- G-Force suspension
- another noob question about rough idle
- LS2 TB actuating motor removal?
- LS7 crate in C5, reliable?
- Quick question about stock c5 performance specs
- Oil pressure at 130 psi!
- R&Rd the throttle body and now have non-related codes
- Horn Question
- Links to old Tech Tips & hopefully some new contributions, too
- Injector Question???
- Z06 wheels on a stock C6 coupe
- How to remove door sill plastic.
- TPMS reading high
- Which Camshaft??
- Automated Bleed on 99 C5 - Help!
- Oil pressure gauge
- diff parts numbers?
- 04 Z06 - Can I swap "front" right and left end links from side to side ?
- Header gaskets and bolts?
- Lost one of my nuts
- Pre 01 vs 01+
- 325/30/19 tires on 11" Wheels
- BCM Loss of Communication
- sterring column lock
- smaller battery in newer c5's
- Column Lock Recall
- Anyone R2 a Clutch Assy?
- Popping out of 2nd Gear
- Time for a new battery?
- Rubberized Trim Paint.... Where can it be found.
- Which Exhaust Systems clear the ECS or DTE Rear Trans Brace?
- Can someone recommend a place online to buy a valve body for my 2000 a4?
- No Alignment Tool???
- SWAP LS7 maniold to C5 corvette?
- Help! Misfire in Cylinder #5!
- Slinging grease from rear boot
- Kooks at carlisle
- replacing diff and seals
- Removing column lock bypass question
- Clutch squeak after Prestone Dot 4 Change
- Fan only works on setting #5.
- O2 sensors on LT's
- 2000 LS1 cam specs
- aux for radio
- Pulling to the right!
- New Headers Backfire at Idle Help
- A&A Edelbrock heads??
- why does?
- brake bleeding with motive powerbleeder any tips
- Powr maf 4 inch housing
- it's the diff that's going bad, I have questions, PLEASE help
- Flood Loss, NEED INPUT!!!!
- What size are the front and rear cradle bolts.
- c5 z06 vs. c5
- Custom exhaust ?'s
- Low/variable Idle on 2000 FRC
- What forum vendors sell the CLB?
- Door squeak
- Traction Control Message
- Clutch fluid question
- How much of a difference?
- Before Vararam: 462rwhp - after Vararam: 450rwhp???
- 160 stat/fan on temps?
- Pfadt coilovers and magnetic ride select
- Cost to Widen a Wheel???
- Texas Speed C5 Long Tubes Nearly Back In Stock!! FINALLY!
- 21st Century Muscle Cars NEWS!
- need help car dies - no restart
- Fuel gauge quits working?
- 59cc heads/compression and quench
- i had the common rocking seat??
- Check Engine Light Stays On
- Misfire
- Right rear brake and signal light don't work, help!
- P0343 Cam Position Sensor code
- Correct Tire Pressures (cold)
- 1999 frc corvette engine question
- Cool iPhone App
- Getting codes...Please help
- Coolant leak at Recovery tank:( stupid cheap plastic:)
- how to fix dtc code 1545 and 1546 a/c clutch problem?
- What tire sizes for 19x11 and 18x9.5?
- Rattle in Dash
- part number for CAGs
- piston to valve clearance
- sway bar rubs
- Rear Bumper Replacement
- C5 6-spd transmission needed
- Drivetrain Issue HELP!
- Repl tb and pigtail - no 1515 but now 1516 - clues?
- Door hinge
- help me spend
- just finished ls6 intake manifold install
- Is my fan(blower motor) shot?
- gauge cluster DEAD. Please help.
- c1295..need advice
- short shifter install question...
- No AC or Radio
- tech 2
- Column lock again!!
- service column lock
- Headlight wont stop running??????
- What would cause these codes dead coil or crank sensor??
- I want a new cam for my car.. Need Help.
- Front/Rear suspension cradle, dimensions?
- CAGS question
- Car won't start, stange buzzing noise
- Intermitant turn signal problem
- Changed my spark plugs and wires
- Good trade or Bad trade
- New H/C and tuned but Bucking
- Car makes a "woosh" "woosh" sound while driving slow...
- whirring noise coming from the rear of the car
- How essential is a tune for this?
- A/C, drivers side hot....
- Big fuse problem
- Have a 2000, need to diable TPMS , does the BCM control this?
- Bad news on the 2000
- Harmonic Balancer Issue...?
- Installing Nick Williams 90mm TB
- Engine harness Question?
- 2001 Convertible A4 Engine Computer Harness Repair HELP!!!!
- Slight rubbing feeling when turning right.
- Changing out Sway Bars
- how do you remove the rear rotors
- homemade rubbing compound
- Gap between top of cluster and dash
- C5 airbox/air cleaner question. I'm puzzled.
