- Blew trans this AM. Have only 1st and 2nd gear.
- What is the part # for the front O2 sensors?
- Lucas - Synthetic Oil Additive
- head install howto
- B&M short throw shifter
- Edelbrock performer RPM cam for LS1???
- Optima Battery Model Number
- ***West Coast Corvettes 20% Off Billet Components***
- determining gear ratio
- Will the dealer give me CLB recall parts?
- Oil level sender "mode of operation"
- *****************Cartek Heads and Cam Special**********
- ///////////////# HELP ON MY VERT "steering wheel colom need sevice"/////////////////
- Tried a new (to me) trick this weekend
- Carbon Build Up
- Torque spec's on OE Mag's?
- wind noise thru passenger window
- Twin disk
- Transmission and rearend fluid? Search wasn't specific to my '99FRC
- Powerbond balancer???
- Textralia OZ700: X-grip or Z-grip?
- service active handling after cam install...
- Look What I Did!!
- Three Gauge Pod for C5 Pillar?
- C-5 rotor replacement
- Headlights go down when they feel like it.
- Torque converter won't come off
- Passenger Wheel Well Access Panel Question
- How to adjust the B&M shifter? searched already
- Wheel weights and clearance?
- driver door jiggles a bit - what do i need door pins?
- K&N air induction system
- were does this connect to
- Why did GM not put 3.42's as "stock" for A-4's?
- Teflon Tape and Fuel Pressure Sending Unit
- Performance Exhaust Question
- Brake lights not working (neither side)
- Need Help Asap Header Install
- C5 Turn signal sequence
- Help Dropped Wrench
- CCR exhaust tips?
- 08 C6Zo6 shifter for sale --new
- eaking RTD shock followed by pricing shock
- What year MN6 tranmissions are better and why?
- Dealership to use for service
- Tips on how to get tires to hook up
- AC Vents
- stock shifter replacement
- C5 Suspension vs. C6 Suspension
- flooding problem
- Borla exhaust and X-pipe
- ques on stock exhaust
- FAST intake, 90mm TB, LG headers
- will driving without a tune hurt car
- Transparent catch can design
- Do Electric Superchargers Work?
- What is the centerbore for "big street" CCW Classic
- L92 Setup
- T56 Pros I need some help I screwed up
- C5 Corvette Modifications Primer
- Oil Sensor Fails Again
- Textralia 0z700
- Textralia 0z700
- is it the clutch?
- Impressions of Fast 90/90 Combo...
- Power steering, pump or sensor
- Window Motor Replacement w/pics
- baer decelerator rotors vs oem rotors
- Engine removal
- Engine removal
- TPS in New Wheels
- Exhaust Hanger - Insulator.... DIY repair.
- milk on dipstip
- Aiming HID headlights
- DeWitts Installation Question
- is this possible? radio swap with pics
- Are B&B bullets alot louder than PRT's?
- remote transmitter not working
- Who Wants A Free 2008 GM Performance Parts Catalog?
- RPO MM6 vs MN6
- C6 ZO6 brake upgrade question
- Better fog lights
- Torque tube snap ring/slinger?
- Where is a good deal on a Steering Wheel Position Sensor?
- Battery leaked into computer module
- pro-charger supercharger time.have question's.
- heater / air conditioner
- VATS function questions
- Seafoam question
- 2001 Z06 Won't Start (Starter won't engage)
- Jack for my C5
- What to check for 2001 Vert, 27K miles
- Wife's final revenge...
- Autocross Tires?
- Ernie & Zturd wake up
- Alternator/regulator going out?
- Never Buy From.....
- I need an X-pipe that will fit these headers!
- Wheel Hop: Why C5 does but C4 does not?
- Rob Bolts on a 1999 FRC
- G5X3 Idle clip, FBod.. Not a Vette...
- Tire pressure problem
- New set-up wondering what #'s to expect
- Header Question's
- clutch pedal falls tot he floor. Fluid or clutch???
- Do they make strut bars for our car?
- Oil Filter Magnet
- Silicone fluids change
- HELP! Dummy Heat Gauge is stuck past 260*
- abs Traction Control/engine power loss.. Help Please.
- Best head gasket for stock heads?
- Import to Denmark/Germany and mods
- Do 18x12s rub?
- "stuck in 4th gear" what do i do??? help
- ? On Changing Ignition Lock Cylinder
- 2000 C5 Center Console Switch??
- Gear change worth the cost??
- GM's Manual "No-Lift" Shift ?
- How do you change the DIC Welcome Message?
- Koni FSD's!!!!!
- AFR Head Vendors
- Speedometer lights
- loud squeal/screech on accel only...thoughts?
