- 2004 RFA on a 1999??
- MY C5 Transformation
- I'm lost- Need advise, help, and some beer
- Help! Did I kill my transmission?
- Window stuck 2001 Z06
- how much air in tires...?
- c5 head lights up switch off
- serpentine belt
- Help!! advice needed cam content
- Have I been had?
- Verticle Lambo doors
- Help please!!!
- 2003 C5 MN6 - Cannot shift from 6th gear down to 5th! Please Help!
- Litte LED above the fuel button
- Roller rockers are pointed in different directions, need help aligning.
- Hello from Spring Mountain, here to represent our Corvette driving schools & more
- Carbon Fiber LS1/LS6 Valve covers
- Adding a HUD
- Wiper problem
- Torque converter lock and unlock
- Problem with new rear sway bar and sts
- Size of M6 Trany fill plug???
- Breathless Performance Corvette Party July 20th
- Squeaky steering wheel
- Best brake pads?
- MAF/IAT Harness Adapter
- steering wheel clicking when turning
- ### St Jude Auction #49..Tuning is not a city in China...####
- A/C Tools
- M12 or new rear end ???
- gas leak?
- Ram powergrip HD needing slave shim on c5?
- Floppy headlight
- Why does my exhaust pop/Backfire?????
- Power driver seat glitchy.....
- 2002 C5 IPC or BCM or Starter No Start
- Whats the highest lift cam for a LS1...
- What causes Hyper-Flash in LEDs?
- Oil
- Where Is The Fuel Pressure Regulator On A 97 Vette Located?
- My Corsa Daytona Exhaust sounds like a farm truck.....
- Demon Key Broke now what?
- Roll Cage pics?
- C5 starting to chug and exhaust sounds awful
- Car Running Hot..
- TPMS ....... do I need to use them?
- Will I need to Flycut with these heads and my cam? Help me out please!
- check engine light on but NO CODES on dic that are current
- A/C Gurus have a ?
- Code reading - When is a code considered History?
- Can I just cut my mufflers off for cheap straight pipes?
- Tryin to identify these lights....
- Need advice on right fender and rocker repair
- Clutch and pressure plate for '97
- How long the Random Tech Cats last??
- Exhaust system polish ?
- Reduce engine speed PROBLEM!
- Why an automatic in a Corvette?
- Anyone know a Vette tuner in Tucson Arizona?
- 243 heads on my old 200 LS1 ?
- C6 Z06 Brake conversion on a C5
- Straight pipe?
- 1/4 mile junkies come on in!
- noob needs advice on additional hp..
- Where will it end 500 cubes!
- Fuel Tank Door Problem
- New rotors
- Flushed brake fluid and now soft pedal?
- C5 Skip Shift Eliminator?
- Coup Hatch Rattle
- Gas tank repair
- MN6 to MN12 Questions
- rear end noise or auto tranny??? Please help
- C5 stopped beeping
- C5 Oil leak
- wire from ignition
- LS2 in 02 Z06 will it work???
- Coolent Leak Under Car
- a/c idler pulley stuck
- No oil pressure after cam swap........
- do it your self line lock...
- Where to tune in Minnesota - HELP!!
- quick help, pic inside...
- Bad Torque Tube Bushings - Help
- good corvette mechanic in RI?
- Power Slot brakes
- Rear O2 sensor reading
- Some bad Z's with Modular Concept Wheels [PICS]
- HELP - Headlight Door Motor Replace
- **NEW FROM LG AND FORGELINE** New wheel styles, bolt colors, and finishes!!
- Can't get any juice from my cigarette lighters!
- ADVICE?? Building an all motor Z06
- 1998 ls1 pilot bearing different than a 2001 ls1 pilot bearing
- Engine Id Numbers
- Horn Problem
- Battery Change
- WOW - LS6 78mm versus 90mm Throttle Body Power Improvement
- How to lower the temps at which fans turn on (need response soon please)
- 2000 c5 headlight question
- Electricals-Radio, etc.
- torque specs list?
- Need help from CA residents
- low oil warning
- Anyone know a good machine shop in the Tampa area?
- Straight pipes
- Diff drain and fill plug size?
- service traction, active handling.......
- Hydrlocked Engine Update
- new C5'er questions
- power seat wont move
- Check valve relocation
- Kooks race headers - what to do with AIR equip for now?
- Wagon Wheel Size??
- ABS Code
- ls6 intake manifold swap question. pic requested please.
- TB questions for new H/C install
- ~~~ St Jude Auction #48 Pfadt Coilovers C5/C6~~~~
- Looking for Cam Swap Tips
- Lesson I learned today...
- Starving for Fuel
- Will the same intake manifold fit a C5 as an F-body??
- c5 mufflers
- AM Radio Outage
- C5 Window Regulator/Motor Replacement
- Blackwing installation on a C5 Vert
- 2003 C5 auto trans replacement??
- rear hazards don't work, front ok
- 2000 coupe removable top coating peel????
