- LS6 intake question
- Weird Gas Gauge Problem!
- Opinions of Aftermarket TPMS
- need some wiring help
- C6 Shifter, I'm Ready!
- 98 c5 hiccups?
- Help with a clutch fried in 1.5k miles
- Where to get the fuel line removal tool?
- Door Panels
- Highest reving LS engine?
- Front turn signals don't work...
- CA cars vs others???????
- Which SS lines to buy and where?????
- Tech II programming ability...
- Spec 3+. Do I need a new flywheel?
- Odd round nut on AC clutch
- 2002 Z06 Wheel Paint
- Best way to install rocker savers?
- How to get fine scratches out of black paint?
- Looking for rear suspension gurus. Thinking of doing something COOL Bushing related
- Noisey Coilovers *PFADT You Out There*
- Bent Rod Ls-1
- Fuel Filter removal tool
- oem c5 z06 wheels rubbing
- DIFC fault P1221 - Service TC & Active Handling
- Going from LS1 to LS6 w/ upgrades - what to upgrade?
- Reasonable Charge for lowering
- F45 position sensor disable
- Leaf spring question
- Can I use a 4l60 from a Camaro in my Corvette?
- How many miles can you do on a C5?
- Installing a set of LG Motorsports GT2 Adjustable Coil overs!
- questions re: striped hood
- 02 Z Steering column POPS when turning...
- blown automatic transmisson
- 02 Z06 map light won't work?/ wrong fuse descriptions??
- Injector upgrade needed with bigger cam?
- 17" wheels all around
- Hard to start after fill-up
- Installing a C6Z shifter in my C5
- Sway bar size
- Bulbs in heater air conditioner unit
- LG Motorsports Carbon Fiber Driveshafts $1195 shipped
- Anyone know who sells ZO6 spyder wheels in ZO6 C5 Sizes?
- Is it possible to bench test an air pump?
- HVAC Question
- Squeaky Wheel Noise & Braking issues
- Will C6 ZR1 Calipers fit my C5
- C5 & C6 Corvette Carbon Fiber Driveshafts
- WORLD PREMIERE, "RITA 2009" Amateur racing at it's best
- C5 427 Help
- Change wheel sizes
- Changing Fuel Tank Sensors in 2001 Coupe
- slave fittings
- Question about the col lock bypass and cags?
- Borla straight pipes with x-pipe
- Make your own oil cap breather ~$20 *Guide*
- Question about underhood light
- Programming key FOB question
- Shifter (not just knob) spins. Any ideas?
- No display on the tire pressure all four tires
- Prepare for a standing mile
- 04 Convertible Top
- problematic ABS/TCS wheel speed sensor
- Borla issues?
- **LG GT2 Coil Over and G1 Sway Bar Package $2290!!**
- Mike Norris Motorsports & RPM Transmission Winter Specials
- shock absorbers (FE1)
- In the process of torque tube rebuild
- who runs 295 tires up front?
- wrong Automatic Transmission Fluid or to much?
- exhaust question
- does anyone know how much the BB bulitt exhaust weighs?
- Hvac codes
- heater control lighting
- Max rim/tire width rear C5 conv
- cold weather shifting
- FRC and convertible quarter panels?
- Headlights refuse to turn on
- Twin Intercoolers with Tigershark
- Yeah yea I know, another harmonic balancer question
- Service Active Handling
- Centerforce DF Clutch Issues...
- Cam Swap
- Help with codes
- zo6 sway bars on a c5
- ?s about C6 LS2 shocks and manifold on a C5 LS1
- Boost-a-pump for radiator fan control
- Help Oil Temp at 175!
- Something loose in my front end?
- catback flange bolt holes?
- Can I rebuild Alternator?
- Trans Output Shaft Seal
- X-pipe question ???
- Longer plug wires?
- Hawk pads...ceramic or regular
- clutch
- Headlights different speed
- LG Pro or LG Super Pro Longtube Headers
- Tranny Problem
- Anyone really familiar with T56?
- vararam power duct C5....review
- Hooker Headers & Exhaust
- broken exhaust valve spring
- Batteries, Charging & Storage
- Changed waterpump and belts. Alternator clicking sound?
- Brake Pads - How long do they last?
- dashlights
- Need to clear up info on C6 shifters, thanks for the help.
- OIL SENSOR replaced by Chevrolet for $575?????
- Cam for LS1...
- Mesuments
- Fuel injector question
- remote will not resync?? help
- Glass top
- Rocking Seats
- ABS/Traction control lights warnings go on and off, traction control works on and off
- warm up and drain oil or drain it cold?
- 1.8 v 1.7 rockers
- Is this valve seal fully seated...?
- Installing c6z51 sway bars
- Tech 2 tool
- rear window defroster timer
- Power seat question
- F55 shocks
- climate control display dimming
- What is this?? Weird tiny aftermatket-looking buttons.
