- brake confusion
- car electric volts flicker
- Weak Starts...any ideas.
- My QTP Placement on a C5
- Optima battery trouble/question
- PCM Swap Out/Upgrade 98 to ????
- How to lower the suspension of a C5 using stock bolts
- Roller Rocker Upgrade Question
- Arh 3inch x-pipe what mufflers?
- looking for source of TPMS bands
- Brake PAd Installation, anything I should know? Tricks?
- vin numbers
- HELP, I'm losing power?
- Clutch Job Check List
- high pitched whine
- Starter problem
- Quick question , 02 extensions
- What should the voltage be at the terminals
- Where is the RTD module located on a 2000?
- cv boot question
- Align ZO6 Ti Exhaust tips on LS1
- Spears on a Torch Red Vette...show me
- Stereo Squeak
- Window Tint in Dallas DFW
- passanger window rotor
- C6 to C5 compatible parts, springs?
- header question.help
- Non named brand clutch for C5
- Shell gasoline
- self locking doors
- 99 C5 Belt Chirp.
- Tie Rods or ?
- Will cats make my exhaust quieter??
- Center console Removale help.........
- Trunk Lid Won't Pop Up
- Who's Using the ACDelco Proffessional Battery?
- How do get my headlights to stay up, but turn off so I don't drain the battery?
- How much tire can fit?
- C5, headlights
- Need Help! Rear Brake I.D.
- My Cam Odessey
- heavy fuel smell coming from the gas cap
- valvetrain noise
- Dyno Tune in Ohio?
- Question on 1st gen Vararam
- Interesting AFR 205 comparo....
- 243 Head milling
- Battery Trickle Charger
- Rear hatch seal makes hatch stick
- What do I torque my motor mounts to?
- Brake Pads, Best Choice?
- TrickFlow As Cast make 57RWHP/38RWTQ over Stock 241 Castings!!
- does 315 falken azenis 615 fit on a c5z lowered on stock bolts
- O2 simulator ?
- 125k miles What should I look out for?
- What did I break with my Drag Radials???
- so i have to decide which flywheel
- Fast Flashing Left turn only?!
- Rattling noise during acceleration
- what bulbs are illuminate the climate control etc??
- Temperature Gauge Reading 265
- how do i install an ac compressor belt
- Do AR Headers have rear hanger support?
- Throttle Body Question
- Harmonic balancer
- Service Colum Lock
- Bolt size for engine stand???????/
- LS6 head weight
- Anybody run these VOLT stainless resonators
- LED light problem
- Engine Ticking
- next mod?
- B0051 and B1001 code
- Help with squeeling noise from rear wheel!
- Total newbie here, a few questions
- I must have my dummy hat on
- Amazing how nice a Fast 90 can look!
- 02 sensor ?
- Passenger side Headlight noise
- Are torque tube bushings a do-able job in 1 day?
- Damper/pulley problem
- Throttle Body question.
- What injectors for a 2000 LS1??
- Did you paint your Powerbond/Pioneer balancer?
- key fob
- What steps to remove the front end of my c5?
- Tpms
- 1.8 rockers/change springs?
- Reducing exhaust sound levels Z06
- Quick tire size question
- Look what the UPS guy brought me today!
- starting problems HELP needed
- A4 2-3 shift problem
- Anyone know of a reseller of Dynatech supermaxx super cats w/ flange?
- two hands needed for reverse!
- Tire pressure sensor p/n
- Misfire now, b*tch!
- estimated HP gain from CAI, tune, LT headers, and cam...
- drilled & slotted rotor question
- Need 12V Ignition source for relay...
- Need Help
- Bolt on Tips Plz
- DIC switch not working HELP PLEASE!!!
- question about a comp cam on my 99 vette
- 2000 Corvette - ABS Pump Problem - Code C1243 BPMV Pump Motor Stalled
- Strange Handling Problem 98 Coupe
- Need info on tying in LED's
- New tire pressure
- Rough Idle and seems to misfire...Help!
- Quaife Rear Limited Slip Differential ANYONE USING ONE ???
- The front end *squeak* has followed me!
- Anyone in So Cal that can Tune out Fuel Cut from Column Lock
- 03-04 water pump thermostat housinf differences
- Parts list for LS1 to LS2 swap?
- How easy is it to change my parling light/new lens
- DMH low profile install location?
- Diconnect lines to ABS - Do I need Tech 2 to bleed brakes?
- Head's ?
- help!!!! PCM prob. maybe
- *** Cam Install Special from LG Motorsports ***
- How much PSI shold the A/C receive?? HELP PLZ!!!
- $$$900 to spend on perfomance.
