- Relocated Battery to trunk
- Edgar Perez and VDP combine to win 2010 NMCA EFI Class Championship
- Can someone explain how hydroforming works?
- Hp gains ?
- Winding Alternator
- Dies on takeoff.
- Well, the clutch finally gave way
- lumbar deflates only.....
- Need help draining coolant
- Spark Plug Choice
- descreening maf with vararam
- Stero display burned out?
- Cleaned grounds, now "Service Coloulm Ock"?
- Need Help ASAP With Under-Drive Pulley!
- Service Column Lock
- Headlights problem
- Starts and Stalls, 1999 C5 Corvette Fuel Questions!
- Switching lubricants
- Stall converter questions
- Telescoping Wheel
- Quick Question on TPMS
- Question about abs and act hand lights
- Need help with header install
- Exhaust advice for C5 50th anniversary
- Dreaded Fuel Leak in Left Tank
- '00+ Harness to '98???
- TPIS long tube install went well. =)
- Checking oil level...
- Difference between front and back tires
- Ground locatrions?
- Anyone leave Seafoam in their oil for long periods of time/miles?
- Me bums getting sore, is this part available???
- 2000 C5 TPMS Issue
- 10-PCM - No Comm
- Passengers Headlight issue
- drls turn off when I turn on when I turn headlights on
- Sway Bar Kits Available - GM Eibach Hotchkis - www.PartsTaxi.com
- C5 Cold Air Intake Sale - Vararam SLP BBK - www.PartsTaxi.com
- Brake Rotor Specials - Brembo, Baer, ACdelco! - www.PartsTaxi.com
- C5 Hawk Performance Pad Sale - www.PartsTaxi.com
- October 2010 C5 Specials - www.PartsTaxi.com
- US Military Seat Armour Car Towels for all Cars and Trucks
- no turn signal when I need them
- [Another] Spark Plug Thread
- coolant tank question
- A4 to rear leak
- Fan is not running instead the lights are flashing
- Part Number Request for my 97
- Speedo droppiing to zero under 25 mph???
- failed o2 sensor or exhaust leak
- October 2010 C5 Specials @ GM Parts House
- Hawk Pads - Lowest Price 10% Guaranteed @ GM Parts House
- AC Delco Drilled & Slotted Rotors Super Special @ GM Parts House
- C6 Z51 Sway Bars - Free Poly Bushing Upgrade @ GM Parts House
- front brake noise
- Differential Temperature
- F45 Delete with Tech II Not Working
- Help!! Head lite doors don't close???
- Thanks to these great vendors!
- Need to relocate my IAT sensor
- how do i adjust my headlight?
- Drained my Coolant (Drain-->Fill). Easy DIY !
- Service Bra
- Transmission replacement at 37k miles?
- Replacement Computers.. Nothing new from GM. Thank you Government Motors
- Hvac showing negative numbers
- A4 Shifting Problem - DTC 1810
- Fuel Trim System Lean Bank 1 & Bank 2 ???
- Is There Any Write Up's On How To Install The Raptor Shift Light In The A/C Vent?
- what's wrong with my lights ?
- 2001 door removal
- Radio will not turn off with key pulled/door open
- Intake valve hit piston?????
- How long to Catalytic Converters last?
- Headers Sale @ KY SPEED - Kooks, LG, ARH!!!
- Squeak Ideals
- Fuse Block repair???
- Patriot Valve Springs
- LS7 Clutch Kits Now Available w/ Ram Aluminum Flywheel - www.PartsTaxi.com
- Adjust TPMS range
- L92/LS3 Heads-Help with fuel and intake manifold
- Stripping
- C5 Coolant Temp Higher than normal
- Q: X pipe placement?
- Code tcs
- HELP! Some major electrical problems
- Slight Shudder in the car
- **Sale on RPS CLutches**
- Clutch Line Length
- \\\people with double dins///
- Multifunction switch part numbers
- My vette and 04 Cobra
- oil filter c5
- Horn stopped working ('01 'vert)
- Cheap 2 core radiators from Ebay? Your thoughts? Ya im a cheap ass!
- can harmonic balancer cause flywheel to shatter
- fuel door removal help
- sorry double post
- what are these valve springs?
- Brakes humming.
- Where to connect fuel pressure sender?
- Clamping force in question !
- Correct Momo hub adapter # for C5?
- Please confirm for me that cam with 110 lsa installed with +4 degrees advance=106 lsa
- Transmission Swap
- Redoing my Interior Thread
- C5 Electric Cooling Fan problem
- Are valve length and size all the same for each Corvette ???
- serious?
- Can you pull the motor from the top or in a garage ???
- Vararam Install Question
- ECS Forged 346/Novi 2000-SC 800 package
- Cranking issue
- Rear Wheel Studs
- >>>10% OFF ALL Online Orders in OCTOBER from LG MOTORSPORTS<<<
- Whats involved in replacing this trim/molding *pic*
- Need Help w/Brake Scoop Installation
- Brights not working
- unbalanced flywheel cause misfire?
