- Oil temp sky rocketing????
- 12 Disk Changer only plays some CDs??
- I fried my HVAC unit !!
- NO REVERSE! 6spd - What happened? Is it the transmission?
- DIC works half the time
- time for new shifter
- Would a wiring problem in passenger door cause "reduced engine power", RDCM issue?
- What it takes to optimize your 102mm FAST??
- A little help with a Vararam Power Duct install....
- How do you remove Torque Tube Bearings?
- Problems with the Radio and Seat
- Need a clutch swap..Looking for shop advice VA
- Codes p1518-----problem?
- AFR 215 Bullet UPDATE!!
- Clutch install question
- Install Complete on the New BBK FINALLY!
- codes found
- Speedo @ 2 when i am going 35MPH
- Oil Presure sensor nightmares...
- will this make a difference?
- Smoke under Hood
- Married into a Corvette...need help!
- "Monroe " shocks
- Vararam, Headers, 4.10's, and Chuck COW
- PCV Check valve
- More clutch problems
- GM Changed oil Filters or are they CHINA Copys ??
- Rattle When Taking Off
- NEW AC OIL filters ?? CHEAP-NED !! flat !!
- Analog Speedo / HUD Mismatch?
- Corsa - Loss of HP
- M6 Trans Fluid Change in a 2000
- Fuel System not venting?
- Windows98
- First gear issue.
- Problems with battery
- Bought the wrong tire size....
- engine starts then stops
- column lock question
- Help with wiring in Nitrous Outlet N20 controller
- clutch. resurface flywheel? do halfshafts too? etc?
- Clutch Install - Tools/Tips/Advice
- What ring and pinion to go with
- bo-rfa codes: u1096,u1064,u1016
- I am re-installing the intake manifold.....
- Random AC/steering questions
- Squealing belt at cold startup
- Rear bumper reinforcements
- Messed up my tire sensor...
- Will it handle the HP??
- Cooling fan question
- How to remove airbag cover
- sway bars
- Need help!! God awful squeaking from the front suspension
- Should I remove my targa top occasionally?
- Need help about suspensions
- SLP Harmonic Balancer Part Number
- Master problems?
- Squeak from Steering column
- might need clutch
- identify heads
- Increase HP with MAF Housing
- Error message
- Cant get rid of creaking noise need help
- Overdrive kicking in and out??? HELP!!!
- Tire sensors problem-----> help
- any interest in pics of an OBX header install?
- Weird noise from rear
- I know I know pull key and wait 10 seconds....
- Help! Rear Hub Replacement
- Ran out of Gas
- Need help with Camshaft Position Sensor
- Help w/codes
- HID light problems - no help w/ search
- Video of new cam in my 2002 w/ cutouts :)
- rims and tires! help
- Fob Gremlins and More
- Heat rated O2 sensor???? which one?
- Blend Door Actuator
- Cam / Tune question
- Heads up for C5's with Pfadt suspension.
- Comp Rocker Arm Trunion Upgrade - $199 shipped with labor
- AC warmer on drivers side - NOT actuator problem
- Halltech Venom to true CAI
- Can't Find Parts
- Electrical gremlin from Hell: need advice
- Swap electronic throttle for cable?
- suspension work to my 1997 vette
- Looking for bolt torques
- shorty headers
- Underhood Chirping Noise
- Need C5 jacking information...
- Water pump question
- brakes & rotors are theses any good ?
- Help, Car won't start!
- Seatbelt bolt
- shifter issue
- The dreaded chirp!! Underdrive?
- c5 differential rebuild help
- ABS problem??????
- mgw shifter order question
- TPMS problem.....
- another thermostat question
- Differential Noise
- Do C6Z06 sway bars fit on a C5Z06?
- Lifter tray bolt size???
- Stumble on cold start..what to do? ...97 A4
- C5 Right Headlight
- Right rear turn signal stays lit...?
- Strange Electrical issue???
- Is 160 stat a good move???
- Random P0410 Codes
- AC Actuator Part# Passenger & Driver-side
- Exhaust Tips
- Anyone know anything about a.r.d.?
- HVAC Control Panel Dead
- p1441 evaporator solonoid pic?
- Another Oil Thread
- security light on?
- QTP cut out wiring question
- Information on changing a flat tire?
- Anyone use the ZR1 clutch setup in a C5
- Speedometer not working, unplugged?
- S. Fla - Top Speed 1-Mile Run 4-10-10 Collier Airport $100
- Exhaust questions....Cats? Headers?
- Patching up the underside.. looks like death right now
- How to get auto C5 to 60 in under 5sec
- What has been Done?
