- 100K mile checks
- Strainge noise from the cluster???
- Fiber-Tuned Intake Manifold??
- All my interior lights dont work now.....
- **Performance Friction Brake Specials at LG Motorsports
- nitrous??? need details please
- speed unit on startup is in cluster
- Air conditioner doesn't blow as hard anymore...
- Clutch Master, Install help question... urgent
- My 03 Z06 is at ECS: LS7 Crate Motor, Katech Cam, Dry Sump & MORE!
- PCM 0650 code????? No ck eng light, anyone ever get this???
- Horn Connector Under Airbag Problem
- Upper Radiator Hose sucked closed
- Used INJECTORS for my C5 #42 or #60, Same Price?
- 25k check up?
- Random, NO Starts, but all gauges light up
- Steering Column Lock problem
- headlight problem with 1 door
- What have you done with your HP Tuners
- AC warm on driver side cold pass side
- The dreaded service AHS/TCS/ABS light with and unknown code!
- Installing aftermarket speakers?
- Brake Lines:Goodridge or Russell?
- Heavy Duty Non-Slip C5 C6 Z06 GS ZR1 Jacking Pucks-FREE SHIPPING!
- Really??
- narrowband meter a/f?
- Whats the correct answer on balance of LS7 FW when installing a LS7 clutch in a C5Z?
- A4 tuniner/tuning question
- Helllp :( Tried to change plugs and..
- c5 fuse panel diagram needed.
- Passenger window won't operate from driver's side PB
- Poor Idle after Highway Cruise
- HUD does not seem correct?
- Short in mirror circuit
- 02 C5 radiator question 6spd vs auto
- Autolite plugs ok? Just wanna get CF's opinion first before I install :)
- CorvetteFront/ BODYGUY/NEEDED
- Help! Car does not move in drive or reverse
- Missing horns
- Noise from steering column
- Corsa Pace Car installed
- HELP plastic cowl
- Brake pedal pulsing during hard cornering??
- lift points for 2 post lifts
- clicking sound on accel and decel
- TR6060 guts VS T56 guts
- Swaping shifter boxes--C6 into a C5--maybe
- 2002 with intermittent miss at idle
- AC Help / 1999 FRC
- Please help!!!! I installed clb still getting errors
- Heat is stuck on please help.
- Better to replace rear hubs in pair?
- DIC Codes - Any Usual Suspects?
- C6 shift knob on C5 oem shaft
- idle control
- 1-3/4 or 1-7/8 long tube?? plz help
- Dropped exhaust, sheared stud in process. What now?!?!
- Check Engine light Help!!! need to pass CA smog ASAP!
- install remote clutch bleeder without drivetrain drop...is it possible?
- HKE Precision 408 sale
- Z06 HUD vs. Standard HUD
- 01 Z06 shifts hard
- Better Catch Can mount
- gas cap BOKEN!!!
- Looking for a tuner
- Brake Squeek
- Car Stalling
- is it possible to drop the transmission then temporarily attach the subframe ?
- low fuel light
- C5 Blower Motor Access
- My list of Diagnostic Codes - Check Engine JUST came on!
- Trunk lid button not working
- LS2 and LS7 intakes
- I need help installing LED lights in the rear view mirror
- C5 Corvette repair manual
- headlight not opening
- question on engine removal from the top
- Headers install in Austin Tx Area
- Was Just told Vettes are Lug Centric
- C5 door panel arm rest wrinkles
- AC hot on driver side?? HELP
- Why the head light motor runs on after it is closed?
- Shocks?
- change oil dash light!!!!
- car wont idle down
- Clutch Master Cylinder.....OEM LS6 or Tick
- car reads low oil..but dip stick is full.
- Windshield wiper question. I need suggestions!
- Broken side mirror - need jack screw
- Problem with F45 Sims
- Active Handling Issue - Please Help!
- Steering Vibration/Noise
- Calling all brake gurus...
- cheapest place to buy heads for ls1?
- reuse wheel studs?
- What would bend first, the valve or the push rod
- Drvr Side Mirror Falls Off (swivels)
- Changing rear inner cv boot?!
- G6X3 cam in LS3 installation plus pictures - unique 2 piece timing cover problems
- trans oil change ??
- Thought I blew my rear
- Might HAve to Pull The Tranny- MN6. Reverse ProbLEms.
- Oil drips under left rear
- Wrapped my beautiful C5 around a tree
- Headlights don't pop-up
- Power steering to tough..
- Running warm
- Oem Ls1 valve spring?
- Need advanced HVAC (well.. AC) help
- I need the part number for the lower oil pan bolts
- 4L60E question
- Gonna need cats for VA safety inspection?
- What kind of transmission fluid?..
- Yet another HVAC question
- Fuel Tanks 1997
- Head gaskets for 06 GTO heads
- Lights have gone crazy
- Need HELP Please!! crazy DIC
- Throwing TCS Codes everywhere
- post on fixing power seat problems
- which would yield better results....
