- Best DIY differential swap thread!!!
- VATS-Doing something wrong
- 6 speed won't start
- Door locks
- 1998 C5 Mystery Knock
- Anyone have their throw out bearing weld to prop shaft?
- Camshaft end-play?
- Nitto Invo's, anyone have them or recommend them ?
- Time for new tires?
- Seeking info on building my own Coilovers
- 00' C5 automatic transmission acting up help please
- Door panel red reflector, pull from the bottom ONLY
- Stock 2004 model want to add 50 HP
- Faulty gas gauge
- Custom cam vs Off the shelf
- Anyone ever done the Washer Mod?
- advantage of c6 shifter
- Rear end clunk!!! Help quick
- Need some help!
- Post Your Dyno sheet N.A
- ques. if someone could help real quick
- COMP Rocker Trunion Install
- Fenders,,,,,,aftermarket, 1/3 of the price of GM, do they fit???
- Speedometer shows 15mph when I'm not moving
- can i use c6 z06 headers on c5??
- Need rough idea where I stand with HP and my current mods
- Can I drive without the AC belt on?
- Another HVAC problem! HELP!
- Left Leaning
- Visors are different.......? zo6 vs. coupe???
- Service Traction Service ABS Light
- How can I troubleshoot my climate control system?
- <<<<>GM DISCONTINUED parts list---C5 hud bezel, FRC roof trim, DOORS????
- Grinding noise from rear..
- OK new valve springs......now what?
- Loose Bezel around starter ****ch -How to Fix?
- Anybody that just bought the Vararam VR-B2
- •► ► CHUCK CoW - BOOKED in ORLANDO this THURS 10th - SUN 13th ◄ ◄•
- Remote Key Fob Sending Double Commands?
- TPS install question
- Just curious?
- FOB Retraining or Tire retraining
- Is it ok to jump start a corvette?
- Does anyone know what this is???
- Sylvania Ultra headlights
- Drivers Front Turn signal not working
- **LG Motorsports Dyno Tune Special $399**
- Why swap o2 sensors
- Is it the relay or headlight motor?
- MILITARY MEMBER STATION OVERSEES NEEDS HELP seems like the fuel is being cutoff.
- 2 Step Questions
- Can a bad REAR O2 sensor cause decreased gas mileage?
- Tire ? 315/30/19
- good cam for "cam only" car
- Best Clutch?
- Centerforce Dual Friction install question
- Cam longevity question
- Trickle charger help please...
- Tick MC - Any Regrets
- Cant decide on which heads to use...help
- Can someone tell me what battery to buy
- Air intake cleaning suggestions???
- Magnaflow 16732 Vs 15713
- Defeating the TPM
- paint
- I need help with Wheel knowledge..
- Noisy headlight
- weird metal on metal sound when I hit bumps
- Ticking sound and service engine light
- high mile 98 vette
- ABSFixer review
- New CO2 Federal Emissions Regulations. How will they affect us?
- Rough idle, codes read Bank 1 and Bank 2 are running too lean
- Car turns off when I put in gear (Drive or Reverse)
- tpms ???????????
- High Performance tire question
- Vac leak...Need Help!
- stroker engine or sc
- Front defog- A/C sometimes on, sometimes off
- **Performance Friction Brake Solutions from LG Motorsports SPECIAL OFFER INSIDE!!!**
- Moaning Steering Wheel
- FAST LSXRT 102mm Intake Manifolds (4.8/5.3/6.0L Truck) in stock!
- Rear tire clearance issue
- Steering rack bushing Q
- Va Speed. We'd like to apologize.......
- Wipers not working after removal
- Whine from Car update
- HELP! EBCM g103 ground location whereabouts?
- How do I drain a cca catch can?
- EBCM and BPMV codes
- HVAC issues
- how to change the a/c module in dash
- Wheel Bearing/Tire issue???
- clutch material in my oil?
- Exhaust / X-Pipe Question
- 300m output shafts breakage
- How much air?
- Need opinions on mods 2002 Z06
- Egr ??
- Holiday Special on Diablosport Predators!
- Does DRM Steering Rack Bushing Work?
- Rear Spindle Question
- DIC going wack
- what is this annoying whining noise?
- help swaping ls1 to ls2
- Head bolt pattern and torque #s
- Instrument panel backlight problem - Please help!
- Wanted: Tire Dressing That Doesn't Pollute Car w/ Back Dots
- rear end creaking with vertical movement
- Upgrade options
- Out with Mobil 1,in with DexronIII
- RPO Codes for an A4 Axle
- Speed Sensor Plug
- clutch repalcement
- Service Active Handling Codes Help!!!
- Torque Tube and couplings
- Power Goals
- Active Handling problem!?
- Wheel hop, rattle
- C1276 h
- GM Parts House December 2009 C5 Specials
- Bose Radio unlock
- OEM Fog Light ???
- Installing new valve springs..need a little help
- Could DIC P4020 codes be caused by a bad wiring connection?
