Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Car Care Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Car Care Discussion
Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette Sponsored by
Auto Geek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-03-2003, 12:33 AM   #1
J Z06
CF Senior Member
J Z06's Avatar
Send a message via AIM to J Z06
Default wd-40 takes off a LOT of caked on grime
I purchased an 87 acura integra coupe today for a daily driver/winter car. Even my beater has to be clean! I tried some 39009 and a foam pad on my rotary buffer and the results we're spectacular! look at the drivers side, then the passenger's side.(oxidation comparison)
The engine was filthy as hell. I didn't get a chance to really soak de greaser on it then rinse it, so I tried spot cleaning here n there with wd 40. Man the stuff is wonderful. Lots of crud came off the side fenders, under the fire blanket etc. It almost doesn't need to be wet cleaned.
So if you're in a pinch and need to remove some heavy grime from a motor, wd works! :cheers:
J Z06 is offline   Reply With Quote
Old 10-03-2003, 01:04 AM   #2
JCAIRE2
CF Senior Member
JCAIRE2's Avatar
Default Re: wd-40 takes off a LOT of caked on grime (Jay 383)
Since it's a petroleum distallate, you will want to keep it away from soft/porous rubber. I wouldn't let it near the rubber or the composite springs on the c4. :cheers:
JCAIRE2 is offline   Reply With Quote
Old 10-03-2003, 10:30 PM   #3
Mystic '95
CF Senior Member
Cruise-In II Veteran
Mystic '95's Avatar
Send a message via AIM to Mystic '95
Default Re: wd-40 takes off a LOT of caked on grime (JCAIRE2)
I was 'forced' to drive through freshly laid tar in the heat of summer, I had lumps and clumps of tar all over the underside wheel wells.. I shot it with WD-40 and just wiped it off with a shop rag.. :cheers:
Mystic '95 is offline   Reply With Quote
Old 10-13-2003, 07:11 PM   #4
oldace84
CF Senior Member
St. Jude Donor '04 & '05
oldace84's Avatar
Never tried it. But I'm game.
tony
:flag
oldace84 is offline   Reply With Quote
Reload this Page wd-40 takes off a LOT of caked on grime
Tags
caked, grime, wd40
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
