- Wire in an NPP switch to OEM fog light toggle? -- Is it possible?
- ~~~~~St Jude Auction #86 LG Motorsports 'Zipper Door' Car Cover~~~~~
- how do i make my horn work
- Oil gauge problem
- Strange clunking noise
- TR6060 Compatibility - Ford version same as Corvette?
- Billy Boat exhuast install = engine problems PLEASE READ
- Help me with my new c6
- Cam package help?
- Installed my lightweight Deka battery
- Help PLEASE AC PROBLEM
- MTI Racing Carbon Fiber Harness Bar
- Livernois Motorsports September LS3 Camshaft Install Package Specials
- where to get nick williams 105mm TB?
- Can I replace electronic shocks with after market shocks?
- MGW Shifter at Thunder Hill Next Week?
- Trying to compile as much suspension info as possible - need Jim Mero's email
- Which intake? The choice is clear to Katech
- What headers do I get?
- Who are the best dyno tuners in Texas?
- Tire sensor issue.
- Dyno Numbers
- EnglandGreen Mayhem II cam+LS3 A6 = almost 500 wheel horsepower
- 08' Shift knob removal?
- 05 doors won't open/car won't start - not DBS
- When will the 2012 GM Performance parts manual be released ?
- Got 3.90 gears installed on an 08 wow.
- The official group buy for Johnny OConnell suspension
- C6 Radio Nav intermittent on and off
- loud whining from rear end 3 days after fluid change
- Need a part number, please...crossover tube o-rings
- FogLights - Adjusting Aim
- Questions about installing an LS2 into another car
- ECS Used C6 1500 Kit - For Installation - $5895!!!
- Anyone with Bolt-In Roll bar like Wolfe/RSD?
- Catch Can news
- Clutch Pedal on Floor
- Disappointed in dyno numbers. Should I be?
- Vibration Question
- Crazy Idea, C5 Drivetrain Swap in to '05 C6???
- Corvette Racing Prepping for ALMS in Baltimore
- Oil Filter "magnets"
- X Pipe
- '07 Hatch Closing - Motorized or ???
- Manual Tranny question from a new guy
- Valve Spring Maintenence with a cam, how often???
- Does the throttle body change between the LS2/3/7 ???
- ZO6 springs on Z51
- Overall cost of owning a vette vs *** cars?
- Cannot move shift lever from N to P after
- DIY Porting and polishing intake
- Rims that will fit my c6 for some drag radials ... plz help.........
- Front 02 extensions-where to buy/order?
- C6 Corvette Sequential Turn Signals
- ► ► CHUCK CoW / CARLISLE WASHOUT SALE! Don't WAIT!!!◄ ◄
- ZR1 cam in LS2
- 07 m6 handling issues please advise
- Where to get a rear upper ball joint?
- Help me choose a cam for A6 LS2?
- LS2: Does 160/180 stat change need fan changes?
- After market Intake Sound ?
- Alarm light on standard radio
- Catalytic converter---c6---help
- Changing my own oil
- Driveline Vibration after hitting pot hole
- Need a Pfadt part? Want a T-Shirt? Come to Tick Performance!
- Jackstand locations for header install?
- 2005 Belt Squeal
- C6 engine oil cooler
- ABC Direct Plug Wires... Anybody use them?
- need part #'s for spark plug wire and ends/relocating
- 2005 Automatic Trans Fluid check
- Anyone running Comp LSR cam?
- Ported 243 heads
- Shift light?
- Recommendations for the best solid roller lifters for an LS7?
- 2011 Z06 Corvette Engine Code P0806
- Brake Fluid Change
- 1st oil change questioni
- >>> St Jude Auction #83 Autographed Wixom Engine builder poster <<<
- #*# St Jude Auction #82 Stop Draggin Your Car Around Part Deux #*#
- 05 oil gauge problems
- What brake fluid to use? Baer 14" rotors, 6 piston big brake kit
- Remove bottom cushion without removing seat
- Fuel sending unit
- 2007 C6 Z51 sway bar end link replacement
- Redline ATF D4 or D6 for 2006 MN6 Coupe?