- Check It Out... Original Pfadt Installed Is Back
- Texas Speed Cam Selection
- Innovate LM-2 basic group purchase
- Trie Pressure sensor
- Front wheel bearing difficult to do????
- How to check mileage on speedometer?HELP!
- changing seat back foam difficult?
- Electrical Issue interfering with HIDs
- Climate Control center view screen
- Service Vehicle Soon?
- depo headlights?
- To cam or not to cam
- Speakin of noises...
- Electrical problems after clutch swap
- Clip-on vs Stick-on (not strap-on) weights
- No power to windshield mirror
- C6 Z51 Sway Bars
- PCM Tuned, Relearns performed, car runs 1-2 secs only.
- Installing new clutch+ more... any tips before I start?
- New to "modding" Couple of simple questions...
- C5 trackwidth
- Electrical Problem
- Valvetrain noise after valve spring change?
- remote start problems
- 1999 passenger headlight problem
- Heads up display too low
- 2003 shock cost is SHOCKI
- shocks cost are SHOCKING
- Shifter boot help
- Imlvnit
- Troubleshoot this please.
- Patriot Heads
- E Brake pawl question Picts & Vid of problem
- how many teeth are on the tone ring in a C5 hub?
- Cam install, Am I missing something ?
- 4.10s ridiculous for the corvette...
- Check Engine Light on and the codes dont make sense...
- End of Summer Cam special
- 78 to 85 mm maf wire harness
- Part # Rear Cross Member to Frame NUTS??
- Long pushrods
- Big Thanks to Everyone!!
- Could I get some help please?
- Okay, how do you get the Airbag light out of cluster???
- DIC buttons inop
- po410 a.i.r. code
- Drivers door, no power.
- New Plugs and Wires Installed..... Misfiring
- Paint questions?
- Grounding Issue?
- Are rear standard speakers interchangable w/bose rear speakrs?
- Replacing my pcm
- My vette is makin strange sounds
- Help! Help! help! ASAP! one quick question will save the day!
- Need some fuel pump/fuel pressure tech help!!
- non synthetic oil
- Front turn signal out...
- can i program a 2001 z06 FOB for a 2003 c5?
- Clear plastic fuel filter for PCV system
- what's this...fuel pressure regulator purge tube..
- Broke my trannys main shaft
- Lowering a c5 on STOCK & baseline suspension
- differences... I searched, no luck...
- Injectors ?
- w rated tires
- She died today
- East Bay Alignment Shop?
- please help me find the right cam for my z06
- On a Hot Day in Dallas - 534 rwhp
- Frankinvette who owns one
- Column lock ad nauseum
- MTI Racing SPECIAL on Pfadt Shocks and Coilovers
- Refinish Clear Coat on C 5 Plastic Top Coupe
- MTI Racing 500ci Dominator Engine Assembly
- Vengeance Racing builds 496 Warhawk... Dyno Graph/Idle Video/Pics Inside
- Lazy Speedo
- DEAD! No crank, lights, gages, nothing.
- Another pushrod question
- How do I shorten my Stock C5 Shifter?
- Sudden onset overheating
- How many mile before new brake pads?
- Dealer installed new thermastat, now coolant temp is 240+??
- Service Active Handling?
- Planning for the future
- How to remove rear bumper
- New user/owner! Advice about initial modifications...
- Not your average stuck clutch issue
- rear o2 sensor question
- Can the cycle time to Competition mode be shortened?
- Thinking about buying a C5- PLEASE ADVISE!
- switching automatic trans for manual
- CRAP!!!!!!!!!!!! Anyone know where the "main" fuse is in this car?
- Cam and Head Package?
- Ebrake Question
- P0343 and cam to far back?
- OK to run motor without serpentine belt...
- 2002 electric radiator fan
- Tire Pressure Read out reset
- Summer Intake Special w/ Free Shipping! (Vararam, Halltech, and SLP)
- Left Head Light -'00
- Engine ticking noise after ECS blower cam install video inside
- C5 z06 rims fit
- How do you reset the computer after changing the battery in 2002 corvette
- NGK-TR55 plugs right for these mods?
- I need a bypass for my bypass.....I think.
- Big Brake Kit Questions
- code p0410\traction control
- 2001 Dash Lights
- Reverse lock out.
- C5 VARARAMs INSTALLED at CARLISLE by CORVETTES OF WESTCHESTER
- Hypertech or Predator?
- Patriot dual extreme .650" valve spring question
- cam and headers or headers and 4.10s
- Knocking - Vid
- Intake manifold gasket replacement ??
- Car is FREAKING OUT!
- active handling warming up???
- Installed new fuel pump, now no pressure
- Stock 02 thinspokes w/runflats vs C6Z06 Repros w/non runflats? Weight difference?
- Supercharge or Turbo
- C5 Exhaust Enhancer Plate
- inside door lock question