- AFR Head Preparation – Setting the Rocker Wipe Pattern
- Window problem...
- s. florida shop to install cam?
- Help on Key Fob
- Traction Control Eliminator?
- horn problem
- Dealership installed new seatbelts
- Blackwing Cleaning kit
- which is better vigilante or Yanks.
- how deep in the 12's will this get me?
- Billet High Fow Fuel Rails
- column lock
- need help cars seems to be loading up!!!! really bad
- what power steering fluid to use?
- Small radiator leak
- Cooling fan speed
- FOB Prob
- Stock Ride Height
- help understanding "C"and"H" codes
- engine cradle
- holy high numbers!... help!
- >>>>NO MORE "REMOVING CRANK PULLEY" THREADS, you NEED this info
- Radiator shroud for Air filter
- Anyone running GM Hot Cam?
- O.K. About to loose my mind.... Harmonic balancer removal issues. Need help!
- where to rent a crank pinning kit?
- Intake manifold gaskets questions
- exhaust flange
- Lifter # 17122490 LS1 ?
- Clutch problems!!NEED help!!
- Clutch Replacement
- New Race Part Service
- ruff racing and z51 suspension
- alignment and suspenson question
- Does anyone recongnize this sound? Rattle from Rear.
- Wheel/tire package for the strip
- Do I have a problem?
- Pit-man 383 Stroker Update
- To those of you that have been tuned....
- What kind of gains will i get with my 3.90 gears at the track(quarter mile)??
- I know not another heads cam question.
- Passenger side diff shaft R&R
- Performance Chips
- L.A.P.D. clutch bleeder SPECIAL !!49.95!!
- Belt squeal and wobbling crankshaft balancer
- Oh No! it happened again :-(
- ******loud Brakes******
- Thanks C5 Kidd (dd Radio Mod)
- clutch master cyclinder
- Livernois Motorsports February Head / Cam special
- oil temp on dic reads, "low"
- Air Intake Shroud
- oil temps on dic reading "low"
- Rear outer tie rod replacement?
- Who do I contact at GM about a prob with a dealer?
- Need Help Please Help!!!!!!!
- Any benifit to Dyno Tune a nearly stock car?
- Where did my gear go?
- Always shifting into Reverse???
- Diff & Converter Special
- Which car will benefit more from this cam?
- Moroso Motorsports Park,WPB
- @ 80mph Reduced Power Traction Control ERROR
- Lock doors but can open drivers side
- TRANSGO Shift Kits
- how tight do i torque the throttle body.
- Shorty Header???
- HELP:No can shift
- How to aim headlight? search wasn't helpful
- are kooks 1 3/4 longtubes and 1 7/8 interchangeable?
- 6 speed 2003
- serpentine belt & over heating...
- Tranny or Rear End Whine?
- Are all TB's created equal?
- code 1283 and Tech 2
- Which GM Brake Pads?
- Will driving with open manifolds hurt anything?
- Headers ques.
- any tuned ms4 vids?
- vette making clicking noise in front
- ??? on TSP Headers
- kp/h indicator on speedo stays on
- WrongOutside Temperture on LED readout
- Help with Wolf Craft Bolt-in Roll bar install in coupe
- Passenger Floor Acc Power Connector
- Potential Oxygen sensor issues
- Wacky Window -- Help?
- Need a screw part # please. PIC INSIDE
- Front Plate Screen MOD by Quick Z06 Installed *PICS*
- What the H-E-Double L!!????
- drilled/slotted rotors
- Squeeks - Struts?
- 228r Cam
- Oil and tranny cooling advice on 04 A4
- 2000 recall question
- Question on what to buy next?
- Corsa Touring and AR Headers
- coolant temp busted fan not working what the heck is going on here already??????
- codes!!!!!!
- Engine builders please step in
- Put in Z06 or aftermarket Valve Springs?
- Need help with codes
- Calibers
- syncro pin in the sifter?
- Drls ?
- 224 Cam
- Smith Brother Push Rods & Oil Pressure
- Head Lights will not close
- is this cam too big
- Wiring Question
- New headlight motor gear problems
- some help with p0420 and p0430 please
- SERVICE LIGHTS need help
- GM Parts House February 2008 C5 Specials!
- 98 corvette with z06 intake an throttle boby ???
- Need A4 Shop, Tampa, FL
- HUD and DIC button lights stay on
- ? about changing to T84 headlights
- Installation questions for those with a C5 Cross-Bar
- CTS-V Brakes on C5?
- Diff. Between 2005c6 Brake /2004c5
- P 0492 H C Code
- ?? Help!! I have a small leak!!!
- Vaccum line missing.
- Opinions needed for best mid area exhaust set-up
- porting?
- Help!
