- Where can I find this cam?
- Where can I findthis cam?
- 1999 procharged vette head question
- HELP! New 6.0L engine, vette won't fire up
- Tire monitoring system
- Car dies when put into gear
- Finally a 10 min. mod.
- aligning a coupe to Z06 specs?
- question about replacing rear outer tie rods
- Need Source For 2001 Engine Wiring Harness
- High oil pressure
- electric windows
- Headlights will not come up randomly.
- Replaced Harmonic wobbling Balancer
- no forward gears
- Secondary Air Valves
- Will this cam work?
- Tranny cooler piping help
- Very Special Shop In DELCO PA
- Oil pan gasket material.
- Engine wants to die when shifting in gear only when a/c is on and makes squeeky noise
- Z51 Package Info, Please
- AC blowing Hot air pass. side
- Gauge Cluster?
- Anyone running a Monster Stage 2 Clutch ?
- Introducing Mantic Clutches - Read Inside For Info
- Interior lights not turning off
- Oil Cooler?
- How can these wheels fit?
- Replacing gasket on exhaust
- Headlights popp up but no light!
- engine knock
- Wtf not happy
- Please recommend an air intake system...
- Should one do the "ranger clutch fluid method" on the brake fluid?
- help with fuel lines.
- while waiting for the EBCM relay to arrive
- Instrument panel dark
- Another popping from rear end thread...
- Speedometer help!
- Ipod adapter....
- Cruise Control will not engage...
- 99 Corvette Security Light/ No Start
- Vacuum Line Info Needed
- Slight Odor Coming into Car
- step 10 on manifold remove
- A Monster Fixed My Car!
- boiling/steaming from coolant tank
- LS6 Intake is on my 2000, and Im impressed
- P0101, P0113, P1111 codes repair help.
- Valve train reassembly
- Who sells O2 Sensor Adapters?
- Oil Filters for my C-5
- C1287 Read post #66 but what about the swps
- Source of cabin noise in Coupe found
- Key Fob Issues! AGGGH Bill Curlee you there?????
- Pinging"...
- Need help 97 Vette
- another climate control question
- 03 Z06 Code 1040 & 1571 repair help needed
- M6 transmission problem
- Oil pump & cam degree kit - necessary for head/cam swap??
- How do i remove rear wheel studs
- Voltage fluctuation question
- coolant question
- HVAC issues?
- How do i remove rear wheel lugs
- 04 Thermostat Mod Question
- My No Cat Dyno Experience
- Best Remote Clutch Bleeder ?
- P0343
- Help--Replacing Steering Wheel Position Sensor
- Comp Cams Rocker Arm Trunion Upgrade Kit
- Torque Specs Please
- Could a bad battery cause all of this?
- About to get it started
- Hid lights
- read this if your fuel gauge is crazy
- Cam for 97 a-4
- reduced engine power after rain, codes inside
- Tips on diff replacement
- A/C not working right and already checked vacuum line
- C5 LS1 coming out SDPC El Toro 427 going in?
- Cam specs - what should I expect?
- manual air and heat controls
- Coolant coming from the bottom drivers side of car in front.
- Service active handling???
- Exhaust system. Help please.
- Crazy O2 sensor issues.....
- Flywheel Clutch swap
- Import Cluster Swap now gauges off
- how to remove fuses
- Cam/head swap - ALL the questions I can think to ask (lots of searching was done..)
- Headlights won't come on and won't raised up
- G5X1 cam call for new rods or no?
- Tonneau Latch Inop in the UP Operation after driving
- Relocate Oil Pressure Sensor
- In general - are bolts in mm or inch on C5?
- Radio Keeps playing
- Help!
- Longtube Headers, X pipe, Cutouts, Stock Exhaust.
- High oil and Coolant temps with LSX376 a D1 SC
- help on diagnosing low oil issue
- vacume diagram
- torque tube couplers?
- In a dilemma. What cam/heads should I get?
- Towed home again/17 codes
- Identify these brakes please
- oops
- HUD gas gauge VS analog gauge not =?
- O2 front sensor, square or flat
- Charging system fault.
- Low oil pressure woes :(
- C5 Tans options???
- oil pan leak
- Loosing communication
- Transmission shop in central NJ
- loose wire
- From stock exhaust to Z06 titanium exhaust
- C5 Cluster Gauge Recalibration- HELP!!
- Factory Height
- Air conditioner problems
- Numbers on the top of the Heads...
- Key fobs not being recognized
- Performance upgrade?Check engine
- Dashboard Rattle !!!!!!!
- DTE Performance summer sale
- GD fuel pump!! advice needed
- Bolt-on opinions: which 1st, 2nd, 3rd, so-on
- hyper flasher relay not working because of LED bulbs??
