- inside door lock question
- hard lesson: oil pick up tube
- Cooling Question
- Studebaker Pickup/ 99 C5
- HUD Mods?
- Fast Intake Question
- LS1 LS3 Valve cover
- 1 st gear 6 sp trans kick out
- remote cd player error
- will not start - need help
- Low tire pressure sensors
- HELP PLEASE!!!! Car is acting retarded....
- Security and Limp mode????
- A/c Leakage Problem
- Billet Steel vs Chromoly flywheel
- c5 Mods
- I think my PCM is FRIED!
- !!!!NEED HELP Pass. Cylinders Out!!!!
- L o w e s t . . P r i c e s . . E v e r !! MONSTER CLUTCHES
- what ? power steering fluid
- Oil P.S.I. sending unit
- C5 Spring weights....
- Trouble w/ downshifting a C5
- Interior lights dont work. Just installeds led's
- Any Bendpak 4 post lift owners?
- FAST installed
- Textralia....finished???
- Active handling warming up after motor install
- Active Handling Warming Up?
- Dual Zone AC Will not change temp
- Installed Battery DIC Problems?
- Getting beat up over header install
- In Dash CD player.....
- What the...F-Body parts on my C5!!
- Remove Adjustable Suspension
- What's Your Max Oil Pressure?
- Help, when installing header on a c5
- A/C belt change instructions
- Question about adjusting TICK Master rod length
- p0141 Code.. 1998 Corvette..
- C5 Z06 Headers Question
- How hot is too hot?
- ? on K'N oil filters for 04 C5 vette
- Paint Question...Detailers please step in!
- Help Have Misfire in Cyl #7
- What rotors would you suggest?
- LS7 MAF extension
- port n polished throttle body
- Electric Cutouts...z06
- Help need instructions to replace clutch 2001
- C6 HUD display in a C5- looks like someone did it! But how??
- vids from track today
- what messes up in the torque lube?
- Double Roller Clearancing
- Seafoam where to buy and how much??
- Help: what required to fit OEM C6Z06 wheels/brakes on C5 Z06
- someone might know this ques about C6 zo6 wheels.
- Analyze My Dyno
- Changed the fluid in my 04 M6 today
- TPS Checking
- Vararam install and Code 1515 - cause or coincidence?
- Exterior door trim/moulding
- 97-2004 corvette service manual on cd.....
- 01 Z06 Catalytic Converter Assembly
- Cat-back Exhaust
- Cold-Air Intake
- Ceramic brake pads
- Santa in August?
- what will i run today!!!??
- Torque conveter unlock at miss fire
- trim the spoiler when you lower the car?
- Ignition switch removal
- Alternator Help.."98" C5 Coupe
- TPM failure?
- Hard to shift into first gear
- EBC Brakes in Race use
- Another Electrical Gremlin Found
- Mechanic in Central Mississippi
- wipers will not cut off
- You want sweet rotors/pads...
- A/C Issues
- OBX LT's, basically an offshore clone of Dynatech LT's????
- One for the books!!!!! Must read!!!!!
- Anodized Rockers: Good or Bad????
- LG streets - 2.5 in Torctite clamps?????
- car wont shift at high rpm's
- Help with gear shift indicator needle
- GM Liquid Gasket/Engine Sealants Information
- hp+hp=$$$$$$
- Noise that I can't identify? hub? trans? cv?
- Rear Gears
- Dropping oil pan without dropping cradle?
- TOOLS : for DIY on C5 Z06
- Beat up and knocked down
- squeaky shifter
- 02-04 ls6 vs ls1.. What is different internally?(pistons, block, etc..)
- Reverse Lockout Help Again
- Need help '02 zo6
- Big Pfadt Sale on coilovers & inverted shocks - with free shipping!!!!
- what could help!!!
- Rollscanhardly
- Polishing stock 243 ls6 heads...anyone?
- Ok to replace steering wheel position sensor if steering wheel not centered?
- 295 tires vs 305 width
- Sound Insulation
- Sway bar help
- Plug Wire Shields.......Necessary?
- DIY ipod hoodup into HU; has this been signed off yet??
- Dash Removal - Link
- oiling and/or cleaning a Halltech Venom
- 97-00 MAF OE intake duct info?? want to verify I have the correct part
- 99-HVAC Code
- Need some info where i can get my TB ported.
- Show to benefit Nevada Paralyzed Veterans
- C5 Tranny help needed in Austin, TX
- Qustion about C5 drag pak setups!!!
- Best Clutch for a 500 HP C5?
- Your thoughts on 4.10 gears w/6spd.
- got my oil changed then this..??
- C6 Shifter - Shift knob doesn't fit?
- Rear side markers....are they required by law?
- Calling all spark plug gurus...
- Needing help on removing Cigarette lighter and Fuel Button
- diff cover DIY needed
- Can This FAST intake be fixed?
