- More power for French Corvettes
- French corvettes need power !
- Leaking Doors
- Driving without EBCM
- 98 Headlight Problem??
- Fixing Discolored seat bolsters?
- Hello from Advanced Composite Products (ACP)
- Why do battery tenders charge so high?
- Removing A.I.R. pump, what codes to tune out with hptuners?
- My Next Mod... Knowledge
- Need this question answered please
- Brake Pulsing
- Need shifter linkage roll-pin...where can I get one???
- **NEED HELP**to plan for future.
- Doors wont unlock when key is removed
- C5 Maintenance Questions
- bad vibration..and belt slipping off.
- Speed Sensor (output)
- Code P0410
- >>> CHUCK CoW TUNING in VEGAS week of SEMA <<<
- *** Chuck CoW TUNING in WICHITA, KANSAS!!! ***
- Stuck clutch pedal??
- Z06 heads & cam on LS1 + Cheap HP?
- Changing the belts
- competitive mod
- F55 sway bar change?
- Z 51 suspension
- How to change ignition switch and lock cylinder?
- Electrical gremlins draining my battery
- When cold it starts and dies
- Does LS6 use 7 or 10 degree valve retainers?
- What is a reasonable HP figure for.....
- Need Help: Fuel Sensor
- What to look for when buying 02-03 C5Z
- Short Shifter effort Mod
- C5 2002 MAF exterior diameter
- **LG Motorsports Sway Bar and GT2 coil over package $2290**
- Traction Control / Active Handling / ABS check lights at random.. need help.
- Lower HP & TQ With lo0sse CAM bolts?
- c5 z06 maf have a screen?
- Anyone have any recommendations for corvette specialty shop near Sacramento?
- G5X3 Cam Only Dyno results
- Which Halltech System to Install?
- Oil Pressure; What does it mean?
- what do you guys think???
- Oil pressure guage showind 75-80 psi
- Maximum horsepower for factory drivetrain
- failed oil pressure sender
- Clutch bleeder line from Charlie at RPM Motors is a great design..
- Small intake issue.
- 2000 won't start
- P 1631 AND B 2721. PASS Key and Theft deterrent. Help!
- Checking Auto/trans fluid
- One more Service Active Handling
- How much labor is required for shifter linkage repair?
- Airbridge question
- How does aligning the shifter work?
- A store with every part for a corvette?
- methanol kit on NA LS motor
- Halltech Venom AIS
- Tire question
- EBCM Question
- Transmission won't go into any gear but 4th
- 2 Tech Questions
- 1963 Clear Hardtop?
- Ignition coil harness routing
- Help me find this part
- undercarriage damage
- EnduraCool Header Reconditioning Sale!!!
- *C5 6 piece blackout kit $64.99 free shipping*
- Rear end leak
- 06-07 z06 fuel pump in a late 03 Z06?
- Mighty Vac
- Can anybody scan the wiring diagram of the steering sensor
- Hvac - mode selector
- Spark plug question..ac delco
- HELP? Code PCM 0492 WTF?
- clutch prefrence and install ?
- "Check Engine" after oil change!!
- Code Master on DIC delete?
- 1.8 RR pac-1218 or 1518.s?
- P1652 Powertrain Induced Chassis Pitch Output Circuit
- 1999 water pump, who makes the best?
- Help me decide!!!
- Having fun...Unfair Fight
- Low torque numbers
- EBCM question?
- Extremely high oil pressure
- Shift light installed, not working
- What is the fastest you can do with stock heads/cam?
- Elgin pro stock valve springs?
- Power Steering fluid leaking... ideas.
- Anyone tried lucas oil octane booster?
- vibration in 4th gear
- Oil leak with A/C off
- Code PO 455
- LG Lontube Header Install
- Buzzing instrument panel bezel..
- Wheel Hop:R Cntrl. Arm poly bush...anybody do this?
- Brake Master Cylinder Bleed?
- Any write ups for switching Manual AC controls to Auto??
- Pin Connector for 6 way seats
- Clutch disc wider than flywheel surface
- Super ratchety shifting on rpm level V
- C5 Water Temp problems... or computer?
- Electrical Question
- Key Fob circuit board experts
- modding fever
- another spark plug removal help
- Anyone ever use Centerforce Clutch
- New motor help lt1
- Quality built Rear Wing and Front Splitter
- Radiator replacement
- Why a check engine light based on these SIC Codes?
- Will a 1.1" taller rear tire affect the C5 AH?
- Low Voltage message displaying on my DIC
- '99 Vert ABS issue
- Code Sheet in glove compartment
- service messages
- Help my C5 is emitting radio signals!
- LS1 Engine questions
- air filter cleaning interval
- 2001 chrome wheel refinishig
- Preferred CAI for the C5
- **Please Advise Me**
- Using factory nutted studs on stock exhaust manifold collectors
- just bought a new 99 corvette frc with some issues
- Stock 96 LT1 faster than Stock 99 LS1??