- e-force supercharger #1572 need some help !!!
- Coil Mounting
- C6 serpentine belt replacement
- Removing heads and installing questions LS2
- ► ► INCREDIBLE DEALS @ CARLISLE on SUNDAY - RAIN OR SHINE! ◄ ◄
- ZO6 mufflers to 2.5" X-pipe
- LS9 vs LS3 air filters(oem)
- Odyssey battery help needed
- Changing Oil Brand
- 1985 A/C Compressor Removal Rough Procedure
- Question for those running a Vararam on their Z06
- Light oil in intake ... Plus spark plug wires off coils!!!
- Using Z06 cables to move battery to trunk
- 5k to spend on a stock LS2
- Help! Reverse gear not engaging
- Just Ordered 3.90 gears for 08 Base, Whats my 1/4 time??
- track times with 570rwhp.
- Rear 02 with LG street headers
- Logging Data via HP Tuners
- Lost 3rd & 4th (D)
- rough idle
- grinding voice from gearbox+diff
- Engine Removal Help
- Hobbs Switch Vacuum connection
- **~~ St Jude Auction #81 One set of LG Motorsports World Challenge Wheels ~~**
- Front end lowered on its own. (HELP)
- Pittsburgh area engine rebuild
- Stiffer suspension
- Halltech Super Bee MF103 Stage 1-If you are afraid to tune, don't open this thread
- Hurricane Sale - 48 Hours
- need help
- MGW Shifter
- I want a cold air intake....
- Halltech C6 Venom II (05-07 LS2) +22 RWHP!
- Katech Performance dyno's Halltech Yellow Jacket
- 1/4 inch rear wheel spacers. Help...
- Engine not getting oil?
- Stock C6 to C6 Z06 exhaust questions
- Good mods for a 2010 Z06?
- Compression
- Battery
- Rhs 427,447 or 500
- Please Help!
- Trickflow 225 Pics and Install! 56K NO WAY!!
- Harmonic Balancer Replacement
- Mgw shifter
- Best off the shelf pistons for a 402 LS2 with LS7 LXR cnc heads?
- Cut radiator shroud question
- Engine Light/fuel door
- Repost: Fix for groaning roof panel
- water in cai
- >>> St Jude Auction #80 Hydrocarbon dash bezel and AC vent<<
- Bellhousing Removal Help
- C6 Z0 with front runners
- New Mexico tuner
- Good midpipe for B&B Bullets
- Cost on Camming an 08 c6?
- Nitto NT05 Whos running them?
- Ported TB with a stock tune - Reduced Engine Power?!?!
- MAF screen removal
- Basic question about mods and performance
- Pfadt Coilovers----Adjustment suggestions
- Dyno comparison on TT C6 Z06.. GM LS7 427 Vs RHS/All Pro 427.. Dyno/Pics/Video Inside
- Why DeWitts?
- Need shop recommendation for clutch balancing
- Rocker Arm Ratio
- Dry Sump Oiling Question
- Exhaust
- Oil Pan has a film of oil on it?
- A6 LS3 12.0 @120!! headers and tune
- Axel Nuts
- ► ► WHO WANTS to DISPLAY their E-FORCE CAR @ CARLISLE??? ◄ ◄
- All corvette exhaust setup sound clips
- screeching noise
- Vegas area installers/tuners
- Will 7/16" pushrods fit an LS7?
- c6 z06 wheels fit a base c6?
- Carlisle A.R. Header Installs / Last Call For Appointments!!!
- NT05 vs NT05R on Vortech A6 LS2
- Upgrading ls2 with ls3 heads
- Iridium Spark Plugs?
- Headlights tinted with laminex? Step inside..
