- Foglights on a Z.
- Slave Cylinder Tolerance? (Pictures inside)
- looking for part
- Suspension Mods & Performance - www.PartsTaxi.com
- i BROKE SOMETHING NEED SOME HELP.
- Intake manifold removal & replacement ?
- DIC Locked up! Electrical Problem?
- Auto dimming mirror upgrade
- Bolt-on sequence of mods
- Electric Actuated Exhaust Cut Outs
- Best way to increase HP without supercharger?
- Gears Grinding?
- manual transmission wont engage gears
- Cam Selection...Stock Stall...(Please Look)
- Check engine code after mod
- FREE Shipping on ALL C5 LG Long Tube Headers @ JWM
- Headers? yes/no
- Are these symtoms normal after throttle body install?
- What is the length/pitch of stock tensioner bolts?
- Kickoff 2012 Sale! LG Motorsports World Challenge Wheels-$1299 FREE SHIPPING!
- Seat Options... Total Rebuild?? Yes I searched. Odd problem also..
- HUD and Gauges not reading the same
- Question on my driver side head (pic included)
- Looking for add on power for LS1
- When do I need better injectors?
- Should I change my fuel filter?
- ACA HID Installation: Methods (if any) For Hiding the Electrical Wiring
- Questions about RX Performance Catch can
- Nitto 555r for street/OCCASIONAL track use?
- dic going haywire after replacing fixed ebcm
- 98 corvette magnasteer failing..
- If I blow the LS1
- Tranny issue...shifting difficulty for 1-3-5 when cold
- Elite engineering catch cans on sale
- Alternator making weird whining sounds, sounds like I have a blower- But I don't. :(
- Rocker arm nuts
- AFR 205 Flow Numbers
- suggestions to a new member
- What type of steel are C5 frames???
- MN12 transmission troubles
- Other Cars Key Fobs Causing Error Codes
- could a vacuum leak be the source of my hesitation?
- What to buy to get a 85mm maf and 90mm tb to fit
- LSX LS/6 Thermostat question
- Projector light problem 02Z06
- ~~~~~ St Jude Auction #3 C5 Interior Door Handle Bezels in Carbon Fiber Hydrocarbon
- *** New promotion for 2012...Cartek line lock special ***
- 2000 FRC engine a little rough
- Help - 2001 C5 Will Not Start
- 1999 C5 MAF issue?
- Is this tire safe?
- alternator issue
- Engine Stalls following LS7 PCV conversion
- Inner shift boot not flush, and Name That Shifter!
- Oil Pressure Reading
- elp bad coolant leak top right rear of engine
- Tough header choices...opinions, suggestions welcomed!
- C5 Z06: LS6 or LS7 clutch?
- 2000 vette code 1217
- Need helpful tips to replace my torque tube couplers.
- Stock flywheel and mcleod RST
- Houston Area Vettes
- Throttle body install step by step: Help a Noob out!!
- headlights up and tail lites out~fuse?
- Will I need different length pushrods?
- Throwing code C1283 and Active Handling message
- Service colum lock
- 01 Z06 Not starting
- head install help
- Slave cyl went out...now I have a question
- Need Help...Flywheel won't come off.
- can't get it in 1st gear,,
- LS2 swap--Knock Sensor tuning table changes?
- can pulling pcm fuses kill battery?
- Magnetic Selective Replacement on 50th Anniversary 2003
- 2011 C6 Z06 shock install question
- How do I physically disconnect the F45 plug on the front shock?
- C5 5 spoke chrome rims
- Z06 motor to Non Z06 Vette
- 90mm Throttle Body
- Need a new clutch, guys. 500+hp
- any body bought a Texas Speed & Performance motor b4??
- 7.5 pushrods with 241 heads
- Front bumper adjustment.
- Lights don't work period following an HID install..
- Key FOB
- c5 cam install w/o pulling heads help?
- Odometer reset - on accident, I swear!!
- Slave cyl.
- Built 383 or supercharged for a base c5
- How do you fix the Fuel gauge issue?
- rear rotors warped. recommendations?
- for anyone that has ordered plug wires from gm parts warehouse
- Need a GOOD alternative to Headlight insulators/tab stops/bumpers
- Possible to replace JUST the OEM Cats?
- driver's seat won't go back
- service column lock victim
- Looking for cam ideas for my car. Any suggestions?!
- Pop up head light repair
- Am i missing some nuts?????????
- Locked out...now what?
- (resolution) 2001 C5 A4, Car shuts off randomly, hard starts, NO CODES
- 1234,1283 and 1288 codes
- Car jerks to right when driving normal
- Brake Fluid Change - seeking advice
- Need help with spark plug gapping
- Odd shifting/sounds from auto tranny drivetrain?
- Headlight Removal / Fog light replacement ??
- callaway honker
- PIC: Name these 3 sensors...
- chirping from right rear area
- Valve spring replacement question
- Heater core replacement
- Harmonic Balancer ?, Can not find answer
- Water pump gasket failure w/ galled bolts - what to do?
- C5 oil pan queary
- 1987 C5 cant get the fuel pump to run hooked up
- Does this sound like Piston Slap?
- Oil Pressure ???