- Burning smell when I put the petal to the metal
- Trans slippage
- Hey.....I need some brain power!
- What is the best cam for my 98??
- DIC Codes??
- Help: throwing codes after heads cam swap
- New to C5s and need tires soon...WHAT SIZE?
- Header torque?
- c6 Zo6 exhaust on a c5
- rear hatch
- The cause of my clutch problems (with pix)
- FS: Corvette 50th anny clock, makes engine sounds..........
- Brake light comes on @ WOT
- Intake Coming Off - What Else Should I Take Care Of?
- looking for DIY on Phoenix tow hook install
- Horn connection/location???
- sway bar install ?
- Need help with ECBM
- Oil Life Monitor changed in 2001 (increased 50%)
- airconditioner control lights
- Can not shift at high RPM since Spec Supertwin was installed. Please help.
- C6 manual transmission in a C5?
- C5 convert A4 cycling hum issue
- Please Help. Having Issues Installing Leds in Clear corners?
- Master Cylinder Drill Mod - does it apply to Vettes?
- How to change the speed shutoff in the C5
- Fouled Plugs on Bank 2 Only
- 03 z06 electrical issues
- Random Engine Shutdown
- Rear 02 Sensors - Where do they plug in?
- Need help
- How can heads/cam net 100+ rwhp?
- Any tips on installing stainless steel brake lines?
- Please help me on my projects - seriously seeking advice
- MTI Racing Six Shooter Shifter
- Weight of a C5 Z06 M12 tranny and diff?
- Ford SVO 30# injectors
- DIY Fix for the dreaded Falling HUD Display
- Place to install headers in Baytown or Houston
- wtb drivers side quarter panel
- 6.0 Iron Block builds : tell me about yours..
- Thoughts on aftermarket exhausts. Mine too loud!
- Strange chassis vibe, any thoughts?
- What connect's to this ?
- Help with installing a Halltech Stinger on a 97' Coupe.
- eng code
- C5 Z06 Manual to Auto Conversion Questions
- **RELEASE** LG Motorsports new Sway bars for C5/C6/C6Z06/ZR1
- STONE CHIP IN WINDSHIELD,can I DIY,KIT AVAIL?
- Electrical scare...what to do now? Bill Curlee HELP!
- Question about separating Tranny from Tq-Tube
- How much HP and torque? (4L60E)
- Need advice; where to go after 400 rwhp?
- Comp Cam 921 springs and retune????
- Climate Control Different Part #
- Where to put Cutouts???
- Lowering C5 on Stock Bolts
- heads cam instal now major oil leak
- Rear Axle leak?
- Snow Tire Rec.?
- Rainy day (Time for a youtube video)
- Car will not start in cold weather!
- Inspection plate is off - what do I look for?
- Does DIC display Intake air temperature?
- Best way to Remove FRONT and REAR Cradle in home garage
- Dyno for your i phone
- New update for c6 and up
- question
- New numbers after england green dyno tune.
- front brake piston diameter
- Missing options in DIC ?
- Will these offsets work on a c5?
- Fall Intake Special w/ Free Shipping! (Vararam, Halltech, and SLP)
- EBCM issue
- How much power gain with CATs off?
- Where is peak power to the road?
- How do I replace my BPMV
- When should drag radials be replaced?
- Oil Change- how often with low mileage
- Replacing BPMV
- cracked rear rims
- Jacked Up: 1st-timer
- Used shock question
- weird elect prob, low voltage, 2000 coupe
- Headlight Motor Acting Up
- ABS lites come on ONLY when backing up
- Key/on Rduce pwr/mess No Start OBD BCM No Comm PCM No Codes
- What is the difference between the Optima Red top and Optima Yellow top?
- smokin deal on GY GS-d3's at tire rack
- 99 six speed issues
- Putten her back together!
- Convertible parade seating
- Aluminum Crank pulley with stock dimensions
- LSA or LS9 clutch part number and prices?
- Passive Locks Going Crazy
- Blackwing fit issue
- HVAC Actuators
- door handel bezel
- Drivers airbag removal!!! What precautions to take?
- c 5 climate control problem
- Thin Spokes - Which ones are Prone to Cracking
- Which LS6 valve springs and roller rockers?
- jerking during decel
- Next steps in suspension upgrades
- Cryo treating trans gears
- Haunted Headlights
- Start up error message
- Nitto Drags Vs. BFG Drags?
- C 5 hvac bo 466 hc
- TPMS kit when changing tires
- Help to clean HVAC
- push rod ?
- Possible broken valvespring.....
- From a Fast90 to LS2 intake question
- reduced power help!
- water on the floor board
- rear end noise
- new clutch
- MGW + Anti Venom = AHHHHHHHHHHHHH!!!!!
- Volt meter reading
- Oil temp sensor adaptor...
- Body Repair