- Dic
- need advice
- Car loses power at between 2000-4000 rpms
- RAM Slave Cylinder VS OEM?
- Depo projector light install
- SLP 97-04 LS1 LS6 C5 Corvette Exhaust System Headers
- belt noise
- replacing oil pressure sending unit
- *HELP NEEDED!!*. Marietta, Atlanta area, pilot bearing and reassembly
- Practically fell through my seat.....
- Active Handling and Cruise control issue
- Car wont start...just a single "click"
- C5 Climate Control tried everything wont work right.
- Aluminum coupler bushing front or back
- DEI radiator Relief?
- flashing check engine after cam, LT's and offroad x pipe
- Cam bolts loose- how common is this?
- OIL Temp Circuit Problem
- Faster coolfans
- electric servo pump kit Corvette C5
- Reduced Engine Power after a TB installation?
- Transmission Problem?
- New Tires ---HELP PLEASE !
- Rear end fluid question?
- Not sure about this torque wrench
- 1 Day 4th of July Special
- LS1 to LS2 conversion checklist
- XS power Header install...
- C5 Engine Upgrades
- any idea for long tube headers??
- Belt slipping off constantly
- My OBX header install experience (very long, but informative)
- Radiator Drain Plug wont tighten?
- Front suspension cradle/crossmember weight?
- Air Pump
- Insturment lights inop
- C6 shifter install mishap
- Omron relay for 99 Vette
- Over torqued oil drain plug!!
- Overheating
- Cracked Radiator Tank
- B&B bullets vs Borla stingers?????
- Headlights not working
- Hey guys please come in and read..
- Dic abs active
- I almost lost my finger. [ VIDEO INSIDE ]
- Towing
- 1998 corvette rear vibration
- Towing
- Lowering question about bushings
- Car just doesnt start!
- Radiator and A/C lines
- z51 option ??????????????
- Is ABS unit repairable (3 pins came off)
- Big problem with my Corvette C5:( please help!
- July 2010 C5 Specials @ GM Parts House
- Ceramic Pad Super Special @ GM Parts House
- 2010 C6 Z06 Shocks Available @ GM Parts House
- July 2010 Hawk Pad GP (Least Expensive Price On The Forum)
- C6 Z51 Sway Bars With Free Poly Bushing Upgrade @ GM Parts House
- Headlamp motor issue
- [Middle of job help] Rear lowering bolt nut is frozen
- Electrical Issues ...
- Does RPM MN12 trans come with sensors screwed in?
- What type of MAF sensor replacement?
- ls1 water pump to ls6
- ls1 to ls6
- Handling Upgrades Completed
- Discounts for our Military Personnel from MTI Racing
- Opinions on AC troubleshooting
- Red Z06 calipers - reuse normal brake pads?
- LED Side Corners Install
- Cowl weather seal/strip Detatched!!!! What tape to use????? Easy fix w/ tape........<
- HELP! C5 suspension problem
- which module is located in front of the right front wheel well?
- Anyone using a one piece TB by-pass line?
- Getting an alignment, what specs?
- Help fix windshield wiper problem!!!!!
- Having sticky clutch issues... whats the best clutch fluid to go with??
- Fast 90 intake install question.
- comp cam pushrod length checker, how to use?
- 6.0 throttle body
- 400 rwhp LS1 C5??
- Speedometer rollback?
- What does the ebrake connect too?
- Need help,overheating issue
- Oil pressure guage fix--Maybe
- Truing Tires
- 1 to 4 shift and flunk California Emissions
- No oil pressure issue answer
- A/C Low pressure Line reading High psi.
- will I regret installing a 224r cam?
- >>> St Jude Auction #45 LS1/LS6/SBC Valve Spring Compression Tool <<<<
- Power plug under all pass seats?
- Of the top rated longtubes
- 1999 Brakes
- P0410 Help
- LS2 into C5 questions
- So, any suggestions before I get raped at the dealership for $672? (HVAC)
- A/C problem fixed!!
- intake manifold LS2 vs LS6
- installing heads
- Squeaky Hawk HP Plus pads
- C5 2002 Fuel pump installation
- early ls2 throttle body vs late ls2/ls7 throttle body
- Wipers stop workin! Need ur help
- Added Z06 springs?
- Car running hot can you plz help
- Please Help : Service ABS, Active Handling, Traction System
- How does the fuel tank system work?
- 2002 convertable
- auto transmission no reverse Help Please
- C5 vs c6-suspension & handling
- separate torque tube from trans, a 2 man job?
- Soundproofing project held up
- Have codes, looking for ground
- Diamond Pistons blowout sale!! Lowest prices ever offered!!
- Vararam intake fitting issues
- LG Motorsports Summer Cam Specials!
- Engine Noise
- A/C Compresssor suction screen size?
- Right front pop when turning steering wheel...???
- Found something strange behind door...
- Need help! Service ABS/TRAC/ACTIVE HANDLING
- Sun Visor Replacement
- Idle issue/Tap
- 2000 Lumbar hoses
- C5 distributors
- Want to replace Air Valves
