- p0343 code still on after CPS replaced
- mini tub question
- 2001 Door Lock Module Question
- Metallic Rattle from rear of the car on deceleration
- Which torque tube couplers do I need for a 2001 auto c5?
- C6 Z51 shocks
- Oil pressure sending unit broken?
- HUD window fog
- HID Headlight Install Question
- Lowering C5 Question!!!
- HVAC module/dash unit part number?
- hard shift on low mileage '05 C5
- H/C LS6-really down on power. Any suggestions on where to look?
- 1st dyno....Are my numbers low?
- Lifter hole orientation??? Front/back/doesn't matter??
- Still diagnosing right front chatter when making left turn
- Ati crank pinning kit?
- Help Wanted on a Tuned C5 Supercharged
- Easy Fix For CD Changer Channel Cut In & Out
- What size is crankshaft thread?
- Should my Vette flow more air through the maf than my Denali?
- Shock question..'04-C5Z06 or C6Zo6
- Air/Fuel Gauges - Whos uses them?
- Is there a proven way to check if your knock sensors are working properly?
- Looking to rebuild a t56 transmission Where to get parts
- Has anyone done the....
- HELP! Rear axle ratio question
- Kooks Nationals NMCA At the Grove June 4-6
- Clutch Bleeding Problem
- rocker arm bolt hole stripped
- Question on Z06 exhaust......
- Power Seat Issue When Unlocking Doors
- Anyone in the Long Island area that can install heads on a c5?
- 243 heads vs 799 heads
- Anyone using an ebay ELM327 ebay scan tool?
- clutch line disconnect tool everyone already has
- Head change
- Fuel Return line & reguator.
- Service column lock message right after headlight install?
- DTC help
- C6 ,Front tires ,Z51
- Pull key wait 10 seconds
- Need C6ZO6 Diff clutch pack Preload springs
- to all cam gods
- Installing new rear axle
- new cam, Dyno graph. Experts please help
- Service Vehicle Soon???
- Help with Brakes plz....
- Quaife differential group buy
- Broke the tranny and diff
- Radiator petcock replacement
- Which wire to tap for LED for exhaust filler plate?
- High flow cats !!!!which ones do i get
- porting and polishing a throttle body
- Installing kooks headers
- What size front rotors?
- plz help with gauges!!!?/
- heeeeellllppppp!!!!!!!!! car failed emissions
- A/C Actuator Replacement
- 01 Z06 Underhood electrical connector pix needed
- ***EnglandGreen Entry Level Mod Specials Through June 30, 2010***
- Centerforce DF Q's?
- Safe to Raise Rev Limiter?
- Shop replacing ac compressor ?! holy s@#!
- Replacing A/C clutch with compressor in place?
- running like crap when cold then racing rpm when hot?
- New Era Performance Ported TB's
- Differential shatterd
- Steering rack/balancer replacement experts, come on in!
- P1637 - Service Vehicle Soon
- Honest opinions please.....
- 6 speed won't go into reverse even with Solenoid removed
- Harmonic Balancer/Front Oil Seal Replacement
- Going from Arp back to stock gm head bolts, arp oil on threads issue?????
- Question on Z06 Yellow Valve Springs
- C5 Left Quarter Panel - are coupe & convertible interchangeable?
- NHTSA investigating fuel leaks in 2004s
- 3.42 differential
- Ls6 vs Ls2.3.7 lifter trays, no diff other than notch???
- Aftermarket restrictorless clutch line? Vendors?
- oil pan torque
- Should I get my manifold ported?
- trans Mn6, pops out of 6th
- squeak from passenger door area
- Trans fluid
- HELLLP with Clutch pedal
- Vibration after flooding help
- 6 speed issues
- 1998 clb
- Let's Talk Targa Tops
- TRANS PROBLEM, HELP NEEDED? Thanks
- Good head and cam package to make around 500hp at the engine.
- Do c5's have a dry or a wet sump oiling system.
- Just finished installing a Monster Stage 2 Clutch and tips
- Hid Installation Help
- Power seat frame bracket broken
- Best tires ?
- •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
- •► ► [EVENT] SATURDAY CRUISE to CoW - BROOKLYN / QUEENS RUN - SATURDAY May 22◄ ◄•
- Check Engine Light On?
- Just did new brass headlight gear...already broken??
- Help, car all of a sudden went to hell
- Climate control runs constantly even after I remove the key and open the door.
- Who here is running 203 heads
- Wierd sound when AC in on
- Roof Interior
- Varnish Help?
- jp exhaust
- LS7 clutch need a break in?????
- Head light and voltage problem
- 6L80 or 6L90 in C5 Vettes?
- TECH II Help
- Issue with Traction Control?? Any ideas?
- C5 vs C6 Rearview compatability
- Steering Column Fixed, Now Rearview Mirror Isn't Working
- MN6 tough to Shift
- My Clutch Pedal Stop
- clutch slave cylinder change
- Has anyone ever removed the body side moulding?
- Driver side headlight problems
- Replacing the 2003 Fog lights ?
- column lockplate removal
- Breathless Performance vs Vararam Ram air
- idles high when A/C is on
- AC compressor electrical plug
- I think I broke my timing chain
- Reduced engine power
- Noise underhood, charging/air leaking by Optim a Battery??
