- EBCM Code C1214
- Repin PCM direct to new plugs without
- Whats the trick to the caliper bracket bolts?
- Drill hole in firewall for gauges
- Need help asap
- Does Royal Purple 5-30 meet GM spec
- check out what happen to my new drag radials
- IS AMSOIL 5-30 as good or better than
- $$$ pricing differences.....hmmmm
- tires
- Any opinions on oil additives like Z-Max?
- coating my kooks headers?
- sport seat wiring harness
- Diablo Predator Programmer
- Service Tire Mon Sys warning
- Looking for 1 or 2 who need a torque converter
- Super charger which one is best
- tire pressure sensors
- Belt squeak
- Braided brake lines???
- C5 rear diff clutch's
- what's more important, Heads or Cam?
- Waterpump replacement
- Power Slots Warped from Factory?
- Bent Control Arm or Not?
- Hood Insulation
- Eliminate 02 sensor???
- New to forum, procedural suggestions ....
- Windshield Wiper gone crazy
- 2004 Z06 fuel filter replacement
- 2000 front ride height
- AC light
- GM Parts House November 2009 C5 Specials
- Battery maintainer using 12V cigarette socket
- Back by popular demand!
- Vararam Power Duct and lean codes.
- DIC trouble code P0492
- Headlamp motor problem
- New guy with tech questions
- help please clear overspray on wheels.
- What happened to my gauges?
- help electric W/P OR STOCK W/P??
- C5 Rim offset??? OE Wheel Distributors????
- Slight oil splatter on side panels
- lowering bolts
- Very high oil pressure problem.
- code?
- Trans/Diff Oil Change (Picts)
- Service Active Handling
- Engine oil flush
- Passenger side headlight won't raise...
- Electrical WOES with headlights, dash, tails??? I think its the selector HELP!!!
- Actuator Cylinder HELP!!!!
- help with tires newbie
- A/C Compressor Clutch proble
- Am I right about my diagnosis?
- Electric problems
- Service active handling and reduced engine power with a 2000rpm idle!!!
- Vibration releasing the clutch from dead stop! Need advice!
- Service active handling with 4 codes - not just the usual 1214
- Cam Install Question
- Master cylinder bracket?!?!?!?
- Whats the difference of a Borla Touring????
- Window motor inoperative
- 2003 coupe Check Engine Light
- Help: 5th and 6th gear issues.
- tire size question
- Battery tender question
- Should I go with a cam only? Any suggestions?
- Stock C-5 Clutch
- tire pressure alarm
- passenger vanity mirror
- Outside Mirrors
- C6 TPS in an early C5???
- Technical question about the steering column lock circuit and bypass
- How To Lower On Stock Bolts
- pcv change
- yank stall question
- virginiaspeed.com......new online calatog
- Is a Borla Touring quieter han a regular Borla?
- What is causing heavy condensation on the inside of my windows?
- Header Got Bent!
- Take a look at these pictures
- Headlights auto off
- where is the proper place to measure "rake" in the suspension
- 02 bose radio fit in a 98 vette
- *Ragin Racin Sale-Best Prices- Cam Packages/B&B Exhaust/Chargers/HPTuners/RPS Clutch
- Brake Fluid & Anti lock ?
- good tuners on long island?
- Innovate Wideband Problem -AFR=21.9
- Shops in Texas that can do M6 to A4?
- When I steer left,Slight rumbling noise.
- Question for the technical folks.
- Big foot strikes the APP wiring!
- 4l60e auto convertion in a 02 zo6
- Need Tech 2 instructions to delete F45 option
- slight noise when turning the wheel
- Clean!
- My car has a mind of it's own. Help!
- HELP Alternator parts numbers 1999, 2000 & 2001
- Tranmission Repair Decision
- tpis headers and borla x pipe
- 6.0 Engine Builders in Houston TX
- 2003 A4 Shift Linkage
- P0135, P0141, P0155, P0161 O2 heater codes
- Bad BCM connections spell HELL
- Need Help Diagnosed Engine noise at high revs
- "Clack" Noise under the car...
- Horn Fixed ...Help with air bag unit removal
- Fuel Injectors
- c5 z06 rears all around and tire size question thread
- 99 C5 TDR wiring Diagram
- Rear diff question
- Rear Stabilizer Bolt Size
- Big Clutch Problems??
- 6 speed to automatic swap
- Front calipers
- Climate Control Lamp (out)
- Headlight motor problem
- Patriot Golds or Comp 921 valve springs
- c6 z06 output shafts
- Keep blowing #6 fuse.....HELP
- Alignment Specs
- Strange exhaust rattle with aftermarket exhaust?
- Need help A.S.A.P Plz Dropping oil pressure
- *** EnglandGreen's CRAZY November Drivetrain SPECIALS!!! ***
- Fall Specials in Ma.
- LG Motorsports GT2 Qualifying Laguna in car one lap
- LS1 heads on an LS2 block????
