- Exhaust manifold (header) gasket replacement...not fun
- c5 leaky butt - right side
- Need Help !!!
- C5 Z06 Shocks
- Car died tonight.
- Forum Problem
- Best trans fluid for a 97-00?
- Need picture or diagram
- Warning! Hypertech company and bad service !!!!!!please help!!!!
- Traden tranny question
- Loosing coolant through exhaust??
- Made a rookie move...sigh
- How do I reset my codes?
- another lowering question
- Dead Battery - Battery Drain? "Low Voltage"
- Vette DIED Need Help?
- Engine Misfire- Bad Oxygen Sensor?
- Help my tranny is messed up since new gears installed.
- Heads for my setup?
- LG Motorsport cam kit
- Thud or low bang noise ?
- A few miles after dealer installs shocks this happens...
- A/C compressor / pressure sensor problems?
- Very loud Squeaking............................... ......................
- LS6 intake swap worth the cost and time?
- Vararam VR-B2 intake..... GOOD or BAD??
- !!! HELP !!! - Cant get HyperFlash to go away
- Low Oil Level - How much to add?
- Shorty headers will burn up your stock cats?
- Looking for a Motor Mount DIY
- 2003 z06 rear deck emblem
- reverse lights stopped working- what should I check first?
- 2 C5 questions? help
- Electronic Brake Control Module & Brake Pressure Modulating Valve
- Sound clip of my car
- Sticking clutch HALF way out!
- Headlights randomly pop-up
- Vette acting wierd, help needed
- Hawk Performance Ceramic
- Odd no start issue - electrical??
- Adjustable Sway Bar Links from Ecklers
- Before I spend the money...
- 2:73 to 3:42 conv at England Green tom morn
- Help with programming tire sensors.Yes i did search.
- Electrical problem - need some advice
- Oil Color
- Electrical nightmare...
- Question about squeeking brakes
- Intake leak: can someone identify this part
- 1998 Heater Problem
- Leaking Window
- Odd fuel gauge reading
- battery dies, pop hood and battery comes back to life...HELP
- Help - installing headers!
- Top belt tensioner noise
- How much power can you make through a stock Ti exhaust (NA)?
- Brake issue while racing. I'm stumped.
- c5 roll bar
- 2000 C5 FRC Lowering/suspension
- Traction Control
- F55 Lowering ?
- Injector ID
- Odd headlight problem
- rear fog can i wire into front fog switch ?
- Exhaust Question
- check engine -no codes
- How did your spec twin disc clutches line up?
- dic comes up low oil
- Does this sound like a clutch?
- Spec twin disc allignment?
- Service Vehicle Soon?!?!?
- Where can I buy extended fuel lines for my 98 Vette?
- Exhaust
- wtf! 8 missfire codes help!
- Yet another good reason to live in Vancouver Wa.
- Front Wheel hub from the auction site?
- 01 Z51 Sway Bars - Diameter
- ABS / Traction Control - Code 1243
- Hptuners knowledgable?
- Knocking vibration....
- How long does the car stay at a reduced power level once Traction Control activates?
- Battery dies... Now car dies?
- Torque tube won't come out !!
- installing B&B mufflers what's the easiest way without a lift..
- C5 Dual fuel tanks drainage question
- C6-Z06 Brakes on a C5
- help with codes PLZ
- Longer rear lowering bolts - unequal lengths?
- Brakes!!! (for occasional track days)
- C5 Handiling Problem
- I need better wheel studs for my C5!
- need a little help about headlights
- Oil Pressure...
- Need some advice. Who's upgraded their rearend?
- FAST 102 Intakes - Cheapest you will find anywhere!!
- replacing my radiator.....
- Im going to be installing a fuel guage ..where do i hook it up??
- Who has a underhood F/P gauge
- CD Changer, how to reset mag. eject after shipment????????????????????????
- Ls2 intake pressure
- car wont turn over
- Higher stall torque converter how-to ?
- Centerforce DF 12" fit stock flywheel?
- Winter Storage
- Stock Height Help!
- Who makes the alum. blocks/heads and valve train parts
- ---AIR PUMP info??? does anyone have the pn breakdown/2 vs. 3 wire harness info??????
- reset oil life indicator??
- Installed CLB tonight....no problems but questions
- will c6 zo6 kooks headers fit a c5 zo6
- Air bag sensor
- Four codes come up at once PO133, PO135, PO153 and PO1133
- Bougtht new LS-6 heads "questions"
- What does your mileage say when you fill up?
- Well it seems i have to replace my ignition cylinder lock. Qeustions though!
- Apsis' C5 Door Panel in Italian Nappa Black & Torch Red Leather........pix
- Misfire number 8 cylinder.
- What is the thickness of New Brake Pads?
- Strange HVAC problem
- Vengeance Racing C5 Z06 with VRX6 Camshaft Idle/Drivabilty Clips Inside
- Drivers side window wont roll down!
- Need some help on installing oil drain lines for my vortech??