- Tire pressure
- Advice
- What are these things???
- New cam and dyno #s
- gaskets for cam swap cheaper together?
- AEM UEGO Install Help
- need info on torque tube coupler for 2001 c5 auto
- 2001 C5 vert electrical issues: head light related
- check this out!
- how much weight and how difficult is it to remove it
- Jet Hot long tube headers?
- Question On Changing Diff's
- Side Corner Install?
- What kind of sandpaper to sand/paint body?
- adding power telescopic on C5?
- Mag wheel fix
- keyless entry no go
- Lowered c5 but no difference.
- Help, Code comes up "reduced engine power and kills my car!!
- Need 02Z Front Brake pad tips
- '01 Z06 Clutch Problems
- axel shaft problem
- after storage
- annoying dilemma
- Help needed
- 2000 fuel evaporator leaking
- RPM Motors
- Column lock issue or so I thought...
- Two questions.....
- Fuel pump questions
- •• Rotating Assembly Sale! - Callies, K1, Diamond ••
- Does GM use 3m brushable seam sealer?
- Ls7 Clutch and Flywheel
- ls6 clutch in a stock 99 coupe
- Question for those with late model FAST
- what kind of exhaust should i get???
- LS1 Head Gaskets '97-'01 vs '02-'04
- Formato Fasterproms Tuning and Porting Gettysburg June 18th thru 26th
- ...and I thought the C5 had a rigid chassis...
- Speedo trouble
- do C5 z06 LS6 exhaust manifolds perform better than LS1 exhaust manifolds?
- LOW OIL TEMP on dash display
- mn6 trans
- Anyone lower only the rear on stock bolts to "level" out?
- 2000 Convertible roof window fell. Can it be repaired without changing the roof?
- EBCM for 2000
- Rear brake help
- Dropping the Oil pan
- FIRST PICS PRC LS-3 Aftermarket Casting Cylinder Heads Sneak Peak INSIDE!!
- "SERVICE ABS" + "SERVICE TRACTION SYS" -- Parts Needed
- Porting 243 heads
- Squeaky pulley? Guess again- bad harmonic balancer
- Finally..Convertible top leaks repaired..
- anyone running a 305 30 19 PS2 on the rear?
- Whole bunch of Active Handling Codes!
- Engine vibration at 2200RPM
- Z06 Shocks - my impression
- Alignment question
- Let's play GUESS WHAT'S BROKE
- accessory belt pulley question
- Dipstick tube bolt thread pitch?
- Can silicone stripper be used on a rubber gasket?
- alright everyone installing my slp exhaust
- Clutch Slave Cylinder-Is it easier to.....?
- Its NOT ME,,,,I sware!
- Socket size?
- Key Fob finnicky, aftermarket options?
- Valvetrain noise!! New cam & heads
- how to change trans fluid in C5 automatic torque converter?
- What can I use to remove sticky grease?
- 02 6spd vs 01 z06 rear end differences
- tie rod end not coming undone ... pic
- C5 spindle nut size?
- Window help and clarification
- Top Speed Preparation Questions
- Alternative oil press location
- Another a/c blower story
- Spindle nut size?
- Replacement Shocks?
- REP, P1120A and P1221A. I'm thinking this is a bad TPS?
- rear end noise
- Seat control problem
- New Adjustable VetteNet Windscreen
- Help...
- MTI Racing Stage 1 Complete Track Package for C5
- need to get my odometer programed after HUD install.
- Photo break down of headlight assy?
- What spark plugs?
- Replacing my fuel pump with a Racetronix
- Whoops - tore the wires out of the wheel speed sensor
- ls6 intake, coolant tubes or not??
- alternators
- Drivers seat and telescopic sterring wheel not working
- front seal question
- 04 z06 fuel leak at crossover pipe>
- How to tell if wheels are real or fake?
- What is this clunking sound in the spindle ?
- Problem with Driver Seat in my 2000 C5! Please Help!
- C5 Radiator upgrade
- How much more power?
- 2000 convertable
- What is this?
- Z51 Sway Bars - Available w/ Pfadt Poly Bushings or OEM Bushings - www.PartsTaxi.com
- Fuel Siphon Pump
- C5 Pop up Headlight Problems
- Replace the A/C Compressor or Clutch?
- Thinking about adding NO2
- (cam install)anyone live between akron oh and pittsburgh pa that can give me a hand.
- windshield wiper
- ok guys, Im thinking of doing my own cam install. can i do it? im nervous
- Zerk fittings on sway bar bushings?
- Making camshaft removal easier?
- 1999 Fuel dripping sound
- A/C ?, blows harder re-circulate or outside forced air?
- Best cleaner for valves, combustion chambers.......,,........
- HUD fades in and out
- C5 Drilled/Slotted Rotors ($255.22) & Brake Pad Sale ($99.68) - www.PartsTaxi.com
- 5/11 - 5/18 Satin Finish Billet Racing Pedal Group Purchase
- LG Header Air tube gaskets ???
- Looking for matching chassis paint for C5 Corvette
- I can't find radiator drain on 2002...