- which fuel pump for a stock set up
- Igntion OFF and DIC errors scrolling?
- Need Help in ATL area for 2004 coupe
- PLEASE HELP! Heater/AC Vent stopped working!
- Rebuilding my T-56...
- C5 Coup Seat Loop Roll Bar ??
- Need best budget in-lb torque wrench
- Fuel additive
- wheel speed sensor wiring ?
- 02 Passenger Window Probelm
- Installation Instructions/pics for Elite Catch Can on 2004 LS1/LS6
- Wife got a lot of errors last night
- How to remove intake? (fast 90)
- Install A/F AEM UEGO
- Pass side window is having issues
- T-Top seals
- fog light wire
- 98 AC Noise when turning off
- Buying another lift, 2 post and a drive on...........MADE IN USA?????????????????????
- I'm going to rebuild my engine.
- Rear defogger glue
- C6 wheels on our C5 corvettes
- Tune?
- ★★ ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! - SALE ENDS TODAY!!! ◄ ★★
- Heat related scraping noise?
- 01 with 30K miles ready for a refurbishment
- Torque Tube rebuild questions?
- Fuel Filter Installation Question
- During Install
- Kooks header problem?
- Vararam install complete but now….
- C5 Vert Overheating Momentarily
- Happy Holidays From VBP!
- Projector light problem on C5 Z06
- Code A6-SCM-U1255H
- New Borla stinger exhaust question
- Column Lock
- "Short shifters"
- Date codes on cylinder heads??
- Chasing down squeaks
- C5 Z Wheels widened to 12", need help
- Windows steam up suddenly while driving!
- Coolant Leak
- Oil pressure questions
- Just changed headlight gear, now lights won't go all the way up or all the way down??
- "LOW COOLANT" message wont go away!!
- Cam Install Special at HorsePowerAddicts!! (Delaware)
- oil pump gear orientation
- Oil Pressure Sending Unit Replacement
- power window making noise
- Replaced EBCM, still have code, messages and lights..
- Column lock bypass, money well spent
- '03 Z06 M12 T56 question
- Has anyone tried this?
- Suspension Woes HELP!!
- Battery Tender/bad charge
- Halltech Killer Bee II LS7 style intake NOW for your C5!!
- Security Light Woe's
- Crank turned without timing chain, issue?
- Shocks Inoperative Error Message
- How to needed: Replacing half shafts
- Sale Ends January 2nd! Your going to wish you have a CoolIt! this summer!
- Window sticks and HVAC Blower noise (fluttering)
- C6 Air Filter on C5
- 4l80 output shaft
- Baer 2-piece rotor and caliper clearance
- Headlights Inop,Alarm is acting strange,need help
- Cracked bell housing 99 M6
- Treadwear and Tire Noise
- Gasket kit options for LS1
- Wheel alignment for more road feel?
- Torque Tube failing? Metal shearing sound?
- help me build my new FI motor
- Best ceramic coating for used headers?
- Crower 00572,springs,wires NEW
- Happy Holiday From VBP!
- C5 exhaust turn downs before axle
- MONSTER CLUTCH- who runs Level 1 or 2?
- rear spring spacing...
- If you don't have Fangs yet, now is the time! Sale ends January 2!
- Need help with Traction and ABS Codes for 2002 Z06
- Throttle Body/Intake cleaning
- Cleaned my engine bay and now it won't start.
- Suspension issue
- Window Motor Replacement
- How To Remove Hood Liner
- Key Fob
- •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
- Year End A&A/ Edelbrock Supercharger Sale!
- Tire Pressure Monitoring
- Torque tube failed, can it be re-built? 99 c5, six speed
- ★★ ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! - WATCH THE NEW VIDEO ◄ ★★
- wheel not locked, service colum lock msg
- Newbie Questions
- Clutch Hyd Line coupling
- Recently getting exhaust smell in cabin
- Lug nut removal on HRE wheels?
- Any Vette Body Techs Here?
- Installed American racing headers and catted 2.5 x pipe now DRONES! What should I do?
- Ticking issue.
- Kooks mids -> catback. Flange not even.
- EXTRA SPECIAL motor from VIRGINIA SPEED
- six shooter couplers
- coilovers on rear only
- Air Conditioning Not Working
- Is there adjustable A-arms for C5?
- while test driving a 1998 corvette....
- Need some help
- Wiper Cowl Weather Strip Replacement
- End of Year Sale-A&A, Edelbrock, LG Motorsports, B&B, Pfadt, APR, McCleod etc....
- Engine running bad?
- very unusal starting problem
- Throttle Body Bypass
- What spark plugs do you like?
- motor swap PICTURE THREAD (write up kinda)
- Trouble with AIR tubes on Header install
- headers or cam??
- ? For all about lg headers and stock cats
- Camshaft selection
- Exhaust Flange Bolts and Clamps?
- Unable to Shift and Then a Miracle
- ABS and Active Handling System Messages Still on after Dealer "Repair"
- HUD question.
- Merry Christmaas everyone!!!!
- Yet another Service Active Handling, Service ABS,TCS thread
- Obx Headers????
- Strange chim when going around an exit ramp?