- High pitch noise on start up
- Headlights
- Shim Availability
- How or Where can I check for codes on the DIC?
- Key Fob Range and Operation... Help if you can :)
- Brake line copper washer/gasket size?
- C6 Shifter Install Help
- seat back hoop installation
- TSP Longtubes Xpipe..?
- wipers not working (replaced motor)
- Changing Thermostat
- Help! New Exhaust System= Too Much Fuel
- Transmisson swap
- Oil Change opinions please
- 427 road race build
- Oil pressure gauge pegs past 80 psi (replaceing the oil pressure sensor)
- Courtesy lights dont work with doors
- Battery charging isues
- Do I really need to do an underdrive pulley?
- Head & Cam on my 1999 1st day
- New Bullet for AFR 215 R&D complete....
- Installed Inake, Vararam, Ported TB, Plugs/Wires, Tune and now Bad MPG
- CD changers
- Cats or Tune?
- LS1 Injectors
- OIL sender
- Valve covers leaky after LQ9 Head install
- Rocking seat fixed - plastic turnbuckle height adjuster was broken also
- Great tip for anyone with a Rev-Extreme (or any) catch can
- [New PLUGS & WIRES] Detonation/spark knock/pinging seems to be gone!! PICS
- New spark plugs now misfire.
- Suspension part identification help please
- bolton performance parts
- Code P1518 - No Start Condition - PCM to TAC Serial Data Interface
- LS2 fuel rails fit on FAST 92?
- Throttle body fuse # 17 blowing
- First Time Vette Owner Having Electrical Problems
- vararam and air bridge question
- Dumb question- need help with Ctek install
- Front drivers turn signal bulb out
- Awesome tune by Chuck Cow
- Battery / electrical issue - need thoughts.
- ASA LS1 Engine
- Low oil pressure
- 2000 C5 Head Up Display stuck in low view
- 2002 C5 Z06 intermittent start HELP!!
- I need US spec tail lights loom scheme or photo
- 2004 Wiring Question - Accessory power outlet
- Charge system fault ?? what could be the resion
- Running lights and tail lights stay on after ignition off, help!
- Humming Sound
- 2003 corvette zo6 turn signal flasher
- help c5 transmission
- ARP bolts vs. studs question
- Thinking about a supercharger.
- Need 4 tenths to run 11.50 index gonna use nitrious.. advice??
- Measuring push rod length
- Fuel Tank Changes Throughout the Years?
- Is the C6 base model shifter an upgrade to C5Z?
- Console Paint Procedure
- Water Pump
- SDPC new from GM LS6 engines!
- Outerwear screen for radiator?
- Window rattle & Radio hum
- Hard to shift
- New Exhaust Systems
- F.A.S.T. LSXR 102 on a C5
- total clutch weight, lets guess
- Code P0343 - LS3 conversions opinions please
- Need Help with FOG LIGHTS
- Speedo not working after clutch change
- Need help with search....
- NGK TR-5 Spark plugs?
- Piston Slap Or?
- Corsa exhuast, how to tell what model it is?
- Adjustinf serpentine Belt
- quick belt help please
- Fob Problems
- Are you or Did you have Horn Problems??? Check This Out
- Injector Install Instructions
- attempted to lower the rear of my C5
- M6 Trans Fluid? To Synthetic or Not to Synthetic?
- Gouges in window
- Ls7 clutch, good stuff?
- What is the best short throw shifter
- Anybody Know The Part Number of 2004 Top Post Battery Cable Nuts?
- Need help with fluid changes. Motor. Trans. Diff.
- Suspension and Brake Buildup thread... with *pics*
- blower assembly help
- Will C6 Z06 sway bars fit a C5?
- Anyone ever buy a mechanic's stethescope?
- Floor Pan Removal
- Whats the best way to hook up n stay planted
- Tires and Rims ??
- RFA receiver bad, on backorder, what to do?
- ATF in power steering
- Need help removing rear bumper
- DRM Valved Bilstein shock Group buy
- DTE & Pfadt Rear End Brace?
- 10-pcm p0440 code
- Is it Clutch Time?
- Octane ratings vs power
- Power locks question
- Headlight aim problems... search helpful, but still not fixed
- spacers??
- Need Instrument Trim Part Number
- Need your help Please....check engine light.
- Intake Manifold
- Turn Signal dash indicator not working for right signal
- Introducing!! TPE's "Re-designed" Oil Pressure Relocation Kit [Bling Pics!!]
- Service tire monitor system, not the usual...
- clutch & brake fluid
- Steering wheel problem
- C-5 Fuel Level Sensor 2 Saga
- 99 ls1 bottom end max rpm
- steering column lock, yes i read the sticky.
- Vortex Rammer: unusual question
- Oil pressure at idle
- Is an alternator rebuild kit in my near future? 14.5+ V
- Seat Studs
- DIFFERENT Headlight speeds
- Tire size and NT05R
- Installed Powder Coated Brake Calipers and Brackets, some pics included.