- Water leak near fuse box
- rear hatch delamination
- abs & active handling display
- Towing a c5?????
- Texas speed and performance
- could someone get the length of stock brake hose for me?
- Anyone install a 6X9 or similar speaker size in the doors in place of the Bose setup?
- will all years clusters interchange? 97-04
- HVAC dim controller fix Q?
- Rotor/brake pad question
- knock sensors - what is proper way to remove the connectors?
- Factory brake question
- 01' vert loose rear window repaired with Rhino Glue & looks good!
- A/C Compressor appears dead. How much to replace?
- High Octane Fuels Use Them At The Strip?
- What CD changers can you use?
- Cam Swap DIY?
- GM Parts House August 2009 C5 Specials
- % of HP lost with age....
- New problems with line lock install???
- Stroker Kits
- titanium exhaust tubing
- need urgent advice.
- stock wheel question
- tire dummy
- AC problem "Not common"
- C5 headlight problem
- Horse Power Rating Rear Wheel Axles
- FAST 90 intake question
- cly. heads
- Finishing Tick Master install. Need Help with connection!!
- G5X3 or MS4 ? I need help !
- Turn Signals
- Turn Signal
- Boot options for C6 shifter in C5?
- F45 Suspension and Squeeks
- Michelin Pilot Sport AS ZP ?
- Anybody wire their own LS1 to LS2 TB adapter?
- HID's on the highbeams?
- A/C not turning on
- left speaker is dead
- Dyno results
- Is the FE1 rear leaf different or same as F45 spring?
- Refreshing Bushing/Ball Joints/Tie Rod Ends
- Active handeling
- Has anyone ever measured the LS6 valve and compared it to a LS1 valve????
- Blade-style battery disconnect switch safety?
- Gas Smell Suggestions please.
- C5 Sport Seats - Seat Control Module SCM and Motor(s)
- HUD problem
- To Tune or Not to tune
- My A/C is fixed! Blowing 42 degree air!
- How to reprogram BCM?
- Worth a tune or wait?
- z06 stalling
- Please look at these tranny pics for a car I might purchase
- Cooling fan #1/fan #1 fuse problem.....
- Brake master cylinder question
- Throttle body question??
- Bought Modded Vette Have a Question
- AC orifice tube debris - how bad is this?
- No tail lights/ dash lights with headlights
- NEED URGENT ADVICE: Will the 2004/2005 LS6 Long Block Fit Easily in My 2001 Z06?
- ignition lead wire
- stock radio help
- Gass smell
- 02-04 Z06 cam into 99 vert.
- Turn Signal and Hazzard Problem. . . Need some Help
- Master cylinder replacement. NEED ASSISTANCE!
- New LGM EMCO Sequential Video at 1/4 mile-stock engine 10.86 - 127
- weird headlight issue
- Fluids Change Out
- Changed Differential Fluid Past Weekend
- did a track day now everything leaks
- PCM P0410 Secondary Air Injection System Malfunction
- Manual transmission question.
- Passenger Door not unlocking
- front end question
- Removing A/C belt..Need help
- Noise behind drivers head.
- Weird Movement!
- Injector upgrade, is a tune required?
- Florida torch red
- Running warmer than usual
- code 1571 - after hand brake adjust
- Installed HP+ pads now it's squeal galore!
- Leaking Transmission
- Ti exhaust restrictions with mods??
- needle on gauge cluster removal
- Vbp's cool sale
- anyone have a copy of US tire and rim year book
- Will putting 18 wheels front & rear effect anything?
- Broken exhaust manifold flange stud... where to get a new one?
- Split second grinding noise??
- Best air intake for C5?
- courtesy lights
- OK 1 more, what about headers on lowered car
- Ebrake
- Need Help Locating Reverse Switch
- Balancer/Cam
- Procedure for complete brake fluid flush?
- Condensation in front turn signals.
- Spark plug wires.......Accel extreme 9000
- Exhaust Hangers
- AC belt is a mofo to put back on.
- Fixing leaky butt this weekend, fastener question
- LS6 Heads
- Tech II SE Michigan
- 2002 ABS/Active Handling
- differential
- Help me find this part! Car is parked indefinitely!
- Has anyone ever had a noisy power steering pump caused by worn out fluid?
- Gear ratio question
- Exhaust Gasket
- New timing chain with cam?
- Upgrades
- Ls7 lifters sound really loud
- Help 1 ls7 lifters sound like a loud typewriter
- Curb Rash on Stock 02 thinspokes...are these Chrome or Polished?
- Use of Jacking Pucks
- Shift knob clip, Automatic
- TPS Connector Repair
- Compression ratio/ quench / and head cc's
- Who sells and stocks AC condensors for our C5s?
- Benefits of X-pipe w/ a new cat-backs?