- What HP are Shorties worth..Look here =>
- Coil-overs on a 2003 without mag select ride
- Cold start question
- Ligenfelter Cams
- Tire Upgrade Question
- No tire pressure #'s
- Turn Signal Help
- Party @ Breathless Performance July 20th
- Happy Birthday Dude!!!!!!!
- Best/Cheapest place to get new rear 02 sensors?
- Need to replace weatherstripping - how hard is it?
- CL remove pin
- Bulbs for Euro tails
- Free Tickets To Texas Motorplex
- will a master cylinder from a 00 camaro work for a 02 vette?
- Rattle when shutting off engine
- For all you AC wizards out there
- Newbie question
- Replacing Air Valve for Code 1416
- Oil Filter Wrench
- 4.10s and cam and heads
- Signal Light Question
- Check Engine???
- ZO6 or fixed roof coupe top....can it be replcaed ??
- How much have you spent on your mod's?
- cam specs - where to find on the net ?
- Pulled my BCM, Charged Battery, now getting Reduced Engine Power Code and more!
- HELP NEEDED: Who Makes These Wheels? What Are They Worth?
- thanks for the good info and some Q;s
- clutch wont bleed..............HELP
- Master Cylinder Sensor Circuit ??
- Another P1221 + Reduced Engine Power Issues thread
- When Air Comes Out of All AC Vents - A How To Fix Write Up with Pics!
- Which stall
- 5-wire MAF IAT wires
- How to: Dash removal and Hud install
- installing sway bars...best if wheels on or off the ground?
- WTF, tire sensors and remote key not working
- Outside Temp Sensor gone crazy!!!
- Torque Values for Ground Points?
- Will this slave work?
- 90degrees out, AC thinks it's 61degrees
- Car making strange noises by fuze box!!
- Anybody do this???
- F55 delete
- 1st Corvette and Tuned by RPM. Dyno sheets posted.
- Problems with you HUD not going up and down?
- Lowering the magnetic suspension (f55)
- Clutch and Tranny ?'s
- Stupid question..... maybe?
- Active Handling Problem!!!!!!!!!!!
- How to set up a C5 Baer Bump Steer Kit
- VIR .. LOOSE BOLT lucky
- Dead play in pedal after clutch install
- LS6 Fuel Injectors on LS1 motor
- Thanks Vette Doctors! 1st time out, 173MPH and a trip to Finals!!! [VIDEO]
- HEEELLPP!!!! Drove through some deep water....
- airbag indicator (on dash)
- Is there a writeup to change Trans & Diff fluids for a 6 speed?
- lg streets and bullets installed! video
- Individual cylinder management?
- Just Got My Vette. What Maint. To Do?
- squealing 98 coupe, belt or A/C??
- Possible head gasket leak? Please help.
- I need engine advice
- Oil Change
- Looking 4 Input
- serpentine belt noisey, squeeks
- Please help with a cam only ques.......
- yello valve springs?
- Throttle Plate - How to Open?
- Dash removal help
- Clamp @ Plastic Air Bridge to Accordion Hose
- MAF Sensor Connector - What's the Trick?
- It's 33 degrees out and it's hot.
- so many cams? so hard to decide? help please
- Removing cats...
- Might be a stupid question but.....?
- LS1 to LS6 PCV Conversion...........Need parts
- Taking apart outside rearview mirror
- Rear Axle nut torque
- What shifter is this in the 99 FRC camera car?
- HELP! What is this on the steering column???
- Valve stem seals..............How much?
- Getting P0133...most likely reason.......?
- what does your car do if the o2 sensors go out?
- What causes knock sensors to malfunction?
- Heavy Duty Front Hubs
- 6.0L block deck height different?
- GM MLS Head Gasket Question
- Stumbling at idle-- worse with ac on
- A/C not blowing? or is it?
- AC Vent Question: Air Comes Out of All Vents - Problem Is?
- How do you calculate your compression ratio?
- quarter panel - coupe vs Z06
- All you with 20" CCW wheels please come in.
- Sound clip request
- FAST LSX Bolting Torque
- HELP - Side Glass Replacement
- Help w/ O2 Sensor problem
- Help with wiring
- Anyone Install a Trailer Hitch?
- need help!!!! asap on decision making
- Voltage Experts...
- How much are you guys paying for an alignment? And 2 front mount/balance?
- 3.42 gear install
- help Brake bleeding question
- 19" Drag radial?
- Slotted Rotors
- Installed Yella Terras......now have tapping
- Basic Alignment Question: Which Wheel/Tire combo to use?
- clutch replacement problem - advice please
- ls1 to a LS3/7 PCV system? how to route it?
- Changing right front turn signal & running light
- Help me set up my fuel rails... LS7 into '98
- One of my HIDs died
- Magnesium wheel color code
- Oil pressure - HOT
- Auto Tranny shifter grommet
- Junk or Not
- Textralia single, what are the torque specs?
- Stutter