- 12 cd changer problem, 02
- Automatic shift indicator
- TCS problems - time for ABSFixer?
- tires
- Just installed tick's adjutable master cylinder...wow
- Engine dies in hard left turn...has this happened to anyone?
- Programming & Scan Tool Limitations
- Need Instructions For A Clutch Swap
- Power Steering Reservoir Replacenent
- Disable 2000 Passenger Side Airbag?
- Ebay Headers almost 3 years later.......
- what are some effective mods for a daily driver?
- underhood fuseboxes ? A4 vs 6 speed ?
- Question regarding components when doing a cam install.
- Hesitation Under Load. Backfires.
- Which Performance Trans?
- I dont have enough backpressure?
- Bad Harmonic Balancer..Need help
- Disadvantage of non-coated headers
- Just got my LS2 Intake today. What do i need to have to install it completly.
- Some changes at Monster Clutch Co.
- Auto dimming mirror quit
- Monster Clutch Co. Holiday Sale!!!
- Intake history on the C5's
- service Active Handling?
- under drive pulley
- Climate control - Blower motor broken?
- 1 3/4" and 1 7/8" long tubes...
- exhaust, cats question
- Cai
- Heads: OEM 243 verse cnc'd 243 worth the extra cost?
- A/C O-Ring Source
- White Face Gauges from Corvette America!
- Does Amsoil 5-30 meet GMs specs?
- Any "How To's" on Clutch Bleeding???
- Best vendor pricing on valve springs, pushrods and YT rockers?
- a shifting concern
- Vbp is driven
- Stock air bridge
- Car going Crazy (electrical): Reduced Eng Pwr, SES, Tires, Traction, ABS, Everything!
- Winter Storage - Down Side to Using Jack Stands?
- Which Pilot bearing - solid (bronze) or roller?
- Oil filter question
- Ever rebuilt your alternator???
- Poly Suspension Bushings
- 02 CD Changer
- considering a DIY diff change
- Slave cylinder question
- I've pretty much had it with this transmission.
- Codes Galore!!!!
- vararam filter change question
- OK.. now what
- Bill Curlee's Zo6 if running!!!!
- Programmer question
- Quick Cam install Q
- RUNNING w/ failed OIL PRESSURE SENDING UNIT
- Stock C5 air box mod
- Operation is a success!
- Interior trim/ash tray - something doesn't look right
- Bellhouse differance between C5 and C6
- Need some help
- Voltage drop while driving
- Custome Exhaust Noise Fix?
- Looking for photo of AIR Pump electrical connector
- Alignment Specs With C6/Z51 suspension Upgrades
- O2 and LG Headers!?!?!
- Wheel Crack and Question
- 2003 Back-up Lights Don't Work
- 255/40/17 versus 275/40/17 for fronts
- Advice on Stroker Decision
- LED Lights/Sequential turn signal/Harness
- Clutch is in,works Sweet!
- What else to do while drive train is out?
- crankcase vacuum?
- Valve spring coil bind
- SSR GT3 Wheels
- "Low Oil Pressure" "Service Engine soon" message
- Valve stem leak
- NAPA, or any rotors
- Help--vibration through stick shift--any ideas?
- Vibration when hot
- What I'm sure is another costly sound in my drivetrain - need experienced insight
- Crank shaft timing gear install Questions?
- Seat lumbar adjustment problem
- Clutch remote bleeders leaking at bleeder end fix?
- Great tune from williams performance
- Few questions
- Drag shocks for C5:s??
- Pfadt Carbon Fiber Drive Shaft Assembly
- Must stop this squeak!
- Vert window adjustment?
- How much hp will it cost me for 24 pound wheels?
- how much fluid????
- Can DOT 4 brake fluid be used in clutch MC?
- 2000 Won't Start
- Steering Sensor 2002: Voltage straigt ahead on Pin 5 and 6
- bose stereo malfunction
- Help!! OMW Home and the electrical system has lost it's F'ing mind
- ATEQ VT10 Universal Trigger Tool for TPMS
- ebay x-pipe... worth messing with?
- High oil pressure
- C-5 Computer problem?
- PCV on LS2 Throttle Body?!
- Problem with LS1 to LS3 upgrade
- Throwout Bearing Question
- Active handling problem
- Better cats?
- Replacing clutch on 99
- MAF relocation mod??
- Rear power deck/trunk lid release does not work
- oil leak?!?! common problem on higher mileage c5s?
- Just rebuilt my trans: On ground out of car can get all gears except reverse. Help!
- Swap 2001 BPMV with 2000
- Battery Voltage Fluctuations With Turns Signals On
- The yellow wire everyone taps on the pass. side. Where is the FUSE
- any shops around West Virginia area to cam and tune my car?
- Whats the fuel pressure of our cars????
- AutoBuffs Fuel Rail Covers QA concern
- Air/Fuel gauge pics?
- Iforged Aeros fitting on a C5?
- How to turn off my TPS service message