- I'm just stupid enough to try
- bad ASP underdrive pulley
- 98 ac compressor
- No Flow!
- high oil pressure
- Does the Cadillac XLR have the same Torque Tube as a Corvette
- Prices of Used Front Caliper Brackets?
- FLT or RPM level 5 transmission?
- Glue Removal
- Can A dirty Maf cause this?
- Ok so UPS drops my transmission! Now i need advice.
- Old Friends needed some help, C5 A/T Shifter
- TPMS Calibration?
- C6 and C5 rear wheel offset. Are they different?
- Tire pressure sensors
- DTC p1220 and p1221
- C 5 Headlight doors-need help
- key fob inop
- head light conversion
- What's a 2004 Z06 Engine Worth ? 8k miles
- rear bearings
- Service ABS, Service Active Handing System, Service Traction Control System
- Does C5 rear hub & bearing fit the C6?
- Torque tube rubber bushing upgrade
- Horn switch repair.....C5 Driver's air bag
- DFW TX shop needed resleeve
- SDPC has LS6 longblocks for $3115
- Have you guys seen this
- Carbon fiber drive shaft warning
- Looking for a good overall shop in Lubbock, Texas?
- P0171 Code....
- Exhaust replacement on Jack stands
- Battery Rec's?
- tranny shifts better when cold!
- AFR gauge mounting in ashtray??
- **EFI-Live Scan & Tune w/LC-1 Special**
- Manual Steering
- ***C5 Screen Sets $44.99 FREE SHIPPING!!!***
- Where is the moulding
- [[HOW TO]] American Racing Headers install thread.................................
- An interesting thing happened on the way to the dyno
- Z06 Injectors
- How much power can you "stick"?
- AIR system and o2 not hooked up
- *American Racing Header Sale*
- Alignment spec questions after lowering?
- Opinion's on this combination
- Brake system experts, Please come in!
- HELP! #%&&* fuse
- Pulled a CV Joint Apart..
- Forgestar F14 Weights...?
- Removing power steering pump pulley?
- anyone fit a 315 on a 10" rim?
- Clevite, TriArmor Coated Main Bearings, Anyone Running With Them?
- Help with code
- Code P1870 AND P1571 Help!!
- ABS Light & Traction Control lights on all of a sudden
- C5 clutch master cylinder differences?
- WHY does the C5 aftermarket shifter not need stops?
- Replacing worn tires
- ~Just did Brakes: What the Heck is this?~
- **** 8th Annual Corvetteforum St Jude Fundraiser****
- NHTSA.gov fuel leaks
- •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
- What makes the difference in brightness.....
- I will never post about street racing again!
- ? about LS1 and LS7 heads
- I will tune your car!!!
- Spark Plug removal?
- AC Delco Plug #41-985 changed to 41-110?
- SD tune in Las Vegas
- Sunvisor vanity light bulbs...
- tpis ls6 intake
- ls2 33lb injector fit ls6 intake?
- MGW doesnt have stops?
- Ebrake shoe replacement
- Picture of coil pack need advice?
- Recommendation for clutch
- What Kind of Spark Plug
- C5 Key Fob Training Problem
- Tire Choice Michelin Pilots Sport A/S Plus or Michelin Pilot Sport PS2
- About control arm bushings...
- How to fill automatic transmission fluid? NEWBIE NEEDS HELP
- What shifter is this?
- Torque tube to trans, how is it connected?
- Modding my A4
- To Align or not?
- ATTN: ABS Fixer
- need water flow through block
- 243 Heads with special markings?
- disconnected battery
- 160 Degree Tstat with stock computer programming will it set off the CEL?
- How to pull engine... top or bottom?
- Weiand 300-111
- Looking to put Procharger in my 2001 C5
- Torque Tube Question
- IR Impact & 4.3 SCFM?
- Recommendations!! Best plugs for my Z?
- ABS problems.
- Very difficult to get into reverse
- Valve springs PAC 1518
- Tire press sensors cheap
- Older C5 Manual 6 Tranny Fluid ?
- Bolt wont come off....need help plz
- Active Handling.. comes on... randomly
- Opinions on crance valve springs?
- can rod bolts be upgraded with the motor in the car?
- Powerbond Pulley & QTP camcover
- •► ► CHUCK CoW's HOLIDAY MAIL ORDER TUNING SAVES YOU CASH!!! 50% OFF! ◄ ◄•
- I had this exhaust and I want it again but I dont know what its called!!
- Head Bolts
- which intake sounds the best?
- so my tuner tells me my stock maf is maxed...
- Jacking a C5 with both passenger tires flat
- E3 Plugs
- C6 Z06 Rims on a C5
- happy with monster 3.0
- Throttle Body Question
- Quick question about door modules
- Do I need Runflats on my C5??
- Fuel Gage stays on empty
- Headers and O2 Sensors ???
- confused about dyno tune and rear dif ratio
- Service Notfications on my new z06
- what are these two pipes on my manifolds?
