216. EFI Live & HP Tuners on Sale plus LC1 for $129shipped
  217. 6l80e build
  218. American Racing Header sale with Free Shipping!!
  219. Failed emissions now CEL
  220. Tail pipe ??
  221. clutch fluid?
  222. C6 normal body running 19 /20 wheels
  223. how much hp will cut outs and a VR intake add to a stock LS2??
  224. H/C LS2 on the airstrip again!
  225. Adding Performance that is not "visible"
  226. Grand sport w/ Z52 (dry sump) + F55 = #?
  227. never-ending diff leak???
  228. 2005 spec LS2 reluctor wheel 24 or 58 thoot ?
  229. Top Gear ZR1 vs Ferrari 458 History Chnl
  230. >*< St Jude Auction # 66 HID Kit C5 or C6 Winners Choice >*<
  231. Ac hot
  232. Water pump leak at 84k
  233. My converter from the factory locks at WOT
  234. Active Handling clips
  235. "G-Tech Pro RR" - Any good?
  236. First oil change
  237. Mustang guy bought Vette, need help
  238. Hankook Ventus V12 evo EXTENSIVE REVIEW
  239. Halltech Super Bee MF103 1 day sale
  240. Radiator plug
  241. HP Tuners' VCM Suite
  242. ported throttle body opinion
  243. Catch-cup runeth over?
  244. 6 disc to gps
  245. California Mods
  246. GM Performance Build Center
  247. GM High-Tech Performance - Supercharged LS7 Engine Build
  248. Why is this forum TECH/PERFORMANCE
  249. Ceramic coated headers? othe exhausting questions
  250. brake advice needed.