- Can Stock C5 Z06 Break Calipers fit on Stock C5 non Z06 Wheels?
- How bad did I break my headlights
- A/C Belt P/N with an UD crankshaft pulley.
- 02Z: driver mirror won't retain memory setting
- Ordering up headers & exhaust. anything to watch for??
- Road Race Tires
- got these codes
- Went to track 11.8 at 120
- Can the radiator be removed from under the car?
- Need help installing polyurethane bushings (pics inside)
- Does anyone have a nice write up on oil pump install?
- C5Z06 ABS and traction control lights
- Tire diameter & active handling
- DRL's not working when car is on
- Fuel pump noise
- NEED HELP!! Popping rearend
- C5Z w/ 1 7/8 Kooks , step inside....
- red line = leaky butt?
- Please Help...Big Problem with beautiful 600hp car!!!!
- wiring guru's help needed
- What should battery voltage be.
- ***The new EnglandGreen Facility! EG GTM SUPERCAR! SPECIALS! GIVEAWAYS!***
- Weather-pac connectors...
- 6speed & rear end issues.
- Need advice for an upcoming drag race...my C5 vs. Chevy Nova
- Help! Cant seem to get a hard brake pedal!
- A question for the GY DSG3 tire owners.
- Service Procedure for Torque Tube Re & Re / Rebuild?
- Rear hatch latch does not work
- Cam Questions???
- Driver's Side Door Lock
- Ram Dual Air-Flow Question...
- Anyone swap a torque converter at home?
- Reseting the HUD in a C5
- rearend gear fluid.....type?
- are longtubes a good idea
- Queations about Rebuilt Sensors
- Questions on an LS1 throttle body
- removing interior trim piece above windshield
- CLB question- i read stickys>>02 z06
- Brake rattle
- oil filter question
- Besides radiator hoses and belt what else should be changed out periodically?
- my headlights only go down 2/3 of the way
- Torque Converter with brazed pump vanes
- non pop up headlights
- Will my MAF sensor learn to digest bigger gulps of air?
- slipping gears/ clutch failure
- crank pinning ???
- 99 Vert Fixed!
- donut gaskets
- Tune decision questions?
- removing tail lights
- Question on Tune
- Mail order tune from ECS !
- The Breathless Big Mouth Air Intake
- HELP...Shocks Inoperative
- are these signs of column lock?
- 97 evap question?
- No full throttle for 300 miles after differential fluid change?
- Lowering Y2K Coupe w/ Adjust-a-Ride?
- new vararam
- ******Headers installed and TUNED SALE!!!!!*****
- First Battery replacement.
- My C 5 wont crank ( Without Help)
- Flywheel ring gear screwed NEED ADVICE
- how to tell what gears I have?
- 98 c5 running problams, searging.... HELP
- xm radio
- New Trans Problems C5
- can a harmonic balancer sqeek?
- Shorty Headers
- Column lock issue 02 z06- i read all stickys/threads
- Scan results - what would you expect the dealer's tech to do?
- Changing front crossmember.....
- dIEING BATTERY
- 12586484 valve springs not yellow?
- How do I fix these codes/problems?
- C1761 RF Position Sensor (Out of Range)
- Soliciting feedback on the state of the art for C5 Shifters
- fuse help
- Man. A/C Controls intermittently dead
- mileage question
- E85 and pump gas
- C5 front calipers in rear with C6 Z51 rotor
- Removed F45 shocks Max Speed 159
- Remote bump starter
- Replacing light bulbs in the DIC buttons
- O E Wheels
- What size lug nuts for C 5 Z06 ?
- Head Gasket Question
- Transmission swap?
- Ring and pinion change
- I couldnt find some information NEED HELP PLEASE LOOK!
- Radio Knobs?
- Which pads or rotors to get
- LS2 engine with ls6 intake
- Pulled steering wheel, horn not working now
- c5 remote trunk release problem
- LED reverse lamps
- Carbon fiber high flow power duct...
- Build Sheet
- Anyone with a Good HPT Config File
- Piston to valve clearance with 1.85 rockers???
- Replace tires in pairs?
- Ebay F1 Stage 2 clutch kit
- HELP, Headlights will not move....
- Procharger Oil Change P1
- OBX exhaust parts, are they all made in China??? are you alright w/ that on your car?
- Throttle Position Sensor
- lowering on stock bolts
- Help! C5 wont start!
- O2 Extension Harness Required w/ ARH Long Tubes?
- GY DS D3's
- Problem with A/C
- Scratch-free lug nut socket or ???
- engine number location
- Parking Lamp
- Front Marker Bulbs
- ACA / JW HID Projector Install Help Needed - What did I do wrong???
- Errant Headlight
- LS3/L92 heads on Stock LS6?
- what size are stock Z06 injectors?
- Need tips to separate shaft from hub
- A4 Leaking at track flaged off for smoke help
- C-5 clutch spring broken
- Column is Locked - I've read stickies and have some questions.
- LG C6 Z06 1 7/8 Super Pro headers in a C5