- ==> The CHUCK CoW Carlisle COUNTDOWN CLOCK - COOL FREE DOWNLOAD <===
- ► ► EDELBROCK E-FORCE cars - on display @ CARLISLE ◄ ◄
- ► ► HOLY CoW!!! CoW BOOSTER for FREE ?!?!?! @ CARLISLE!!! ◄ ◄
- ► ► CHUCK CoW AutoCal SUPER DEAL @ CARLISLE!!! ◄ ◄
- Cam choice...help
- How to run accufab 4500? maf?
- need your opinion and help
- Thrumming Vibration
- ~~~ St Jude Auction #78 ** Vette Bin for C6 Coupe, Z06 and Zr1~~~
- Parking Brake
- 08 A6, Park Lockout
- **Stop in and see ECS @ Corvettes @ Carlisle for your performance & tuning needs!!**
- DBA 4000 Rotor cracks/gerissen
- After market brake discs?
- Sun Visor Replacement
- HELP! New Black Exhaust Teaser.....
- Heater / Blower System will not turn on
- need some on advice for going from magnapack to long tubes...
- Tpms & ah
- boost a pump question
- How to repair a nail pucture....
- ► ► THE OFFICIAL TUNER OF 2011 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER ◄ ◄
- #### St Jude Auction #77 LG Motorsports 'Zipper Door' Car Cover ###
- sway bar end links upgrade year?
- vararam gen 2 coupler question
- C6R E-85 Racing
- Vararam snake charmer gen 2 Coupler
- Shifting question
- New GS pulls left a little
- Pfadt drag coilovers
- LG Super Pro Headers Introductory Sale- Discounted Coating and FREE Shipping!
- Newbie Performance Question
- Service charging system message
- Climate Control Head Unit Change Out
- Coil Overs vs leafs
- More Low Stroker power questions?
- This $#%@ is really getting old!
- Condensation
- Vararam question
- Headers and x-pipe question
- 07 corvette vibration,any help is appreciated!!
- Sirus converter
- Whats the Ultimate Head/Cam Package??
- Diablo tuner question
- Attn Cam guru's: Calculating pushrod length and lifter preload?
- kirban shifter install 2011 GS
- C6 Radio Problem
- **LETHAL Racing Supercharger Install Special - ECS - A&A**
- Warm Air A/C Problemo!
- 60+ RWHP gain with LG Street Series and G5X1 cam kit - LG Motorsports
- 1.75" vs. 1.875" Kooks Headers Results
- Service active handling and stuck park, but not forever
- Difference between intake ports on stock LS3 heads vs Trickflow
- 2007 c6z
- Tuners
- Report on Edelbrock E Force Install and Test on 2005 C6.
- PLEASE help me diagnose this problem! (Videos)
- Trying to get my corvette to 550 rwhp, suggestions?
- Code P0449 will be covered by warranty?
- Air conditioner problem, Any ideas?
- Torque Android App
- Z06 front gill insert in C6. I did it PICS
- Leaving BMW Jack Pads installed?
- Introducing Velocity Sway Bars. The Ultimate Track and Street Sway Bar.
- Long tube Headers with Stock Mufflers?
- Leaky Header/Midpipe install
- NEW - Quantum C6 Fog Light Brake Cooling Inlets
- No Passanger side reverse light?
- CARLISLE---who's going ??
- Finally putting in my order for all of my cam goodies
- Mcleod RST/ RXT Twin Disc Clutches-FREE SHIPPING!
- Vengeance Racing builds 447 RHS for C6 Z06.. Pics/Dyno/Video inside... MUST SEE!!!!
- @@@ St Jude Auction #76 Case of Royal Purple and a K&N Filter @@@
- >> St Jude Auction #75 C6 Corvette ZR1 Style Carbon Fiber Side Skirts <<
- TFS 235s on stock LS3 block
- Well here goes, my first header install.
- 416 stroker
- C6 Differential Chatter
- Advice Appreciated
- Battery Voltage Question