- AC Compressor Will Only Kick On Intermittently
- Valve spring install, BDC.
- fresh Oil on a spark plug=??bad gasket
- Heads ?
- HUD install
- All C-5 owners how is your oil consumption?
- 06 GTO or 04 Vette
- Help - Trying to identify part corroded by battery acid
- Need to replace a bad A/C compressor
- Upgrade front speakers..
- Tire Pressures not being read by PCM
- Z06 tranny/diff/clutch into LS1 car?
- Torque tube rear bushing removal"?
- Shock advice, help. Easy one.....
- header question
- Those of you with Yella Terras come on in..
- Koni FSD's & Al who used to be at LAPD...
- Lg Street Longtubes installation!
- Largest brake package for 17" front rims
- Column Lock New Issues
- Sticky clutch during spirited driving........
- adjusting HUD brightness?
- Is there some kind off stop
- Which gears is best for me?
- Help Oil pressure question
- check engine light - knock sensor
- Help! Service Traction System
- Textralia clutch question.
- Active Handling service light
- Dual Zone Air Motor/Fan just quit
- Driver seat slides back and forth about an inch
- coil relocation kits
- Taking out my rack for balancer install
- Painting my front bumper.
- engine gurus only please.........
- Clutch Replacment ?s
- Low Washer fluid indicator comes on
- Fuel tank will not come out
- Another Headlight Door Problem
- Cam question
- Putting z06 wheels onto my 97 c5? is it ok??
- Starting procedure 02 vert out of gas
- Car Smells Like Gas and Runs Very Rich. PLEASE HELP!!!
- black box under passenger head light
- Security light on when driving...
- Forged Question
- High volume fuel pump question
- New Castrol EDGE oil ?!?!?!
- b&m short shifter or hurst short shifter
- 19/20" Z06 repro opinions ?
- tranny help
- High Flow Cat Help Please
- memory seats sometimes work sometimes dont???
- 1999 corvette alway takes 2 or 3 times to start
- Cleaned my radiator - Three times
- Anyone know what these error codes mean?
- ls2 engine into ls1
- major problems again...
- Cigarette lighter?
- Failed Fuel sender Pics
- Soft top window came unglued
- NEED HELP with AIR Pipe bolt on a 1999...LG Streets
- VaraRam install
- Help! Drive belt won't tighten.
- M6 oil change
- Installed GTO Spares and car shook terribly. What did I do wrong?
- What causes "High System Voltage" - P0563 and C1237?
- Getting new Tires will an allignment fix my problem??
- Z-51
- dtc codes p1111 en p0113, b0446
- Key fob acting weird
- Has anyone cam doctored a g5x3?
- Need some help with tires and wheels ?
- Auto trans fluid change
- 2001 Shifter Lamp, Radio, And Steering Lock
- HELP!! Misfire after LG Header install
- True or false coil covers ?
- How hard to replace headlight?
- Center-to-center for preferred jack points?
- Check engine light 02 vert
- Need some Guidance?
- K-Harness location
- Are performance gear sets "supposed" to make noise?
- Cam install - help!
- horse power
- how the heck do you adjust the window clip?
- Gears for a 99 auto
- Need a Cam
- Checking header temps, Why?
- Heads Differences LS2 & LS6
- c5 z06 exhaust on 99 c5?
- Does anybody know the answer?
- Got drink holder instead of tail light grills
- Can I swap an LS6 into my 98 Vette? How hard?
- Help please. Active handling problem
- New battery in car, new battery in keyfob, still won't sync!
- C5 Stock Exhaust Removal Question
- C5 Differential Fluid
- Racing Seats & 5 point harnesses
- Need some help understanding
- pressure test cooling system for leak
- Climate Control unit changeout
- Please help
- Reverse Lights Not Working
- operating temp for 1997 c5
- ** 516 RWHP 402 cu from LG Motorsports **
- Fast 90 Installation Help!!
- car dies at idle-ideas?
- Aluminum speedo bezel fell off - how to repair?
- still no luck with the clb, need some advice
- Rear Wheel Hop
- Head damage-Can it be repaired
- Differential Question
- rubber rings for magnesium wheels?
- Frozen bolt in front spring.
- C5 electrical system improvements
- Power steering cooler line to lower port?
- Possible Major Issue (Just Being Cautious)
- Tire selection advise needed
- DIC light issue
- Popping noise left rear
- HELP: Reverse Lamps Not Working
- Need to find the tps senor wire at pcm(1998)
- Wanted: Raptor Shift Light Installation Guide
- Auto Trans Fluid Change? Need Advice..
- Squeeks when turning the steering wheel
- gear select (skip shift) solenoid part number?
- Reset Button Wont reset Codes