- Front sway bar or not to front sway bar....
- •► ► AUTOCAL E-MAIL TUNE TOOL @ Corvettes of Westchester - ON SALE NOW! ◄ ◄•
- C5 seat bevel replacement
- Anyone running LS6 manifold WITHOUT a tune?
- Starting issue.
- Cam is done, Getting the car to the tuner?
- Rad. water ????
- Help!!!! Massive, mysterious oil leak
- Weight vs gas mileage
- Need Help, What Transmission Brace Should I Go With?
- need help with this thing I found
- Has anyone done a soild rear on a c5 here??
- Wiring
- Service ABS - dealer says lots of luck?
- LS2 intake and TB on LS1?????
- Tech'ie question-Torque converters
- Air suspension or coil overs
- Overheating Veterans
- Changed BCM need help!!!
- 02 oil pressure?
- Bad Squeak – Front Suspension – Solved – Sway Bar Bushings
- LS7 clutch problem?
- 18/19 Street to a 18/18 for the Track???
- Need help with leak
- FRC Mini Build
- Interior lights not coming.....I don't think?
- ZO6 Air Box
- Right Turn Signal Acting Up... Help Needed
- What is stock fuel pressure?
- 99 FRC M6 Wont Crank...
- washer and coolant tank
- Help 02 vert will not start!
- Design this cam !
- security light
- Reverse Giving Me Issues... Advice Needed
- lt1 heads fitting ls1
- Centerforce Dual Friction Centrifugal Weight System Failure
- Paint over chrome?
- Weird no start then starts question - Got me scracthing my head.....
- Cam swap....Oil pump???
- Best single disc clutch
- Pre-2001 LS1 Questions
- to gear or not to gear?
- I reset "oil life %" but says "change oil soon"???
- Valve Stem
- active handling & ABS not working
- fuse boses..confused
- A/C compressor noise
- Tire Question.... Bridgestone
- clunk in drivetrain
- ls7 intake
- I Need help
- Changing shocks=Changing ride height?
- P0300 code and flashing CEL
- PICS: Heavily Modified LS2’s look to Billet Custom Products.
- Help to ID this broken part (pics inside)
- exhaust cut outs
- Cam install, few pics.
- cant program my fob
- Gas under pass. seat
- C5 Vanity Mirror Lights.
- Need Help Plz, LS2 LS1 TB Harness, REP P1516
- 2000 coupe auto trans question
- how difficult to install heads
- shifter wont go in reverse
- M6 lube change, nice results!
- Instrument Cluster Driver Information Display Switch
- head lights stay open
- Nitro AKA Nitromethane has anybody ever "Tipped the can"
- Speed Bleeders....who has them?
- Where to buy OEM Key Blanks?
- Are these tires still good? Cracking on the tread (Mickey Thompson drag radials)
- timing and fuel table needed
- Slotted vs. drilled rotors
- oil fill cap vent and filter?
- Interior light
- skit kit
- Pop up headlights
- Halltech Air Filter Cleaning Question
- What r the symptons of a bad brake booster?
- Non run-flats and LTPMS idea
- Halo weather strip seal questions
- Trans leak
- RPM's polyurethane TT couplers
- Check Engine Light Rest......
- A couple Head/cam questions
- LS6 intake throttle opening size???
- Seized 02 Z06 engine.
- small lightweight jack
- c5 or c5 zo6
- Computer...i guess ? Help !
- Where is the EXTERNAL thermostat located?
- rack and pinion c5 2004
- po351 coil a primary ignition malfunction
- 6 spd. help needed
- ebcm problems
- instrument removal
- Fuel Gauge ? not like the rest...
- Fuel gauge goes Empty after half !!
- Code C1288???
- Hydraulic/Clutch Issues HELP!
- ACA Lights No Low Beams
- To Mod or Not?
- Battery minder
- PRC 650 spring kit - no retainers?
- Need some EGR and Intake Manifold help
- Help Needed! Turn signal lights won't shut off!
- will tpsm from an 02 fit a 97
- Help Winhshield Wipers problems
- 110 Octane Fuel????
- On the fence about changing shifters?
- Lowering nightmare - ball joint question
- Low Oil Pressure
- ** New ForgeLine News from LG Motorsports **
- Will the engine run with the MAF disconnected?
- Vbp's fall sale
- Vbp's fall sale
- Help calculating DCR
- Sudden low voltage to cluster
- Replacing knock senesors in a '97
- A/C condenser needed if I never use A/C or defrost mode?
- 1999 fuel gauge malfunction
- QA1 Coilovers
- 1998 C5 LS1 to LS6 intake manifold swap Continued...
- ABS issues....
- buying cam, need some info.
- I need the templates for the Z06 brake ducts
- Thermostat change time
- Any special tools for replacing spark plugs?
- Sway bar end link ?
- C5 hood struts