- Charging issues, (thoughts/ comments on this?)
- Clutch install. ???????
- black wheel help
- rear end gear.
- What does this plug plug into?
- *** EnglandGreen April Specials! We're Giving The Stuff Away! [Practically] ***
- c5 normal wear points for up-keep?
- injector question
- Carpet Glue
- Tire/ wheel size question
- Injector ?
- C6 Keyless Entry on C5 Corvette
- 1999 Clutch replacement Question
- universal X-pipe
- C5 Sport Seat Cover/Foam Swap?
- P0343 CMP Sensor Circuit High Voltage
- 2000 coupe DTC codes
- AC issue after H/C
- Question on pfadt coilovers and getting the car lower
- Diablo Sport Predator tune question
- which ac compressor to buy??
- F-Body water pump same as Vette?
- Lost 5th and Reverse in 2002 ZO6
- Anyone ever modify their HUD?
- AC intermittent ON
- Need your 2 cents on this...
- Need Steering sensor
- bogging
- ac head unit issues
- EnglandGreen Whiplash II cam + 2003 Z06 =
- Cam and Heads install
- New LS7 clutch and RAM flywheel followed by transmission failure?
- G107
- Oil drain plug leak....?
- Exhaust=+HP ???????????
- LG's stoptech stage 2 brake package?
- Insturment cluster odometer board swap?
- Active handling service??
- Trunk Won't Open
- shorty antenna
- AC Actuator and DRL lamp socket
- Introducing the 457/460 upgrade
- A4 Trans Cooler Plumbing
- Vette Wont Turn Over Click From Passenger Seat
- 98 corvette blend motor
- evaporator a/c question
- NEED HELP IMMEDIATELY - STRANDED - Column Lock Bypass Installed
- LED Tail Light problem
- Trans Temp reading on DIC (Z06) how to turn on?
- Brakes brakes brakes
- Something is wrong
- 01Z with smoking problems!!
- May finally start cam swap - What else do I need to buy?
- Question About TB Porting
- Need help with two problems. Hard to start and seat issue.
- Power Seat Tilt Gearbox
- Concern regarding airbags
- fast 92 combo
- What injectors should I run?
- Clutch install check list ?
- Headlight doors open, wont close correctly
- Clutch Pedal sticky
- LED's in climate control head unit
- Where is the Fuel Filter on a 2001 ?
- 99 Fixed Roof Coupe No Fog light Wire
- Hazard Switch Question
- Quick question about chassis ground - PIC
- Bronze C5 wheels... Aluminum or Magnesium?
- Spark Plug Question
- Startup Security Problem
- lowering bolts from home depo/lowes
- Brakes stick on, help !!
- Vararam installed...thinking about removing it
- Map Lights...
- 2003 Owners Manual
- charging / battery issues?
- c5 345/35r18 fitment
- DIY window regular install?????
- casper electronics install question
- Help wih TCM code
- Keep Throwing p0137 and p0157 code
- Pop up light video
- codes u1096 u1064 u1016 need help
- Crankcase vent line, need vacuum?
- Alignment specs for modifed car...
- Brake upgrade !!!!!!!!!
- Invisicord Problem
- Michelin PS2, ZP vs. non ZP performance advice
- Breather change
- Chattering in 1st and Reverse Question
- C5 LS1 KS resistance
- DRL, blinker, relays problem
- 2000 C5 Transmission Problem
- Throttle body disassembly?
- HELP - Does anyone know the
- New Torque Converter too Aggressive
- HID lights
- Coolant tank question??
- Which Flows better.........
- new crate motor on my 2002 zo6
- Starting Tip - No Gas Pedal
- Is My Oil Pressure Too High?
- need help clutch problem
- Ebrake issue - Please help!
- On my way to work, My TC/AH "Threw Up" these DTCs?
- Code p1518/ p0300 on headers install
- Column Lock Service on DIC
- C5 with engine apart for 3 years
- LPE 24X to 58X converter question
- Oh the Codes, the Codes!!
- ride height
- Widest tire and wheel width for C5?
- TOTAL LUBRICANTS Tranny fluids
- question about horsepower
- Best cam for TFS 215 heads on an LS6?
- Project complete: Pre-filter/screen for ac condenser and radiator
- I have a slight rattle in the drivetrain. Could it be the Torque Tube bushings?
- Manual gearbox Cluncky shifting
- Squeaking after suspension upgrades....
- C6 Z51 Shocks
- Coolant temps jumping all over the place...
- C5 gauge bezels upgrade with mystery part ?