- Corbeau FX1 / FX1 PRO, Pole Position, EVO
- Inviscord - did search...nothing
- I NEED SOME CLUTCH DIY links
- C6Z06 intake/maf on a C5
- I can get a set of 5.3L heads for $100 should I do it?
- Aftermarket fuel pump setups
- HELP! Got water in my Zo6 and now it wont start!
- Magnetic drain plugs
- Leaking fuel injector
- clicking from rear end
- Creaking and cracking from the inside of the coupe trunk is killing me
- Jumped 2003 Conv - AC no longer works
- aftermarket shifter poll/question
- Gained almost 40 hp with My SW headers LONG review inside.
- Parking brake handle seems broken...
- Stroker motor!
- Oil leak front of engine need help
- Adj master keeps needing adjustment
- Automatic help please
- ac blower ?
- havc code what is it B0361
- How to straight pipe my 99 C5 ?????
- Loose steering question.
- AC cold blower weak ?
- foglights all of a sudden stopped working?
- signal problems
- Ethanol free gas?
- Stock ride height on a 2004 Coupe with full tank and base suspension?
- whats c6 linkage mod ona c5?
- Stock rod bolts & 550whp: Pushing my luck?
- Multiple Error Messages
- ambient temp digital readout on console
- ls1 to ls6 manifold swap
- GHL Memorial Day Sale
- OBX Headers - Who has purchased in the last few months?
- Poor Shifting
- Racing Solutions (RSI) Valve Spring Compressor
- Cam for 97' A4
- Catback install in Beaumont area
- cigarette lighter issue
- Instrument Panel Electrical Center removable?
- Im Down To My Last DTC Code... Please help Me Kill It
- Anyone have a DIY valve spring replacement w pics?
- back to stock exhaust for smog.
- C5 TickPerformance Master Cylinder
- I am so smar... DOH!
- Smell fuel
- Driver door panel power
- now what ... cam sensor not working ?
- Issue with starting
- Transmission line size (-6AN or -8AN)
- DRL lights doesn't work after a car wash.
- Key problem --- any ideas?
- Lost power
- Trac/active handling warming up?
- Anyone recommend a good H9 HID bulb?
- Front Wheel Bearing Bolt Size
- how to replace turn signal bulb in c 4 corvette
- Trans cooler mounting straps
- Connecting Rod Question
- play in wheel, problem?
- Are c5 calipers unidirectional?
- 2004 fuel pressure
- need help with electrical issue
- anyone have bcm issues?
- C1296 will not clear
- Question
- Feels like a loss of power
- timing chain issues
- 04 Z06 Shocks HELP
- 1997 C-5 Widnshield Wipers
- Problems after ls6 Inatke manifold swap
- Engine oil dipstick tube
- 12 CD changer went bonkers when selecting another CD what now?
- Codes P0103, P0452 and P1639.
- 1998 c5 windshield washer pump not working
- CT Electrical Specialist ?
- '01 Sport Seat Lumbar & Bolster not working
- Service Active Handling/Traction Control, C1295 H
- MGW Shifter Length and knob preference?
- Heads and Fast Intake? How much Power?
- Can the Safety/Neutral switch be bypass
- faint consistant noise coming back drivers side area.
- Engine pull question?
- DTC code B2723
- 98 Oil pressure low and fluctuating
- Johnny O'Connell shocks and sway bars: suspension REVIEW
- A/C help. Driver's side control does not lower temperature in display
- ebcm, repair question
- Lowering a C5 by adjusting stock bolts
- How to reset DIC after reinflating tires????
- For those of you with A/C issues
- Slow starting
- Catless and smell
- A little disapointed in my LS6 intake upgrade.
- ***EUROS are in, no reverse lights, HELP PLEASE???***
- A/C 1/2 working
- pushrod question
- Engine temp goes from 220-240 at stop lights! Is it a bad sensor, thermostat?
- Header install help
- Cleared Codes Now Radio Sound is Improved?
- Need help with clutch
- battery change
- Clutches, ok need some help McLeod super street pro,ACT-HDSS,Diamond,Monster?
- Will these 17" inch wheels fit a 2000 FRC C5?
- Service Column Lock; found water in footwell
- 17/18" swap to 18/19" wheels - 3:15 gear affect?
- I need a steering column wiring diagram
- Removing AIR tube, stock manifolds.
- Air Cleaner Clamps
- overheating problem on 1999 corvette
- Low Oil Level
- high volume pump and oil filter choice
- What headers with cats to buy
- Oil Pressure...a survey
- AC Sensor????
- Digital Display Center Console Out?
- PVC Valve tubing
- another Newbi question
